path: root/drivers/net/ppp
2013-12-26ppp: slight optimization of addr comparedingtianhong
Use possibly more efficient ether_addr_equal to instead of memcmp. Cc: Michal Ostrowski <mostrows@earthlink.net> Cc: netdev@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06drivers/net/*: Fix FSF address in file headersJeff Kirsher
Several files refer to an old address for the Free Software Foundation in the file header comment. Resolve by replacing the address with the URL <http://www.gnu.org/licenses/> so that we do not have to keep updating the header comments anytime the address changes. CC: Jay Vosburgh <fubar@us.ibm.com> CC: Veaceslav Falico <vfalico@redhat.com> CC: Andy Gospodarek <andy@greyhouse.net> CC: Haiyang Zhang <haiyangz@microsoft.com> CC: "K. Y. Srinivasan" <kys@microsoft.com> CC: Paul Mackerras <paulus@samba.org> CC: Ian Campbell <ian.campbell@citrix.com> CC: Wei Liu <wei.liu2@citrix.com> CC: Rusty Russell <rusty@rustcorp.com.au> CC: "Michael S. Tsirkin" <mst@redhat.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Wei Liu <wei.liu2@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-19ip: generate unique IP identificator if local fragmentation is allowedAnsis Atteka
If local fragmentation is allowed, then ip_select_ident() and ip_select_ident_more() need to generate unique IDs to ensure correct defragmentation on the peer. For example, if IPsec (tunnel mode) has to encrypt large skbs that have local_df bit set, then all IP fragments that belonged to different ESP datagrams would have used the same identificator. If one of these IP fragments would get lost or reordered, then peer could possibly stitch together wrong IP fragments that did not belong to the same datagram. This would lead to a packet loss or data corruption. Signed-off-by: Ansis Atteka <aatteka@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-13pptp: fix byte order warningsstephen hemminger
Pptp driver has lots of byte order warnings from sparse. This was because the on-the-wire header is in network byte order (obviously) but the definition did not reflect that. Also, the address structure to user space actually put the call id in host order. Rather than break ABI compatibility, just acknowledge the existing design. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-09pptp: fix sparse pointer warningstephen hemminger
callid_sock array is referenced via rcu_dereference and sparse rcu checks complains about address space mismatch. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-28net: pass info struct via netdevice notifierJiri Pirko
So far, only net_device * could be passed along with netdevice notifier event. This patch provides a possibility to pass custom structure able to provide info that event listener needs to know. Signed-off-by: Jiri Pirko <jiri@resnulli.us> v2->v3: fix typo on simeth shortened dev_getter shortened notifier_info struct name v1->v2: fix notifier_call parameter in call_netdevice_notifier() Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights (1721 non-merge commits, this has to be a record of some sort): 1) Add 'random' mode to team driver, from Jiri Pirko and Eric Dumazet. 2) Make it so that any driver that supports configuration of multiple MAC addresses can provide the forwarding database add and del calls by providing a default implementation and hooking that up if the driver doesn't have an explicit set of handlers. From Vlad Yasevich. 3) Support GSO segmentation over tunnels and other encapsulating devices such as VXLAN, from Pravin B Shelar. 4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton. 5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita Dukkipati. 6) In the PHY layer, allow supporting wake-on-lan in situations where the PHY registers have to be written for it to be configured. Use it to support wake-on-lan in mv643xx_eth. From Michael Stapelberg. 7) Significantly improve firewire IPV6 support, from YOSHIFUJI Hideaki. 8) Allow multiple packets to be sent in a single transmission using network coding in batman-adv, from Martin Hundebøll. 9) Add support for T5 cxgb4 chips, from Santosh Rastapur. 10) Generalize the VXLAN forwarding tables so that there is more flexibility in configurating various aspects of the endpoints. From David Stevens. 11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver, from Dmitry Kravkov. 12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo Neira Ayuso. 13) Start adding networking selftests. 14) In situations of overload on the same AF_PACKET fanout socket, or per-cpu packet receive queue, minimize drop by distributing the load to other cpus/fanouts. From Willem de Bruijn and Eric Dumazet. 15) Add support for new payload offset BPF instruction, from Daniel Borkmann. 16) Convert several drivers over to mdoule_platform_driver(), from Sachin Kamat. 17) Provide a minimal BPF JIT image disassembler userspace tool, from Daniel Borkmann. 18) Rewrite F-RTO implementation in TCP to match the final specification of it in RFC4138 and RFC5682. From Yuchung Cheng. 19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear you like netlink, so I implemented netlink dumping of netlink sockets.") From Andrey Vagin. 20) Remove ugly passing of rtnetlink attributes into rtnl_doit functions, from Thomas Graf. 21) Allow userspace to be able to see if a configuration change occurs in the middle of an address or device list dump, from Nicolas Dichtel. 22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes Frederic Sowa. 23) Increase accuracy of packet length used by packet scheduler, from Jason Wang. 24) Beginning set of changes to make ipv4/ipv6 fragment handling more scalable and less susceptible to overload and locking contention, from Jesper Dangaard Brouer. 25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*() instead. From Hong Zhiguo. 26) Optimize route usage in IPVS by avoiding reference counting where possible, from Julian Anastasov. 27) Convert IPVS schedulers to RCU, also from Julian Anastasov. 28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger Eitzenberger. 29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG, nfnetlink_log, and nfnetlink_queue. From Gao feng. 30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa. 31) Support several new r8169 chips, from Hayes Wang. 32) Support tokenized interface identifiers in ipv6, from Daniel Borkmann. 33) Use usbnet_link_change() helper in USB net driver, from Ming Lei. 34) Add 802.1ad vlan offload support, from Patrick McHardy. 35) Support mmap() based netlink communication, also from Patrick McHardy. 36) Support HW timestamping in mlx4 driver, from Amir Vadai. 37) Rationalize AF_PACKET packet timestamping when transmitting, from Willem de Bruijn and Daniel Borkmann. 38) Bring parity to what's provided by /proc/net/packet socket dumping and the info provided by netlink socket dumping of AF_PACKET sockets. From Nicolas Dichtel. 39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin Poirier" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) filter: fix va_list build error af_unix: fix a fatal race with bit fields bnx2x: Prevent memory leak when cnic is absent bnx2x: correct reading of speed capabilities net: sctp: attribute printl with __printf for gcc fmt checks netlink: kconfig: move mmap i/o into netlink kconfig netpoll: convert mutex into a semaphore netlink: Fix skb ref counting. net_sched: act_ipt forward compat with xtables mlx4_en: fix a build error on 32bit arches Revert "bnx2x: allow nvram test to run when device is down" bridge: avoid OOPS if root port not found drivers: net: cpsw: fix kernel warn on cpsw irq enable sh_eth: use random MAC address if no valid one supplied 3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA) tg3: fix to append hardware time stamping flags unix/stream: fix peeking with an offset larger than data in queue unix/dgram: fix peeking with an offset larger than data in queue unix/dgram: peek beyond 0-sized skbs openvswitch: Remove unneeded ovs_netdev_get_ifindex() ...
2013-03-27ppp: reuse print_hex_dump_bytesAndy Shevchenko
There is a native function to dump hex buffers. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-18tty: Fix recursive deadlock in tty_perform_flush()Peter Hurley
tty_perform_flush() can deadlock when called while holding a line discipline reference. By definition, all ldisc drivers hold a ldisc reference, so calls originating from ldisc drivers must not block for a ldisc reference. The deadlock can occur when: CPU 0 | CPU 1 | tty_ldisc_ref(tty) | .... | <line discipline halted> tty_ldisc_ref_wait(tty) | | CPU 0 cannot progess because it cannot obtain an ldisc reference with the line discipline has been halted (thus no new references are granted). CPU 1 cannot progress because an outstanding ldisc reference has not been released. An in-tree call-tree audit of tty_perform_flush() [1] shows 5 ldisc drivers calling tty_perform_flush() indirectly via n_tty_ioctl_helper() and 2 ldisc drivers calling directly. A single tty driver safely uses the function. [1] Recursive usage: /* These functions are line discipline ioctls and thus * recursive wrt line discipline references */ tty_perform_flush() - ./drivers/tty/tty_ioctl.c n_tty_ioctl_helper() hci_uart_tty_ioctl(default) - drivers/bluetooth/hci_ldisc.c (N_HCI) n_hdlc_tty_ioctl(default) - drivers/tty/n_hdlc.c (N_HDLC) gsmld_ioctl(default) - drivers/tty/n_gsm.c (N_GSM0710) n_tty_ioctl(default) - drivers/tty/n_tty.c (N_TTY) gigaset_tty_ioctl(default) - drivers/isdn/gigaset/ser-gigaset.c (N_GIGASET_M101) ppp_synctty_ioctl(TCFLSH) - drivers/net/ppp/pps_synctty.c ppp_asynctty_ioctl(TCFLSH) - drivers/net/ppp/ppp_async.c Non-recursive use: tty_perform_flush() - drivers/tty/tty_ioctl.c ipw_ioctl(TCFLSH) - drivers/tty/ipwireless/tty.c /* This function is a tty i/o ioctl method, which * is invoked by tty_ioctl() */ Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-27ppp: convert to idr_alloc()Tejun Heo
Convert to the much saner new idr interface. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge tag 'tty-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial patches from Greg Kroah-Hartman: "Here's the big tty/serial driver patches for 3.9-rc1. More tty port rework and fixes from Jiri here, as well as lots of individual serial driver updates and fixes. All of these have been in the linux-next tree for a while." * tag 'tty-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits) tty: mxser: improve error handling in mxser_probe() and mxser_module_init() serial: imx: fix uninitialized variable warning serial: tegra: assume CONFIG_OF TTY: do not update atime/mtime on read/write lguest: select CONFIG_TTY to build properly. ARM defconfigs: add missing inclusions of linux/platform_device.h fb/exynos: include platform_device.h ARM: sa1100/assabet: include platform_device.h directly serial: imx: Fix recursive locking bug pps: Fix build breakage from decoupling pps from tty tty: Remove ancient hardpps() pps: Additional cleanups in uart_handle_dcd_change pps: Move timestamp read into PPS code proper pps: Don't crash the machine when exiting will do pps: Fix a use-after free bug when unregistering a source. pps: Use pps_lookup_dev to reduce ldisc coupling pps: Add pps_lookup_dev() function tty: serial: uartlite: Support uartlite on big and little endian systems tty: serial: uartlite: Fix sparse and checkpatch warnings serial/arc-uart: Miscll DT related updates (Grant's review comments) ... Fix up trivial conflicts, mostly just due to the TTY config option clashing with the EXPERIMENTAL removal.
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-19ppp: set qdisc_tx_busylock to avoid LOCKDEP splatEric Dumazet
If a qdisc is installed on a ppp device, its possible to get a lockdep splat under stress, because nested dev_queue_xmit() can lock busylock a second time (on a different device, so its a false positive) Avoid this problem using a distinct lock_class_key for ppp devices. Reported-by: Yanko Kaneti <yaneti@declera.com> Tested-by: Yanko Kaneti <yaneti@declera.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18net: proc: change proc_net_remove to remove_proc_entryGao feng
proc_net_remove is only used to remove proc entries that under /proc/net,it's not a general function for removing proc entries of netns. if we want to remove some proc entries which under /proc/net/stat/, we still need to call remove_proc_entry. this patch use remove_proc_entry to replace proc_net_remove. we can remove proc_net_remove after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18net: proc: change proc_net_fops_create to proc_createGao feng
Right now, some modules such as bonding use proc_create to create proc entries under /proc/net/, and other modules such as ipv4 use proc_net_fops_create. It looks a little chaos.this patch changes all of proc_net_fops_create to proc_create. we can remove proc_net_fops_create after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-15net: Add skb_unclone() helper function.Pravin B Shelar
This function will be used in next GRE_GSO patch. This patch does not change any functionality. Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Acked-by: Eric Dumazet <edumazet@google.com>
2013-01-22drivers/net/ppp: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-18tty: Added a CONFIG_TTY option to allow removal of TTYJoe Millenbach
The option allows you to remove TTY and compile without errors. This saves space on systems that won't support TTY interfaces anyway. bloat-o-meter output is below. The bulk of this patch consists of Kconfig changes adding "depends on TTY" to various serial devices and similar drivers that require the TTY layer. Ideally, these dependencies would occur on a common intermediate symbol such as SERIO, but most drivers "select SERIO" rather than "depends on SERIO", and "select" does not respect dependencies. bloat-o-meter output comparing our previous minimal to new minimal by removing TTY. The list is filtered to not show removed entries with awk '$3 != "-"' as the list was very long. add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350) function old new delta chr_dev_init 166 170 +4 allow_signal 80 82 +2 static.__warned 143 142 -1 disallow_signal 63 62 -1 __set_special_pids 95 94 -1 unregister_console 126 121 -5 start_kernel 546 541 -5 register_console 593 588 -5 copy_from_user 45 40 -5 sys_setsid 128 120 -8 sys_vhangup 32 19 -13 do_exit 1543 1526 -17 bitmap_zero 60 40 -20 arch_local_irq_save 137 117 -20 release_task 674 652 -22 static.spin_unlock_irqrestore 308 260 -48 Signed-off-by: Joe Millenbach <jmillenbach@gmail.com> Reviewed-by: Jamey Sharp <jamey@minilop.net> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-01ppp: make ppp_get_stats64 staticstephen hemminger
This was picked up by sparse. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/team/team.c drivers/net/usb/qmi_wwan.c net/batman-adv/bat_iv_ogm.c net/ipv4/fib_frontend.c net/ipv4/route.c net/l2tp/l2tp_netlink.c The team, fib_frontend, route, and l2tp_netlink conflicts were simply overlapping changes. qmi_wwan and bat_iv_ogm were of the "use HEAD" variety. With help from Antonio Quartulli. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-22pppoe: drop PPPOX_ZOMBIEs in pppoe_releaseXiaodong Xu
When PPPOE is running over a virtual ethernet interface (e.g., a bonding interface) and the user tries to delete the interface in case the PPPOE state is ZOMBIE, the kernel will loop forever while unregistering net_device for the reference count is not decreased to zero which should have been done with dev_put(). Signed-off-by: Xiaodong Xu <stid.smth@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-08-08pptp: lookup route with the proper net namespaceGao feng
pptp always use init_net as the net namespace to lookup route, this will cause route lookup failed in container. because we already set the correct net namespace to struct sock in pptp_create,so fix this by using sock_net(sk) to replace &init_net. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-03ppp: add 64 bit statsKevin Groeneveld
Add 64 bit stats to ppp driver. The 64 bit stats include tx_bytes, rx_bytes, tx_packets and rx_packets. Other stats are still 32 bit. The 64 bit stats can be retrieved via the ndo_get_stats operation. The SIOCGPPPSTATS ioctl is still 32 bit stats only. Signed-off-by: Kevin Groeneveld <kgroeneveld@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-19ppp: avoid false drop_monitor false positivesEric Dumazet
Call consume_skb() in place of kfree_skb() were appropriate. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-17pppoe: remove unused return value from two methods.Rami Rosen
The patch removes unused return value from __delete_item() and delete_item() methods in drivers/net/ppp/pppoe.c. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/atheros/atlx/atl1.c drivers/net/ethernet/atheros/atlx/atl1.h Resolved a conflict between a DMA error bug fix and NAPI support changes in the atl1 driver. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-13ppp: Fix race condition with queue start/stopDavid Woodhouse
Commit e675f0cc9a872fd152edc0c77acfed19bf28b81e ("ppp: Don't stop and restart queue on every TX packet") introduced a race condition which could leave the net queue stopped even when the channel is no longer busy. By calling netif_stop_queue() from ppp_start_xmit(), based on the return value from ppp_xmit_process() but *after* all the locks have been dropped, we could potentially do so *after* the channel has actually finished transmitting and attempted to re-wake the queue. Fix this by moving the netif_stop_queue() into ppp_xmit_process() under the xmit lock. I hadn't done this previously, because it gets called from other places than ppp_start_xmit(). But I now think it's the better option. The net queue *should* be stopped if the channel becomes congested due to writes from pppd, anyway. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-04-03ppp: use for_each_set_bit_fromAkinobu Mita
Use for_each_set_bit_from to iterate over all the set bit in a memory region. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Dmitry Kozlov <xeb@mail.ru> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-03ppp: Don't stop and restart queue on every TX packetDavid Woodhouse
For every transmitted packet, ppp_start_xmit() will stop the netdev queue and then, if appropriate, restart it. This causes the TX softirq to run, entirely gratuitously. This is "only" a waste of CPU time in the normal case, but it's actively harmful when the PPP device is a TEQL slave — the wakeup will cause the offending device to receive the next TX packet from the TEQL queue, when it *should* have gone to the next slave in the list. We end up seeing large bursts of packets on just *one* slave device, rather than using the full available bandwidth over all slaves. This patch fixes the problem by *not* unconditionally stopping the queue in ppp_start_xmit(). It adds a return value from ppp_xmit_process() which indicates whether the queue should be stopped or not. It *doesn't* remove the call to netif_wake_queue() from ppp_xmit_process(), because other code paths (especially from ppp_output_wakeup()) need it there and it's messy to push it out to the other callers to do it based on the return value. So we leave it in place — it's a no-op in the case where the queue wasn't stopped, so it's harmless in the TX path. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-04ppp: Replace uses of <linux/if_ppp.h> with <linux/ppp-ioctl.h>Paul Mackerras
Since all that include/linux/if_ppp.h does is #include <linux/ppp-ioctl.h>, this replaces the occurrences of #include <linux/if_ppp.h> with #include <linux/ppp-ioctl.h>. It also corrects an error in Documentation/networking/l2tp.txt, where it referenced include/linux/if_ppp.h as the source of some definitions that are actually now defined in include/linux/if_pppol2tp.h. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-04ppp: Move ioctl definitions from if_ppp.h to new ppp-ioctl.hPaul Mackerras
This moves the definitions of the ioctls, constants and structures relating to the ppp_generic interface to userspace out from if_ppp.h to a new file, ppp-ioctl.h. The new file has my copyright since I designed and implemented the ppp_generic interface in the late 1990s. None of the contents of this file comes from the original if_ppp.h published by Carnegie Mellon University. Of the remainder of if_ppp.h, only the PPP_MTU definition was being used, and this replaces the uses of it with PPP_MRU (which is identical). Therefore, this replaces the entire file with the single line #include <linux/ppp-ioctl.h> which clearly doesn't contain any CMU code. Thus I have removed the CMU copyright notice with its problematic advertising clause, and in fact since it's only one trivial line I have not added any other copyright notice. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-04ppp: Change copyright notices from ANU to mePaul Mackerras
This changes the copyright notices on the PPP code that I developed in the late 1990s from being copyright The Australian National University to copyright Paul Mackerras. I can do this as I have an acknowledgement in writing from the Head of the Computer Science Department at ANU (where I worked then) that ANU does not claim any intellectual property in this code. While I'm at it, change the copyright notice from BSD-style to GNU GPL like the rest of the kernel. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/sfc/rx.c Overlapping changes in drivers/net/ethernet/sfc/rx.c, one to change the rx_buf->is_page boolean into a set of u16 flags, and another to adjust how ->ip_summed is initialized. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-24ppp: fix 'ppp_mp_reconstruct bad seq' errorsBen McKeegan
This patch fixes a (mostly cosmetic) bug introduced by the patch 'ppp: Use SKB queue abstraction interfaces in fragment processing' found here: http://www.spinics.net/lists/netdev/msg153312.html The above patch rewrote and moved the code responsible for cleaning up discarded fragments but the new code does not catch every case where this is necessary. This results in some discarded fragments remaining in the queue, and triggering a 'bad seq' error on the subsequent call to ppp_mp_reconstruct. Fragments are discarded whenever other fragments of the same frame have been lost. This can generate a lot of unwanted and misleading log messages. This patch also adds additional detail to the debug logging to make it clearer which fragments were lost and which other fragments were discarded as a result of losses. (Run pppd with 'kdebug 1' option to enable debug logging.) Signed-off-by: Ben McKeegan <ben@netservers.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-13ppp: fix truesize underestimationEric Dumazet
When building frag_list, head truesize should be sum of all frag truesize. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-31drivers/net: Remove unnecessary k.alloc/v.alloc OOM messagesJoe Perches
alloc failures use dump_stack so emitting an additional out-of-memory message is an unnecessary duplication. Remove the allocation failure messages. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-12pptp: Accept packet with seq zeroBradley Peterson
Initialize the PPTP "seq received" value to 0xffffffff, so we don't ignore packets with seq zero. Signed-off-by: Bradley Peterson <despite@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/freescale/fsl_pq_mdio.c net/batman-adv/translation-table.c net/ipv6/route.c
2011-12-07ppp: fix pptp double release_sock in pptp_bind()Djalal Harouni
Signed-off-by: Djalal Harouni <tixxdz@opendz.org> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-23net: treewide use of RCU_INIT_POINTEREric Dumazet
rcu_assign_pointer(ptr, NULL) can be safely replaced by RCU_INIT_POINTER(ptr, NULL) (old rcu_assign_pointer() macro was testing the NULL value and could omit the smp_wmb(), but this had to be removed because of compiler warnings) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-24Merge branch 'master' of ra.kernel.org:/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2011-09-22Merge branch 'master' of github.com:davem330/netDavid S. Miller
Conflicts: MAINTAINERS drivers/net/Kconfig drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c drivers/net/ethernet/broadcom/tg3.c drivers/net/wireless/iwlwifi/iwl-pci.c drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c drivers/net/wireless/rt2x00/rt2800usb.c drivers/net/wireless/wl12xx/main.c
2011-08-27ppp: Move the PPP driversJeff Kirsher
Move the PPP drivers into drivers/net/ppp/ and make the necessary Kconfig and Makefile changes. CC: Paul Mackerras <paulus@samba.org> CC: Frank Cusack <fcusack@fcusack.com> CC: Michal Ostrowski <mostrows@speakeasy.net> CC: Michal Ostrowski <mostrows@earthlink.net> CC: Dmitry Kozlov <xeb@mail.ru> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
