Trivial fix to spelling mistake in ms_to_errno array of error messages
and remove confusing "not" from the error text since the error code
refers to an uninitialized error code.
In preparation to enabling -Wimplicit-fallthrough, mark switch cases
where we are expecting to fall through.
Notice that in this particular case, I placed the "fall through"
annotation at the bottom of the case, which is what GCC is expecting
to find.
Addresses-Coverity-ID: 115075 ("Missing break in switch")
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
to find.
Addresses-Coverity-ID: 1369529 ("Missing break in switch")
Variables ack_status, bcf and protocol are being assigned but are
never used hence they are redundant and can be removed.
Also declare ack_type as unsigned int rather than unsigned to clean
up a checkpatch warning.
Cleans up clang warnings:
warning: variable 'ack_status' set but not used [-Wunused-but-set-variable]
warning: variable 'bcf' set but not used [-Wunused-but-set-variable]
warning: variable 'protocol' set but not used [-Wunused-but-set-variable]
skb_copy_expand without __GFP_NOWARN already does a dump_stack
on OOM so these messages are redundant.
Convert DEVICE_ATTR uses to DEVICE_ATTR_WO where possible.
Done with perl script:
$ git grep -w --name-only DEVICE_ATTR | \
xargs perl -i -e 'local $/; while (<>) { s/\bDEVICE_ATTR\s*\(\s*(\w+)\s*,\s*\(?(?:\s*S_IWUSR\s*|\s*0200\s*)\)?\s*,\s*NULL\s*,\s*\s_store\s*\)/DEVICE_ATTR_WO(\1)/g; print;}'
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Convert Variable Length Array in Struct (VLAIS) to valid C by converting
local struct definition to use a flexible array. The structure is only
used to define a cast of a buffer so the size of the struct is not used
to allocate storage.
Signed-off-by: Behan Webster <behanw@converseincode.com>
Signed-off-by: Mark Charebois <charlebm@gmail.com>
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions return void * and remove all the casts across
the tree, adding a (u8 *) cast only where the unsigned char pointer
was used directly, all done with the following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_push, __skb_push, skb_push_rcsum };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
- fn(SKB, LEN)[0]
Note that the last part there converts from push(...)[0] to the
more idiomatic *(u8 *)push(...).
A common pattern with skb_put() is to just want to memcpy()
some data into the new space, introduce skb_put_data() for
this.
An spatch similar to the one for skb_put_zero() converts many
of the places using it:
identifier p, p2;
expression len, skb, data;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_data(skb, data, len);
-p = (t)skb_put(skb, len);
p2 = (t2)p;
-memcpy(p2, data, len);
-memcpy(p, data, len);
type t, t2;
identifier p, p2;
expression skb, data;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_data(skb, data, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
p2 = (t2)p;
-memcpy(p2, data, sizeof(*p));
-memcpy(p, data, sizeof(*p));
expression skb, len, data;
-memcpy(skb_put(skb, len), data, len);
+skb_put_data(skb, data, len);
(again, manually post-processed to retain some comments)
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
Use time_after() for time comparison with the new fix.
Signed-off-by: Karim Eshapa <karim.eshapa@gmail.com>
Make sure to check the number of endpoints to avoid dereferencing a
NULL-pointer or accessing memory beyond the endpoint array should a
malicious device lack the expected endpoints.
The endpoints are specifically dereferenced in the i2400m_bootrom_init
path during probe (e.g. in i2400mu_tx_bulk_out).
Fixes: f398e4240fce ("i2400m/USB: probe/disconnect, dev init/shutdown
and reset backends")
Cc: Inaky Perez-Gonzalez <inaky@linux.intel.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
Fix typos and add the following to the scripts/spelling.txt:
varible||variable
While we are here, tidy up the comment blocks that fit in a single line
for drivers/net/ethernet/intel/i40e/i40e_virtchnl_pf.c and
net/sctp/transport.c.
Link: http://lkml.kernel.org/r/1481573103-11329-11-git-send-email-yamada.masahiro@socionext.com
- set max_mtu in wil6210 driver
- set max_mtu in atmel driver
- set min/max_mtu in cisco airo driver, remove airo_change_mtu
- set min/max_mtu in ipw2100/ipw2200 drivers, remove libipw_change_mtu
- set min/max_mtu in p80211netdev, remove wlan_change_mtu
- set min/max_mtu in net/mac80211/iface.c and remove ieee80211_change_mtu
- set min/max_mtu in wimax/i2400m and remove i2400m_change_mtu
- set min/max_mtu in intersil/hostap and remove prism2_change_mtu
- set min/max_mtu in intersil/orinoco
- set min/max_mtu in tty/n_gsm and remove gsm_change_mtu
CC: netdev@vger.kernel.org
CC: linux-wireless@vger.kernel.org
CC: Maya Erez <qca_merez@qca.qualcomm.com>
CC: Simon Kelley <simon@thekelleys.org.uk>
CC: Stanislav Yakovlev <stas.yakovlev@gmail.com>
CC: Johannes Berg <johannes@sipsolutions.net>
CC: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
kmalloc will print enough information in case of failure.
Signed-off-by: Wolfram Sang <wsa-dev@sang-engineering.com>
Replace all trans_start updates with netif_trans_update helper.
change was done via spatch:
struct net_device *d;
- d->trans_start = jiffies
+ netif_trans_update(d)
Compile tested only.
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: linux-xtensa@linux-xtensa.org
Cc: linux1394-devel@lists.sourceforge.net
Cc: linux-rdma@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: MPT-FusionLinux.pdl@broadcom.com
Cc: linux-scsi@vger.kernel.org
Cc: linux-can@vger.kernel.org
Cc: linux-parisc@vger.kernel.org
Cc: linux-omap@vger.kernel.org
Cc: linux-hams@vger.kernel.org
Cc: linux-usb@vger.kernel.org
Cc: linux-wireless@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: devel@driverdev.osuosl.org
Cc: b.a.t.m.a.n@lists.open-mesh.org
Cc: linux-bluetooth@vger.kernel.org
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Acked-by: Antonio Quartulli <a@unstable.cc>
In these Makefiles, at least one of "obj-y" and "obj-" is non-empty,
hence built-in.o is always created without such a trick.
Acked-by: Peter Foley <pefoley2@pefoley.com>
Acked-by: Mike Turquette <mturquette@linaro.org>
Acked-by: Simon Horman <horms+renesas@verge.net.au> [shmobile]
Acked-by: David S. Miller <davem@davemloft.net> [networking]
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert
all users to pass NET_NAME_UNKNOWN.
Coccinelle patch:
expression sizeof_priv, name, setup, txqs, rxqs, count;
-alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs)
+alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs)
-alloc_netdev_mq(sizeof_priv, name, setup, count)
+alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count)
-alloc_netdev(sizeof_priv, name, setup)
+alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup)
v9: move comments here from the wrong commit
Signed-off-by: Tom Gundersen <teg@jklm.no>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
Logical conjunction always evaluates to false: minor < 2 && minor > 1
I guess what you wanted is rather: minor > 2 || minor < 1
This was partly found using a static code analysis program called cppcheck.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
Delete unnecessary local variable whose value is always 0 and that hides
the fact that the result is always 0.
A simplified version of the semantic patch that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
local idexpression ret;
expression e;
position p;
-ret = 0;
... when != ret = e
return
- ret
+ 0
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
There are a mix of function prototypes with and without extern
in the kernel sources. Standardize on not using extern for
function prototypes.
Function prototypes don't need to be written with extern.
extern is assumed by the compiler. Its use is as unnecessary as
using auto to declare automatic/local variables in a block.
Pull networking update from David Miller:
1) Checkpoint/restarted TCP sockets now can properly propagate the TCP
timestamp offset. From Andrey Vagin.
2) VMWARE VM VSOCK layer, from Andy King.
3) Much improved support for virtual functions and SR-IOV in bnx2x,
from Ariel ELior.
4) All protocols on ipv4 and ipv6 are now network namespace aware, and
all the compatability checks for initial-namespace-only protocols is
removed. Thanks to Tom Parkin for helping deal with the last major
holdout, L2TP.
5) IPV6 support in netpoll and network namespace support in pktgen,
from Cong Wang.
6) Multiple Registration Protocol (MRP) and Multiple VLAN Registration
Protocol (MVRP) support, from David Ward.
7) Compute packet lengths more accurately in the packet scheduler, from
Eric Dumazet.
8) Use per-task page fragment allocator in skb_append_datato_frags(),
also from Eric Dumazet.
9) Add support for connection tracking labels in netfilter, from
Florian Westphal.
10) Fix default multicast group joining on ipv6, and add anti-spoofing
checks to 6to4 and 6rd. From Hannes Frederic Sowa.
11) Make ipv4/ipv6 fragmentation memory limits more reasonable in modern
times, rearrange inet frag datastructures for better cacheline
locality, and move more operations outside of locking. From Jesper
Dangaard Brouer.
12) Instead of strict master <--> slave relationships, allow arbitrary
scenerios with "upper device lists". From Jiri Pirko.
13) Improve rate limiting accuracy in TBF and act_police, also from Jiri
Pirko.
14) Add a BPF filter netfilter match target, from Willem de Bruijn.
15) Orphan and delete a bunch of pre-historic networking drivers from
Paul Gortmaker.
16) Add TSO support for GRE tunnels, from Pravin B SHelar. Although
this still needs some minor bug fixing before it's %100 correct in
all cases.
17) Handle unresolved IPSEC states like ARP, with a resolution packet
queue. From Steffen Klassert.
18) Remove TCP Appropriate Byte Count support (ABC), from Stephen
Hemminger. This was long overdue.
19) Support SO_REUSEPORT, from Tom Herbert.
20) Allow locking a socket BPF filter, so that it cannot change after a
process drops capabilities.
21) Add VLAN filtering to bridge, from Vlad Yasevich.
22) Bring ipv6 on-par with ipv4 and do not cache neighbour entries in
the ipv6 routes, from YOSHIFUJI Hideaki.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1538 commits)
ipv6: fix race condition regarding dst->expires and dst->from.
net: fix a wrong assignment in skb_split()
ip_gre: remove an extra dst_release()
ppp: set qdisc_tx_busylock to avoid LOCKDEP splat
atl1c: restore buffer state
net: fix a build failure when !CONFIG_PROC_FS
net: ipv4: fix waring -Wunused-variable
net: proc: fix build failed when procfs is not configured
Revert "xen: netback: remove redundant xenvif_put"
net: move procfs code to net/core/net-procfs.c
qmi_wwan, cdc-ether: add ADU960S
bonding: set sysfs device_type to 'bond'
bonding: fix bond_release_all inconsistencies
b44: use netdev_alloc_skb_ip_align()
net: fec: Do a sanity check on the gpio number
ip_gre: propogate target device GSO capability to the tunnel device
ip_gre: allow CSUM capable devices to handle packets
bonding: Fix initialize after use for 3ad machine state spinlock
bonding: Fix race condition between bond_enslave() and bond_3ad_update_lacp_rate()
i2400m_net_wake_tx() sets ->wake_tx_skb with the given skb if
->wake_tx_ws is not pending; however, i2400m_wake_tx_work() could have
just started execution and haven't fetched -><wake_tx_skb yet. The
previous packet will be leaked.
Update ->wake_tx_skb handling.
* i2400m_net_wake_tx() now tests whether the previous ->wake_tx_skb
has been consumed by ->wake_tx_ws instead of testing work_pending().
* i2400m_net_wake_stop() is simplified similarly. It always puts
->wake_tx_skb if non-NULL.
* Spurious ->wake_tx_skb dereference outside critical section dropped
from i2400m_wake_tx_work().
Only compile tested.
Acked-by: Dan Williams <dcbw@redhat.com>
Cc: linux-wimax@intel.com
Cc: wimax@linuxwimax.org
commits 9d11bd159
("wimax: Remove unnecessary alloc/OOM messages, alloc cleanups")
and b2adaca92
("ethernet: Remove unnecessary alloc/OOM messages, alloc cleanups")
added a couple of unused variable warnings.
Remove the now unused variables.
Noticed-by: kbuild test robot <fengguang.wu@intel.com>
alloc failures already get standardized OOM
messages and a dump_stack.
Convert kzalloc's with multiplies to kcalloc.
Remove now unused size variables.
perm_addr is initialized correctly in register_netdevice() so to init it in
drivers is no longer needed.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Use strlcpy where possible to ensure the string is \0 terminated.
Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN
and custom defines.
Use snprintf instead of sprint.
Remove unnecessary inits of ->fw_version
Remove unnecessary inits of drvinfo struct.
Add device IDs for WiMAX function of Intel 6150 cards.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Cc: stable@vger.kernel.org
Sync up with Linus' tree to be able to apply Cesar's patch
against newer version of the code.
Missing a break
Signed-off-by: Alan Cox <alan@linux.intel.com>
Using is_zero_ether_addr() instead of directly use
memcmp() to determine if the ethernet address is all
zeros.
spatch with a semantic match is used to found this problem.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
// <smpl>
identifier ret;
expression e1,e2;
if (ret < 0)
{ ... return ret; }
... when != ret = e1
when forall
*if(...)
... when != ret = e2
* return ret;
// </smpl>
Fix printk format warnings in drivers/net/wimax/i2400m:
drivers/net/wimax/i2400m/control.c: warning: format '%zu' expects argument of type 'size_t', but argument 4 has type 'ssize_t' [-Wformat]
drivers/net/wimax/i2400m/control.c: warning: format '%zu' expects argument of type 'size_t', but argument 5 has type 'ssize_t' [-Wformat]
drivers/net/wimax/i2400m/usb-fw.c: warning: format '%zu' expects argument of type 'size_t', but argument 4 has type 'ssize_t' [-Wformat]
I don't see these warnings on x86. The warnings that are quoted above
are from Geert's kernel build reports.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Convert the existing uses of random_ether_addr to
the new eth_random_addr.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
SDIO support in this driver was intended to support the iwmc3200
device. This hardware never became available to normal humans.
Leaving this driver imposes unwelcome maintenance costs for no clear
benefit.
Acked-by: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Adding casts of objects to the same type is unnecessary
and confusing for a human reader.
For example, this cast:
int y;
int *p = (int *)&y;
I used the coccinelle script below to find and remove these
unnecessary casts. I manually removed the conversions this
script produces of casts with __force, __iomem and __user.
type T;
T *p;
- (T *)p
+ p
With the recent changes for how we compute the skb truesize it occurs to me
we are probably going to have a lot of calls to skb_end_pointer -
skb->head. Instead of running all over the place doing that it would make
more sense to just make it a separate inline skb_end_offset(skb) that way
we can return the correct value without having gcc having to do all the
optimization to cancel out skb->head - skb->head.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
The iwmc3200 driver selects other code in Kconfig that depends on
EXPERIMENTAL. Kconfig warns about this when CONFIG_EXPERIMENTAL
is not already set, so logically, these options should also
be marked experimental or promoted to stable.
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Correct spelling typo within drivers/net.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Merge batch of fixes from Andrew Morton:
"The simple_open() cleanup was held back while I wanted for laggards to
merge things.
I still need to send a few checkpoint/restore patches. I've been
wobbly about merging them because I'm wobbly about the overall
prospects for success of the project. But after speaking with Pavel
at the LSF conference, it sounds like they're further toward
completion than I feared - apparently davem is at the "has stopped
complaining" stage regarding the net changes. So I need to go back
and re-review those patchs and their (lengthy) discussion."
* emailed from Andrew Morton <akpm@linux-foundation.org>: (16 patches)
memcg swap: use mem_cgroup_uncharge_swap fix
backlight: add driver for DA9052/53 PMIC v1
C6X: use set_current_blocked() and block_sigmask()
MAINTAINERS: add entry for sparse checker
MAINTAINERS: fix REMOTEPROC F: typo
alpha: use set_current_blocked() and block_sigmask()
simple_open: automatically convert to simple_open()
scripts/coccinelle/api/simple_open.cocci: semantic patch for simple_open()
libfs: add simple_open()
hugetlbfs: remove unregister_filesystem() when initializing module
drivers/rtc/rtc-88pm860x.c: fix rtc irq enable callback
fs/xattr.c:setxattr(): improve handling of allocation failures
fs/xattr.c:listxattr(): fall back to vmalloc() if kmalloc() failed
fs/xattr.c: suppress page allocation failure warnings from sys_listxattr()
sysrq: use SEND_SIG_FORCED instead of force_sig()
proc: fix mount -t proc -o AAA
Many users of debugfs copy the implementation of default_open() when
they want to support a custom read/write function op. This leads to a
proliferation of the default_open() implementation across the entire
tree.
Now that the common implementation has been consolidated into libfs we
can replace all the users of this function with simple_open().
This replacement was done with the following semantic patch:
<smpl>
@ open @
identifier open_f != simple_open;
identifier i, f;
-int open_f(struct inode *i, struct file *f)
-if (i->i_private)
-f->private_data = i->i_private;
-return 0;
@ has_open depends on open @
identifier fops;
identifier open.open_f;
struct file_operations fops = {
-.open = open_f,
+.open = simple_open,
</smpl>
[akpm@linux-foundation.org: checkpatch fixes]
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
This way the USB variant of the driver uses usb_make_path in order to
provide bus-info compatible to other USB drivers (like e.g. asix.c).
Signed-off-by: Phil Sutter <phil.sutter@viprinet.com>
This happened on a machine with a custom hotplug script calling nameif,
probably due to slow firmware loading. At the time nameif uses ethtool
to gather interface information, i2400m->fw_name is zero and so a null
pointer dereference occurs from within i2400m_get_drvinfo().
A driver start_xmit() method cannot free skb and return NETDEV_TX_BUSY,
since caller is going to reuse freed skb.
In fact netif_tx_stop_queue() / netif_stop_queue() is needed before
returning NETDEV_TX_BUSY or you can trigger a ksoftirqd fatal loop.
In case of memory allocation error, only safe way is to drop the packet
and return NETDEV_TX_OK
Also increments tx_dropped counter
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits)
Kconfig: acpi: Fix typo in comment.
misc latin1 to utf8 conversions
devres: Fix a typo in devm_kfree comment
btrfs: free-space-cache.c: remove extra semicolon.
fat: Spelling s/obsolate/obsolete/g
SCSI, pmcraid: Fix spelling error in a pmcraid_err() call
tools/power turbostat: update fields in manpage
mac80211: drop spelling fix
types.h: fix comment spelling for 'architectures'
typo fixes: aera -> area, exntension -> extension
devices.txt: Fix typo of 'VMware'.
sis900: Fix enum typo 'sis900_rx_bufer_status'
decompress_bunzip2: remove invalid vi modeline
treewide: Fix comment and string typo 'bufer'
hyper-v: Update MAINTAINERS
treewide: Fix typos in various parts of the kernel, and fix some comments.
clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR
gpio: Kconfig: drop unknown symbol 'CS5535_GPIO'
leds: Kconfig: Fix typo 'D2NET_V2'
sound: Kconfig: drop unknown symbol ARCH_CLPS7500
Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new
kconfig additions, close to removed commented-out old ones)
DaveM said:
Please, this kind of stuff rots forever and not using bool properly
drives me crazy.
Joe Perches <joe@perches.com> gave me the spatch script:
bool b;
-b = 0
+b = false
bool b;
-b = 1
+b = true
I merely installed coccinelle, read the documentation and took credit.
"result" isn't used. We ignore errors here because there is not much we
can do about them.
The below patch fixes some typos in various parts of the kernel, as well as fixes some comments.
Please let me know if I missed anything, and I will try to get it changed and resent.
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
