path: root/drivers/net/myri10ge
2009-04-15myr10ge: again fix lro_gen_skb() alignmentStanislaw Gruszka
Add LRO alignment initially committed in 621544eb8c3beaa859c75850f816dd9b056a00a3 ("[LRO]: fix lro_gen_skb() alignment") and removed in 0dcffac1a329be69bab0ac604bf7283737108e68 ("myri10ge: add multislices support") during conversion to multi-slice. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24myri10ge: update firmware headers to 1.4.41Brice Goglin
Update myri10ge firmware headers to firmware version 1.4.41. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-27net: Add skb_record_rx_queue() calls to multiqueue capable drivers.David S. Miller
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-20myri10ge: don't forget pci_disable_device()Brice Goglin
Don't forget to call pci_disable_device() in myri10ge_remove() and when myri10ge_probe() fails. By the way, update the copyright years. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-05myri10ge: print MAC and serial number on probe failureBrice Goglin
To help board identification and diagnosis, print the MAC and serial number on probe failure if they are available. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-26net: Fix warning fallout from recent NAPI interface changes.David S. Miller
When we removed the network device argument from several NAPI interfaces in 908a7a16b852ffd618a9127be8d62432182d81b4 ("net: Remove unused netdev arg from some NAPI interfaces.") several drivers now started getting unused variable warnings. This fixes those up. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-25myri10ge: update driver version to 1.4.4-1.395Brice Goglin
Update myri10ge driver version to 1.4.4-1.395. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-25myri10ge: update firmware headers to 1.4.37Brice Goglin
Update myri10ge firmware headers to 1.4.37: * Make each member of the error/cmd enum an initialized one, so there is a convenient numerical reference to look for reverse conversion. * Add new MXGEFW_CMD_RELAX_RXBUFFER_ALIGNMENT command. * Add new "features" field to mcp_header. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-09myri10ge: check fragmentation in LRO get_frag_header()Brice Goglin
Add a fragmentation check to myri10ge's LRO get_frag_header() callback. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-23myri10ge: update firmware headersBrice Goglin
Update myri10ge firmware headers. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-23myri10ge: update DCA commentsBrice Goglin
Update DCA sections closing comments. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21myri10ge: convert to net_device_opsStephen Hemminger
Convert driver to new net_device_ops. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20myri10ge: remove hardcoded sram_sizeBrice Goglin
Removes the use of a hardcoded sram_size, determine string_spec location from the MCP header instead. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20myri10ge: fix per-slice rx/tx_dropped countersBrice Goglin
Properly attribute transmit and receive drops by incrementing the per-slice counter. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/isdn/i4l/isdn_net.c fs/cifs/connect.c
2008-11-11myri10ge: fix stop/go ordering even moreBrice Goglin
The doorbell writes may be seen out of order by the firmware if they are in WC memory since the tx spin(un)lock does not flush WC writes. Hence if the "stop" is written on a different CPU than the "go", it is possible that the stop will arrive after the go unless we add an explicit memory barrier (and mmiowb() is not enough). It fixes transmit hangs in multi tx queue mode. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/p54/p54common.c
2008-10-31myri10ge: fix stop/go mmio orderingBrice Goglin
Use mmiowb() to ensure "stop" and "go" commands are sent in order on ia64. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-22myri10ge: disable NAPI on failure to setup the interfaceBrice Goglin
Disable NAPI if a failure occurs when setting up the interface. Leaving it enabled could cause a BUG the next time an ifconfig up is issued. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-16[netdrvr] myri10ge, ixgbe: remove broken select INTEL_IOATDMAJeff Garzik
We cannot select INTEL_IOATDMA in Kconfig as soon as MYRI10GE or IXGBE is enabled since the former is not available on all architectures. Just use a Kconfig bool {IXGBE,MYRI10GE}_DCA set to =y when DCA support can actually be built. [myri10ge portion written and signed-off-by] Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-10myri10ge: update driver version number to 1.4.3-1.369Brice Goglin
Update myri10ge driver version number to 1.4.3-1.369. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-09myri10ge: remove over-paranoid queue number modulusBrice Goglin
No need to modulus the queue number in ->hard_start_xmit() since the core is going to do that for you modulus ->real_num_tx_queues. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08myri10ge: add multiqueue TXBrice Goglin
Add multiqueue TX support to myri10ge. [ Removed reference to deprecated CONFIG_NETDEVICES_MULTIQUEUE and NETIF_F_MULTI_QUEUE ] Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-24myri10ge: use DCA if DCA is compiled as a moduleBrice Goglin
Use DCA in myri10ge when CONFIG_DCA_MODULE is set as well. And thus force INTEL_IOATDMA to =y so that DCA=y if we are =y. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-24myri10ge: Rename DCA-related firmware countersBrice Goglin
Rename the cryptic "dca_capable" to "dca_capable_firmware" and "dca_enabled" to "dca_device_present" in the firmware counters. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-24myri10ge: Stop scaring people when DCA is built but absentBrice Goglin
Stop scaring people with what looks like a fatal message when DCA support is compiled into their kernel, but the DCA device is not present. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03[netdrvr] removed unused #include <version.h>Huang Weiyi
The drivers below do not use LINUX_VERSION_CODE nor KERNEL_VERSION. drivers/net/myri10ge/myri10ge.c drivers/net/netxen/netxen_nic_ethtool.c drivers/net/tokenring/lanstreamer.c This patch removes the said #include <version.h>. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-27myri10ge: update version string to 1.4.3-1.358Brice Goglin
Update myri10ge version string to 1.4.3-1.358. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-14myri10ge: myri10ge_fw_name also overrides the rss firmwareBrice Goglin
When myri10ge_fw_name is given, use it to override the rss firmware name as well. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-07myri10ge: set 64bits consistent DMA maskBrice Goglin
Set 64bits consistent DMA mask since it improves performance in some cases. No need to check the return value since it is not required for the driver to work. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-07myri10ge: update firmware headersBrice Goglin
Update myri10ge firmware headers. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-22myri10ge: use ioremap_wcBrice Goglin
Switch to ioremap_wc(). We keep the MTRR code since ioremap_wc() will use UC_MINUS when falling back to uncachable, and thus let the MTRR WC take precedence. Also rename the error path better. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-22myri10ge: remove wcfifoBrice Goglin
Remove the wcfifo since it never gave any performance improvement. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/powerpc/booting-without-of.txt drivers/atm/Makefile drivers/net/fs_enet/fs_enet-main.c drivers/pci/pci-acpi.c net/8021q/vlan.c net/iucv/iucv.c
2008-07-10myri10ge: treat firmware data as constDavid Woodhouse
... which means allocating our own buffer for reading it back. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-06-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/tg3.c drivers/net/wireless/rt2x00/rt2x00dev.c net/mac80211/ieee80211_i.h
2008-05-30myri10ge: add Direct Cache Access supportBrice Goglin
Add I/O AT DCA (Direct Cache Access) support. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30myri10ge: add multislices supportBrice Goglin
Add multi-slice/MSI-X support. By default, a single slice (and the normal firmware) are used. To enable msi-x, multi-slice mode, one must load the driver with myri10ge_max_slices set to either -1, or something larger than 1. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30myri10ge: add routines for multislicesBrice Goglin
Add several routines that multislices support will use. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30myri10ge: update driver versionBrice Goglin
Update myri10ge version to 1.3.99-1.347. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22make myri10ge_get_firmware_capabilities() staticAdrian Bunk
This patch makes the needlessly global myri10ge_get_firmware_capabilities() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13myri10ge: fix the number of interrupt slotsBrice Goglin
Fix a long-standing bug/misunderstanding between the driver and the firmware. The size of the interrupt queue must be set to the number of rx slots (big + small), and it should never have been a tunable. Setting it too small results in chaos. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13myri10ge: cleanup retrieving of firmware capabilitiesBrice Goglin
Add myri10ge_get_firmware_capabilities() to retrieve TSO6 and interrupt slots capabilities from the firmware. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13myri10ge: move data structures into a single sliceBrice Goglin
To prepare and simplify multislice rx support, add a single slice structure and move some fields in there. No functional change yet. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
