For the devices in this driver, the default qdisc is "noqueue",
because their "tx_queue_len" is 0.
In function "__dev_queue_xmit" in "net/core/dev.c", devices with the
"noqueue" qdisc are specially handled. Packets are transmitted without
being queued after a "dev->flags & IFF_UP" check. However, it's possible
that even if this check succeeds, "ops->ndo_stop" may still have already
been called. This is because in "__dev_close_many", "ops->ndo_stop" is
called before clearing the "IFF_UP" flag.
If we call "netif_stop_queue" in "ops->ndo_stop", then it's possible in
"__dev_queue_xmit", it sees the "IFF_UP" flag is present, and then it
checks "netif_xmit_stopped" and finds that the queue is already stopped.
In this case, it will complain that:
"Virtual device ... asks to queue packet!"
To prevent "__dev_queue_xmit" from generating this complaint, we should
not call "netif_stop_queue" in "ops->ndo_stop".
We also don't need to call "netif_start_queue" in "ops->ndo_open",
because after a netdev is allocated and registered, the
"__QUEUE_STATE_DRV_XOFF" flag is initially not set, so there is no need
to call "netif_start_queue" to clear it.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Xie He <xie.he.0141@gmail.com>
Acked-by: Martin Schiller <ms@dev.tdt.de>
When priv->rx_skbuff or priv->tx_skbuff is NULL, no error return code of
uhdlc_init() is assigned.
To fix this bug, ret is assigned with -ENOMEM in these cases.
Reported-by: TOTE Robot <oslab@tsinghua.edu.cn>
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
dev->name is determined only after calling register_hdlc_device(),
however ,it is used by printk before the name is fully determined.
[ 4.565137] hdlc%d: detected at e8000000, irq 11
Instead of printing out a %d, print hdlc directly
Signed-off-by: Tong Zhang <ztong0001@gmail.com>
lmc set sc->lmc_media pointer when there is a matching device.
However, when no matching device is found, this pointer is NULL
and the following dereference will result in a null-ptr-deref.
To fix this issue, unregister the hdlc device and return an error.
[ 4.569359] BUG: KASAN: null-ptr-deref in lmc_init_one.cold+0x2b6/0x55d [lmc]
[ 4.569748] Read of size 8 at addr 0000000000000008 by task modprobe/95
[ 4.570102]
[ 4.570187] CPU: 0 PID: 95 Comm: modprobe Not tainted 5.11.0-rc7 #94
[ 4.570527] Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS rel-1.13.0-48-gd9c812dda519-preb4
[ 4.571125] Call Trace:
[ 4.571261] dump_stack+0x7d/0xa3
[ 4.571445] kasan_report.cold+0x10c/0x10e
[ 4.571667] ? lmc_init_one.cold+0x2b6/0x55d [lmc]
[ 4.571932] lmc_init_one.cold+0x2b6/0x55d [lmc]
[ 4.572186] ? lmc_mii_readreg+0xa0/0xa0 [lmc]
[ 4.572432] local_pci_probe+0x6f/0xb0
[ 4.572639] pci_device_probe+0x171/0x240
[ 4.572857] ? pci_device_remove+0xe0/0xe0
[ 4.573080] ? kernfs_create_link+0xb6/0x110
[ 4.573315] ? sysfs_do_create_link_sd.isra.0+0x76/0xe0
[ 4.573598] really_probe+0x161/0x420
[ 4.573799] driver_probe_device+0x6d/0xd0
[ 4.574022] device_driver_attach+0x82/0x90
[ 4.574249] ? device_driver_attach+0x90/0x90
[ 4.574485] __driver_attach+0x60/0x100
[ 4.574694] ? device_driver_attach+0x90/0x90
[ 4.574931] bus_for_each_dev+0xe1/0x140
[ 4.575146] ? subsys_dev_iter_exit+0x10/0x10
[ 4.575387] ? klist_node_init+0x61/0x80
[ 4.575602] bus_add_driver+0x254/0x2a0
[ 4.575812] driver_register+0xd3/0x150
[ 4.576021] ? 0xffffffffc0018000
[ 4.576202] do_one_initcall+0x84/0x250
[ 4.576411] ? trace_event_raw_event_initcall_finish+0x150/0x150
[ 4.576733] ? unpoison_range+0xf/0x30
[ 4.576938] ? ____kasan_kmalloc.constprop.0+0x84/0xa0
[ 4.577219] ? unpoison_range+0xf/0x30
[ 4.577423] ? unpoison_range+0xf/0x30
[ 4.577628] do_init_module+0xf8/0x350
[ 4.577833] load_module+0x3fe6/0x4340
[ 4.578038] ? vm_unmap_ram+0x1d0/0x1d0
[ 4.578247] ? ____kasan_kmalloc.constprop.0+0x84/0xa0
[ 4.578526] ? module_frob_arch_sections+0x20/0x20
[ 4.578787] ? __do_sys_finit_module+0x108/0x170
[ 4.579037] __do_sys_finit_module+0x108/0x170
[ 4.579278] ? __ia32_sys_init_module+0x40/0x40
[ 4.579523] ? file_open_root+0x200/0x200
[ 4.579742] ? do_sys_open+0x85/0xe0
[ 4.579938] ? filp_open+0x50/0x50
[ 4.580125] ? exit_to_user_mode_prepare+0xfc/0x130
[ 4.580390] do_syscall_64+0x33/0x40
[ 4.580586] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 4.580859] RIP: 0033:0x7f1a724c3cf7
[ 4.581054] Code: 48 89 57 30 48 8b 04 24 48 89 47 38 e9 1d a0 02 00 48 89 f8 48 89 f7 48 89 d6 48 891
[ 4.582043] RSP: 002b:00007fff44941c68 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[ 4.582447] RAX: ffffffffffffffda RBX: 00000000012ada70 RCX: 00007f1a724c3cf7
[ 4.582827] RDX: 0000000000000000 RSI: 00000000012ac9e0 RDI: 0000000000000003
[ 4.583207] RBP: 0000000000000003 R08: 0000000000000000 R09: 0000000000000001
[ 4.583587] R10: 00007f1a72527300 R11: 0000000000000246 R12: 00000000012ac9e0
[ 4.583968] R13: 0000000000000000 R14: 00000000012acc90 R15: 0000000000000001
[ 4.584349] ==================================================================
This converts the driver to use the new tasklet API introduced in
commit 12cc923f1ccc ("tasklet: Introduce new initialization API")
The new API changes the argument passed to callback functions,
but fortunately it is unused so it is straight forward to use
DECLARE_TASKLET rather than DECLARE_TASLKLET_OLD.
Signed-off-by: Emil Renner Berthing <kernel@esmil.dk>
Link: https://lore.kernel.org/r/20210204173947.92884-1-kernel@esmil.dk
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
It's not meaningful to pass on LAPB error codes to HDLC code or other
parts of the system, because they will not understand the error codes.
Instead, use system-wide recognizable error codes.
Fixes: f362e5fe0f1f ("wan/hdlc_x25: make lapb params configurable")
Link: https://lore.kernel.org/r/20210203071541.86138-1-xie.he.0141@gmail.com
Trivial conflict in CAN on file rename.
drivers/net/can/m_can/tcan4x5x-core.c
Without this, the driver runs into a link failure
arm-linux-gnueabi-ld: drivers/net/wan/slic_ds26522.o: in function `slic_ds26522_probe':
slic_ds26522.c:(.text+0x100c): undefined reference to `byte_rev_table'
arm-linux-gnueabi-ld: slic_ds26522.c:(.text+0x1cdc): undefined reference to `byte_rev_table'
arm-linux-gnueabi-ld: drivers/net/wan/slic_ds26522.o: in function `slic_write':
slic_ds26522.c:(.text+0x1e4c): undefined reference to `byte_rev_table'
Fixes: c37d4a0085c5 ("Maxim/driver: Add driver for maxim ds26522")
spinlock can be initialized automatically with DEFINE_SPINLOCK()
rather than explicitly calling spin_lock_init().
Signed-off-by: Zheng Yongjun <zhengyongjun3@huawei.com>
The simple_strtol() function is deprecated, use simple_strtoul() instead.
ppp_cp_event is called directly or indirectly by ppp_rx with "ppp->lock"
held. It may call mod_timer to add a new timer. However, at the same time
ppp_timer may be already running and waiting for "ppp->lock". In this
case, there's no need for ppp_timer to continue running and it can just
exit.
If we let ppp_timer continue running, it may call add_timer. This causes
kernel panic because add_timer can't be called with a timer pending.
This patch fixes this problem.
Fixes: e022c2f07ae5 ("WAN: new synchronous PPP implementation for generic HDLC.")
Cc: Krzysztof Halasa <khc@pm.waw.pl>
(dis)connected
When the upper layer instruct us to connect (or disconnect), but we have
already connected (or disconnected), consider this operation successful
rather than failed.
This can help the upper layer to correct its record about whether we are
connected or not here in layer 2.
The upper layer may not have the correct information about whether we are
connected or not. This can happen if this driver has already been running
for some time when the "x25" module gets loaded.
Another X.25 driver (hdlc_x25) is already doing this, so we make this
driver do this, too.
Cc: Martin Schiller <ms@dev.tdt.de>
1. In x25_xmit, skb_reset_network_header is not necessary before we call
lapb_data_request. The lapb module doesn't need skb->network_header.
So there is no need to set skb->network_header before calling
lapb_data_request.
2. In x25_data_indication (called by the lapb module after data have
been received), skb_reset_network_header is not necessary before we
call netif_rx. After we call netif_rx, the code in net/core/dev.c will
call skb_reset_network_header before handing the skb to upper layers
(in __netif_receive_skb_core, called by __netif_receive_skb_one_core,
called by __netif_receive_skb, called by process_backlog). So we don't
need to call skb_reset_network_header by ourselves.
The macro use will already have a semicolon.
Signed-off-by: Tom Rix <trix@redhat.com>
Link: https://lore.kernel.org/r/20201127165734.2694693-1-trix@redhat.com
The DLCI driver (dlci.c) implements the Frame Relay protocol. However,
we already have another newer and better implementation of Frame Relay
provided by the HDLC_FR driver (hdlc_fr.c).
The DLCI driver's implementation of Frame Relay is used by only one
hardware driver in the kernel - the SDLA driver (sdla.c).
The SDLA driver provides Frame Relay support for the Sangoma S50x devices.
However, the vendor provides their own driver (along with their own
multi-WAN-protocol implementations including Frame Relay), called WANPIPE.
I believe most users of the hardware would use the vendor-provided WANPIPE
driver instead.
(The WANPIPE driver was even once in the kernel, but was deleted in
commit 8db60bcf3021 ("[WAN]: Remove broken and unmaintained Sangoma
drivers.") because the vendor no longer updated the in-kernel WANPIPE
driver.)
Cc: Mike McLagan <mike.mclagan@linux.org>
Link: https://lore.kernel.org/r/20201114150921.685594-1-xie.he.0141@gmail.com
If memory allocation for 'kbuf' succeed, cosa_write() doesn't have a
corresponding kfree() in exception handling. Thus add kfree() for this
function implementation.
Signed-off-by: Wang Hai <wanghai38@huawei.com>
Acked-by: Jan "Yenya" Kasprzak <kas@fi.muni.cz>
Link: https://lore.kernel.org/r/20201110144614.43194-1-wanghai38@huawei.com
This driver transports LAPB (X.25 link layer) frames over TTY links.
I can safely say that this driver has no actual user because it was
not working at all until:
commit 8fdcabeac398 ("drivers/net/wan/x25_asy: Fix to make it work")
The code in its current state still has problems:
1.
The uses of "struct x25_asy" in x25_asy_unesc (when receiving) and in
x25_asy_write_wakeup (when sending) are not protected by locks against
x25_asy_change_mtu's changing of the transmitting/receiving buffers.
Also, all "netif_running" checks in this driver are not protected by
locks against the ndo_stop function.
2.
The driver stops all TTY read/write when the netif is down.
I think this is not right because this may cause the last outgoing frame
before the netif goes down to be incompletely transmitted, and the first
incoming frame after the netif goes up to be incompletely received.
And there may also be other problems.
I was planning to fix these problems but after recent discussions about
deleting other old networking code, I think we may just delete this
driver, too.
Link: https://lore.kernel.org/r/20201105073434.429307-1-xie.he.0141@gmail.com
Change the fr_rx function to make this driver support any Ethertype
when receiving skbs on normal (non-Ethernet-emulating) PVC devices.
(This driver is already able to handle any Ethertype when sending.)
Originally in the fr_rx function, the code that parses the long (10-byte)
header only recognizes a few Ethertype values and drops frames with other
Ethertype values. This patch replaces this code to make fr_rx support
any Ethertype. This patch also creates a new function fr_snap_parse as
part of the new code.
Acked-by: Willem de Bruijn <willemb@google.com>
1.
Change the skb->len check from "<= 4" to "< 4".
At first we only need to ensure a 4-byte header is present. We indeed
normally need the 5th byte, too, but it'd be more logical and cleaner
to check its existence when we actually need it.
2.
Add an fh->ea2 check to the initial checks in fr_rx. fh->ea2 == 1 means
the second address byte is the final address byte. We only support the
case where the address length is 2 bytes.
When an skb is received on a normal (non-Ethernet-emulating) PVC device,
call skb_reset_mac_header before we pass it to upper layers.
This is because normal PVC devices don't have header_ops, so any header we
have would not be visible to upper layer code when sending, so the header
shouldn't be visible to upper layer code when receiving, either.
Cc: Willem de Bruijn <willemdebruijn.kernel@gmail.com>
The eth_type_trans function is called when we receive frames carrying
Ethernet frames. This function expects a non-NULL pointer as an argument,
and assigns it directly to skb->dev.
However, the code handling other types of frames first assigns the pointer
to "dev", and then at the end checks whether the value is NULL, and if it
is not NULL, assigns it to skb->dev.
The two flows are different. Mixing them in this function makes the code
messy. It's better that we convert the second flow to align with how
eth_type_trans does things.
So this patch changes the code to: first make sure the pointer is not
NULL, then assign it directly to skb->dev. "dev" is no longer needed until
the end where we use it to update stats.
When the fr_rx function drops a received frame (because the protocol type
is not supported, or because the PVC virtual device that corresponds to
the DLCI number and the protocol type doesn't exist), the function frees
the skb and returns.
The code for freeing the skb and returning is repeated several times, this
patch uses "goto rx_drop" to replace them so that the code looks cleaner.
drivers/net/wan/lmc/lmc_main.c: In function ‘lmc_ioctl’:
drivers/net/wan/lmc/lmc_main.c:356:25: warning: variable ‘mii’ set but not used [-Wunused-but-set-variable]
356 | u16 mii;
drivers/net/wan/lmc/lmc_main.c:427:25: warning: variable ‘mii’ set but not used [-Wunused-but-set-variable]
427 | u16 mii;
drivers/net/wan/lmc/lmc_main.c: In function ‘lmc_interrupt’:
drivers/net/wan/lmc/lmc_main.c:1188:9: warning: variable ‘firstcsr’ set but not used [-Wunused-but-set-variable]
1188 | u32 firstcsr;
This file has funky indentation, and makes little use of tabs. Keep
with this style in the patch, but that makes checkpatch unhappy.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lore.kernel.org/r/20201031181417.1081511-1-andrew@lunn.ch
This driver calls ether_setup to set up the network device.
The ether_setup function would add the IFF_TX_SKB_SHARING flag to the
device. This flag indicates that it is safe to transmit shared skbs to
the device.
However, this is not true. This driver may pad the frame (in eth_tx)
before transmission, so the skb may be modified.
Fixes: 550fd08c2ceb ("net: Audit drivers to identify those needing IFF_TX_SKB_SHARING cleared")
Cc: Neil Horman <nhorman@tuxdriver.com>
Link: https://lore.kernel.org/r/20201020063420.187497-1-xie.he.0141@gmail.com
The hdlc_rcv function is used as hdlc_packet_type.func to process any
skb received in the kernel with skb->protocol == htons(ETH_P_HDLC).
The purpose of this function is to provide second-stage processing for
skbs not assigned a "real" L3 skb->protocol value in the first stage.
This function assumes the device from which the skb is received is an
HDLC device (a device created by this module). It assumes that
netdev_priv(dev) returns a pointer to "struct hdlc_device".
However, it is possible that some driver in the kernel (not necessarily
in our control) submits a received skb with skb->protocol ==
htons(ETH_P_HDLC), from a non-HDLC device. In this case, the skb would
still be received by hdlc_rcv. This will cause problems.
hdlc_rcv should be able to recognize and drop invalid skbs. It should
first make sure "dev" is actually an HDLC device, before starting its
processing. This patch adds this check to hdlc_rcv.
Link: https://lore.kernel.org/r/20201020013152.89259-1-xie.he.0141@gmail.com
A break is not needed if it is preceded by a return or goto
Link: https://lore.kernel.org/r/20201019172607.31622-1-trix@redhat.com
Move the skb_headroom check out of fr_hard_header and into pvc_xmit.
This has two benefits:
1. Originally we only do this check for skbs sent by users on Ethernet-
emulating PVC devices. After the change we do this check for skbs sent on
normal PVC devices, too.
(Also add a comment to make it clear that this is only a protection
against upper layers that don't take dev->needed_headroom into account.
Such upper layers should be rare and I believe they should be fixed.)
2. After the change we can simplify the parameter list of fr_hard_header.
We no longer need to use a pointer to pointers (skb_p) because we no
longer need to replace the skb inside fr_hard_header.
Rejecting non-native endian BTF overlapped with the addition
of support for it.
The rest were more simple overlapping changes, except the
renesas ravb binding update, which had to follow a file
move as well as a YAML conversion.
1. Keep the code for the normal (non-error) flow at the lowest
indentation level. And use "goto drop" for all error handling.
2. Replace code that pads short Ethernet frames with a "__skb_pad" call.
3. Change "dev_kfree_skb" to "kfree_skb" in error handling code.
"kfree_skb" is the correct function to call when dropping an skb due to
an error. "dev_kfree_skb", which is an alias of "consume_skb", is for
dropping skbs normally (not due to an error).
Cc: Stephen Hemminger <stephen@networkplumber.org>
The fr_hard_header function is used to prepend the header to skbs before
transmission. It is used in 3 situations:
1) When a control packet is generated internally in this driver;
2) When a user sends an skb on an Ethernet-emulating PVC device;
3) When a user sends an skb on a normal PVC device.
These 3 situations need to be handled differently by fr_hard_header.
Different headers should be prepended to the skb in different situations.
Currently fr_hard_header distinguishes these 3 situations using
skb->protocol. For situation 1 and 2, a special skb->protocol value
will be assigned before calling fr_hard_header, so that it can recognize
these 2 situations. All skb->protocol values other than these special ones
are treated by fr_hard_header as situation 3.
However, it is possible that in situation 3, the user sends an skb with
one of the special skb->protocol values. In this case, fr_hard_header
would incorrectly treat it as situation 1 or 2.
This patch tries to solve this issue by using skb->dev instead of
skb->protocol to distinguish between these 3 situations. For situation
1, skb->dev would be NULL; for situation 2, skb->dev->type would be
ARPHRD_ETHER; and for situation 3, skb->dev->type would be ARPHRD_DLCI.
This way fr_hard_header would be able to distinguish these 3 situations
correctly regardless what skb->protocol value the user tries to use in
situation 3.
lmc_trace() was first introduced in commit e7a392d5158af ("Import
2.3.99pre6-5") and was not touched ever since.
The reason for looking at this was to get rid of the in_interrupt() usage,
but while looking at it the following observations were made:
- At least lmc_get_stats() (->ndo_get_stats()) is invoked with disabled
preemption which is not detected by the in_interrupt() check, which
would cause schedule() to be called from invalid context.
- The code is hidden behind #ifdef LMC_TRACE which is not defined within
the kernel and wasn't at the time it was introduced.
- Three jiffies don't match 50ms. msleep() would be a better match which
would also avoid the schedule() invocation. But why have it to begin
with?
- Nobody would do something like this today. Either netdev_dbg() or
trace_printk() or a trace event would be used. If only the functions
related to this driver are interesting then ftrace can be used with
filtering.
As it is obviously broken for years, simply remove it.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
1.
Move the lapb_register/lapb_unregister calls into the ndo_open/ndo_stop
functions.
This makes the LAPB protocol start/stop when the network interface
starts/stops. When the network interface is down, the LAPB protocol
shouldn't be running and the LAPB module shoudn't be generating control
frames.
2.
Move netif_start_queue/netif_stop_queue into the ndo_open/ndo_stop
functions.
This makes the TX queue start/stop when the network interface
starts/stops.
(netif_stop_queue was originally in the ndo_stop function. But to make
the code look better, I created a new function to use as ndo_stop, and
made it call the original ndo_stop function. I moved netif_stop_queue
from the original ndo_stop function to the new ndo_stop function.)
Two minor conflicts:
1) net/ipv4/route.c, adding a new local variable while
moving another local variable and removing it's
initial assignment.
2) drivers/net/dsa/microchip/ksz9477.c, overlapping changes.
One pretty prints the port mode differently, whilst another
changes the driver to try and obtain the port mode from
the port node rather than the switch node.
This patch sets skb->protocol before transmitting frames on the HDLC
device, so that a user listening on the HDLC device with an AF_PACKET
socket will see outgoing frames' sll_protocol field correctly set and
consistent with that of incoming frames.
1. Control frames in hdlc_cisco and hdlc_ppp
When these drivers send control frames, skb->protocol is not set.
This value should be set to htons(ETH_P_HDLC), because when receiving
control frames, their skb->protocol is set to htons(ETH_P_HDLC).
When receiving, hdlc_type_trans in hdlc.h is called, which then calls
cisco_type_trans or ppp_type_trans. The skb->protocol of control frames
is set to htons(ETH_P_HDLC) so that the control frames can be received
by hdlc_rcv in hdlc.c, which calls cisco_rx or ppp_rx to process the
control frames.
2. hdlc_fr
When this driver sends control frames, skb->protocol is set to internal
values used in this driver.
When this driver sends data frames (from upper stacked PVC devices),
skb->protocol is the same as that of the user data packet being sent on
the upper PVC device (for normal PVC devices), or is htons(ETH_P_802_3)
(for Ethernet-emulating PVC devices).
However, skb->protocol for both control frames and data frames should be
set to htons(ETH_P_HDLC), because when receiving, all frames received on
the HDLC device will have their skb->protocol set to htons(ETH_P_HDLC).
When receiving, hdlc_type_trans in hdlc.h is called, and because this
driver doesn't provide a type_trans function in struct hdlc_proto,
all frames will have their skb->protocol set to htons(ETH_P_HDLC).
The frames are then received by hdlc_rcv in hdlc.c, which calls fr_rx
to process the frames (control frames are consumed and data frames
are re-received on upper PVC devices).
This driver is a virtual driver stacked on top of Ethernet interfaces.
When this driver transmits data on the Ethernet device, the skb->protocol
setting is inconsistent with the Ethernet header prepended to the skb.
This causes a user listening on the Ethernet interface with an AF_PACKET
socket, to see different sll_protocol values for incoming and outgoing
frames, because incoming frames would have this value set by parsing the
Ethernet header.
This patch changes the skb->protocol value for outgoing Ethernet frames,
making it consistent with the Ethernet header prepended. This makes a
user listening on the Ethernet device with an AF_PACKET socket, to see
the same sll_protocol value for incoming and outgoing frames.
x25_type_trans only needs to be called before we call netif_rx to pass
the skb to upper layers.
It does not need to be called before lapb_data_received. The LAPB module
does not need the fields that are set by calling it.
In the other two X.25 drivers - lapbether and hdlc_x25. x25_type_trans
is only called before netif_rx and not before lapb_data_received.
The "SLF_OUTWAIT" flag defined in x25_asy.h is not actually used.
It is only cleared at one place in x25_asy.c but is never read or set.
So we can remove it.
There are a couple bugs here:
1) If opt[1] is zero then this results in a forever loop. If the value
is less than 2 then it is invalid.
2) It assumes that "len" is more than sizeof(valid_accm) or 6 which can
result in memory corruption.
In the case of LCP_OPTION_ACCM, then we should check "opt[1]" instead
of "len" because, if "opt[1]" is less than sizeof(valid_accm) then
"nak_len" gets out of sync and it can lead to memory corruption in the
next iterations through the loop. In case of LCP_OPTION_MAGIC, the
only valid value for opt[1] is 6, but the code is trying to log invalid
data so we should only discard the data when "len" is less than 6
because that leads to a read overflow.
Reported-by: ChenNan Of Chaitin Security Research Lab <whutchennan@gmail.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
PVC devices are virtual devices in this driver stacked on top of the
actual HDLC device. They are the devices normal users would use.
PVC devices have two types: normal PVC devices and Ethernet-emulating
PVC devices.
When transmitting data with PVC devices, the ndo_start_xmit function
will prepend a header of 4 or 10 bytes. Currently this driver requests
this headroom to be reserved for normal PVC devices by setting their
hard_header_len to 10. However, this does not work when these devices
are used with AF_PACKET/RAW sockets. Also, this driver does not request
this headroom for Ethernet-emulating PVC devices (but deals with this
problem by reallocating the skb when needed, which is not optimal).
This patch replaces hard_header_len with needed_headroom, and set
needed_headroom for Ethernet-emulating PVC devices, too. This makes
the driver to request headroom for all PVC devices in all cases.
We got slightly different patches removing a double word
in a comment in net/ipv4/raw.c - picked the version from net.
Simple conflict in drivers/net/ethernet/ibm/ibmvnic.c. Use cached
values instead of VNIC login response buffer (following what
commit 507ebe6444a4 ("ibmvnic: Fix use-after-free of VNIC login
response buffer") did).
Pull networking fixes from David Miller:
1) Use netif_rx_ni() when necessary in batman-adv stack, from Jussi
Kivilinna.
2) Fix loss of RTT samples in rxrpc, from David Howells.
3) Memory leak in hns_nic_dev_probe(), from Dignhao Liu.
4) ravb module cannot be unloaded, fix from Yuusuke Ashizuka.
5) We disable BH for too lokng in sctp_get_port_local(), add a
cond_resched() here as well, from Xin Long.
6) Fix memory leak in st95hf_in_send_cmd, from Dinghao Liu.
7) Out of bound access in bpf_raw_tp_link_fill_link_info(), from
Yonghong Song.
8) Missing of_node_put() in mt7530 DSA driver, from Sumera
Priyadarsini.
9) Fix crash in bnxt_fw_reset_task(), from Michael Chan.
10) Fix geneve tunnel checksumming bug in hns3, from Yi Li.
11) Memory leak in rxkad_verify_response, from Dinghao Liu.
12) In tipc, don't use smp_processor_id() in preemptible context. From
Tuong Lien.
13) Fix signedness issue in mlx4 memory allocation, from Shung-Hsi Yu.
14) Missing clk_disable_prepare() in gemini driver, from Dan Carpenter.
15) Fix ABI mismatch between driver and firmware in nfp, from Louis
Peens.
* git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net: (110 commits)
net/smc: fix sock refcounting in case of termination
net/smc: reset sndbuf_desc if freed
net/smc: set rx_off for SMCR explicitly
net/smc: fix toleration of fake add_link messages
tg3: Fix soft lockup when tg3_reset_task() fails.
doc: net: dsa: Fix typo in config code sample
net: dp83867: Fix WoL SecureOn password
nfp: flower: fix ABI mismatch between driver and firmware
tipc: fix shutdown() of connectionless socket
ipv6: Fix sysctl max for fib_multipath_hash_policy
drivers/net/wan/hdlc: Change the default of hard_header_len to 0
net: gemini: Fix another missing clk_disable_unprepare() in probe
net: bcmgenet: fix mask check in bcmgenet_validate_flow()
amd-xgbe: Add support for new port mode
net: usb: dm9601: Add USB ID of Keenetic Plus DSL
vhost: fix typo in error message
net: ethernet: mlx4: Fix memory allocation in mlx4_buddy_init()
pktgen: fix error message with wrong function name
net: ethernet: ti: am65-cpsw: fix rmii 100Mbit link mode
cxgb4: fix thermal zone device registration
Change the default value of hard_header_len in hdlc.c from 16 to 0.
Currently there are 6 HDLC protocol drivers, among them:
hdlc_raw_eth, hdlc_cisco, hdlc_ppp, hdlc_x25 set hard_header_len when
attaching the protocol, overriding the default. So this patch does not
affect them.
hdlc_raw and hdlc_fr don't set hard_header_len when attaching the
protocol. So this patch will change the hard_header_len of the HDLC
device for them from 16 to 0.
This is the correct change because both hdlc_raw and hdlc_fr don't have
header_ops, and the code in net/packet/af_packet.c expects the value of
hard_header_len to be consistent with header_ops.
In net/packet/af_packet.c, in the packet_snd function,
for AF_PACKET/DGRAM sockets it would reserve a headroom of
hard_header_len and call dev_hard_header to fill in that headroom,
and for AF_PACKET/RAW sockets, it does not reserve the headroom and
does not call dev_hard_header, but checks if the user has provided a
header of length hard_header_len (in function dev_validate_header).
Add missing MODULE_DESCRIPTION.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
There is no caller in tree any more.
This driver didn't set hard_header_len. This patch sets hard_header_len
for it according to its header_ops->create function.
This driver's header_ops->create function (cisco_hard_header) creates
a header of (struct hdlc_header), so hard_header_len should be set to
sizeof(struct hdlc_header).
Acked-by: Krzysztof Halasa <khc@pm.waw.pl>
Set the skb's network_header before it is passed to the underlying
Ethernet device for transmission.
This patch fixes the following issue:
When we use this driver with AF_PACKET sockets, there would be error
messages of:
protocol 0805 is buggy, dev (Ethernet interface name)
printed in the system "dmesg" log.
This is because skbs passed down to the Ethernet device for transmission
don't have their network_header properly set, and the dev_queue_xmit_nit
function in net/core/dev.c complains about this.
Reason of setting the network_header to this place (at the end of the
Ethernet header, and at the beginning of the Ethernet payload):
Because when this driver receives an skb from the Ethernet device, the
network_header is also set at this place.
Use semicolons and braces.
