path: root/drivers/net/ne2k-pci.c
2009-05-03ne2k-pci: use dev->addr_len instead of "6"Jiri Pirko
Spotted a tiny ugliness in a recently posted patch. This patch cuts it out. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> drivers/net/ne2k-pci.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-02ne2k-pci: Do not register device until initialized.Lubomir Rintel
Doing it in reverse order causes uevent to be sent before we have a MAC address, which confuses udev. Signed-off-by: Lubomir Rintel <lkundrak@v3.sk> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26ne2k-pci: fix non-constant printk warningsStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11netdev: add missing set_mac_address hookStephen Hemminger
Many drivers lost the ability to set ethernet address accidently during the net_device_ops conversion. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21ne2k: convert to net_device_opsStephen Hemminger
Convert driver to new net_device_ops. Compile tested only. This required some additional work to export common code ei_XXX. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12netdevice: safe convert to netdev_priv() #part-2Wang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. This patch is a safe convert for netdev->priv to netdev_priv(netdev). Since all of the netdev->priv is only for read. But it is too big to be sent in one mail. I split it to 4 parts and make every part smaller than 100,000 bytes, which is max size allowed by vger. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-17more misannotations: ne2k-pciAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[ETHTOOL] Provide default behaviors for a few ethtool sub-ioctlsJeff Garzik
For the operations get-tx-csum get-sg get-tso get-ufo the default ethtool_op_xxx behavior is fine for all drivers, so we permit op==NULL to imply the default behavior. This provides a more uniform behavior across all drivers, eliminating ethtool(8) "ioctl not supported" errors on older drivers that had not been updated for the latest sub-ioctls. The ethtool_op_xxx() functions are left exported, in case anyone wishes to call them directly from a driver-private implementation -- a not-uncommon case. Should an ethtool_op_xxx() helper remain unused for a while, except by net/core/ethtool.c, we can un-export it at a later date. [ Resolved conflicts with set/get value ethtool patch... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10drivers/net/: all drivers/net/ cleanup with ARRAY_SIZEDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[NET]: ethtool_perm_addr only has one implementationMatthew Wilcox
All drivers implement ethtool get_perm_addr the same way -- by calling the generic function. So we can inline the generic function into the caller and avoid going through the drivers. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-17[netdrvr] eepro100, ne2k-pci: abort resume if pci_enable_device() failsJeff Garzik
2007-05-09remove broken URLs from net drivers' outputMarkus Dahms
Remove broken URLs (www.scyld.com) from network drivers' logging output. URLs in comments and other strings are left intact. Signed-off-by: Markus Dahms <dahms@fh-brandenburg.de> Acked-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Alan Cox <alan@redhat.com> igned-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] use dev_xxx() printk helpers, rather than dev_printk(KERN_xxx, ...Jeff Garzik
Suggested by Jiri Slaby. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] Use dev_printk() when ethernet interface isn't availableJeff Garzik
For messages prior to register_netdev(), prefer dev_printk() because that prints out both our driver name and our [PCI | whatever] bus id. Updates: 8139{cp,too}, b44, bnx2, cassini, {eepro,epic}100, fealnx, hamachi, ne2k-pci, ns83820, pci-skeleton, r8169. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02BUG_ON() Conversion in drivers/net/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-24[PATCH] net: ne2k.c won't compile if pci_clone_list is constHorms
net: ne2k.c won't compile if pci_clone_list is const f71e130966ba429dbd24be08ddbcdf263df9a5ad which (amongst other things) made pci_clone_list in ne2k-pci.c const causes the following compile error. This patch reverses that portion of that changeset drivers/net/ne2k-pci.c:123: error: pci_clone_list causes a section type conflict ~/ gcc --version gcc (GCC) 4.0.3 (Debian 4.0.3-1) ~/ dpkg gcc-4.0 | grep Version Version: 4.0.3-1 Signed-Off-By: Horms <horms@verge.net.au ne2k-pci.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-) cee0890cc97247b6a9decd94f5dc0719ac8f0b1b Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-03Massive net driver const-ification.Arjan van de Ven
2005-10-28[netdrvr] ne2k-pci based card does not support bus-mastering.Komuro
pci_set_master is unnecessary. Signed-off-by: komurojun-mbn@nifty.com Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14[PATCH] ne2k-pci: support ETHTOOL_GPERMADDRJohn W. Linville
Add support for ETHTOOL_GPERMADDR to ne2k-pci. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-11[ACPI] S3 Suspend to RAM: fix driver suspend/resume methodsDavid Shaohua Li
Drivers should do this: .suspend() pci_disable_device() .resume() pci_enable_device() http://bugzilla.kernel.org/show_bug.cgi?id=3469 Signed-off-by: David Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
