drivers/net/wireless/ath/ath9k/ar9003_eeprom.c
net/llc/af_llc.c
Cc: netdev@vger.kernel.org
Some aspects of PHY initialization are board dependent, things like
indicator LED connections and some clocking modes cannot be determined
by probing. The dev_flags element of struct phy_device can be used to
control these things if an appropriate value can be passed from the
Ethernet driver. We run into problems however if the PHY connections
are specified by the device tree. There is no way for the Ethernet
driver to know what flags it should pass.
If we are using the device tree, the struct phy_device will be
populated with the device tree node corresponding to the PHY, and we
can extract extra configuration information from there.
The next question is what should the format of that information be?
It is highly device specific, and the device tree representation
should not be tied to any arbitrary kernel defined constants. A
straight forward representation is just to specify the exact bits that
should be set using the "marvell,reg-init" property:
phy5: ethernet-phy@5 {
reg = <5>;
compatible = "marvell,88e1149r";
marvell,reg-init =
/* led[0]:1000, led[1]:100, led[2]:10, led[3]:tx */
<3 0x10 0 0x5777>, /* Reg 3,16 <- 0x5777 */
/* mix %:0, led[0123]:drive low off hiZ */
<3 0x11 0 0x00aa>, /* Reg 3,17 <- 0x00aa */
/* default blink periods. */
<3 0x12 0 0x4105>, /* Reg 3,18 <- 0x4105 */
/* led[4]:rx, led[5]:dplx, led[45]:drive low off hiZ */
<3 0x13 0 0x0a60>; /* Reg 3,19 <- 0x0a60 */
phy6: ethernet-phy@6 {
reg = <6>;
compatible = "marvell,88e1118";
marvell,reg-init =
/* Fix rx and tx clock transition timing */
<2 0x15 0xffcf 0>, /* Reg 2,21 Clear bits 4, 5 */
/* Adjust LED drive. */
<3 0x11 0 0x442a>, /* Reg 3,17 <- 0442a */
/* irq, blink-activity, blink-link */
<3 0x10 0 0x0242>; /* Reg 3,16 <- 0x0242 */
The Marvell PHYs have a page select register at register 22 (0x16), we
can specify any register by its page and register number. These are
the first and second word. The third word contains a mask to be ANDed
with the existing register value, and the fourth word is ORed with the
result to yield the new register value. The new marvell_of_reg_init
function leaves the page select register unchanged, so a call to it
can be dropped into the .config_init functions without unduly
affecting the state of the PHY.
If CONFIG_OF_MDIO is not set, there is no of_node, or no
"marvell,reg-init" property, the PHY initialization is unchanged.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Cyril Chemparathy <cyril@ti.com>
Cc: David Daney <ddaney@caviumnetworks.com>
Cc: Arnaud Patard <arnaud.patard@rtp-net.org>
Reviewed-by: Grant Likely <grant.likely@secretlab.ca>
The 88E1149R is 10/100/1000 quad-gigabit Ethernet PHY. The
.config_aneg function can be shared with 88E1118, but it needs its own
.config_init.
Cc: Wolfram Sang <w.sang@pengutronix.de>
The definition of the Marvell PHY page register is not specific to
88E1121, so rename the macro to MII_MARVELL_PHY_PAGE, and use it
throughout.
Suggested-by: Cyril Chemparathy <cyril@ti.com>
The marvell 88ec048's official part number is 88e1318s. This patch renames
definitions in the driver to reflect this.
In addition, a minor bug fix has been added to write back the MSCR1 register
value properly.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
The following functions are not used directly by any drivers:
phy_attach_direct
phy_device_create
phy_prepare_link
genphy_config_advert
genphy_setup_forced
phy_config_interrupt
phy_clear_interrypt
phy_sanitize_settings
phy_enable_interrupts
phy_disable_interrupts
Commit c477d0447db08068a497e7beb892b2b2a7bff64b added support for RGMII
rx/tx delays except that it ends up clearing rx/tx delays bit for modes
differents that RGMII*ID. Due to this, ethernet is not working anymore
on my guruplug server +. This patch is fixing that.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
The kernel doesn't have a symbol called BCM63XX. There is a symbol
BCM63XX_ENET (introduced in 9b1fc55a0500, 6 weeks after 09bb9aa0ed that
introduced BCM63XX_PHY), but the driver compiles without that, too.
Cc: Maxime Bizon <mbizon@freebox.fr>
Cc: Florian Fainelli <florian@openwrt.org>
MODULE_DEVICE_TABLE only expands to something if it's compiled
for a module. So when building-in support for the phys, the
mdio_device_id tables are unused. Marking them with __maybe_unused
fixes the following warnings:
drivers/net/phy/bcm63xx.c:134: warning: 'bcm63xx_tbl' defined but not used
drivers/net/phy/broadcom.c:933: warning: 'broadcom_tbl' defined but not used
drivers/net/phy/cicada.c:162: warning: 'cicada_tbl' defined but not used
drivers/net/phy/davicom.c:222: warning: 'davicom_tbl' defined but not used
drivers/net/phy/et1011c.c:114: warning: 'et1011c_tbl' defined but not used
drivers/net/phy/icplus.c:137: warning: 'icplus_tbl' defined but not used
drivers/net/phy/lxt.c:226: warning: 'lxt_tbl' defined but not used
drivers/net/phy/marvell.c:724: warning: 'marvell_tbl' defined but not used
drivers/net/phy/micrel.c:234: warning: 'micrel_tbl' defined but not used
drivers/net/phy/national.c:154: warning: 'ns_tbl' defined but not used
drivers/net/phy/qsemi.c:141: warning: 'qs6612_tbl' defined but not used
drivers/net/phy/realtek.c:82: warning: 'realtek_tbl' defined but not used
drivers/net/phy/smsc.c:257: warning: 'smsc_tbl' defined but not used
drivers/net/phy/ste10Xp.c:135: warning: 'ste10Xp_tbl' defined but not used
drivers/net/phy/vitesse.c:195: warning: 'vitesse_tbl' defined but not used
On resume, before starting the PAL state machine, check if the
adjust_link() method is well supplied. If not, this would lead to a
NULL pointer dereference in the phy_state_machine() function.
This scenario can happen if the Ethernet driver call manually the PHY
functions instead of using the PAL state machine. The mv643xx_eth driver
is a such example.
Signed-off-by: Simon Guinot <sguinot@lacie.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
net/ipv4: Eliminate kstrdup memory leak
net/caif/cfrfml.c: use asm/unaligned.h
ax25: missplaced sock_put(sk)
qlge: reset the chip before freeing the buffers
l2tp: test for ethernet header in l2tp_eth_dev_recv()
tcp: select(writefds) don't hang up when a peer close connection
tcp: fix three tcp sysctls tuning
tcp: Combat per-cpu skew in orphan tests.
pxa168_eth: silence gcc warnings
pxa168_eth: update call to phy_mii_ioctl()
pxa168_eth: fix error handling in prope
pxa168_eth: remove unneeded null check
phylib: Fix race between returning phydev and calling adjust_link
caif-driver: add HAS_DMA dependency
3c59x: Fix deadlock between boomerang_interrupt and boomerang_start_tx
qlcnic: fix poll implementation
netxen: fix poll implementation
bridge: netfilter: fix a memory leak
It is possible that phylib will call adjust_link before returning
from {,of_}phy_connect(), which may cause the following [very rare,
though] oops upon reopening the device:
Unable to handle kernel paging request for data at address 0x0000024c
Oops: Kernel access of bad area, sig: 11 [#1]
PREEMPT SMP NR_CPUS=2 LTT NESTING LEVEL : 0
P1021 RDB
Modules linked in:
NIP: c0345dac LR: c0345dac CTR: c0345d84
TASK = dffab6b0[30] 'events/0' THREAD: c0d24000 CPU: 0
NIP [c0345dac] adjust_link+0x28/0x19c
LR [c0345dac] adjust_link+0x28/0x19c
Call Trace:
[c0d25f00] [000045e1] 0x45e1 (unreliable)
[c0d25f30] [c036c158] phy_state_machine+0x3ac/0x554
Here is why. Drivers store phydev in their private structures, e.g.
gianfar driver:
static int init_phy(struct net_device *dev)
priv->phydev = of_phy_connect(...);
So that adjust_link could retrieve it back:
static void adjust_link(struct net_device *dev)
struct phy_device *phydev = priv->phydev;
If the device has been opened before, then phydev->state is set to
PHY_HALTED (or undefined if the driver didn't call phy_stop()).
Now, phy_connect starts the PHY state machine before returning phydev to
the driver:
phy_start_machine(phydev, NULL);
if (phydev->irq > 0)
phy_start_interrupts(phydev);
return phydev;
The time between 'phy_start_machine()' and 'return phydev' is undefined.
The start machine routine delays execution for 1 second, which is enough
for most cases. But under heavy load, or if you're unlucky, it is quite
possible that PHY state machine will execute before phy_connect()
returns, and so adjust_link callback will try to dereference phydev,
which is not yet ready.
To fix the issue, simply initialize the PHY's state to PHY_READY during
phy_attach(). This will ensure that phylib won't call adjust_link before
phy_start().
Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits)
ctcm: rename READ/WRITE defines to avoid redefinitions
claw: rename READ/WRITE defines to avoid redefinitions
phylib: available for any speed ethernet
can: add limit for nframes and clean up signed/unsigned variables
pkt_sched: Check .walk and .leaf class handlers
pkt_sched: Fix sch_sfq vs tc_modify_qdisc oops
caif-spi: Bugfix SPI_DATA_POS settings were inverted.
caif: Bugfix - Increase default headroom size for control channel.
net: make netpoll_rx return bool for !CONFIG_NETPOLL
Bluetooth: Use 3-DH5 payload size for default ERTM max PDU size
Bluetooth: Fix incorrect setting of remote_tx_win for L2CAP ERTM
Bluetooth: Change default L2CAP ERTM retransmit timeout
Bluetooth: Fix endianness issue with L2CAP MPS configuration
net: Use NET_XMIT_SUCCESS where possible.
isdn: mISDN: call pci_disable_device() if pci_probe() failed
isdn: avm: call pci_disable_device() if pci_probe() failed
usbnet: rx_submit() should return an error code.
pkt_sched: Add some basic qdisc class ops verification. Was: [PATCH] sfq: add dummy bind/unbind handles
pkt_sched: sch_sfq: Add dummy unbind_tcf and put handles. Was: [PATCH] sfq: add dummy bind/unbind handles
Several gigabit network drivers (SB1250_MAC, TIGON3, FSL, GIANFAR,
UCC_GETH, MV643XX_ETH, XILINX_LL_TEMAC, S6GMAC, STMMAC_ETH, PASEMI_MAC,
and OCTEON_ETHERNET) select PHYLIB. These drivers are not under
NET_ETHERNET (10/100 mbit), so this warning is generated (long, irrelevant
parts are omitted):
warning: (NET_DSA && NET && EXPERIMENTAL && NET_ETHERNET && !S390 || ... || SB1250_MAC && NETDEVICES && NETDEV_1000 && SIBYTE_SB1xxx_SOC || TIGON3 && NETDEVICES && NETDEV_1000 && PCI || FSL_PQ_MDIO && NETDEVICES && NETDEV_1000 && FSL_SOC || GIANFAR && NETDEVICES && NETDEV_1000 && FSL_SOC || UCC_GETH && NETDEVICES && NETDEV_1000 && QUICC_ENGINE || MV643XX_ETH && NETDEVICES && NETDEV_1000 && (MV64X60 || PPC32 || PLAT_ORION) || XILINX_LL_TEMAC && NETDEVICES && NETDEV_1000 && (PPC || MICROBLAZE) || S6GMAC && NETDEVICES && NETDEV_1000 && XTENSA_VARIANT_S6000 || STMMAC_ETH && NETDEV_1000 && NETDEVICES && CPU_SUBTYPE_ST40 || PASEMI_MAC && NETDEVICES && NETDEV_10000 && PPC_PASEMI && PCI || OCTEON_ETHERNET && STAGING && !STAGING_EXCLUDE_BUILD && CPU_CAVIUM_OCTEON) selects PHYLIB which has unmet direct dependencies (!S390 && NET_ETHERNET)
PHYLIB is used by non-10/100 mbit ethernet drivers, so change the dependencies
to be NETDEVICES instead of NET_ETHERNET.
Fix phy.c kernel-doc notation:
Warning(drivers/net/phy/phy.c:313): No description found for parameter 'ifr'
Warning(drivers/net/phy/phy.c:313): Excess function parameter 'mii_data' description in 'phy_mii_ioctl'
of_device is just an alias for platform_device, so remove it entirely. Also
replace to_of_device() with to_platform_device() and update comment blocks.
This patch was initially generated from the following semantic patch, and then
edited by hand to pick up the bits that coccinelle didn't catch.
-struct of_device
+struct platform_device
Reviewed-by: David S. Miller <davem@davemloft.net>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits)
phy/marvell: add 88ec048 support
igb: Program MDICNFG register prior to PHY init
e1000e: correct MAC-PHY interconnect register offset for 82579
hso: Add new product ID
can: Add driver for esd CAN-USB/2 device
l2tp: fix export of header file for userspace
can-raw: Fix skb_orphan_try handling
Revert "net: remove zap_completion_queue"
net: cleanup inclusion
phy/marvell: add 88e1121 interface mode support
u32: negative offset fix
net: Fix a typo from "dev" to "ndev"
igb: Use irq_synchronize per vector when using MSI-X
ixgbevf: fix null pointer dereference due to filter being set for VLAN 0
e1000e: Fix irq_synchronize in MSI-X case
e1000e: register pm_qos request on hardware activation
ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice
net: Add getsockopt support for TCP thin-streams
cxgb4: update driver version
cxgb4: add new PCI IDs
Manually fix up conflicts in:
- drivers/net/e1000e/netdev.c: due to pm_qos registration
infrastructure changes
- drivers/net/phy/marvell.c: conflict between adding 88ec048 support
and cleaning up the IDs
- drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req
conflict (registration change vs marking it static)
Marvell 88ec048 is a derivative of its 88e1121r device. From the programmer's
perspective, the one major difference is the addition of an additional control
bit in Page 2 Register 16 - used to control the padding of odd nibble
preambles.
This patch adds support for this new device, while inheriting as much code as
possible from the existing 88e1121r implementation.
This patch adds support for RGMII RX/TX delay configuration on marvell 88e1121
and derivatives. With this patch, PHY_INTERFACE_MODE_RGMII_*ID modes are now
supported on these devices.
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
This patch adds a new networking option to allow hardware time stamps
from PHY devices. When enabled, likely candidates among incoming and
outgoing network packets are offered to the PHY driver for possible
time stamping. When accepted by the PHY driver, incoming packets are
deferred for later delivery by the driver.
The patch also adds phylib driver methods for the SIOCSHWTSTAMP ioctl
and callbacks for transmit and receive time stamping. Drivers may
optionally implement these functions.
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
The phy_mii_ioctl() function unnecessarily throws away the original ifreq.
We need access to the ifreq in order to support PHYs that can perform
hardware time stamping.
Two maverick drivers filter the ioctl commands passed to phy_mii_ioctl().
This is unnecessary since phylib will check the command in any case.
This moves the various known Marvell PHY IDs to include/linux/marvell_phy.h
along with dev_flags definitions for use by the driver.
I then added a flag that changes the PHY init code to setup the LEDs
config to the values needed to operate a dns323 rev C1 NAS.
I moved the existing "resistance" flag to the .h as well, though I've
been unable to find whoever sets this to convert it to use that constant.
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
Hello all:
This patch fixes what Ben mentioned, namely duplicated ids.
Body of the explanation: This patch has changes as followings;
-support the interrupt from phy devices from Micrel Inc.
-support more phy devices, ks8737, ks8721, ks8041, ks8051 from Micrel.
-remove vsc8201 because this device was used only internal test at Micrel.
Signed-off-by: David J. Choi <david.choi@micrel.com>
We started getting:
WARNING: vmlinux.o(.data+0x20bd0): Section mismatch in reference from
the variable octeon_mdiobus_driver to the function
.init.text:octeon_mdiobus_probe()
This fixes it.
Commit e13647c1 (phylib: Add support for the LXT973 phy.) added a new ID
but neglected to also add it to the MODULE_DEVICE_TABLE.
This patch adds the 5241 PHY ID to the broadcom module.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Move all PHY IDs to brcmphy.h header for completeness and unification of code.
This patch implements a work around for Erratum 5, "3.3 V Fiber Speed
Selection." If the hardware wiring does not respect this erratum, then
fiber optic mode will not work properly.
Merging in current state of Linus' tree to deal with merge conflicts and
build failures in vio.c after merge.
drivers/i2c/busses/i2c-cpm.c
drivers/i2c/busses/i2c-mpc.c
drivers/net/gianfar.c
Also fixed up one line in arch/powerpc/kernel/vio.c to use the
correct node pointer.
.name, .match_table and .owner are duplicated in both of_platform_driver
and device_driver. This patch is a removes the extra copies from struct
of_platform_driver and converts all users to the device_driver members.
This patch is a pretty mechanical change. The usage model doesn't change
and if any drivers have been missed, or if anything has been fixed up
incorrectly, then it will fail with a compile time error, and the fixup
will be trivial. This patch looks big and scary because it touches so
many files, but it should be pretty safe.
Acked-by: Sean MacLennan <smaclennan@pikatech.com>
The following structure elements duplicate the information in
'struct device.of_node' and so are being eliminated. This patch
makes all readers of these elements use device.of_node instead.
(struct of_device *)->node
(struct dev_archdata *)->prom_node (sparc)
(struct dev_archdata *)->of_node (powerpc & microblaze)
This patch removes from drivers/net/ all the unnecessary
return; statements that precede the last closing brace of
void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
It also does not remove null void functions with return.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
with some cleanups by hand.
Compile tested x86 allmodconfig only.
Documentation/feature-removal-schedule.txt
drivers/net/wireless/ath/ar9170/usb.c
drivers/scsi/iscsi_tcp.c
net/ipv4/ipmr.c
net: Fix FDDI and TR config checks in ipv4 arp and LLC.
IPv4: unresolved multicast route cleanup
mac80211: remove association work when processing deauth request
ar9170: wait for asynchronous firmware loading
ipv4: udp: fix short packet and bad checksum logging
phy: Fix initialization in micrel driver.
sctp: Fix a race between ICMP protocol unreachable and connect()
veth: Dont kfree_skb() after dev_forward_skb()
IPv6: fix IPV6_RECVERR handling of locally-generated errors
net/gianfar: drop recycled skbs on MTU change
iwlwifi: work around passive scan issue
Missing name string in ks8001_driver, so we crash on register.
Reported-by: Ingo Molnar <mingo@elte.hu>
Tested-by: Ingo Molnar <mingo@elte.hu>
FEC: Fix kernel panic in fec_set_mac_address.
ipv6: Fix default multicast hops setting.
net: ep93xx_eth stops receiving packets
drivers/net/phy: micrel phy driver
dm9601: fix phy/eeprom write routine
ppp_generic: handle non-linear skbs when passing them to pppd
ppp_generic: pull 2 bytes so that PPP_PROTO(skb) is valid
net: fix compile error due to double return type in SOCK_DEBUG
net/usb: initiate sync sequence in sierra_net.c driver
net/usb: remove default in Kconfig for sierra_net driver
r8169: Fix rtl8169_rx_interrupt()
e1000e: Fix oops caused by ASPM patch.
net/sb1250: register mdio bus in probe
sctp: Fix skb_over_panic resulting from multiple invalid parameter errors (CVE-2010-1173) (v4)
p54pci: fix bugs in p54p_check_tx_ring
This is the first version of phy driver from Micrel Inc.
In some cases the mdio bus is not enabled at the time of probing.
This prevents anything from working, so we will enable it before
trying to use it, and disable it when the driver is removed.
To: linux-mips@linux-mips.org
To: netdev@vger.kernel.org
To: gregkh@suse.de
Patchwork: http://patchwork.linux-mips.org/patch/1090/
Signed-off-by: Florian Fainelli <ffainelli@freebox.fr>
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
We don't use the normal hotplug mechanism because it doesn't work. It will
load the module some time after the device appears, but that's not good
enough for us -- we need the driver loaded _immediately_ because otherwise
the NIC driver may just abort and then the phy 'device' goes away.
[bwh: s/phy/mdio/ in module alias, kerneldoc for struct mdio_device_id]
Acked-by: Andy Fleming <afleming@freescale.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
IEEE 802.3ae clause 45 specifies a somewhat modified MDIO protocol
for use by 10GIGE phys. The main change is a 21 bit address split into
a 5 bit device ID and a 16 bit register offset. The definition is designed
so that normal and extended devices can run on the same MDIO bus.
Extend mdio-bitbang to do the new protocol. At the MDIO bus level the
protocol is requested by or'ing MII_ADDR_C45 into the register offset.
Make phy_read/phy_write/etc pass a full 32 bit register offset.
This does not attempt to make the phy layer support C45 style PHYs, just
to provide the MDIO bus support.
Tested against a Broadcom 10GE phy with ID 0x206034, and several
Broadcom 10/100/1000 Phys in normal mode.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
This patch pushes phylib definitions out to phylib headers. For phy
IDs, this removes some code duplication.
Signed-off-by: Matt Carlson <mcarlson@broadcom.com>
Reviewed-by: Michael Chan <mchan@broadcom.com>
