[ Upstream commit 8d0d21f4053c07714802cbe8b1fe26913ec296cc ]
Even if we create a stacked vlan interface such as veth0.10.20, it sends
single tagged frames (tagged with only vid 10).
Because vlan_features of a veth interface has the
NETIF_F_HW_VLAN_[CTAG/STAG]_TX bits, veth0.10 also has that feature, so
dev_hard_start_xmit(veth0.10) doesn't call __vlan_put_tag() and
vlan_dev_hard_start_xmit(veth0.10) overwrites vlan_tci.
This prevents us from using a combination of 802.1ad and 802.1Q
in containers, etc.
Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
Acked-by: Flavio Leitner <fbl@redhat.com>
Pull core locking changes from Ingo Molnar:
"The biggest changes:
- add lockdep support for seqcount/seqlocks structures, this
unearthed both bugs and required extra annotation.
- move the various kernel locking primitives to the new
kernel/locking/ directory"
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits)
block: Use u64_stats_init() to initialize seqcounts
locking/lockdep: Mark __lockdep_count_forward_deps() as static
lockdep/proc: Fix lock-time avg computation
locking/doc: Update references to kernel/mutex.c
ipv6: Fix possible ipv6 seqlock deadlock
cpuset: Fix potential deadlock w/ set_mems_allowed
seqcount: Add lockdep functionality to seqcount/seqlock structures
net: Explicitly initialize u64_stats_sync structures for lockdep
locking: Move the percpu-rwsem code to kernel/locking/
locking: Move the lglocks code to kernel/locking/
locking: Move the rwsem code to kernel/locking/
locking: Move the rtmutex code to kernel/locking/
locking: Move the semaphore core to kernel/locking/
locking: Move the spinlock code to kernel/locking/
locking: Move the lockdep code to kernel/locking/
locking: Move the mutex code to kernel/locking/
hung_task debugging: Add tracepoint to report the hang
x86/locking/kconfig: Update paravirt spinlock Kconfig description
lockstat: Report avg wait and hold times
lockdep, x86/alternatives: Drop ancient lockdep fixup message
In order to enable lockdep on seqcount/seqlock structures, we
must explicitly initialize any locks.
The u64_stats_sync structure, uses a seqcount, and thus we need
to introduce a u64_stats_init() function and use it to initialize
the structure.
This unfortunately adds a lot of fairly trivial initialization code
to a number of drivers. But the benefit of ensuring correctness makes
this worth while.
Because these changes are required for lockdep to be enabled, and the
changes are quite trivial, I've not yet split this patch out into 30-some
separate patches, as I figured it would be better to get the various
maintainers thoughts on how to best merge this change along with
the seqcount lockdep enablement.
Feedback would be appreciated!
Signed-off-by: John Stultz <john.stultz@linaro.org>
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Jesse Gross <jesse@nicira.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Mirko Lindner <mlindner@marvell.com>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Roger Luethi <rl@hellgate.ch>
Cc: Simon Horman <horms@verge.net.au>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Wensong Zhang <wensong@linux-vs.org>
Cc: netdev@vger.kernel.org
Link: http://lkml.kernel.org/r/1381186321-4906-2-git-send-email-john.stultz@linaro.org
While investigating on a recent vxlan regression, I found veth
was using a zero features set for vxlan tunnels.
We have to segment GSO frames, copy the payload, and do the checksum.
This patch brings a ~200% performance increase
We probably have to add hw_enc_features support
on other virtual devices.
Cc: Alexei Starovoitov <ast@plumgrid.com>
We can only setup multicast address for network device when
net_device_ops->ndo_set_rx_mode is not null.
Some configurations need to add multicast address for net
device, such as netfilter cluster match module.
Add a fake ndo_set_rx_mode function to allow this operation.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
This reverts commit 612c337306f00dc8d396830212de51c475844791.
As per Stephen Hemminger, the layout of the netlink attribute
is not implemented correctly so revert this for now.
ip link has ability to show extra information of net work device if
kernel provides sunh information. With this patch veth driver can
provide its peer ifindex information to ip command via netlink
interface.
Signed-off-by: Masatake YAMATO <yamato@redhat.com>
The veth device doesn't provide the vlan features,
so TSO for example is disabled and that causes
performance issues when using tagged traffic.
The test topology looks like this:
br0 br1
vnet veth0.10 ----- veth1.10 vnet
VM VM
The netperf results with current veth driver:
MIGRATED TCP STREAM TEST from 192.168.1.1 ()
port 0 AF_INET to 192.168.1.2 () port 0 AF_INET
Recv Send Send
Socket Socket Message Elapsed
Size Size Size Time Throughput
bytes bytes bytes secs. 10^6bits/sec
87380 16384 16384 10.01 2210.22
Now after applying the proposed patch:
Recv Send Send
87380 16384 16384 10.00 13067.47
Signed-off-by: Flavio Leitner <fbl@redhat.com>
it's called in the following register_netdevice. No need to call it
here.
Tested with "ip link add type veth" and "ip link add xxx%d type veth".
Signed-off-by: Hong Zhiguo <honkiko@gmail.com>
- macvlan: propagate STAG filtering capabilities from underlying device
- ifb: announce STAG tagging support in addition to CTAG tagging support
- veth: announce STAG tagging/stripping support in addition to CTAG support
Rename the hardware VLAN acceleration features to include "CTAG" to indicate
that they only support CTAGs. Follow up patches will introduce 802.1ad
server provider tagging (STAGs) and require the distinction for hardware not
supporting acclerating both.
commit d0e2c55e7c940 (veth: avoid a NULL deref in veth_stats_one)
added another NULL deref in veth_dellink().
# ip link add name veth1 type veth peer name veth0
# rmmod veth
We crash because veth_dellink() is called twice, so we must
take care of NULL peer.
In commit d0e2c55e7c94 (veth: avoid a NULL deref in veth_stats_one)
we now clear the peer pointers in veth_dellink()
veth_close() must therefore make sure the peer pointer is set.
Reported-by: Tom Parkin <tom.parkin@gmail.com>
commit 2681128f0ced8a (veth: extend device features) added a NULL deref
in veth_stats_one(), as veth_get_stats64() was not testing if the peer
device was setup or not.
At init time, we call dev_get_stats() before veth pair is fully setup.
[ 178.854758] [<ffffffffa00f5677>] veth_get_stats64+0x47/0x70 [veth]
[ 178.861013] [<ffffffff814f0a2d>] dev_get_stats+0x6d/0x130
[ 178.866486] [<ffffffff81504efc>] rtnl_fill_ifinfo+0x47c/0x930
[ 178.872299] [<ffffffff81505b93>] rtmsg_ifinfo+0x83/0x100
[ 178.877678] [<ffffffff81505cc6>] rtnl_configure_link+0x76/0xa0
[ 178.883580] [<ffffffffa00f52fa>] veth_newlink+0x16a/0x350 [veth]
[ 178.889654] [<ffffffff815061cc>] rtnl_newlink+0x4dc/0x5e0
[ 178.895128] [<ffffffff81505e1e>] ? rtnl_newlink+0x12e/0x5e0
[ 178.900769] [<ffffffff8150587d>] rtnetlink_rcv_msg+0x11d/0x310
[ 178.906669] [<ffffffff81505760>] ? __rtnl_unlock+0x20/0x20
[ 178.912225] [<ffffffff81521f89>] netlink_rcv_skb+0xa9/0xd0
[ 178.917779] [<ffffffff81502d55>] rtnetlink_rcv+0x25/0x40
[ 178.923159] [<ffffffff815218d1>] netlink_unicast+0x1b1/0x230
[ 178.928887] [<ffffffff81521c4e>] netlink_sendmsg+0x2fe/0x3b0
[ 178.934615] [<ffffffff814dbe22>] sock_sendmsg+0xd2/0xf0
So we must check if peer was setup in veth_get_stats64()
As pointed out by Ben Hutchings, priv->peer is missing proper
synchronization. Adding RCU protection is a safe and well documented
way to make sure we don't access about to be freed or already
freed data.
Reported-by: Tom Parkin <tparkin@katalix.com>
CC: Ben Hutchings <bhutchings@solarflare.com>
veth is lacking most modern facilities, like SG, checksums, TSO.
It makes sense to extend dev->features to get them, or GRO aggregation
is defeated by a forced segmentation.
Reported-by: Andrew Vagin <avagin@parallels.com>
Cc: Michał Mirosław <mirq-linux@rere.qmqm.pl>
veth stats are a bit bloated. There is no need to account transmit
and receive stats, since they are absolutely symmetric.
Also use a per device atomic64_t for the dropped counter, as it
should never be used in fast path.
This patch removes an unused parameter (src_net) from rtnl_create_link()
method and from the method single invocation, in veth.
This parameter was used in the past when calling
ops->get_tx_queues(src_net, tb) in rtnl_create_link().
The get_tx_queues() member of rtnl_link_ops was replaced by two methods,
get_num_tx_queues() and get_num_rx_queues(), which do not get any
parameter. This was done in commit d40156aa5ecbd51fed932ed4813df82b56e5ff4d by
Jiri Pirko ("rtnl: allow to specify different num for rx and tx queue count").
Signed-off-by: Rami Rosen <ramirose@gmail.com>
The ifinfomsg is in there (thanks kaber@ for foreseeing this long time ago),
so take the given ifidex and register netdev with it.
Ben noticed, that this code path previously ignored ifmp->ifi_index and
userland could be passing in garbage. Thus it may now fail occasionally
because the value clashes with an existing interface.
To address this it's assumed that if the caller specifies the ifindex for
the veth master device, then it's aware of this possibility and should
explicitly specify (or set to 0 for auto-assignment) the peer's ifindex as
well. With this the compatibility with old tools not setting ifindex is
preserved.
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
drivers/net/ethernet/broadcom/bnx2x/bnx2x_stats.c
Small minor conflict in bnx2x, wherein one commit changed how
statistics were stored in software, and another commit
fixed endianness bugs wrt. reading the values provided by
the chip in memory.
Replace usage of random_ether_addr() with eth_hw_addr_random()
to set addr_assign_type correctly to NET_ADDR_RANDOM.
Change the trivial cases.
v2: adapt to renamed eth_hw_addr_random()
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
VETH_INFO_PEER carries struct ifinfomsg plus optional IFLA
attributes. A minimal size of sizeof(struct ifinfomsg) must be
enforced or we may risk accessing that struct beyond the limits
of the netlink message.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
number of drivers
Per discussion with Ben Hutchings and David Miller, go through and
remove assignments of "N/A" to fw_version in various drivers'
.get_drvinfo routines. While there clean-up some use of bare
constants and such.
Signed-off-by: Rick Jones <rick.jones2@hp.com>
Only distinct use is checking if NETIF_F_NOCACHE_COPY should be
enabled by default. The check heuristics is altered a bit here,
so it hits other people than before. The default shouldn't be
trusted for performance-critical cases anyway.
For all other uses NETIF_F_NO_CSUM is equivalent to NETIF_F_HW_CSUM.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Convert some remaining straglers' .get_drvinfo routines to use strlcpy
rather than strcpy/strncpy.
Tunnels can force an alignment of their percpu data to reduce number of
cache lines used in fast path, or read in .ndo_get_stats()
percpu_alloc() is a very fine grained allocator, so any small hole will
be used anyway.
The device.h header was including module.h, making it present for
most of these drivers. But we want to clean that up. Call out the
include of module.h in the modular network drivers.
After the last patch, We are left in a state in which only drivers calling
ether_setup have IFF_TX_SKB_SHARING set (we assume that drivers touching real
hardware call ether_setup for their net_devices and don't hold any state in
their skbs. There are a handful of drivers that violate this assumption of
course, and need to be fixed up. This patch identifies those drivers, and marks
them as not being able to support the safe transmission of skbs by clearning the
IFF_TX_SKB_SHARING flag in priv_flags
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Karsten Keil <isdn@linux-pingi.de>
CC: "David S. Miller" <davem@davemloft.net>
CC: Jay Vosburgh <fubar@us.ibm.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: Patrick McHardy <kaber@trash.net>
CC: Krzysztof Halasa <khc@pm.waw.pl>
CC: "John W. Linville" <linville@tuxdriver.com>
CC: Greg Kroah-Hartman <gregkh@suse.de>
CC: Marcel Holtmann <marcel@holtmann.org>
CC: Johannes Berg <johannes@sipsolutions.net>
Followup to commit f82528bc13a (Exclude duplicated checking for
iface-up) : We no longer need percpu tx_dropped field.
'is_skb_forwardable' function, which is subroutine of 'dev_forward_skb'.
Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
Using 64bit stats on 32bit arches must use a synchronization or readers
can get transient values.
Fixes bug introduced in commit 6311cc44a2 (veth: convert to 64 bit
statistics)
Not much change, device was already keeping per cpu statistics.
Use recent 64 statistics interface.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Reviewed-by: Jiri Pirko <jpirko@redhat.com>
drivers/net/tg3.c
84c49d8c3e4abefb0a41a77b25aa37ebe8d6b743 ("veth: remove unneeded
ifname code from veth_newlink()") caused regression on veth
creation. This patch reverts the original one.
Reported-by: Michał Mirosław <mirqus@gmail.com>
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
This updates the network drivers so that they don't access the
ethtool_cmd::speed field directly, but use ethtool_cmd_speed()
instead.
For most of the drivers, these changes are purely cosmetic and don't
fix any problem, such as for those 1GbE/10GbE drivers that indirectly
call their own ethtool get_settings()/mii_ethtool_gset(). The changes
are meant to enforce code consistency and provide robustness with
future larger throughputs, at the expense of a few CPU cycles for each
ethtool operation.
All drivers compiled with make allyesconfig ion x86_64 have been
updated.
Tested: make allyesconfig on x86_64 + e1000e/bnx2x work
Signed-off-by: David Decotigny <decot@google.com>
This should probably get TSO available as it's basically a loopback device.
Offloads are left disabled by default - as before.
Commit 44540960 "veth: move loopback logic to common location" introduced
a bug in the packet counters. I don't understand why that happened as it
is not explained in the comments and the mut check in dev_forward_skb
retains the assumption that skb->len is the total length of the packet.
I just measured this emperically by setting up a veth pair between two
noop network namespaces setting and attempting a telnet connection between
the two. I saw three packets in each direction and the byte counters were
exactly 14*3 = 42 bytes high in each direction. I got the actual
packet lengths with tcpdump.
So remove the extra ETH_HLEN from the veth byte count totals.
Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com>
The code is not needed because tb[IFLA_IFNAME] is already
processed in rtnl_newlink(). Remove this redundancy.
We can't change ip_summed from CHECKSUM_PARTIAL to CHECKSUM_NONE
or CHECKSUM_UNNECESSARY because checksum in packet's headers is
not valid and will cause invalid checksum when frame is forwarded.
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
In case of congestion, netif_rx() frees the skb, so we must assume
dev_forward_skb() also consume skb.
Bug introduced by commit 445409602c092
(veth: move loopback logic to common location)
We must change dev_forward_skb() to always consume skb, and veth to not
double free it.
Bug report : http://marc.info/?l=linux-netdev&m=127310770900442&w=3
Reported-by: Martín Ferrari <martin.ferrari@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
commit e8469ed959c373c2ff9e6f488aa5a14971aebe1f
Author: Patrick McHardy <kaber@trash.net>
Date: Tue Feb 23 20:41:30 2010 +0100
Support specifying the initial device flags when creating a device though
rtnl_link. Devices allocated by rtnl_create_link() are marked as INITIALIZING
in order to surpress netlink registration notifications. To complete setup,
rtnl_configure_link() must be called, which performs the device flag changes
and invokes the deferred notifiers if everything went well.
Two examples:
# add macvlan to eth0
$ ip link add link eth0 up allmulticast on type macvlan
[LINK]11: macvlan0@eth0: <BROADCAST,MULTICAST,ALLMULTI,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN
link/ether 26:f8:84:02:f9:2a brd ff:ff:ff:ff:ff:ff
[ROUTE]ff00::/8 dev macvlan0 table local metric 256 mtu 1500 advmss 1440 hoplimit 0
[ROUTE]fe80::/64 dev macvlan0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
[ADDR]11: macvlan0 inet6 fe80::24f8:84ff:fe02:f92a/64 scope link
valid_lft forever preferred_lft forever
[ROUTE]local fe80::24f8:84ff:fe02:f92a via :: dev lo table local proto none metric 0 mtu 16436 advmss 16376 hoplimit 0
[ROUTE]default via fe80::215:e9ff:fef0:10f8 dev macvlan0 proto kernel metric 1024 mtu 1500 advmss 1440 hoplimit 0
[NEIGH]fe80::215:e9ff:fef0:10f8 dev macvlan0 lladdr 00:15:e9:f0:10:f8 router STALE
[ROUTE]2001:6f8:974::/64 dev macvlan0 proto kernel metric 256 expires 0sec mtu 1500 advmss 1440 hoplimit 0
[PREFIX]prefix 2001:6f8:974::/64 dev macvlan0 onlink autoconf valid 14400 preferred 131084
[ADDR]11: macvlan0 inet6 2001:6f8:974:0:24f8:84ff:fe02:f92a/64 scope global dynamic
valid_lft 86399sec preferred_lft 14399sec
# add VLAN to eth1, eth1 is down
$ ip link add link eth1 up type vlan id 1000
RTNETLINK answers: Network is down
<no events>
Add __percpu sparse annotations to net drivers.
These annotations are to make sparse consider percpu variables to be
in a different address space and warn if accessed without going
through percpu accessors. This patch doesn't affect normal builds.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits)
m68k: rename global variable vmalloc_end to m68k_vmalloc_end
percpu: add missing per_cpu_ptr_to_phys() definition for UP
percpu: Fix kdump failure if booted with percpu_alloc=page
percpu: make misc percpu symbols unique
percpu: make percpu symbols in ia64 unique
percpu: make percpu symbols in powerpc unique
percpu: make percpu symbols in x86 unique
percpu: make percpu symbols in xen unique
percpu: make percpu symbols in cpufreq unique
percpu: make percpu symbols in oprofile unique
percpu: make percpu symbols in tracer unique
percpu: make percpu symbols under kernel/ and mm/ unique
percpu: remove some sparse warnings
percpu: make alloc_percpu() handle array types
vmalloc: fix use of non-existent percpu variable in put_cpu_var()
this_cpu: Use this_cpu_xx in trace_functions_graph.c
this_cpu: Use this_cpu_xx for ftrace
this_cpu: Use this_cpu_xx in nmi handling
this_cpu: Use this_cpu operations in RCU
this_cpu: Use this_cpu ops for VM statistics
Fix up trivial (famous last words) global per-cpu naming conflicts in
arch/x86/kvm/svm.c
mm/slab.c
drivers/ieee802154/fakehard.c
drivers/net/e1000e/ich8lan.c
drivers/net/e1000e/phy.c
drivers/net/netxen/netxen_nic_init.c
drivers/net/wireless/ath/ath9k/main.c
The veth driver contains code to forward an skb
from the start_xmit function of one network
device into the receive path of another device.
Moving that code into a common location lets us
reuse the code for direct forwarding of data
between macvlan ports, and possibly in other
drivers.
Acked-by: Patrick McHardy <kaber@trash.net>
veth_get_stats() can be called in parallel on several cpus.
It's better to not reset dev->stats as it could give wrong result on
one cpu. Use temporary variables, then store the final results.
Also, we should loop on every possible cpus, not only online cpus,
or cpu hotplug can suddenly give wrong veth stats.
