path: root/drivers/net/sfc/regs.h
2011-08-11sfc: Move the Solarflare driversJeff Kirsher
Moves the Solarflare drivers into drivers/net/ethernet/sfc/ and make the necessary Kconfig and Makefile changes. CC: Steve Hodgson <shodgson@solarflare.com> CC: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-02-28sfc: Update copyright datesBen Hutchings
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-15sfc: Add TX queues for high-priority trafficBen Hutchings
Implement the ndo_setup_tc() operation with 2 traffic classes. Current Solarstorm controllers do not implement TX queue priority, but they do allow queues to be 'paced' with an enforced delay between packets. Paced and unpaced queues are scheduled in round-robin within two separate hardware bins (paced queues with a large delay may be placed into a third bin temporarily, but we won't use that). If there are queues in both bins, the TX scheduler will alternate between them. If we make high-priority queues unpaced and best-effort queues paced, and high-priority queues are mostly empty, a single high-priority queue can then instantly take 50% of the packet rate regardless of how many of the best-effort queues have descriptors outstanding. We do not actually want an enforced delay between packets on best- effort queues, so we set the pace value to a reserved value that actually results in a delay of 0. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2010-09-21sfc: Add filter table managementBen Hutchings
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-29sfc: Remove duplicate hardware structure definitionsBen Hutchings
2009-10-24sfc: Update hardware definitions for SienaBen Hutchings
Siena is still based on the Falcon hardware architecture and will share many of these definitions, so replace falcon_hwdefs.h with regs.h. The new definitions have been generated according to a naming convention which incorporates the type and revision information. Update the code accordingly. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
