path: root/drivers/net/skfp/ess.c
2008-08-27drivers/net/skfp/ess.c: fix compile warningsTakashi Iwai
CC [M] drivers/net/skfp/ess.o drivers/net/skfp/ess.c: In function 'ess_send_response': drivers/net/skfp/ess.c:513: warning: cast from pointer to integer of different size drivers/net/skfp/ess.c: In function 'ess_send_alc_req': drivers/net/skfp/ess.c:609: warning: cast from pointer to integer of different size drivers/net/skfp/ess.c:639: warning: cast from pointer to integer of different size Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-03Spelling fixes: lenght->lengthPaulius Zaleckas
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2005-06-27[PATCH] drivers/net/skfp/: cleanupsAdrian Bunk
This patch contains the following cleanups: - make needlessly global code static - remove the completely unused smtparse.c - remove the following unused global functions: - drvfbi.c: init_dma - drvfbi.c: dis_dma - drvfbi.c: get_rom_byte - drvfbi.c: mac_drv_vpd_read - drvfbi.c: mac_drv_pci_fix - fplustm.c: mac_set_func_addr - fplustm.c: mac_del_multicast - hwmtm.c: mac_drv_rx_frag - pcmplc.c: pcm_set_lct_short - smt.c: smt_please_reconnect - smt.c: smt_change_t_neg - smtdef.c: smt_set_defaults Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
