path: root/drivers/net/pptp.c
2010-09-21net: constify some ppp/pptp structsEric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-21PPTP: PPP over IPv4 (Point-to-Point Tunneling Protocol)Dmitry Kozlov
PPP: introduce "pptp" module which implements point-to-point tunneling protocol using pppox framework NET: introduce the "gre" module for demultiplexing GRE packets on version criteria (required to pptp and ip_gre may coexists) NET: ip_gre: update to use the "gre" module This patch introduces then pptp support to the linux kernel which dramatically speeds up pptp vpn connections and decreases cpu usage in comparison of existing user-space implementation (poptop/pptpclient). There is accel-pptp project (https://sourceforge.net/projects/accel-pptp/) to utilize this module, it contains plugin for pppd to use pptp in client-mode and modified pptpd (poptop) to build high-performance pptp NAS. There was many changes from initial submitted patch, most important are: 1. using rcu instead of read-write locks 2. using static bitmap instead of dynamically allocated 3. using vmalloc for memory allocation instead of BITS_PER_LONG + __get_free_pages 4. fixed many coding style issues Thanks to Eric Dumazet. Signed-off-by: Dmitry Kozlov <xeb@mail.ru> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
