This is nicer than the MAC_FMT stuff.
We now have struct net_device_stats embedded in struct net_device,
and the default ->get_stats() hook does the obvious thing for us.
Run through drivers/net/* and remove the driver-local storage of
statistics, and driver-local ->get_stats() hook where applicable.
This was just the low-hanging fruit in drivers/net; plenty more drivers
remain to be updated.
[ Resolved conflicts with napi_struct changes and fix sunqe build
regression... -DaveM ]
Signed-off-by: Jeff Garzik <jeff@garzik.org>
It's been a useless no-op for long enough in 2.6 so I figured it's time to
remove it. The number of people that could object because they're
maintaining unified 2.4 and 2.6 drivers is probably rather small.
[ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ]
To clearly state the intent of copying from linear sk_buffs, _offset being a
overly long variant but interesting for the sake of saving some bytes.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
For the cases where we want to set skb->mac.raw to an offset from skb->data.
Simple cases first, the memmove ones and specially pktgen will be left for later.
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can
later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in
64bit land while possibly keeping it as a pointer on 32bit.
This one touches just the most simple case, next will handle the slightly more
"complex" cases.
Signed-off-by: Ben Collins <ben.collins@ubuntu.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Cc: Jeff Garzik <jeff@garzik.org>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
tr_type_trans(), hippi_type_trans() left as-is.
infrastructure for it.
Let it rip!
