path: root/drivers/net/tg3.h
2009-12-03tg3: Add some VPD preprocessor constantsMatt Carlson
This patch cleans up the VPD code by creating preprocessor definitions and using them in the place of hardcoded constants. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03tg3: Add 57765 asic revMatt Carlson
This patch adds the 57765 asic revision. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03tg3: Make TSS enable independent of MSI-X enableMatt Carlson
The 57765 asic rev has MSI-X capability, but does not support TSS. This patch changes the tx paths so that TSS is explicitly mentioned, rather than implied through the ENABLE_MSIX flag. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02tg3: remove use of skb_dma_map/unmapAlexander Duyck
Due to the fact that skb_dma_map/unmap do not work correctly when a HW IOMMU is enabled it has been recommended to go about removing the calls from the network device drivers. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> CC: Matt Carlson <mcarlson@broadcom.com> CC: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-15tg3: Fix DIDs, Enable 5717 supportMatt Carlson
This patch fixes the 5717 variant device ID enumerations and adds those DIDs to the PCI ID table. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-15tg3: Add rx prod ring consolidationMatt Carlson
This patch adds code to funnel each MSI-X vector's rx packet buffers into a single set of producer rings which will then be submitted to the hardware. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-15tg3: Create aliases for rx producer mailbox regsMatt Carlson
The rx producer mailbox registers are used in several spots in the code. The addition of TG3_64BIT_REG_LOW makes register references uncomfortably long. This patch creates an alias for the standard and jumbo ring producer index registers to make the code cleaner. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-15tg3: Lay proucer ring handling groundworkMatt Carlson
The patch increases the number of producer rings available and implements the constructor and destructor code that deals with them. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-15tg3: rename rx_[std|jmb]_ptrMatt Carlson
A later patch is going to add consumer indicies for the producer rings. To keep things readable, this patch renames rx_[std|jmb]_ptr to rx_[std|jmb]_prod_idx. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-15tg3: Allow DMAs to cross cacheline boundariesMatt Carlson
By default, the 5717 (and future chips) break up PCIe DMA packets across cacheline boundaries. This isn't necessary on x86. This patch selectively loosens the restriction. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-15tg3: Use tg3_start_xmit_dma_bug for 5717 A0Matt Carlson
The A0 revision of the 5717 has problems with short packet fragments. It needs to use the tg3_start_xmit_dma_bug() routine. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-15tg3: Add new HW_TSO_3 flag for 5717Matt Carlson
The 5717 sets up TSO slightly differently in the transmit path. It looks like this method will be the new way of doing things. This patch defines a flag to indicate this. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-15tg3: Move TG3_FLG2_PROTECTED_NVRAM to tg3_flags3Matt Carlson
We need room for another TSO flag and it would be most efficient if it resided in tg3_flags2. This patch moves the TG3_FLG2_PROTECTED_NVRAM to tg3_flags3 to make room. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-15tg3: Add 5717 phy IDMatt Carlson
This patch adds the 5717 phy ID. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Add 50610M phy ID for 5785Matt Carlson
This patch adds the 50610M phy ID for 5785. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Add AC131 power down supportMatt Carlson
The AC131 does not respect the power down bit (bit 11) of the MII Control Register (reg 0x0). Instead, software is required to put the phy into standby power down mode through the shadow register set. This patch implements support for the AC131 standby power down mode. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Improve 5785 PCIe performanceMatt Carlson
This patch improves 5785 performance by allowing the write DMA engine to request larger DMA burst sizes than it otherwise would. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Prevent a PCIe tx glitchMatt Carlson
This patch prevents a PCIe tx glitch by allowing the transmitter to go to a low power state. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Convert PHY_ADDR => TG3_PHY_MII_ADDRMatt Carlson
This patch renames the PHY_ADDR preprocessor definition. The following patch will identify a new member on the MDIO bus, so we want this preprocessor definition to be a little more descriptive. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Fix disappearing 57780 devicesMatt Carlson
Under certain power saving conditions, 57780 asic rev devices might disappear from the system. The fix is to disallow the PCIe PLL from powering down. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Fix 5906 transmit hangsMatt Carlson
The 5906 has trouble with fragments that are less than 8 bytes in size. This patch works around the problem by pivoting the 5906's transmit routine to tg3_start_xmit_dma_bug() and introducing a new SHORT_DMA_BUG flag that enables code to detect and react to the problematic condition. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Assign flags to fixes in start_xmit_dma_bugMatt Carlson
This patch adds a flag for each bug workaround in tg3_start_xmit_dma_bug(). This is prep work for the following patch. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07tg3: Fix phylib locking strategyMatt Carlson
Felix Radensky noted that chip resets were generating stack trace dumps. This is because the driver is attempting to acquire the mdio bus mutex while holding the tp->lock spinlock. The fix is to change the code such that every phy access takes the tp->lock spinlock instead. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-01tg3: Remove prev_vlan_tag from struct tx_ring_infoEric Dumazet
prev_vlan_tag field is not used. Patch saves 512*8 bytes per tx queue ring on 64bit arches. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Matthew Carlson <mcarlson@broadcom.com>
2009-09-02tg3: Add MDIO bus address assignmentsMatt Carlson
The 5717 is a dual port chip that has a shared MDIO bus design. While it is impossible for one function to interface with the wrong phy, that function still needs to know which MDIO bus address to use when interfacing with its own phy. This patch adds code to determine which MDIO bus address to use. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02tg3: Add 5717 NVRAM detection routinesMatt Carlson
This patch adds NVRAM detection routines for the 5717. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02tg3: Add 5717 asic revMatt Carlson
This patch adds the 5717 asic rev. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02tg3: Assign rx ret producer indexes by vectorMatt Carlson
When RSS is enabled, the status block format changes slightly. The "rx_jumbo_consumer", "reserved", and "rx_mini_consumer" members get mapped to the other three rx return ring producer indexes. This patch introduces a new per-interrupt member which identifies which location in the status block a particular vector should look for return ring updates. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02tg3: Add RSS supportMatt Carlson
This patch adds code needed to enable RSS. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02tg3: Add coalesce parameters for msix vectorsMatt Carlson
This patch adds code to tune the coalescing parameters for the other msix vectors. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02tg3: Add TSS supportMatt Carlson
This patch exposes the additional transmit rings to the kernel and makes the necessary modifications to transmit, open, and close paths. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02tg3: Add tx and rx ring resource trackingMatt Carlson
This patch adds code to assign status block, tx producer ring and rx return ring resources needed for the other interrupt vectors. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02tg3: Add MSI-X supportMatt Carlson
This patch adds MSI-X support. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02tg3: Add support code around kernel interrupt APIMatt Carlson
This patch adds code to support multiple interrupt vectors around the kernel's interrupt API. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02tg3: Add per-int coalesce now memberMatt Carlson
Each interrupt vector has its own bit in the host coalescing register to force that vector's status block to be updated and generate an interrupt. This patch adds a member to the per-interrupt structure that records which bit belongs to that vector. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-29tg3: Move per-int tx members to a per-int structMatt Carlson
This patch moves the tx_prod, tx_cons, tx_pending, tx_ring, and tx_buffers transmit ring device members to a per-interrupt structure. It also adds a new transmit producer mailbox member (prodmbox) and converts the code to use it rather than a preprocessor constant. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-29tg3: Move per-int rx members to per-int structMatt Carlson
This patch moves the rx_rcb, rx_rcb_mapping, and rx_rcb_ptr return ring device members to a per-interrupt structure. It also adds a new return ring consumer mailbox register member (consmbox) and converts the code to use it rather than a preprocessor constant. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-29tg3: Move general int members to a per-int structMatt Carlson
This patch moves the last_tag, last_tag_irq, and hw_status device members to a per-interrupt structure. It also adds a new interrupt mailbox member (int_mbox) and converts the code to use it rather than a direct preprocessor constant. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-29tg3: Move napi to per-int structMatt Carlson
This patch creates a per-interrupt data structure, moves the napi member over, and creates a tg3 pointer back to the device structure. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-29tg3: Use ext rx bdsMatt Carlson
The 5717 only uses extended buffer descriptors for the jumbo producer ring. Extended buffer descriptors are available on all devices that support a separate jumbo producer ring so make the change universal. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-29tg3: Create a new prodring_set structureMatt Carlson
This patch migrates most of the rx producer ring variables to a new tg3_rx_prodring_set structure and modifies the code accordingly. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-29tg3: Clarify rx buffer relationshipsMatt Carlson
This patch attempts to document the various rx buffer sizes used by the driver and how they relate to each other. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-29tg3: Move the JUMBO_CAPABLE and SUPPORT_MSI flagsMatt Carlson
This patch moves where the jumbo capable and msi support flags are located. This is prep work for the addition of msix support flags. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-29tg3: Add new 5785 10/100 only device IDMatt Carlson
This patch adds a new device ID for those 5785 devices that will only use 10/100 phys. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-26tg3: Convert code to use PHY_IS_FETMatt Carlson
This patch converts the code to use the PHY_IS_FET flag rather than the ASIC revision to decide whether or not to use FET paths. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-26tg3: Create MII_TG3_FET namespaceMatt Carlson
Broadcom's phys come in two distinctly different register layouts. For the lack of an official term to distinguish between the two formats, we can loosely categorize them by their fast ethernet or gigabit ethernet transceiver description. This patch creates the (driver-internal) Fast Ethernet Transceiver (FET) namespace and converts the 5906 EPHY definitions over. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-26tg3: Tune 5785 clock switchingMatt Carlson
This patch tunes the timeouts the CPMU uses to decide when to switch from the clocks output by the PHY to internal clock sources. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-26tg3: Add 57788, remove 57720Matt Carlson
This patch adds support for the 57788 and removes support for the 57720 which was never released. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-26tg3: Prevent tx BD corruptionMatt Carlson
This patch prevents a tx BD corruption bug by preventing the device from powering down the PLL from L1 if the link speed is 10Mbps or 100Mbps. The same bits are also used to prevent a system hang during chip reset resulting from a complicated set of events that ultimately leads to PCIe block register corruption. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-26tg3: Fix 57780 asic rev PCIe link receiver errorsMatt Carlson
This patch fixes some PCIe link receiver errors by decreasing the internal electrical idle timeout. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
