Instead of dereferencing pointer and put values on stack we could use nice
%*phC specifier.
Merge net into net-next because some upcoming net-next changes
build on top of bug fixes that went into net.
Pull networking fixes from David Miller:
"It's been a while since my last pull request so quite a few fixes have
piled up."
Indeed.
1) Fix nf_{log,queue} compilation with PROC_FS disabled, from Pablo
Neira Ayuso.
2) Fix data corruption on some tg3 chips with TSO enabled, from Michael
Chan.
3) Fix double insertion of VLAN tags in be2net driver, from Sarveshwar
Bandi.
4) Don't have TCP's MD5 support pass > PAGE_SIZE page offsets in
scatter-gather entries into the crypto layer, the crypto layer can't
handle that. From Eric Dumazet.
5) Fix lockdep splat in 802.1Q MRP code, also from Eric Dumazet.
6) Fix OOPS in netfilter log module when called from conntrack, from
Hans Schillstrom.
7) FEC driver needs to use netif_tx_{lock,unlock}_bh() rather than the
non-BH disabling variants. From Fabio Estevam.
8) TCP GSO can generate out-of-order packets, fix from Eric Dumazet.
9) vxlan driver doesn't update 'used' field of fdb entries when it
should, from Sridhar Samudrala.
10) ipv6 should use kzalloc() to allocate inet6 socket cork options,
otherwise we can OOPS in ip6_cork_release(). From Eric Dumazet.
11) Fix races in bonding set mode, from Nikolay Aleksandrov.
12) Fix checksum generation regression added by "r8169: fix 8168evl
frame padding.", from Francois Romieu.
13) ip_gre can look at stale SKB data pointer, fix from Eric Dumazet.
14) Fix checksum handling when GSO is enabled in bnx2x driver with
certain chips, from Yuval Mintz.
15) Fix double free in batman-adv, from Martin Hundebøll.
16) Fix device startup synchronization with firmware in tg3 driver, from
Nithin Sujit.
17) perf networking dropmonitor doesn't work at all due to mixed up
trace parameter ordering, from Ben Hutchings.
18) Fix proportional rate reduction handling in tcp_ack(), from Nandita
Dukkipati.
19) IPSEC layer doesn't return an error when a valid state is detected,
causing an OOPS. Fix from Timo Teräs.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (85 commits)
be2net: bug fix on returning an invalid nic descriptor
tcp: xps: fix reordering issues
net: Revert unused variable changes.
xfrm: properly handle invalid states as an error
virtio_net: enable napi for all possible queues during open
tcp: bug fix in proportional rate reduction.
net: ethernet: sun: drop unused variable
net: ethernet: korina: drop unused variable
net: ethernet: apple: drop unused variable
qmi_wwan: Added support for Cinterion's PLxx WWAN Interface
perf: net_dropmonitor: Remove progress indicator
perf: net_dropmonitor: Use bisection in symbol lookup
perf: net_dropmonitor: Do not assume ordering of dictionaries
perf: net_dropmonitor: Fix symbol-relative addresses
perf: net_dropmonitor: Fix trace parameter order
net: fec: use a more proper compatible string for MVF type device
qlcnic: Fix updating netdev->features
qlcnic: remove netdev->trans_start updates within the driver
qlcnic: Return proper error codes from probe failure paths
tg3: Update version to 3.132
Added support for Cinterion's PLxx WWAN Interface by adding QMI_FIXED_INTF with
Cinterion's Vendor ID as well as Product ID and WWAN Interface Number.
Signed-off-by: Hans-Christoph Schemmel <hans-christoph.schemmel@gemalto.com>
Signed-off-by: Christian Schmiedl <christian.schmiedl@gemalto.com>
Acked-by: Bjørn Mork <bjorn@mork.no>
This patch fixes a potential race with concurrently running asynchronous
write requests. The values for device's RX control register are now
stored in dynamically allocated buffers so each URB submission has it's
own copy. Doing it the old way is data clobbering prone.
This patch is against latest 'net' tree.
Signed-off-by: Petko Manolov <petkan@nucleusys.com>
module_usb_driver() eliminates boilerplate and simplifies the code.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Cc: Realtek linux nic maintainers <nic_swsd@realtek.com>
version.h header inclusion is not necessary as detected by
checkversion.pl.
Commit 84ebc10294a3d7be4c66f51070b7aedbaa24de9b (USB: remove
CONFIG_USB_SUSPEND option) failed to remove all of the usages of
USB_SUSPEND throughout the kernel. This patch (as1677) removes the
remaining instances of that symbol.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
The driver and firmware sync up through SYNC messages, and the
firmware's affirmative reply to these SYNC messages appears to be the
"Reset" indication received via the status interrupt endpoint. Thus the
driver needs the status interrupt endpoint always active so that the
Reset indication can be received even if the netdev is closed, which is
the case right after device insertion.
If the Reset indication is not received by the driver, it continues
sending SYNC messages to the firmware, which crashes about 10 seconds
later and the device stops responding.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Some drivers (sierra_net) need the status interrupt URB
active even when the device is closed, because they receive
custom indications from firmware. Add functions to refcount
the status interrupt URB submit/kill operation so that
sub-drivers and the generic driver don't fight over whether
the status interrupt URB is active or not.
A sub-driver can call usbnet_status_start() at any time, but
the URB is only submitted the first time the function is
called. Likewise, when the sub-driver is done with the URB,
it calls usbnet_status_stop() but the URB is only killed when
all users have stopped it. The URB is still killed and
re-submitted for suspend/resume, as before, with the same
refcount it had at suspend.
Acked-by: Oliver Neukum <oliver@neukum.org>
A rebranded Novatel E371 for AT&T's LTE bands. qmi_wwan should drive this
device, while cdc_ether should ignore it. Even though the USB descriptors
are plain CDC-ETHER that USB interface is a QMI interface.
Cc: <stable@vger.kernel.org>
Add new driver for supporting Realtek RTL8152 Based USB 2.0 Ethernet Adapters
Signed-off-by: Hayes Wang <hayeswang@realtek.com>
There is bug in the receive path of the asix driver at the time a
packet is received larger than MTU size and DF bit set:
BUG: unable to handle kernel paging request at 0000004000000001
IP: [<ffffffff8126f65b>] skb_release_head_state+0x2d/0xd2
Call Trace:
<IRQ>
[<ffffffff8126f86d>] ? skb_release_all+0x9/0x1e
[<ffffffff8126f8ad>] ? __kfree_skb+0x9/0x6f
[<ffffffffa00b4200>] ? asix_rx_fixup_internal+0xff/0x1ae [asix]
[<ffffffffa00fb3dc>] ? usbnet_bh+0x4f/0x226 [usbnet]
It is easily reproducable by setting an MTU of 512 e. g. and sending
something like
ping -s 1472 -c 1 -M do $SELF
from another box.
And this is because the rx->ax_skb is freed on error, but rx->ax_skb
is not reset, and the size is not reset to zero in this case.
And since the skb is added again to the usbnet->done skb queue it is
accessing already freed memory, resulting in the BUG when freeing a
2nd time. I therefore think the value 0x0000004000000001 show in the
trace is more or less random data.
Signed-off-by: Holger Eitzenberger <holger@eitzenberger.org>
Information from driver description files:
diag: VID_19D2&PID_0412&MI_00
nmea: VID_19D2&PID_0412&MI_01
at: VID_19D2&PID_0412&MI_02
modem: VID_19D2&PID_0412&MI_03
net: VID_19D2&PID_0412&MI_04
Signed-off-by: Teppo Kotilainen <qubit303@gmail.com>
We're only passing the two high bytes of an integer. It works for
little endian but not for big endian.
Pull networking updates from David Miller:
"Highlights (1721 non-merge commits, this has to be a record of some
sort):
1) Add 'random' mode to team driver, from Jiri Pirko and Eric
Dumazet.
2) Make it so that any driver that supports configuration of multiple
MAC addresses can provide the forwarding database add and del
calls by providing a default implementation and hooking that up if
the driver doesn't have an explicit set of handlers. From Vlad
Yasevich.
3) Support GSO segmentation over tunnels and other encapsulating
devices such as VXLAN, from Pravin B Shelar.
4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton.
5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita
Dukkipati.
6) In the PHY layer, allow supporting wake-on-lan in situations where
the PHY registers have to be written for it to be configured.
Use it to support wake-on-lan in mv643xx_eth.
From Michael Stapelberg.
7) Significantly improve firewire IPV6 support, from YOSHIFUJI
Hideaki.
8) Allow multiple packets to be sent in a single transmission using
network coding in batman-adv, from Martin Hundebøll.
9) Add support for T5 cxgb4 chips, from Santosh Rastapur.
10) Generalize the VXLAN forwarding tables so that there is more
flexibility in configurating various aspects of the endpoints.
From David Stevens.
11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver,
from Dmitry Kravkov.
12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo
Neira Ayuso.
13) Start adding networking selftests.
14) In situations of overload on the same AF_PACKET fanout socket, or
per-cpu packet receive queue, minimize drop by distributing the
load to other cpus/fanouts. From Willem de Bruijn and Eric
Dumazet.
15) Add support for new payload offset BPF instruction, from Daniel
Borkmann.
16) Convert several drivers over to mdoule_platform_driver(), from
Sachin Kamat.
17) Provide a minimal BPF JIT image disassembler userspace tool, from
Daniel Borkmann.
18) Rewrite F-RTO implementation in TCP to match the final
specification of it in RFC4138 and RFC5682. From Yuchung Cheng.
19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear
you like netlink, so I implemented netlink dumping of netlink
sockets.") From Andrey Vagin.
20) Remove ugly passing of rtnetlink attributes into rtnl_doit
functions, from Thomas Graf.
21) Allow userspace to be able to see if a configuration change occurs
in the middle of an address or device list dump, from Nicolas
Dichtel.
22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes
Frederic Sowa.
23) Increase accuracy of packet length used by packet scheduler, from
Jason Wang.
24) Beginning set of changes to make ipv4/ipv6 fragment handling more
scalable and less susceptible to overload and locking contention,
from Jesper Dangaard Brouer.
25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*()
instead. From Hong Zhiguo.
26) Optimize route usage in IPVS by avoiding reference counting where
possible, from Julian Anastasov.
27) Convert IPVS schedulers to RCU, also from Julian Anastasov.
28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger
Eitzenberger.
29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG,
nfnetlink_log, and nfnetlink_queue. From Gao feng.
30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa.
31) Support several new r8169 chips, from Hayes Wang.
32) Support tokenized interface identifiers in ipv6, from Daniel
Borkmann.
33) Use usbnet_link_change() helper in USB net driver, from Ming Lei.
34) Add 802.1ad vlan offload support, from Patrick McHardy.
35) Support mmap() based netlink communication, also from Patrick
McHardy.
36) Support HW timestamping in mlx4 driver, from Amir Vadai.
37) Rationalize AF_PACKET packet timestamping when transmitting, from
Willem de Bruijn and Daniel Borkmann.
38) Bring parity to what's provided by /proc/net/packet socket dumping
and the info provided by netlink socket dumping of AF_PACKET
sockets. From Nicolas Dichtel.
39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin
Poirier"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
filter: fix va_list build error
af_unix: fix a fatal race with bit fields
bnx2x: Prevent memory leak when cnic is absent
bnx2x: correct reading of speed capabilities
net: sctp: attribute printl with __printf for gcc fmt checks
netlink: kconfig: move mmap i/o into netlink kconfig
netpoll: convert mutex into a semaphore
netlink: Fix skb ref counting.
net_sched: act_ipt forward compat with xtables
mlx4_en: fix a build error on 32bit arches
Revert "bnx2x: allow nvram test to run when device is down"
bridge: avoid OOPS if root port not found
drivers: net: cpsw: fix kernel warn on cpsw irq enable
sh_eth: use random MAC address if no valid one supplied
3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA)
tg3: fix to append hardware time stamping flags
unix/stream: fix peeking with an offset larger than data in queue
unix/dgram: fix peeking with an offset larger than data in queue
unix/dgram: peek beyond 0-sized skbs
openvswitch: Remove unneeded ovs_netdev_get_ifindex()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB patches from Greg Kroah-Hartman:
"Here's the big USB pull request for 3.10-rc1.
Lots of USB patches here, the majority being USB gadget changes and
USB-serial driver cleanups, the rest being ARM build fixes / cleanups,
and individual driver updates. We also finally got some chipidea
fixes, which have been delayed for a number of kernel releases, as the
maintainer has now reappeared.
All of these have been in linux-next for a while"
* tag 'usb-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (568 commits)
USB: ehci-msm: USB_MSM_OTG needs USB_PHY
USB: OHCI: avoid conflicting platform drivers
USB: OMAP: ISP1301 needs USB_PHY
USB: lpc32xx: ISP1301 needs USB_PHY
USB: ftdi_sio: enable two UART ports on ST Microconnect Lite
usb: phy: tegra: don't call into tegra-ehci directly
usb: phy: phy core cannot yet be a module
USB: Fix initconst in ehci driver
usb-storage: CY7C68300A chips do not support Cypress ATACB
USB: serial: option: Added support Olivetti Olicard 145
USB: ftdi_sio: correct ST Micro Connect Lite PIDs
ARM: mxs_defconfig: add CONFIG_USB_PHY
ARM: imx_v6_v7_defconfig: add CONFIG_USB_PHY
usb: phy: remove exported function from __init section
usb: gadget: zero: put function instances on unbind
usb: gadget: f_sourcesink.c: correct a copy-paste misnomer
usb: gadget: cdc2: fix error return code in cdc_do_config()
usb: gadget: multi: fix error return code in rndis_do_config()
usb: gadget: f_obex: fix error return code in obex_bind()
USB: storage: convert to use module_usb_driver()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial driver update from Greg Kroah-Hartman:
"Here's the big tty/serial driver merge request for 3.10-rc1
Once again, Jiri has a number of TTY driver fixes and cleanups, and
Peter Hurley came through with a bunch of ldisc fixes that resolve a
number of reported issues. There are some other serial driver
cleanups as well.
All of these have been in the linux-next tree for a while"
* tag 'tty-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (117 commits)
tty/serial/sirf: fix MODULE_DEVICE_TABLE
serial: mxs: drop superfluous {get|put}_device
serial: mxs: fix buffer overflow
ARM: PL011: add support for extended FIFO-size of PL011-r1p5
serial_core.c: add put_device() after device_find_child()
tty: Fix unsafe bit ops in tty_throttle_safe/unthrottle_safe
serial: sccnxp: Replace pdata.init/exit with regulator API
serial: sccnxp: Do not override device name
TTY: pty, fix compilation warning
TTY: rocket, fix compilation warning
TTY: ircomm: fix DTR being raised on hang up
TTY: synclinkmp: fix DTR being raised on hang up
TTY: synclink_gt: fix DTR being raised on hang up
TTY: synclink: fix DTR being raised on hang up
serial: 8250_dw: Fix the stub for dw8250_probe_acpi()
serial: 8250_dw: Convert to devm_ioremap()
serial: 8250_dw: Set port capabilities based on CPR register
serial: 8250_dw: Let ACPI code extract the DMA client info
serial: 8250_dw: Support clk framework also with ACPI
serial: 8250_dw: Enable runtime PM
Pegasus driver used single callback for sync and async control URBs.
Special flags were employed to distinguish between both, but due to flawed
logic it didn't always work. As a result of this change
[get|set]_registers() are now much simpler. Async write is also leaner
and does not use single, statically allocated memory for usb_ctrlrequest,
which is another potential race when asynchronously submitting URBs.
Duplicated code in routines reading and writing MII registers is now
packed in __mii_op().
The socket buffer pool for the receive path is now gone. It's existence
didn't make much difference (performance-wise) and the code is better off
without the spinlocks protecting it.
drivers/net/ethernet/emulex/benet/be_main.c
drivers/net/ethernet/intel/igb/igb_main.c
drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c
include/net/scm.h
net/batman-adv/routing.c
net/ipv4/tcp_input.c
The e{uid,gid} --> {uid,gid} credentials fix conflicted with the
cleanup in net-next to now pass cred structs around.
The be2net driver had a bug fix in 'net' that overlapped with the VLAN
interface changes by Patrick McHardy in net-next.
An IGB conflict existed because in 'net' the build_skb() support was
reverted, and in 'net-next' there was a comment style fix within that
code.
Several batman-adv conflicts were resolved by making sure that all
calls to batadv_is_my_mac() are changed to have a new bat_priv first
argument.
Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO
rewrite in 'net-next', mostly overlapping changes.
Thanks to Stephen Rothwell and Antonio Quartulli for help with several
of these merge resolutions.
We normally trust and use the CDC functional descriptors provided by a
number of devices. But some of these will erroneously list the address
reserved for the device end of the link. Attempting to use this on
both the device and host side will naturally not work.
Work around this bug by ignoring the functional descriptor and assign a
random address instead in this case.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Received packets are sometimes addressed to 00:a0:c6:00:00:00
instead of the address the device firmware should have learned
from the host:
321.224126 77.16.85.204 -> 148.122.171.134 ICMP 98 Echo (ping) request id=0x4025, seq=64/16384, ttl=64
0000 82 c0 82 c9 f1 67 82 c0 82 c9 f1 67 08 00 45 00 .....g.....g..E.
0010 00 54 00 00 40 00 40 01 57 cc 4d 10 55 cc 94 7a .T..@.@.W.M.U..z
0020 ab 86 08 00 62 fc 40 25 00 40 b2 bc 6e 51 00 00 ....b.@%.@..nQ..
0030 00 00 6b bd 09 00 00 00 00 00 10 11 12 13 14 15 ..k.............
0040 16 17 18 19 1a 1b 1c 1d 1e 1f 20 21 22 23 24 25 .......... !"#$%
0050 26 27 28 29 2a 2b 2c 2d 2e 2f 30 31 32 33 34 35 &'()*+,-./012345
0060 36 37 67
321.240607 148.122.171.134 -> 77.16.85.204 ICMP 98 Echo (ping) reply id=0x4025, seq=64/16384, ttl=55
0000 00 a0 c6 00 00 00 02 50 f3 00 00 00 08 00 45 00 .......P......E.
0010 00 54 00 56 00 00 37 01 a0 76 94 7a ab 86 4d 10 .T.V..7..v.z..M.
0020 55 cc 00 00 6a fc 40 25 00 40 b2 bc 6e 51 00 00 U...j.@%.@..nQ..
0060 36 37 67
The bogus address is always the same, and matches the address
suggested by many devices as a default address. It is likely a
hardcoded firmware default.
The circumstances where this bug has been observed indicates that
the trigger is related to timing or some other factor the host
cannot control. Repeating the exact same configuration sequence
that caused it to trigger once, will not necessarily cause it to
trigger the next time. Reproducing the bug is therefore difficult.
This opens up a possibility that the bug is more common than we can
confirm, because affected devices often will work properly again
after a reset. A procedure most users are likely to try out before
reporting a bug.
Unconditionally rewriting the destination address if the first digit
of the received packet is 0, is considered an acceptable compromise
since we already have to inspect this digit. The simplification will
cause unnecessary rewrites if the real address starts with 0, but this
is still better than adding additional tests for this particular case.
A number of LTE devices from different vendors all suffer from the
same firmware bug: Most of the packets received from the device while
it is attached to a LTE network will not have an ethernet header. The
devices work as expected when attached to 2G or 3G networks, sending
an ethernet header with all packets.
This driver is not aware of which network the modem attached to, and
even if it were there are still some packet types which are always
received with the header intact.
All devices supported by this driver have severely limited
networking capabilities:
- can only transmit IPv4, IPv6 and possibly ARP
- can only support a single host hardware address at any time
- will only do point-to-point communcation with the host
Because of this, we are able to reliably identify any bogus raw IP
packets by simply looking at the 4 IP version bits. All we need to
do is to avoid 4 or 6 in the first digit of the mac address. This
workaround ensures this, and fix up the received packets as necessary.
Given the distribution of the bug, it is believed that the source is
the chipset vendor. The devices which are verified to be affected are:
Huawei E392u-12 (Qualcomm MDM9200)
Pantech UML290 (Qualcomm MDM9600)
Novatel USB551L (Qualcomm MDM9600)
Novatel E362 (Qualcomm MDM9600)
It is believed that the bug depend on firmware revision, which means
that possibly all devices based on the above mentioned chipset may be
affected if we consider all available firmware revisions.
The information about affected devices and versions is likely
incomplete. As the additional overhead for packets not needing this
fixup is very small, it is considered acceptable to apply the
workaround to all devices handled by this driver.
Reported-by: Dan Williams <dcbw@redhat.com>
Add a protocol argument to the VLAN packet tagging functions. In case of HW
tagging, we need that protocol available in the ndo_start_xmit functions,
so it is stored in a new field in the skb. The new field fits into a hole
(on 64 bit) and doesn't increase the sks's size.
Rename the hardware VLAN acceleration features to include "CTAG" to indicate
that they only support CTAGs. Follow up patches will introduce 802.1ad
server provider tagging (STAGs) and require the distinction for hardware not
supporting acclerating both.
Remove warning introduced by commit 418fc57 ("usbnet: cdc-ether: apply
usbnet_link_change"):
CHECK .../drivers/net/usb/cdc_ether.c
.../drivers/net/usb/cdc_ether.c:409:46: warning: incorrect type in argument 2 (different base types)
.../drivers/net/usb/cdc_ether.c:409:46: expected bool [unsigned] [usertype] <noident>
.../drivers/net/usb/cdc_ether.c:409:46: got restricted __le16 [usertype] wValue
Cc: Ming Lei <ming.lei@canonical.com>
Acked-by: Ming Lei <ming.lei@canonical.com>
The intention was to test against the constant, not the size of
the constant.
We want the fixes here.
The link change is detected via the interrupt pipe, and bulk
pipes are responsible for transfering packets, so it is reasonable
to stop bulk transfer after link is reported as off.
Two adavantages may be obtained with stopping bulk transfer
after link becomes off:
- USB bus bandwidth is saved(USB bus is shared bus except for
USB3.0), for example, lots of 'IN' token packets and 'NYET'
handshake packets is transfered on 2.0 bus.
- probabaly power might be saved for usb host controller since
cancelling bulk transfer may disable the asynchronous schedule of
host controller.
With this patch, when link becomes off, about ~10% performance
boost can be found on bulk transfer of anther usb device which
is attached to same bus with the usbnet device, see below
test on next-20130410:
- read from usb mass storage(Sandisk Extreme USB 3.0) on pandaboard
with below command after unplugging ethernet cable:
dd if=/dev/sda iflag=direct of=/dev/null bs=1M count=800
- without the patch
1, 838860800 bytes (839 MB) copied, 36.2216 s, 23.2 MB/s
2, 838860800 bytes (839 MB) copied, 35.8368 s, 23.4 MB/s
3, 838860800 bytes (839 MB) copied, 35.823 s, 23.4 MB/s
4, 838860800 bytes (839 MB) copied, 35.937 s, 23.3 MB/s
5, 838860800 bytes (839 MB) copied, 35.7365 s, 23.5 MB/s
average: 23.6MB/s
- with the patch
1, 838860800 bytes (839 MB) copied, 32.3817 s, 25.9 MB/s
2, 838860800 bytes (839 MB) copied, 31.7389 s, 26.4 MB/s
3, 838860800 bytes (839 MB) copied, 32.438 s, 25.9 MB/s
4, 838860800 bytes (839 MB) copied, 32.5492 s, 25.8 MB/s
5, 838860800 bytes (839 MB) copied, 31.6178 s, 26.5 MB/s
average: 26.1MB/s
Signed-off-by: Ming Lei <ming.lei@canonical.com>
Use usbnet_link_change to handle link change centrally.
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
Use the introduced usbnet_link_change to handle link change.
This patch uses the introduced usbnet_link_change() to handle
link change.
The driver doesn't implement link_reset() callback, so it needn't
to send link reset event.
This patch introduces the API of usbnet_link_change, so that
usbnet can handle link change centrally, which may help to
implement killing traffic URBs for saving USB bus bandwidth
and host controller power.
Receiving unhandled notifications is most certainly not an error
and should not be logged as one. Knowing that the device sends
notifications we don't handle is useful for developers, but there
is very little a user can do about this. The message is therefore
just annoying noise to most users with devices sending unhandled
notifications like e.g. USB_CDC_NOTIFY_RESPONSE_AVAILABLE
Cc: Alexey Orishko <alexey.orishko@stericsson.com>
We want the fixes here as well.
We need the fixes here as well.
net/mac80211/sta_info.c
net/wireless/core.h
Two minor conflicts in wireless. Overlapping additions of extern
declarations in net/wireless/core.h and a bug fix overlapping with
the addition of a boolean parameter to __ieee80211_key_free().
return -ENOMEM instead if kzalloc of cdc_ncm_ctx structure is failed.
and also remove the comparision of ctx structure with NULL and make
it as !ctx.
Signed-off-by: Devendra Naga <devendra.aaru@gmail.com>
This patch enables RX of jumbo frames for LAN7500.
Previously the driver would transmit jumbo frames succesfully but
would drop received jumbo frames (incrementing the interface errors
count).
With this patch applied the device can succesfully receive jumbo
frames up to MTU 9000 (9014 bytes on the wire including ethernet
header).
Signed-off-by: Steve Glendinning <steve.glendinning@shawell.net>
If suspend callback fails in system sleep context, usb core will
ignore the failure and let system sleep go ahead further, so
this patch doesn't recover device under this situation.
Also add comments on this case.
Cc: Steve Glendinning <steve.glendinning@shawell.net>
Also add comments on the case.
this patch comments on the case and requires that both
usbnet_suspend() and subdriver->suspend() MUST return 0 in
system sleep context.
