For the ppp driver, there are currently two open-coded BPF filters in use,
that is, pass_filter and active_filter. Migrate both to make proper use
of sk_unattached_filter_{create,destroy} API so that the actual BPF code
is decoupled from direct access, and filters can be jited as a side-effect
by the internal filter compiler.
Joint work with Alexei Starovoitov.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Cc: linux-ppp@vger.kernel.org
Use possibly more efficient ether_addr_equal
to instead of memcmp.
Cc: Michal Ostrowski <mostrows@earthlink.net>
Cc: netdev@vger.kernel.org
Signed-off-by: Ding Tianhong <dingtianhong@huawei.com>
Several files refer to an old address for the Free Software Foundation
in the file header comment. Resolve by replacing the address with
the URL <http://www.gnu.org/licenses/> so that we do not have to keep
updating the header comments anytime the address changes.
CC: Jay Vosburgh <fubar@us.ibm.com>
CC: Veaceslav Falico <vfalico@redhat.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: Haiyang Zhang <haiyangz@microsoft.com>
CC: "K. Y. Srinivasan" <kys@microsoft.com>
CC: Paul Mackerras <paulus@samba.org>
CC: Ian Campbell <ian.campbell@citrix.com>
CC: Wei Liu <wei.liu2@citrix.com>
CC: Rusty Russell <rusty@rustcorp.com.au>
CC: "Michael S. Tsirkin" <mst@redhat.com>
Acked-by: Wei Liu <wei.liu2@citrix.com>
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
If local fragmentation is allowed, then ip_select_ident() and
ip_select_ident_more() need to generate unique IDs to ensure
correct defragmentation on the peer.
For example, if IPsec (tunnel mode) has to encrypt large skbs
that have local_df bit set, then all IP fragments that belonged
to different ESP datagrams would have used the same identificator.
If one of these IP fragments would get lost or reordered, then
peer could possibly stitch together wrong IP fragments that did
not belong to the same datagram. This would lead to a packet loss
or data corruption.
Signed-off-by: Ansis Atteka <aatteka@nicira.com>
Pptp driver has lots of byte order warnings from sparse.
This was because the on-the-wire header is in network byte order (obviously)
but the definition did not reflect that.
Also, the address structure to user space actually put the call id
in host order. Rather than break ABI compatibility, just acknowledge
the existing design.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
callid_sock array is referenced via rcu_dereference and
sparse rcu checks complains about address space mismatch.
So far, only net_device * could be passed along with netdevice notifier
event. This patch provides a possibility to pass custom structure
able to provide info that event listener needs to know.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
v2->v3: fix typo on simeth
shortened dev_getter
shortened notifier_info struct name
v1->v2: fix notifier_call parameter in call_netdevice_notifier()
Pull networking updates from David Miller:
"Highlights (1721 non-merge commits, this has to be a record of some
sort):
1) Add 'random' mode to team driver, from Jiri Pirko and Eric
Dumazet.
2) Make it so that any driver that supports configuration of multiple
MAC addresses can provide the forwarding database add and del
calls by providing a default implementation and hooking that up if
the driver doesn't have an explicit set of handlers. From Vlad
Yasevich.
3) Support GSO segmentation over tunnels and other encapsulating
devices such as VXLAN, from Pravin B Shelar.
4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton.
5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita
Dukkipati.
6) In the PHY layer, allow supporting wake-on-lan in situations where
the PHY registers have to be written for it to be configured.
Use it to support wake-on-lan in mv643xx_eth.
From Michael Stapelberg.
7) Significantly improve firewire IPV6 support, from YOSHIFUJI
Hideaki.
8) Allow multiple packets to be sent in a single transmission using
network coding in batman-adv, from Martin Hundebøll.
9) Add support for T5 cxgb4 chips, from Santosh Rastapur.
10) Generalize the VXLAN forwarding tables so that there is more
flexibility in configurating various aspects of the endpoints.
From David Stevens.
11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver,
from Dmitry Kravkov.
12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo
Neira Ayuso.
13) Start adding networking selftests.
14) In situations of overload on the same AF_PACKET fanout socket, or
per-cpu packet receive queue, minimize drop by distributing the
load to other cpus/fanouts. From Willem de Bruijn and Eric
Dumazet.
15) Add support for new payload offset BPF instruction, from Daniel
Borkmann.
16) Convert several drivers over to mdoule_platform_driver(), from
Sachin Kamat.
17) Provide a minimal BPF JIT image disassembler userspace tool, from
Daniel Borkmann.
18) Rewrite F-RTO implementation in TCP to match the final
specification of it in RFC4138 and RFC5682. From Yuchung Cheng.
19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear
you like netlink, so I implemented netlink dumping of netlink
sockets.") From Andrey Vagin.
20) Remove ugly passing of rtnetlink attributes into rtnl_doit
functions, from Thomas Graf.
21) Allow userspace to be able to see if a configuration change occurs
in the middle of an address or device list dump, from Nicolas
Dichtel.
22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes
Frederic Sowa.
23) Increase accuracy of packet length used by packet scheduler, from
Jason Wang.
24) Beginning set of changes to make ipv4/ipv6 fragment handling more
scalable and less susceptible to overload and locking contention,
from Jesper Dangaard Brouer.
25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*()
instead. From Hong Zhiguo.
26) Optimize route usage in IPVS by avoiding reference counting where
possible, from Julian Anastasov.
27) Convert IPVS schedulers to RCU, also from Julian Anastasov.
28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger
Eitzenberger.
29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG,
nfnetlink_log, and nfnetlink_queue. From Gao feng.
30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa.
31) Support several new r8169 chips, from Hayes Wang.
32) Support tokenized interface identifiers in ipv6, from Daniel
Borkmann.
33) Use usbnet_link_change() helper in USB net driver, from Ming Lei.
34) Add 802.1ad vlan offload support, from Patrick McHardy.
35) Support mmap() based netlink communication, also from Patrick
McHardy.
36) Support HW timestamping in mlx4 driver, from Amir Vadai.
37) Rationalize AF_PACKET packet timestamping when transmitting, from
Willem de Bruijn and Daniel Borkmann.
38) Bring parity to what's provided by /proc/net/packet socket dumping
and the info provided by netlink socket dumping of AF_PACKET
sockets. From Nicolas Dichtel.
39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin
Poirier"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
filter: fix va_list build error
af_unix: fix a fatal race with bit fields
bnx2x: Prevent memory leak when cnic is absent
bnx2x: correct reading of speed capabilities
net: sctp: attribute printl with __printf for gcc fmt checks
netlink: kconfig: move mmap i/o into netlink kconfig
netpoll: convert mutex into a semaphore
netlink: Fix skb ref counting.
net_sched: act_ipt forward compat with xtables
mlx4_en: fix a build error on 32bit arches
Revert "bnx2x: allow nvram test to run when device is down"
bridge: avoid OOPS if root port not found
drivers: net: cpsw: fix kernel warn on cpsw irq enable
sh_eth: use random MAC address if no valid one supplied
3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA)
tg3: fix to append hardware time stamping flags
unix/stream: fix peeking with an offset larger than data in queue
unix/dgram: fix peeking with an offset larger than data in queue
unix/dgram: peek beyond 0-sized skbs
openvswitch: Remove unneeded ovs_netdev_get_ifindex()
There is a native function to dump hex buffers.
tty_perform_flush() can deadlock when called while holding
a line discipline reference. By definition, all ldisc drivers
hold a ldisc reference, so calls originating from ldisc drivers
must not block for a ldisc reference.
The deadlock can occur when:
CPU 0 | CPU 1
tty_ldisc_ref(tty) |
.... | <line discipline halted>
tty_ldisc_ref_wait(tty) |
CPU 0 cannot progess because it cannot obtain an ldisc reference
with the line discipline has been halted (thus no new references
are granted).
CPU 1 cannot progress because an outstanding ldisc reference
has not been released.
An in-tree call-tree audit of tty_perform_flush() [1] shows 5
ldisc drivers calling tty_perform_flush() indirectly via
n_tty_ioctl_helper() and 2 ldisc drivers calling directly.
A single tty driver safely uses the function.
[1]
Recursive usage:
/* These functions are line discipline ioctls and thus
* recursive wrt line discipline references */
tty_perform_flush() - ./drivers/tty/tty_ioctl.c
hci_uart_tty_ioctl(default) - drivers/bluetooth/hci_ldisc.c (N_HCI)
n_hdlc_tty_ioctl(default) - drivers/tty/n_hdlc.c (N_HDLC)
gsmld_ioctl(default) - drivers/tty/n_gsm.c (N_GSM0710)
n_tty_ioctl(default) - drivers/tty/n_tty.c (N_TTY)
gigaset_tty_ioctl(default) - drivers/isdn/gigaset/ser-gigaset.c (N_GIGASET_M101)
ppp_synctty_ioctl(TCFLSH) - drivers/net/ppp/pps_synctty.c
ppp_asynctty_ioctl(TCFLSH) - drivers/net/ppp/ppp_async.c
Non-recursive use:
tty_perform_flush() - drivers/tty/tty_ioctl.c
ipw_ioctl(TCFLSH) - drivers/tty/ipwireless/tty.c
/* This function is a tty i/o ioctl method, which
* is invoked by tty_ioctl() */
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Convert to the much saner new idr interface.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial patches from Greg Kroah-Hartman:
"Here's the big tty/serial driver patches for 3.9-rc1.
More tty port rework and fixes from Jiri here, as well as lots of
individual serial driver updates and fixes.
All of these have been in the linux-next tree for a while."
* tag 'tty-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits)
tty: mxser: improve error handling in mxser_probe() and mxser_module_init()
serial: imx: fix uninitialized variable warning
serial: tegra: assume CONFIG_OF
TTY: do not update atime/mtime on read/write
lguest: select CONFIG_TTY to build properly.
ARM defconfigs: add missing inclusions of linux/platform_device.h
fb/exynos: include platform_device.h
ARM: sa1100/assabet: include platform_device.h directly
serial: imx: Fix recursive locking bug
pps: Fix build breakage from decoupling pps from tty
tty: Remove ancient hardpps()
pps: Additional cleanups in uart_handle_dcd_change
pps: Move timestamp read into PPS code proper
pps: Don't crash the machine when exiting will do
pps: Fix a use-after free bug when unregistering a source.
pps: Use pps_lookup_dev to reduce ldisc coupling
pps: Add pps_lookup_dev() function
tty: serial: uartlite: Support uartlite on big and little endian systems
tty: serial: uartlite: Fix sparse and checkpatch warnings
serial/arc-uart: Miscll DT related updates (Grant's review comments)
Fix up trivial conflicts, mostly just due to the TTY config option
clashing with the EXPERIMENTAL removal.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core patches from Greg Kroah-Hartman:
"Here is the big driver core merge for 3.9-rc1
There are two major series here, both of which touch lots of drivers
all over the kernel, and will cause you some merge conflicts:
- add a new function called devm_ioremap_resource() to properly be
able to check return values.
- remove CONFIG_EXPERIMENTAL
Other than those patches, there's not much here, some minor fixes and
updates"
* tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits)
base: memory: fix soft/hard_offline_page permissions
drivercore: Fix ordering between deferred_probe and exiting initcalls
backlight: fix class_find_device() arguments
TTY: mark tty_get_device call with the proper const values
driver-core: constify data for class_find_device()
firmware: Ignore abort check when no user-helper is used
firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER
firmware: Make user-mode helper optional
firmware: Refactoring for splitting user-mode helper code
Driver core: treat unregistered bus_types as having no devices
watchdog: Convert to devm_ioremap_resource()
thermal: Convert to devm_ioremap_resource()
spi: Convert to devm_ioremap_resource()
power: Convert to devm_ioremap_resource()
mtd: Convert to devm_ioremap_resource()
mmc: Convert to devm_ioremap_resource()
mfd: Convert to devm_ioremap_resource()
media: Convert to devm_ioremap_resource()
iommu: Convert to devm_ioremap_resource()
drm: Convert to devm_ioremap_resource()
If a qdisc is installed on a ppp device, its possible to get
a lockdep splat under stress, because nested dev_queue_xmit() can
lock busylock a second time (on a different device, so its a false
positive)
Avoid this problem using a distinct lock_class_key for ppp
devices.
Reported-by: Yanko Kaneti <yaneti@declera.com>
Tested-by: Yanko Kaneti <yaneti@declera.com>
proc_net_remove is only used to remove proc entries
that under /proc/net,it's not a general function for
removing proc entries of netns. if we want to remove
some proc entries which under /proc/net/stat/, we still
need to call remove_proc_entry.
this patch use remove_proc_entry to replace proc_net_remove.
we can remove proc_net_remove after this patch.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
Right now, some modules such as bonding use proc_create
to create proc entries under /proc/net/, and other modules
such as ipv4 use proc_net_fops_create.
It looks a little chaos.this patch changes all of
proc_net_fops_create to proc_create. we can remove
proc_net_fops_create after this patch.
This function will be used in next GRE_GSO patch. This patch does
not change any functionality.
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
The option allows you to remove TTY and compile without errors. This
saves space on systems that won't support TTY interfaces anyway.
bloat-o-meter output is below.
The bulk of this patch consists of Kconfig changes adding "depends on
TTY" to various serial devices and similar drivers that require the TTY
layer. Ideally, these dependencies would occur on a common intermediate
symbol such as SERIO, but most drivers "select SERIO" rather than
"depends on SERIO", and "select" does not respect dependencies.
bloat-o-meter output comparing our previous minimal to new minimal by
removing TTY. The list is filtered to not show removed entries with awk
'$3 != "-"' as the list was very long.
add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350)
function old new delta
chr_dev_init 166 170 +4
allow_signal 80 82 +2
static.__warned 143 142 -1
disallow_signal 63 62 -1
__set_special_pids 95 94 -1
unregister_console 126 121 -5
start_kernel 546 541 -5
register_console 593 588 -5
copy_from_user 45 40 -5
sys_setsid 128 120 -8
sys_vhangup 32 19 -13
do_exit 1543 1526 -17
bitmap_zero 60 40 -20
arch_local_irq_save 137 117 -20
release_task 674 652 -22
static.spin_unlock_irqrestore 308 260 -48
Signed-off-by: Joe Millenbach <jmillenbach@gmail.com>
Reviewed-by: Jamey Sharp <jamey@minilop.net>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
This was picked up by sparse.
drivers/net/team/team.c
drivers/net/usb/qmi_wwan.c
net/batman-adv/bat_iv_ogm.c
net/ipv4/fib_frontend.c
net/ipv4/route.c
net/l2tp/l2tp_netlink.c
The team, fib_frontend, route, and l2tp_netlink conflicts were simply
overlapping changes.
qmi_wwan and bat_iv_ogm were of the "use HEAD" variety.
With help from Antonio Quartulli.
When PPPOE is running over a virtual ethernet interface (e.g., a
bonding interface) and the user tries to delete the interface in case
the PPPOE state is ZOMBIE, the kernel will loop forever while
unregistering net_device for the reference count is not decreased to
zero which should have been done with dev_put().
Signed-off-by: Xiaodong Xu <stid.smth@gmail.com>
pptp always use init_net as the net namespace to lookup
route, this will cause route lookup failed in container.
because we already set the correct net namespace to struct
sock in pptp_create,so fix this by using sock_net(sk) to
replace &init_net.
Add 64 bit stats to ppp driver. The 64 bit stats include tx_bytes,
rx_bytes, tx_packets and rx_packets. Other stats are still 32 bit.
The 64 bit stats can be retrieved via the ndo_get_stats operation. The
SIOCGPPPSTATS ioctl is still 32 bit stats only.
Signed-off-by: Kevin Groeneveld <kgroeneveld@gmail.com>
Call consume_skb() in place of kfree_skb() were appropriate.
The patch removes unused return value from __delete_item() and
delete_item() methods in drivers/net/ppp/pppoe.c.
Signed-off-by: Rami Rosen <ramirose@gmail.com>
drivers/net/ethernet/atheros/atlx/atl1.c
drivers/net/ethernet/atheros/atlx/atl1.h
Resolved a conflict between a DMA error bug fix and NAPI
support changes in the atl1 driver.
Commit e675f0cc9a872fd152edc0c77acfed19bf28b81e ("ppp: Don't stop and
restart queue on every TX packet") introduced a race condition which
could leave the net queue stopped even when the channel is no longer
busy. By calling netif_stop_queue() from ppp_start_xmit(), based on the
return value from ppp_xmit_process() but *after* all the locks have been
dropped, we could potentially do so *after* the channel has actually
finished transmitting and attempted to re-wake the queue.
Fix this by moving the netif_stop_queue() into ppp_xmit_process() under
the xmit lock. I hadn't done this previously, because it gets called
from other places than ppp_start_xmit(). But I now think it's the better
option. The net queue *should* be stopped if the channel becomes
congested due to writes from pppd, anyway.
Use for_each_set_bit_from to iterate over all the set bit in a memory
region.
Cc: Dmitry Kozlov <xeb@mail.ru>
For every transmitted packet, ppp_start_xmit() will stop the netdev
queue and then, if appropriate, restart it. This causes the TX softirq
to run, entirely gratuitously.
This is "only" a waste of CPU time in the normal case, but it's actively
harmful when the PPP device is a TEQL slave — the wakeup will cause the
offending device to receive the next TX packet from the TEQL queue, when
it *should* have gone to the next slave in the list. We end up seeing
large bursts of packets on just *one* slave device, rather than using
the full available bandwidth over all slaves.
This patch fixes the problem by *not* unconditionally stopping the queue
in ppp_start_xmit(). It adds a return value from ppp_xmit_process()
which indicates whether the queue should be stopped or not.
It *doesn't* remove the call to netif_wake_queue() from
ppp_xmit_process(), because other code paths (especially from
ppp_output_wakeup()) need it there and it's messy to push it out to the
other callers to do it based on the return value. So we leave it in
place — it's a no-op in the case where the queue wasn't stopped, so it's
harmless in the TX path.
Since all that include/linux/if_ppp.h does is #include <linux/ppp-ioctl.h>,
this replaces the occurrences of #include <linux/if_ppp.h> with
#include <linux/ppp-ioctl.h>.
It also corrects an error in Documentation/networking/l2tp.txt, where
it referenced include/linux/if_ppp.h as the source of some definitions
that are actually now defined in include/linux/if_pppol2tp.h.
This moves the definitions of the ioctls, constants and structures
relating to the ppp_generic interface to userspace out from if_ppp.h
to a new file, ppp-ioctl.h. The new file has my copyright since I
designed and implemented the ppp_generic interface in the late 1990s.
None of the contents of this file comes from the original if_ppp.h
published by Carnegie Mellon University.
Of the remainder of if_ppp.h, only the PPP_MTU definition was being
used, and this replaces the uses of it with PPP_MRU (which is identical).
Therefore, this replaces the entire file with the single line
which clearly doesn't contain any CMU code. Thus I have removed the
CMU copyright notice with its problematic advertising clause, and in
fact since it's only one trivial line I have not added any other
copyright notice.
This changes the copyright notices on the PPP code that I developed
in the late 1990s from being copyright The Australian National
University to copyright Paul Mackerras. I can do this as I have an
acknowledgement in writing from the Head of the Computer Science
Department at ANU (where I worked then) that ANU does not claim any
intellectual property in this code.
While I'm at it, change the copyright notice from BSD-style to
GNU GPL like the rest of the kernel.
drivers/net/ethernet/sfc/rx.c
Overlapping changes in drivers/net/ethernet/sfc/rx.c, one to change
the rx_buf->is_page boolean into a set of u16 flags, and another to
adjust how ->ip_summed is initialized.
This patch fixes a (mostly cosmetic) bug introduced by the patch
'ppp: Use SKB queue abstraction interfaces in fragment processing'
found here: http://www.spinics.net/lists/netdev/msg153312.html
The above patch rewrote and moved the code responsible for cleaning
up discarded fragments but the new code does not catch every case
where this is necessary. This results in some discarded fragments
remaining in the queue, and triggering a 'bad seq' error on the
subsequent call to ppp_mp_reconstruct. Fragments are discarded
whenever other fragments of the same frame have been lost.
This can generate a lot of unwanted and misleading log messages.
This patch also adds additional detail to the debug logging to
make it clearer which fragments were lost and which other fragments
were discarded as a result of losses. (Run pppd with 'kdebug 1'
option to enable debug logging.)
Signed-off-by: Ben McKeegan <ben@netservers.co.uk>
When building frag_list, head truesize should be sum of all frag
truesize.
alloc failures use dump_stack so emitting an additional
out-of-memory message is an unnecessary duplication.
Remove the allocation failure messages.
Initialize the PPTP "seq received" value to 0xffffffff, so we don't
ignore packets with seq zero.
Signed-off-by: Bradley Peterson <despite@gmail.com>
drivers/net/ethernet/freescale/fsl_pq_mdio.c
net/batman-adv/translation-table.c
net/ipv6/route.c
Signed-off-by: Djalal Harouni <tixxdz@opendz.org>
rcu_assign_pointer(ptr, NULL) can be safely replaced by
RCU_INIT_POINTER(ptr, NULL)
(old rcu_assign_pointer() macro was testing the NULL value and could
omit the smp_wmb(), but this had to be removed because of compiler
warnings)
MAINTAINERS
drivers/net/Kconfig
drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c
drivers/net/ethernet/broadcom/tg3.c
drivers/net/wireless/iwlwifi/iwl-pci.c
drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c
drivers/net/wireless/rt2x00/rt2800usb.c
drivers/net/wireless/wl12xx/main.c
Move the PPP drivers into drivers/net/ppp/ and make the
necessary Kconfig and Makefile changes.
CC: Frank Cusack <fcusack@fcusack.com>
CC: Michal Ostrowski <mostrows@speakeasy.net>
CC: Michal Ostrowski <mostrows@earthlink.net>
CC: Dmitry Kozlov <xeb@mail.ru>
