path: root/drivers/net/sis900.h
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-20[PATCH] Add VLAN (802.1q) support to sis900 driverDaniele Venzano
The attached patch adds support for VLANs to the sis900 driver and bumps the version number. It is based on an old (2003) patch for the 2.4 series by Hamid Hashemi Golpayegani. It applies on top of 2.6.16(.5). I have one report that it works and behaves as intended. Please review and consider for inclusion. Signed-off-by: Daniele Venzano <venza@brownhat.org> -- Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-02-07[PATCH] sis900: remove cfgpmcsr I/O space register defineLennert Buytenhek
sis900 defines 'cfgpmcsr' as an I/O space register, but CFGPMCSR is in fact a config space register, and there is no register at offset 0x44 in I/O space, so delete the enum. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] Add Wake on LAN support to sis900 (2)Daniele Venzano
Sorry, but that day I had smoked somthing too heavy for me, the patch didn't apply. Here's a new one. The patch availble below adds support for Wake on LAN to the sis900 driver. Some register addresses were added to sis900.h and two new functions were implemented in sis900.c. WoL status is controlled by ethtool. Patch is against 2.6.13. Comments are welcome, but also consider for inclusion in the -mm series. Signed-off-by: Daniele Venzano <venza@brownhat.org> -- Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
