path: root/drivers/net/tulip/21142.c
2010-01-31tulip/21142.c: Use dev_<level> and pr_<level>Joe Perches
Convert printks to dev_<level> where a dev is available Convert printks to pr_<level> where not Coalesce format strings Change print formats with %d.dx to %0dx Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-29tulip: fix 21142 with 10Mbps without negotiationPhilippe De Muyter
with current kernels, tulip 21142 ethernet controllers fail to connect to a 10Mbps only (i.e. without negotiation-partner) network. It used to work in 2.4 kernels. Fix that. Tested on a 21142 Rev 0x11. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-24drivers/net/tulip: update first comment in tulip filesGrant Grundler
Three basic changes to the comments at the top of each file: 1) remove stale "Maintained by" line...I prefer people look in MAINTAINERS. 2) Drop reference to stale sf.net/tulip website (I didn't see anything of value there) 3) Point people at bugzilla.kernel.org to submit bugs...will always get tracked regardless of who the maintainer is. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Acked-by-stale-maintainer: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-09-11[PATCH] Defer tulip_select_media() to process contextFrancois Romieu
Move tulip_select_media() processing to a workqueue, instead of delaying in interrupt context, edited by Kyle McMartin to use kevent thread, instead of creating its own workqueue. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Valerie Henson <val_henson@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-11[PATCH] Change tulip maintainerValerie Henson
Signed-off-by: Valerie Henson <val_henson@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> MAINTAINERS | 4 ++-- drivers/net/tulip/21142.c | 2 +- drivers/net/tulip/eeprom.c | 2 +- drivers/net/tulip/interrupt.c | 2 +- drivers/net/tulip/media.c | 2 +- drivers/net/tulip/pnic.c | 2 +- drivers/net/tulip/pnic2.c | 2 +- drivers/net/tulip/timer.c | 2 +- drivers/net/tulip/tulip_core.c | 2 +- 9 files changed, 10 insertions(+), 10 deletions(-)
2005-10-03[PATCH] tulip DC21143 rev 48 10Mbit HDX fixPhilippe De Muyter
The patch below is necessary to allow my Digital DS21143 Tulip rev 48 ethernet interface to work in a 10Mbit Half Duplex network. Without it, the driver keeps retrying other modes in an endless loop. It seems like someone already had the same problem with a rev 65 board :) Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
