An HDLC device can change type when the protocol driver is changed.
Calling the notifier change allows potential users of the interface
know about this planned change, and even block it. After the change
has occurred, send a second notification to users can evaluate the new
device type etc.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
We'll either hit one of the case labels or the default in the switch
and in all cases do we then 'goto out' and we also have a 'goto out'
after the switch that is redundant. Change to just use break in the
case statements and leave the 'goto out' after the lop for everyone to
hit.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Use pr_fmt, pr_<level> and netdev_<level> as appropriate.
tx_queue is used as a temporary queue when not allowed to queue skb
directly to the hw device driver (which may sleep). Most paths flush
it before returning, but ppp_start() currently cannot. Make sure we
don't leave skbs pointing to a non-existent device.
Thanks to Michael Barkowski for reporting this problem.
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
Error handling code following a kmalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f1 = E
(x->f1 == NULL || ...)
f(...,x->f1,...)
return \(0\|<+...x...+>\|ptr\);
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
// </smpl>
Base versions handle constant folding now.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Also remove unneeded last_rx update from Synclink drivers.
Synclink part mostly by Stephen Hemminger.
standard.
The syncppp layer wants a mid-level netdev private pointer.
It was using netdev->priv but that only worked by accident,
and thus this scheme was broken when the device private
allocation strategy changed.
Add a proper mid-layer private pointer for uses like this,
update syncppp and all users, and remove the HDLC_PPP broken
tag from drivers/net/wan/Kconfig
Removes now unneeded struct hdlc_device_desc
Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Since hardware header operations are part of the protocol class
not the device instance, make them into a separate object and
save memory.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Switching HDLC devices from Ethernet-framing mode caused stale ethernet
function assignments within net_device.
This patch enables building of individual WAN protocol support
routines (parts of generic HDLC) as separate modules.
All protocol-private definitions are moved from hdlc.h file
to protocol drivers. User-space interface and interface
between generic HDLC and underlying low-level HDLC drivers
are unchanged.
WAN: Fixed a problem with PPP/raw HDLC/X.25 protocols not doing
netif_dormant_off() at startup.
tr_type_trans(), hippi_type_trans() left as-is.
infrastructure for it.
Let it rip!
