path: root/drivers/net/phy/bcm63xx.c
2012-07-09phylib: Support registering a bunch of driversChristian Hohnstaedt
If registering of one of them fails, all already registered drivers of this module will be unregistered. Use the new register/unregister functions in all drivers registering more than one driver. amd.c, realtek.c: Simplify: directly return registration result. Tested with broadcom.c All others compile-tested. Signed-off-by: Christian Hohnstaedt <chohnstaedt@innominate.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-03net:phy:bcm63xx: remove unnecessary codeSrinivas Kandagatla
Compile tested. remove unnecessary code that matches this coccinelle pattern ret = phy_write(x, y , z) if (ret < 0) return ret; return 0; As phy_write returns error code, we dont need to do not need extra check before returning. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05net/phy: fix many "defined but unused" warningsUwe Kleine-König
MODULE_DEVICE_TABLE only expands to something if it's compiled for a module. So when building-in support for the phys, the mdio_device_id tables are unused. Marking them with __maybe_unused fixes the following warnings: drivers/net/phy/bcm63xx.c:134: warning: 'bcm63xx_tbl' defined but not used drivers/net/phy/broadcom.c:933: warning: 'broadcom_tbl' defined but not used drivers/net/phy/cicada.c:162: warning: 'cicada_tbl' defined but not used drivers/net/phy/davicom.c:222: warning: 'davicom_tbl' defined but not used drivers/net/phy/et1011c.c:114: warning: 'et1011c_tbl' defined but not used drivers/net/phy/icplus.c:137: warning: 'icplus_tbl' defined but not used drivers/net/phy/lxt.c:226: warning: 'lxt_tbl' defined but not used drivers/net/phy/marvell.c:724: warning: 'marvell_tbl' defined but not used drivers/net/phy/micrel.c:234: warning: 'micrel_tbl' defined but not used drivers/net/phy/national.c:154: warning: 'ns_tbl' defined but not used drivers/net/phy/qsemi.c:141: warning: 'qs6612_tbl' defined but not used drivers/net/phy/realtek.c:82: warning: 'realtek_tbl' defined but not used drivers/net/phy/smsc.c:257: warning: 'smsc_tbl' defined but not used drivers/net/phy/ste10Xp.c:135: warning: 'ste10Xp_tbl' defined but not used drivers/net/phy/vitesse.c:195: warning: 'vitesse_tbl' defined but not used Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13PHY: fix typo in bcm63xx PHY driver tableFlorian Fainelli
Signed-off-by: Florian Fainelli <ffainelli@freebox.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-02phylib: Add module table to all existing phy driversDavid Woodhouse
Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-07MIPS: BCM63XX: Add integrated ethernet PHY support for phylib.Maxime Bizon
Signed-off-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> drivers/net/phy/Kconfig | 6 ++ drivers/net/phy/Makefile | 1 drivers/net/phy/bcm63xx.c | 132 ++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 139 insertions(+) create mode 100644 drivers/net/phy/bcm63xx.c Signed-off-by: David S. Miller <davem@davemloft.net>
