This patch allows the GPIO/LED settings to be configured by the
EEPROM if present, and only sets the default values (LED outputs
for link/activity) when an EEPROM is not detected.
Signed-off-by: Steve Glendinning <steve.glendinning@shawell.net>
Only a write is necessary to clear the interrupt status, and we
don't use the value from the preceding read operation. This
patch eliminates the unnecessary read.
This patch defines PHY_INT_SRC_CLEAR_ALL to replace the value 0xffff
in order to be more self-documenting.
This patch should make no functional change, it is purely cosmetic.
drivers/net/ethernet/intel/e1000e/param.c
drivers/net/wireless/iwlwifi/iwl-agn-rx.c
drivers/net/wireless/iwlwifi/iwl-trans-pcie-rx.c
drivers/net/wireless/iwlwifi/iwl-trans.h
Resolved the iwlwifi conflict with mainline using 3-way diff posted
by John Linville and Stephen Rothwell. In 'net' we added a bug
fix to make iwlwifi report a more accurate skb->truesize but this
conflicted with RX path changes that happened meanwhile in net-next.
In e1000e a conflict arose in the validation code for settings of
adapter->itr. 'net-next' had more sophisticated logic so that
logic was used.
Some RNDIS devices include a bogus CDC Union descriptor pointing
to non-existing interfaces. The RNDIS code is already prepared
to handle devices without a CDC Union descriptor by hardwiring
the driver to use interfaces 0 and 1, which is correct for the
devices with the bogus descriptor as well. So we can reuse the
existing workaround.
Cc: Markus Kolb <linux-201011@tower-net.de>
Cc: Iker Salmón San Millán <shaola@esdebian.org>
Cc: Jonathan Nieder <jrnieder@gmail.com>
Cc: Oliver Neukum <oliver@neukum.org>
Cc: 655387@bugs.debian.org
Cc: stable@vger.kernel.org
Signed-off-by: Bjørn Mork <bjorn@mork.no>
If register_netdev returns failure, the dev->interrupt and
its transfer buffer should be released, so just fix it.
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
The transfer buffer of dev->interrupt is allocated in .probe path,
but not freed in .disconnet path, so mark the interrupt URB as
URB_FREE_BUFFER to free the buffer when the URB is destroyed.
Acked-by: Oliver Neukum <oneukum@suse.de>
This patch sets the automatic speed and duplex detection bits
in MAC_CR to enable the mac to determine its speed automatically
from the phy.
Note this must be done BEFORE the receiver or transmitter is
enabled.
Signed-off-by: Stephane Fillod <fillods@users.sf.net>
also explicitly set the phy to advertise 1000 speeds
smsc75xx phy interrupt acknowledge needs an mdio_write to clear
PHY_INT_SRC instead of just a read like in smsc95xx.
fix bug in phy_init loop that was ignoring BMCR reset bit, akin to smsc95xx's d946092000698fd204d82a9d239103c656fb63bf
smsc75xx needs MII_ACCESS_BUSY to be set to correctly trigger mdio I/O. Note smsc75xx is different from smsc95xx in this regard.
changes
This patch fixes the same issue as reported on smsc95xx, where the
usb device is connected with no ethernet cable plugged-in.
Without this patch sysfs reports the cable as present
flag@flag-desktop:~$ cat /sys/class/net/eth0/carrier
1
while it's not:
flag@flag-desktop:~$ sudo mii-tool eth0
eth0: no link
changes
1
while it's not:
eth0: no link
Tested on my Beagle XM.
v2: added mantainer to the list of recipient
Signed-off-by: Paolo Pisati <paolo.pisati@canonical.com>
Acked-by: Steve Glendinning <steve.glendinning@shawell.net>
The asix.c USB Ethernet driver avoids ending a tx transfer with a zero-
length packet by appending a four-byte padding to transfers whose length
is a multiple of maxpacket. However, the hard-coded 512 byte maxpacket
length is valid for high-speed USB only; full-speed USB uses 64 byte
packets.
Signed-off-by: Ingo van Lil <inguin@gmx.de>
Make smsc95xx recalculate the hard_mtu after adjusting the
hard_header_len.
Without this, usbnet adjusts the MTU down to 1488 bytes, and the host is
unable to receive standard 1500-byte frames from the device.
Inspired by same fix on cdc_eem 78fb72f7936c01d5b426c03a691eca082b03f2b9.
Tested on ARM/Beagle.
Fix merge between commit 3adadc08cc1e ("net ax25: Reorder ax25_exit to
remove races") and commit 0ca7a4c87d27 ("net ax25: Simplify and
cleanup the ax25 sysctl handling")
The former moved around the sysctl register/unregister calls, the
later simply removed them.
With help from Stephen Rothwell.
The MC77xx devices can operate in two modes: "Direct IP" or "QMI",
switchable using a password protected AT command. Both product ID
and USB interface configuration will change when switched.
The "sierra_net" driver supports the "Direct IP" mode. This driver
supports the "QMI" mode.
There are also multiple possible USB interface configurations in each
mode, some providing more than one wwan interface. Like many other
devices made for Windows, different interface types are identified
using a static interface number. We define a Sierra specific
interface whitelist to support this.
Make smsc75xx recalculate the hard_mtu after adjusting the
hard_header_len.
Without this, usbnet adjusts the MTU down to 1492 bytes, and the host is
Tested on ARM/Omap3 with EVB-LAN7500-LC.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
Make CDC EEM recalculate the hard_mtu after adjusting the
hard_header_len.
Without this, usbnet adjusts the MTU down to 1494 bytes, and the host is
Tested with the Linux USB Ethernet gadget.
Cc: Oliver Neukum <oliver@neukum.name>
Signed-off-by: Rabin Vincent <rabin@rab.in>
There exist duplicated macro definitions in rtl8150.c, remove them.
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
Now skb_add_rx_frag() has a truesize parameter, we can fix cdc-phonet to
properly account truesize of each fragment : a full page.
Cc: Felipe Balbi <balbi@ti.com>
Cc: Rémi Denis-Courmont <remi.denis-courmont@nokia.com>
Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com>
Added Vendor/Device Id of Motorola Rokr E6 (22b8:6027) so it can be
recognized by the "zaurus" USBNet driver.
Applies to Linux 3.2.13 and 2.6.39.4.
Signed-off-by: Guan Xin <guanx.bac@gmail.com>
skb_add_rx_frag() API is misleading.
Network skbs built with this helper can use uncharged kernel memory and
eventually stress/crash machine in OOM.
Add a 'truesize' parameter and then fix drivers in followup patches.
Cc: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Now that we have the beginnings of an OSS method to use the network
interfaces on these USB broadband modems, add the ZTE manufactured
Vodafone items to the whitelist
Signed-off-by: Andrew Bird <ajb@spheresystems.co.uk>
Acked-by: Bjørn Mork <bjorn@mork.no>
usbnet should centrally handle busy reporting in the rx path
so subdrivers need not worry. This hurts use cases which do
rx only or predominantly.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
URB unlinking is always racing with its completion and tx_complete
may be called before or during running usb_unlink_urb, so tx_complete
must not clear urb->dev since it will be used in unlink path,
otherwise invalid memory accesses or usb device leak may be caused
inside usb_unlink_urb.
Cc: stable@kernel.org
Cc: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d(net/usbnet: avoid
recursive locking in usbnet_stop()) fixes the recursive locking
problem by releasing the skb queue lock, but it makes usb_unlink_urb
racing with defer_bh, and the URB to being unlinked may be freed before
or during calling usb_unlink_urb, so use-after-free problem may be
triggerd inside usb_unlink_urb.
The patch fixes the use-after-free problem by increasing URB
reference count with skb queue lock held before calling
usb_unlink_urb, so the URB won't be freed until return from
usb_unlink_urb.
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Reported-by: Dave Jones <davej@redhat.com>
Pull networking merge from David Miller:
"1) Move ixgbe driver over to purely page based buffering on receive.
From Alexander Duyck.
2) Add receive packet steering support to e1000e, from Bruce Allan.
3) Convert TCP MD5 support over to RCU, from Eric Dumazet.
4) Reduce cpu usage in handling out-of-order TCP packets on modern
systems, also from Eric Dumazet.
5) Support the IP{,V6}_UNICAST_IF socket options, making the wine
folks happy, from Erich Hoover.
6) Support VLAN trunking from guests in hyperv driver, from Haiyang
Zhang.
7) Support byte-queue-limtis in r8169, from Igor Maravic.
8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but
was never properly implemented, Jiri Benc fixed that.
9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang.
10) Support kernel side dump filtering by ctmark in netfilter
ctnetlink, from Pablo Neira Ayuso.
11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker.
12) Add new peek socket options to assist with socket migration, from
Pavel Emelyanov.
13) Add sch_plug packet scheduler whose queue is controlled by
userland daemons using explicit freeze and release commands. From
Shriram Rajagopalan.
14) Fix FCOE checksum offload handling on transmit, from Yi Zou."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits)
Fix pppol2tp getsockname()
Remove printk from rds_sendmsg
ipv6: fix incorrent ipv6 ipsec packet fragment
cpsw: Hook up default ndo_change_mtu.
net: qmi_wwan: fix build error due to cdc-wdm dependecy
netdev: driver: ethernet: Add TI CPSW driver
netdev: driver: ethernet: add cpsw address lookup engine support
phy: add am79c874 PHY support
mlx4_core: fix race on comm channel
bonding: send igmp report for its master
fs_enet: Add MPC5125 FEC support and PHY interface selection
net: bpf_jit: fix BPF_S_LDX_B_MSH compilation
net: update the usage of CHECKSUM_UNNECESSARY
fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx
net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso
ixgbe: Fix issues with SR-IOV loopback when flow control is disabled
net/hyperv: Fix the code handling tx busy
ixgbe: fix namespace issues when FCoE/DCB is not enabled
rtlwifi: Remove unused ETH_ADDR_LEN defines
igbvf: Use ETH_ALEN
Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and
drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
Pull USB merge for 3.4-rc1 from Greg KH:
"Here's the big USB merge for the 3.4-rc1 merge window.
Lots of gadget driver reworks here, driver updates, xhci changes, some
new drivers added, usb-serial core reworking to fix some bugs, and
other various minor things.
There are some patches touching arch code, but they have all been
acked by the various arch maintainers."
* tag 'usb-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (302 commits)
net: qmi_wwan: add support for ZTE MF820D
USB: option: add ZTE MF820D
usb: gadget: f_fs: Remove lock is held before freeing checks
USB: option: make interface blacklist work again
usb/ub: deprecate & schedule for removal the "Low Performance USB Block" driver
USB: ohci-pxa27x: add clk_prepare/clk_unprepare calls
USB: use generic platform driver on ath79
USB: EHCI: Add a generic platform device driver
USB: OHCI: Add a generic platform device driver
USB: ftdi_sio: new PID: LUMEL PD12
USB: ftdi_sio: add support for FT-X series devices
USB: serial: mos7840: Fixed MCS7820 device attach problem
usb: Don't make USB_ARCH_HAS_{XHCI,OHCI,EHCI} depend on USB_SUPPORT.
usb gadget: fix a section mismatch when compiling g_ffs with CONFIG_USB_FUNCTIONFS_ETH
USB: ohci-nxp: Remove i2c_write(), use smbus
USB: ohci-nxp: Support for LPC32xx
USB: ohci-nxp: Rename symbols from pnx4008 to nxp
USB: OHCI-HCD: Rename ohci-pnx4008 to ohci-nxp
usb: gadget: Kconfig: fix typo for 'different'
usb: dwc3: pci: fix another failure path in dwc3_pci_probe()
Pull TTY/serial patches from Greg KH:
"tty and serial merge for 3.4-rc1
Here's the big serial and tty merge for the 3.4-rc1 tree.
There's loads of fixes and reworks in here from Jiri for the tty
layer, and a number of patches from Alan to help try to wrestle the vt
layer into a sane model.
Other than that, lots of driver updates and fixes, and other minor
stuff, all detailed in the shortlog."
* tag 'tty-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (132 commits)
serial: pxa: add clk_prepare/clk_unprepare calls
TTY: Wrong unicode value copied in con_set_unimap()
serial: PL011: clear pending interrupts
serial: bfin-uart: Don't access tty circular buffer in TX DMA interrupt after it is reset.
vt: NULL dereference in vt_do_kdsk_ioctl()
tty: serial: vt8500: fix annotations for probe/remove
serial: remove back and forth conversions in serial_out_sync
serial: use serial_port_in/out vs serial_in/out in 8250
serial: introduce generic port in/out helpers
serial: reduce number of indirections in 8250 code
serial: delete useless void casts in 8250.c
serial: make 8250's serial_in shareable to other drivers.
serial: delete last unused traces of pausing I/O in 8250
pch_uart: Add module parameter descriptions
pch_uart: Use existing default_baud in setup_console
pch_uart: Add user_uartclk parameter
pch_uart: Add Fish River Island II uart clock quirks
pch_uart: Use uartclk instead of base_baud
mpc5200b/uart: select more tolerant uart prescaler on low baudrates
tty: moxa: fix bit test in moxa_start()
Fixes:
drivers/built-in.o: In function `qmi_wwan_bind_shared':
qmi_wwan.c:(.text+0x25b686): undefined reference to `usb_cdc_wdm_register'
make[1]: *** [.tmp_vmlinux1] Error 1
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
If host is going to autosuspend function with two interfaces and
if IP packet has arrived in-between of two usbnet_suspend() callbacks,
i.e usbnet_resume() is called in-between, tx data flow is stopped.
When autosuspend timer expires and device is put to autosuspend
again, tx queue is waked up and data can be sent again.
This behavior might be repeated several times in a row.
Tested on Intel/ARM.
Reviewed-by: Sjur Brændeland <sjur.brandeland@stericsson.com>
Tested-by: Dmitry Tarnyagin <dmitry.tarnyagin@stericsson.com>
Signed-off-by: Alexey Orishko <alexey.orishko@stericsson.com>
ZTE have yet to discover the magic of USB descriptors. These
devices use ff/ff/ff for class/subclass/protocol regardless of
function, except for usb-storage. Use an interface number
whitelist to force the driver to bind only to the QMI/wwan
interface.
Changes:
- removed a limit for amount of datagrams for IN NTB
- using pointer to traverse NTB in rx_fixup()
- renamed "temp" to "len" in rx_fixup()
- do NTB sequence number check in rx path
Tested-by: Dmitry Tarnyagin <Dmitry.Tarnyagin@stericsson.com>
Changes/fixes:
- inform device if max_datagram_size was changed by host
- max_datagram_size can't be bigger MTU in ETH func descr
- fix constants definitions to enable running CAIF service over NCM
Changes:
- use high resolution timer
latency became approx. 10-15 times less than before
- use taklet for sending remaining data in tx path
network drivers should reserve some headroom on incoming skbs so that we
dont need expensive reallocations, eg forwarding packets in tunnels.
This NET_SKB_PAD padding is done in various helpers, like
__netdev_alloc_skb_ip_align() in this patch, combining NET_SKB_PAD and
NET_IP_ALIGN magic.
Cc: Oliver Neukum <oneukum@suse.de>
asix_rx_fixup() is complex, and does some unnecessary memory copies (at
least on x86 where NET_IP_ALIGN is 0)
Also, it tends to provide skbs with a big truesize (4096+256 with
MTU=1500) to upper stack, so incoming trafic consume a lot of memory and
I noticed early packet drops because we hit socket rcvbuf too fast.
Switch to a different strategy, using copybreak so that we provide nice
skbs to upper stack (including the NET_SKB_PAD to avoid future head
reallocations in some paths)
With this patch, I no longer see packets drops or tcp collapses on
various tcp workload with a AX88772 adapter.
Cc: Aurelien Jacobs <aurel@gnuage.org>
Cc: Trond Wuellner <trond@chromium.org>
Cc: Grant Grundler <grundler@chromium.org>
Cc: Paul Stewart <pstew@chromium.org>
Reviewed-by: Grant Grundler <grundler@chromium.org>
This resolves the conflict with drivers/usb/host/ehci-fsl.h that
happened with changes in Linus's and this branch at the same time.
This patch adds support for the Sitecom LN-031 USB adapter with a AX88178 chip.
Added USB id to find correct driver for AX88178 1000 Ethernet adapter.
Signed-off-by: Joerg Neikes <j.neikes@midlandgate.de>
Adding the Pantech UML290 and all non-QDL Gobi device IDs from the
qcserial driver now that we have support for shared net/QMI USB
interfaces. Most of these are not yet tested with this driver, but
should be mostly identical to tested devices, except for device IDs.
Gobi devices provide several different interfaces (serial/net/other)
using the exact same class, subclass and protocol values. This driver
will only support the net/QMI function while there are other drivers
supporting other device functions. The net/QMI interface number may
also differ from device to device. It has been noted that all the
other interfaces have additional functional descriptors, so we use that
to detect the interface supported by this driver.
Use the new cdc-wdm subdriver interface to create a device management
device even for USB devices having a single combined QMI/wwan USB
interface with three endpoints (int, bulk in, bulk out) instead of
separate data and control interfaces.
Some Huawei devices can be switched to a single interface mode for
use with other operating systems than Linux. This adds support
for these devices when they run in such non-Linux modes.
Some WWAN LTE/3G devices based on chipsets from Qualcomm provide
near standard CDC ECM interfaces in addition to the usual serial
interfaces. The Huawei E392/E398 are examples of such devices.
These typically cannot be fully configured using AT commands
over a serial interface. It is necessary to speak the proprietary
Qualcomm MSM Interface (QMI) protocol to the device to enable the
ethernet proxy functionality.
The devices embed the QMI protocol in CDC on the control interface,
using standard CDC commands and notifications. The do not otherwise
use CDC commands for the ethernet function. This driver does
therefore not need access to any other aspects of the control
interface than the descriptors attached to it.
Another driver, cdc-wdm, will provide userspace access to the
QMI protocol independently of this driver. To facilitate this,
this driver avoids binding to the control interface, and uses
only the associated data interface after parsing the common CDC
functional descriptors on the control interface.
You will want both the cdc-wdm and option drivers as companions to
this driver, to have full access to all interfaces and protocols
exported by the device.
