path: root/drivers/net/pcnet32.c
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-08pcnet32: round off carrier watch timerStephen Hemminger
The link check watchdog timer on this driver fires every two seconds, but since not aligned it causes extra wakeups. It is more important on this driver than most because it is the hardware that is emulated by default when using network interfaces on VMware. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-07pcnet32: update to net_device_opsStephen Hemminger
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-25Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/cpmac.c net/mac80211/mlme.c
2008-05-22pcnet32: fix warningAndrew Morton
pci_name() will be changed to return `const char *': drivers/net/pcnet32.c: In function 'pcnet32_probe1': drivers/net/pcnet32.c:1884: warning: passing argument 2 of 'pcnet32_alloc_ring' discards qualifiers from pointer target type Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-15Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-4965-rs.c drivers/net/wireless/rt2x00/rt61pci.c
2008-05-13[netdrvr] Trim trailing whitespace for several driversJeff Garzik
2008-05-06pcnet32: delete non NAPI code from driver.Don Fry
Delete the non-napi code from the driver and Kconfig. Tested x86_64. Apply at next open opportunity. Signed-off-by: Don Fry <pcnet32@verizon.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-11pcnet32: Use print_macDon Fry
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Don Fry <pcnet32@verizon.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11pcnet32: use NET_IP_ALIGN instead of 2Don Fry
Change hard coded 2 to NET_IP_ALIGN. Added new #define with comments. Tested amd_64 Signed-off-by: Don Fry <pcnet32@verizon.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28netdev: use ARRAY_SIZE() instead of sizeof(array) / ETH_GSTRING_LENAlejandro Martinez Ruiz
Using ARRAY_SIZE() on arrays of the form array[][K] makes it unnecessary to know the value of K when checking its size. Signed-off-by: Alejandro Martinez Ruiz <alex@flawedcode.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-08[NET]: Fix drivers to handle napi_disable() disabling interrupts.David S. Miller
When we add the generic napi_disable_pending() breakout logic to net_rx_action() it means that napi_disable() can cause NAPI poll interrupt events to be disabled. And this is exactly what we want. If a napi_disable() is pending, and we are looping in the ->poll(), we want ->poll() event interrupts to stay disabled and we want to complete the NAPI poll ASAP. When ->poll() break out during device down was being handled on a per-driver basis, often these drivers would turn interrupts back on when '!netif_running()' was detected. And this would just cause a reschedule of the NAPI ->poll() in the interrupt handler before the napi_disable() could get in there and grab the NAPI_STATE_SCHED bit. The vast majority of drivers don't care if napi_disable() might have the side effect of disabling NAPI ->poll() event interrupts. In all such cases, when a napi_disable() is performed, the driver just disabled interrupts or is about to. However there were three exceptions to this in PCNET32, R8169, and SKY2. To fix those cases, at the subsequent napi_enable() points, I added code to ensure that the ->poll() interrupt events are enabled in the hardware. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Don Fry <pcnet32@verizon.net>
2007-10-17pcnet32: remove private net_device_stats structureDon Fry
Remove the statistics from the private structure. Use the net_device_stats in netn_device structure. Following Jeff Garzik's massive cleanup Sep 01. pcnet32 was not "low-hanging fruit". Tested x86_64. Signed-off-by: Don Fry <pcnet32@verizon.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-17pcnet32: remove compile warnings in non-napi modeDon Fry
Remove compile warning when in non-napi mode. Signed-off-by: Don Fry <pcnet32@verizon.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-17pcnet32: fix non-napi packet receptionDon Fry
Recent changes to the driver for the new napi API broke the reception of packets when in non-napi mode. The initialization of napi.weight was removed for the non-napi case leaving the value zero. Tested NAPI and non-NAPI on x86_64. Signed-off-by: Don Fry <pcnet32@verizon.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10pcnet32: endiannessAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[netdrvr] Stop using legacy hooks ->self_test_count, ->get_stats_countJeff Garzik
These have been superceded by the new ->get_sset_count() hook. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[ETHTOOL] Provide default behaviors for a few ethtool sub-ioctlsJeff Garzik
For the operations get-tx-csum get-sg get-tso get-ufo the default ethtool_op_xxx behavior is fine for all drivers, so we permit op==NULL to imply the default behavior. This provides a more uniform behavior across all drivers, eliminating ethtool(8) "ioctl not supported" errors on older drivers that had not been updated for the latest sub-ioctls. The ethtool_op_xxx() functions are left exported, in case anyone wishes to call them directly from a driver-private implementation -- a not-uncommon case. Should an ethtool_op_xxx() helper remain unused for a while, except by net/core/ethtool.c, we can un-export it at a later date. [ Resolved conflicts with set/get value ethtool patch... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10pcnet32: add suspend and resume capabilityDon Fry
Add suspend and resume capability to the driver. Tested both to ram and to disk on x86_64 platform. Signed-off-by: Don Fry <pcnet32@verizon.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[NET]: ethtool_perm_addr only has one implementationMatthew Wilcox
All drivers implement ethtool get_perm_addr the same way -- by calling the generic function. So we can inline the generic function into the caller and avoid going through the drivers. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Kill eth_copy_and_sum().David S. Miller
It hasn't "summed" anything in over 7 years, and it's just a straight mempcy ala skb_copy_to_linear_data() so just get rid of it. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-28pcnet32: change to use netdev_privDon Fry
use netdev_priv() instead of dev->priv Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Don Fry <pcnet32@verizon.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28pcnet32: only allocate init_block dma consistentDon Fry
The patch below moves the init_block out of the private struct and only allocates init block with pci_alloc_consistent. This has two effects: 1. Performance increase for non cache coherent machines, because the CPU only data in the private struct are now cached 2. locks are working now for platforms, which need to have locks in cached memory Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Acked-by: Don Fry <pcnet32@verizon.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-06pcnet32: Fix PCnet32 performance bug on non-coherent architecutresDon Fry
The PCnet32 driver always passed the the size of the largest possible packet to the pci_dma_sync_single_for_cpu and pci_dma_sync_single_for_device. This results in a fairly large "colateral damage" in the caches and makes the flush operation itself much slower. On a system with a 40MHz CPU this patch increases network bandwidth by about 12%. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Don Fry <pcnet32@verizon.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-10-06drivers/net: eliminate irq handler impossible checks, needless castsJeff Garzik
- Eliminate check for irq handler 'dev_id==NULL' where the condition never occurs. - Eliminate needless casts to/from void* Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-13[PATCH] pcnet32: NAPI implementationDon Fry
Implement NAPI changes to pcnet32 driver. Compile default is off. Listed as experimental. Len and Don both worked on a NAPI implementation and have both tested these changes. An e1000 blasting short packets to the pcnet32 will lockup Don's system until the receive storm stops. Without NAPI Len's system watchdog would expire causing the system to reboot. With NAPI the system will stay operational. Tested ia32 and ppc64. Tested '970A, '971, '972, '973, '975, '976, and '978. The Kconfig changes came from Len. Don is to blame for all the others. Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca> Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13[PATCH] pcnet32: break receive routine into two pieces.Don Fry
Breaking the receive frame processing into two routines for greater clarity. Tested ia32 and ppc64. Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13[PATCH] pcnet32: move/create receive and transmit routinesDon Fry
Move the receive routine and create the transmit routine. Tested ia32 and ppc64. Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13[PATCH] pcnet32: magic number cleanupDon Fry
Change some magic numbers to clearer names. A few whitespace changes. Tested ia32 and ppc64. Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13[PATCH] pcnet32: remove unnecessary save/restore register accesses.Don Fry
Delete unnecessary save/restore of rap in interrupt handler and statistics. tested ia32 and ppc64. Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-24Merge branch 'upstream-fixes' into upstreamJeff Garzik
2006-08-24[PATCH] pcnet32: break in 2.6.18-rc1 identifiedDon Fry
A change I made for 2.6.17 and another for 2.6.18 do not work on older pcnet32 chips which I do not have access to. If the chip is a 79C970 or 79C965, do not try and suspend or check the link status. I have tested with a 79C970A, 79C971, 79C972, 79C973, 79C975, 79C976, and 79C978. Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[PATCH] pcnet32: Cleanup rx buffers after loopback test.Don Fry
More cleanup to pcnet32_loopback_test to release receive buffers if device is not up. Created common routine to free rx buffers. Tested ia32 and ppc64 Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[PATCH] pcnet32: Suspend the chip rather than restart when changing ↵Don Fry
multicast/promisc Suspend the chip if possible rather than stop and discard all tx and rx frames, when changing the mcast list or entering/leaving promiscuous mode. Created common pcnet32_suspend routine. Tested ia32 and ppc64 Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[PATCH] pcnet32: Handle memory allocation failures cleanly when resizing ↵Don Fry
tx/rx rings Fix pcnet32_set_ringparam to handle memory allocation errors without leaving the adapter in an inoperative state and null pointers waiting to be dereferenced. Tested ia32 and ppc64. Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[PATCH] pcnet32: Use kcalloc instead of kmalloc and memsetDon Fry
On 2006-03-08 Eric Sesterhenn wrote: converts drivers/net to kzalloc usage. Don Fry modified it to use netif_msg_drv. Tested ia32 and ppc64. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[PATCH] pcnet32: Fix off-by-one in get_ringparamDon Fry
Fix off-by-one in pcnet32_get_ringparam Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[PATCH] pcnet32: Use PCI_DEVICE macroDon Fry
Jon Mason wrote on Thu, 12 Jan 2006 17:07:49 -0600: This patch adds the PCI_DEVICE macro to the pcnet32 driver. This has been tested on my opteron with my "trident" adapter. Don Fry modified it slightly and tested on ia32 and ppc64. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[PATCH] pcnet32: Fix Section mismatch errorDon Fry
Fix Section mismatch error. Tested ia32 and ppc64. Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
