path: root/drivers/net/tlan.c
2006-02-24[PATCH] drivers/net/tlan.c: #ifdef CONFIG_PCI the PCI specific codeAdrian Bunk
drivers/net/tlan.c compiles with CONFIG_PCI=n only with a warning and due to the dead code elimination of gcc. Additionally, this fixes the only compile error I found with CONFIG_PCI=n and the gcc -Werror-implicit-function-declaration flag on i386. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-01-03s/retreiv/retriev/gMatt Mackall
As everyone knows, the rule is: "i before e.. um.. always." Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-06-26drivers/net/: Use the DMA_{64,32}BIT_MASK constantsDomen Puncer
Use the DMA_{64,32}BIT_MASK constants from dma-mapping.h when calling pci_set_dma_mask() or pci_set_consistent_dma_mask() This patch includes dma-mapping.h explicitly because it caused errors on some architectures otherwise. See http://marc.theaimsgroup.com/?t=108001993000001&r=1&w=2 for details Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org>
2005-06-04Automatic merge of /spare/repo/netdev-2.6 branch iff-running
2005-05-15[PATCH] fix PROMISC/bridging in TLAN driverJames Harper
This has been a problem for me for ages. When using bridging, the driver is switched into promiscuous mode before the link init is complete. The init complete routine then resets the promisc bit on the card so the kernel still thinks the card is in promiscuous mode but the card isn't. doh. I think this bug only shows up in bridging when the bridge is started at boot time (or something else that sets promisc at the same time the card was started). If promisc is enabled later it works. Here's a trivial (and hopefully correct) patch that works for me. It just calls the promisc/multicast setup routine after init. Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-05-15[PATCH] tlan: restore deleted module parameters.Stephen Hemminger
The module parameter values got lost in the conversion to the new module_param interface. This should fix it. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Index: tlan/drivers/net/tlan.c ===================================================================
2005-05-12[netdrvrs] Use netif_carrier_* instead of IFF_RUNNING
