path: root/drivers/net/tun.c
2008-04-16[TUN]: Allow to register tun devices in namespace.Pavel Emelyanov
This is basically means that a net is set for a new device, but actually also involves two more steps: 1. mark the tun device as "local", i.e. do not allow for it to move across namespaces. This is done so, since tun device is most often associated to some file (and thus to some process) and moving the device alone is not valid while keeping the file and the process outside. The need in ability to move a detached persistent device is to be investigated later. 2. get the tun device's net when tun becomes attached and put one when it becomes detached. This is needed to handle the case when a task owning the tun dies, but a files lives for some more time - in this case we must not allow for net to be freed, since its exit hook will spoil that file's private data by unregistering the tun from under tun_chr_close. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[TUN]: Make the tun_dev_list per-net.Pavel Emelyanov
Remove the static tun_dev_list and replace its occurrences in driver with per-net one. It is used in two places - in tun_set_iff and tun_cleanup. In the first case it's legal to use current net_ns. In the cleanup call - move the loop, that unregisters all devices in net exit hook. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[TUN]: Introduce the tun_net structure and init/exit net ops.Pavel Emelyanov
This is the first step in making tuntap devices work in net namespaces. The structure mentioned is pointed by generic net pointer with tun_net_id id, and tun driver fills one on its load. It will contain only the tun devices list. So declare this structure and introduce net init and exit hooks. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12net: check for underlength tap writesRusty Russell
If the user gives a packet under 14 bytes, we'll end up reading off the end of the skb (not oopsing, just reading off the end). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Max Krasnyanskiy <maxk@qualcomm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12net: make struct tun_struct private to tun.cRusty Russell
There's no reason for this to be in the header, and it just hurts recompile time. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Max Krasnyanskiy <maxk@qualcomm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-29[TUN]: Fix RTNL-locking in tun/tap driverKim B. Heino
Current tun/tap driver sets also net device's hw address when asked to change character device's hw address. This is a good idea, but it misses RTLN-locking, resulting following error message in 2.6.25-rc3's inetdev_event() function: RTNL: assertion failed at net/ipv4/devinet.c (1050) Attached patch fixes this problem. Signed-off-by: Kim B. Heino <Kim.Heino@bluegiga.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05tun: impossible to deassert IFF_ONE_QUEUE or IFF_NO_PINathaniel Filardo
From: "Nathaniel Filardo" <nwfilardo@gmail.com> Taken from http://bugzilla.kernel.org/show_bug.cgi?id=9806 The TUN/TAP driver only permits one-way transitions of IFF_NO_PI or IFF_ONE_QUEUE during the lifetime of a tap/tun interface. Note that tun_set_iff contains 541 if (ifr->ifr_flags & IFF_NO_PI) 542 tun->flags |= TUN_NO_PI; 543 544 if (ifr->ifr_flags & IFF_ONE_QUEUE) 545 tun->flags |= TUN_ONE_QUEUE; This is easily fixed by adding else branches which clear these bits. Steps to reproduce: This is easily reproduced by setting an interface persistant using tunctl then attempting to open it as IFF_TAP or IFF_TUN, without asserting the IFF_NO_PI flag. The ioctl() will succeed and the ifr.flags word is not modified, but the interface remains in IFF_NO_PI mode (as it was set by tunctl). Acked-by: Maxim Krasnyansky <maxk@qualcomm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28annotate tunAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28[TUN]: Use iov_length()Akinobu Mita
Use iov_length() instead of tun's homemade iov_total(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-26[TUNTAP]: Fix wrong debug message.Toyo Abe
This is a trivial fix of debug message. When a persist flag is set, the message should say "enabled". Signed-off-by: Toyo Abe <tabe@miraclelinux.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[TAP]: Configurable interface MTU.Ed Swierk
2007-10-10[NET] drivers/net: statistics cleanup #1 -- save memory and shrink codeJeff Garzik
We now have struct net_device_stats embedded in struct net_device, and the default ->get_stats() hook does the obvious thing for us. Run through drivers/net/* and remove the driver-local storage of statistics, and driver-local ->get_stats() hook where applicable. This was just the low-hanging fruit in drivers/net; plenty more drivers remain to be updated. [ Resolved conflicts with napi_struct changes and fix sunqe build regression... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Allow group ownership of TUN/TAP devices.Guido Guenther
Introduce a new syscall TUNSETGROUP for group ownership setting of tap devices. The user now is allowed to send packages if either his euid or his egid matches the one specified via tunctl (via -u or -g respecitvely). If both, gid and uid, are set via tunctl, both have to match. Signed-off-by: Guido Guenther <agx@sigxcpu.org> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[NET] tun/tap: fixed hw address handlingBrian Braunstein
Fixed tun/tap driver's handling of hw addresses. The hw address is stored in both the net_device.dev_addr and tun.dev_addr fields. These fields were not kept synchronized, and in fact weren't even initialized to the same value. Now during both init and when performing SIOCSIFHWADDR on the tun device these values are both updated. However, if SIOCSIFHWADDR is performed on the net device directly (for instance, setting the hw address using ifconfig), the tun device does not get updated. Perhaps the tun.dev_addr field should be removed completely at some point, as it is redundant and net_device.dev_addr can be used anywhere it is used. Signed-off-by: Brian Braunstein <linuxkernel@bristyle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[SK_BUFF]: Introduce skb_reset_mac_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 5Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-02[PATCH] file: modify struct fown_struct to use a struct pidEric W. Biederman
File handles can be requested to send sigio and sigurg to processes. By tracking the destination processes using struct pid instead of pid_t we make the interface safe from all potential pid wrap around problems. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove readv/writev methods and use aio_read/aio_write insteadBadari Pulavarty
This patch removes readv() and writev() methods and replaces them with aio_read()/aio_write() methods. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-06-26[PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer neededGreg Kroah-Hartman
Also fixes all drivers that set this field. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-23[NET]: Require CAP_NET_ADMIN to create tuntap devices.David Woodhouse
The tuntap driver allows an admin to create persistent devices and assign ownership of them to individual users. Unfortunately, relaxing the permissions on the /dev/net/tun device node so that they can actually use those devices will _also_ allow those users to create arbitrary new devices of their own. This patch corrects that, and adjusts the recommended permissions for the device node accordingly. Signed-off-By: David Woodhouse <dwmw2@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-11[TUN]: Fix leak in tun_get_user()Dave Jones
We're leaking an skb in a failure path in this function. Coverity #632 Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-01[TUNTAP]: Allow setting the linktype of the tap device from userspaceMike Kershaw
Currently tun/tap only supports the EN10MB ARP type. For use with wireless and other networking types it should be possible to set the ARP type via an ioctl. Patch v2: Included check that the tap interface is down before changing the link type out from underneath it Signed-off-by: Mike Kershaw <dragorn@kismetwireless.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-08[NET]: Transform skb_queue_len() binary tests into skb_queue_empty()David S. Miller
This is part of the grand scheme to eliminate the qlen member of skb_queue_head, and subsequently remove the 'list' member of sk_buff. Most users of skb_queue_len() want to know if the queue is empty or not, and that's trivially done with skb_queue_empty() which doesn't use the skb_queue_head->qlen member and instead uses the queue list emptyness as the test. Signed-off-by: David S. Miller <davem@davemloft.net>
