path: root/drivers/net/sfc/net_driver.h
2008-05-22sfc: Remove sub-minor component from driver versionBen Hutchings
This driver has diverged from the out-of-tree driver to which the version number originally applied. It should be identified primarily by kernel version. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22sfc: Change type of efx_nic::nic_data to struct falcon_nic_data *Ben Hutchings
Remove redundant casts and variable. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22sfc: Do not define inline macroBen Hutchings
2008-05-22sfc: Use DMA_BIT_MASK() instead of our own DMA mask macrosBen Hutchings
Also change type of efx_nic_type::max_dma_mask to u64, matching pci_dma_supported() parameter type. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22sfc: Use resource_size_t for PCI bus addressBen Hutchings
This should make the driver work on 32-bit systems with 64-bit PCI support. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22sfc: Replaced various macros with inline functionsBen Hutchings
2008-05-13[netdrvr] sfc: sfc: Add self-test supportBen Hutchings
Add a set of self-tests accessible thorugh ethtool. Add hardware loopback and TX disable control code to support them. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13[netdrvr] sfc: Remove kernel-doc comments for removed members of struct efx_nicBen Hutchings
2008-05-13[netdrvr] sfc: Add TSO supportBen Hutchings
The SFC4000 controller does not have hardware support for TSO, and the core GSO code incurs a high cost in allocating and freeing skbs. This TSO implementation uses lightweight packet header structures and is substantially faster. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29New driver "sfc" for Solarstorm SFC4000 controller.Ben Hutchings
The driver supports the 10Xpress PHY and XFP modules on our reference designs SFE4001 and SFE4002 and the SMC models SMC10GPCIe-XFP and SMC10GPCIe-10BT. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
