path: root/drivers/net/saa9730.c
2007-03-23SAA9730: Fix large pile of warningsRalf Baechle
The SAA9730 driver doesn't quite grok what the difference between an ioport and memory mapped I/O is. It just happened to work on the one Linux system the SAA9730 happens to spend it's misserable existence on. drivers/net/saa9730.c: In function 'evm_saa9730_enable_lan_int': drivers/net/saa9730.c:68: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:70: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:72: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'evm_saa9730_disable_lan_int': drivers/net/saa9730.c:78: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:80: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'evm_saa9730_clear_lan_int': drivers/net/saa9730.c:85: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'evm_saa9730_block_lan_int': drivers/net/saa9730.c:91: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'evm_saa9730_unblock_lan_int': drivers/net/saa9730.c:97: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'show_saa9730_regs': drivers/net/saa9730.c:150: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'lan_saa9730_allocate_buffers': drivers/net/saa9730.c:292: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:295: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:302: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:305: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:312: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'lan_saa9730_cam_load': drivers/net/saa9730.c:329: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:332: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'lan_saa9730_mii_init': drivers/net/saa9730.c:369: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:395: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:403: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:410: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:432: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'lan_saa9730_control_init': drivers/net/saa9730.c:470: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:474: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:478: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:484: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:487: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:490: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:493: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'lan_saa9730_stop': drivers/net/saa9730.c:505: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:508: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:510: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'lan_saa9730_dma_init': drivers/net/saa9730.c:536: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'lan_saa9730_start': drivers/net/saa9730.c:556: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:560: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:564: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:567: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'lan_saa9730_tx': drivers/net/saa9730.c:590: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'lan_saa9730_rx': drivers/net/saa9730.c:664: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:729: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'lan_saa9730_write': drivers/net/saa9730.c:848: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c: In function 'lan_saa9730_set_multicast': drivers/net/saa9730.c:943: warning: passing argument 2 of 'outl' makes integer from pointer without a cast drivers/net/saa9730.c:949: warning: passing argument 2 of 'outl' makes integer from pointer without a cast Fixed by using writel instead of outl. 42 warnings less. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-10-06drivers/net: eliminate irq handler impossible checks, needless castsJeff Garzik
- Eliminate check for irq handler 'dev_id==NULL' where the condition never occurs. - Eliminate needless casts to/from void* Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-11-11[PATCH] SAA9730: Driver overhaulRalf Baechle
o Try to work around some of the undocumented "features" of the SAA9730 o Use netdev_priv() instead of the previous broken mechanism to allocate the private data structure. o Try to make sure we don't leak resources on exit. o No more need to call SET_MODULE_OWNER in 2.6. o Use pci_free_consistent instead of homegrown architecture-specific allocation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> drivers/net/saa9730.c | 531 +++++++++++++++++++++++--------------------------- 1 files changed, 249 insertions(+), 282 deletions(-) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-11[PATCH] SAA9730: Whitespace cleanup.Ralf Baechle
Kill trailing whitespace, replace leading whitespace with tabs. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> drivers/net/saa9730.c | 98 +++++++++++++++++++++++++------------------------- 1 files changed, 49 insertions(+), 49 deletions(-) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28drivers/net: Remove pointless checks for NULL prior to calling kfree()Jesper Juhl
