path: root/drivers/net/smc911x.h
2010-02-15omap3: Replace ARCH_OMAP34XX with ARCH_OMAP3Tony Lindgren
Replace ARCH_OMAP34XX with ARCH_OMAP3 Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap2: Convert ARCH_OMAP24XX to ARCH_OMAP2Tony Lindgren
Convert ARCH_OMAP24XX to ARCH_OMAP2 Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-08-12net: smc911x: includecheck fix for smc911x.hJaswinder Singh Rajput
fix the following 'make includecheck' warning: drivers/net/smc911x.h: mach/dma.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-13Merge branch 'for-rmk' of git://git.pengutronix.de/git/imx/linux-2.6 into develRussell King
Conflicts: arch/arm/mach-at91/gpio.c
2009-03-09[ARM] pxa: remove unnecessary #include of pxa-regs.h and hardware.hEric Miao
pxa-regs.h and hardware.h are not intended for use directly in driver code, remove those unnecessary references. Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-03-02OMAP: enable smc911x support for LDP platformRussell King
The following patch enables SMC911x support to work on the OMAP LDP board. Although the SMC911x driver will eventually be obsoleted, the smsc911x patches are rather invasive for the -rc kernels. Rather than risk destablising smsc911x, this simpler patch is preferred to allow the network interface to work. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-02[ARM] pxa: explicit #include <mach/dma.h> in various driversEric Miao
Where 'pxa_dma_desc' and 'pxa_{request,free}_dma' are referenced. Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-10-22SMC911x: unbreak PXA buildsDmitry Baryshkov
Currently SMC911x driver is broken on ARM/PXA builds. Unbreak such configurations. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-12smc911x: Add support for LAN921{5,7,8} chips from SMSCGuennadi Liakhovetski
LAN92{5,7,8} chips from SMSC are register compatible with LAN911{5,6,7,8} controllers, and only add support for HP Auto-MDIX. LAN9218 doesn't have an external MII interface. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-13Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smc911x.c
2008-06-11smc911x: SuperH architecture supportMagnus Damm
Enable the smc911x driver for the SuperH architecture. While at it remove the unused SMC_USE_SH_DMA definition. Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-11smc911x: introduce platform data flagsMagnus Damm
This patch adds a new header file for platform data information together with code that adds run time bus width and irq flag support. Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-11smc911x: pass along private data and use iomemMagnus Damm
This patch contains changes needed for platform data support: - Move smc911x_local structure to header file - Pass along smc911x_local structure pointer to macros - Keep register base address in smc911x_local structure - Remove unused ioaddr variables [m.kozlowski@tuxland.pl: Parenthesis fix in drivers/net/smc911x.h] Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-11smc911x: fix 16-bit I/O operationsMagnus Damm
This patch fixes the following issues related to 16-bit support: - Remove unused 16-bit PXA DMA implementation. - Remove unused SMC_inw() and SMC_outw() functions. - Fix 16-bit SMC_outl to use writew() instead of writel(). Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-11smc911x: remove unused 8-bit I/O operationsMagnus Damm
Remove unused SMC_inb() and SMC_outb() functions. Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-12-14net: smc911x: shut up compiler warningsPaul Mundt
Trivial fix to shut up gcc. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-23smc911x: Fix undefined CONFIG_ symbol warningPeter Korsgaard
elif defined(CONFIG_*) should be used instead of elif CONFIG_* so GCC doesn't give warnings about undefined symbols when the config option is disabled. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10smc911x irq sense request and MPR2 board supportMarkus Brunner
Hi, this are the changes to the smc911x driver, which were necessary to get it running on the Magic Panel R2 (smsc9115). It is a SH3-DSP based board. The other patches are available on the linuxsh-dev mailinglist. http://marc.info/?l=linuxsh-dev&r=1&b=200708&w=2 It was necessary to set the irq sense to low level. Therefor the SMC_IRQ_SENSE define was added. How are the chances for inclusion in 2.6.24? Signed-off by: Markus Brunner <super.firetwister@gmail.com> Signed-off by: Mark Jonas <toertel@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-20[netdrvr smc911x] trim trailing whitespaceJeff Garzik
2006-04-20[PATCH] RE: [PATCH 1/1] net driver: Add support for SMSC LAN911x line of ↵Dustin McIntire
ethernet chips > > The patch was badly wordwrapped. Please fix and resend. > OK, I've fixed the wrapping and removed the CONFIG_ARM restriction. I've also did my best to modify the C style to conform to the comments. I noticed that the patch is getting ignored by majordomo due to its size >100K. Should it be broken up somehow to allow posting to the lists? Signed-off-by: Dustin McIntire <dustin@sensoria.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
