Store physical port number in netxen_adapter structure.
Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com>
This patch #if 0's the no longer used netxen_nic_link_ok().
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Don't count rx dropped packets based on return value of netif_receive_skb(),
which is misleading.
Tested-by: Vernon Mauery <mauery@us.ibm.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
o separate and simpler irq handler for msi interrupts, avoids few checks
than legacy mode.
o avoid redudant tx_has_work() and rx_has_work() checks in interrupt
and napi, which can uncork irq based on racy (lockless) access to tx
and rx ring indices. If we get interrupt, there's sufficient reason to
schedule napi.
o replenish rx ring more often, remove self-imposed threshold rcv_free
that prevents posting rx desc to card. This improves performance in
low memory.
This patch contains the following cleanups:
- static functions in .c files shouldn't be marked inline
- make needlessly global code static
- #if 0 unused code
NetXen: Fix incorrect link status even with switch turned OFF.
NetXen driver failed to accurately indicate when a link is up or down.
This was encountered during failover testing, when the first port
indicated that the link was up even when the 10G switch it was assigned
to in the Bladecenter was turned off completely.
Signed-off by: Wen Xiong <wenxiong@us.ibm.com>
Signed-off by: Mithlesh Thukral <mithlesh@netxen.com>
NetXen: Port Swap feature
This patch will allow a port numbers on the card to be swapped in
host driver. This feature is applicable to cards having more than
1 port.
Signed-off by: Milan Bag <mbag@netxen.com>
NetXen: Removal of redundant function call parameters and bug fixes.
This patch will remove the redundant paramters which were being passed to
many functions since now adapter->portnum can be used.
Signed-off-by: Mithlesh Thukral <mithlesh@netxen.com>
NetXen: Make driver use multiple PCI functions.
This patch will make NetXen driver work with multiple PCI functions. This will
make the usage of memory resources as well as interrupts more independent
among different functions which results in better throughput. This change has
been done after the multiport support is added in firmware.
Have fun.
>From 24f4a1a77431575a9cdfaae25adda85842099f70 Mon Sep 17 00:00:00 2001
Date: Mon, 1 Jan 2007 15:22:56 -0500
Subject: [PATCH] netxen trivial annotations
Signed-off-by: Amit S. Kale <amitkale@netxen.com>
netxen_nic_isr.c | 3 ++-
1 files changed, 2 insertions(+), 1 deletion(-)
NetXen: 1G/10G Ethernet driver updates
- Multiport and newer firmware support
- ioctl interface for user level tools
- Cast error fix for multiport
netxen_nic.h | 281 +++++++++++++++++++++++++-------
netxen_nic_ethtool.c | 12 -
netxen_nic_hw.c | 429 +++++++++++++++++++++++++++++++++++++++++---------
netxen_nic_init.c | 301 ++++++++++++++++++++++++++++++-----
netxen_nic_ioctl.h | 2
netxen_nic_main.c | 260 ++++++++++++++++++------------
netxen_nic_niu.c | 22 +-
netxen_nic_phan_reg.h | 228 ++++++++++++++++----------
9 files changed, 1161 insertions(+), 377 deletions(-)
netxen_nic.h | 56 ++++++++++++++++++++--------------------------
netxen_nic_ethtool.c | 53 +++++++++++++++++++++-----------------------
netxen_nic_hdr.h | 6 ++---
netxen_nic_hw.c | 54 +++++++++++++++++++++------------------------
netxen_nic_hw.h | 10 ++++----
netxen_nic_init.c | 61 +++++++++++++++++++++++++--------------------------
netxen_nic_ioctl.h | 6 ++---
netxen_nic_isr.c | 48 +++++++++++++++++-----------------------
netxen_nic_main.c | 54 +++++++++++++++++----------------------------
netxen_nic_niu.c | 10 ++++----
10 files changed, 165 insertions(+), 193 deletions(-)
NetXen: 1G/10G Ethernet Driver updates
- Temparature monitoring and device control
- Memory footprint reduction
- Driver changes to support newer version of firmware
netxen_nic.h | 165 ++++++++++++++++++++++++++++++++--
netxen_nic_ethtool.c | 89 ++++++++++++------
netxen_nic_hdr.h | 71 +++++++++++++-
netxen_nic_hw.c | 206 +++++++++++++++++++++++++++++--------------
netxen_nic_hw.h | 8 +
netxen_nic_init.c | 239 +++++++++++++++++++++++++++++++++++++++++---------
netxen_nic_ioctl.h | 12 +-
netxen_nic_isr.c | 54 +++++------
netxen_nic_main.c | 121 +++++++++++++++++--------
netxen_nic_niu.c | 172 +++++++++++++++++++++++++++--------
netxen_nic_phan_reg.h | 24 ++++-
11 files changed, 891 insertions(+), 270 deletions(-)
