path: root/drivers/net/mv643xx_eth.c
2010-09-27mv643xx_eth: Use netif_set_real_num_{rx, tx}_queues()Ben Hutchings
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-23mv643xx_eth: potential null dereferenceDan Carpenter
We assume that "pd" can be null on the previous line, and throughout the function so we should check it here as well. This was introduced by 9b2c2ff7a1c0 "mv643xx_eth: use sw csum for big packets" Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-18net: preserve ifreq parameter when calling generic phy_mii_ioctl().Richard Cochran
The phy_mii_ioctl() function unnecessarily throws away the original ifreq. We need access to the ifreq in order to support PHYs that can perform hardware time stamping. Two maverick drivers filter the ioctl commands passed to phy_mii_ioctl(). This is unnecessary since phylib will check the command in any case. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-07Merge branch 'master' of ↵David S. Miller
2010-06-30ethtool: Change ethtool_op_set_flags to validate flagsBen Hutchings
ethtool_op_set_flags() does not check for unsupported flags, and has no way of doing so. This means it is not suitable for use as a default implementation of ethtool_ops::set_flags. Add a 'supported' parameter specifying the flags that the driver and hardware support, validate the requested flags against this, and change all current callers to pass this parameter. Change some other trivial implementations of ethtool_ops::set_flags to call ethtool_op_set_flags(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-30mv643xx_eth: use sw csum for big packetsSaeed Bishara
Some controllers (KW, Dove) limits the TX IP/layer4 checksum offloading to a max size. Signed-off-by: Saeed Bishara <saeed@marvell.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17drivers/net: Use kzallocJulia Lawall
Use kzalloc rather than the combination of kmalloc and memset. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x,size,flags; statement S; @@ -x = kmalloc(size,flags); +x = kzalloc(size,flags); if (x == NULL) S -memset(x, 0, size); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-26net: convert multiple drivers to use netdev_for_each_mc_addr, part5 V2Jiri Pirko
removed some needless checks and also corrected bug in lp486e (dmi was passed instead of dmi->dmi_addr) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17mv643xx_eth: fix missing validate_addr hookkirjanov@gmail.com
Fix missing validate_addr hook. Signed-off-by: Denis Kirjanov <kirjanov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-25net: use helpers to access uc list V2Jiri Pirko
This patch introduces three macros to work with uc list from net drivers. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07mv643xx_eth: don't include cache padding in rx desc buffer sizeSaeed Bishara
If NET_SKB_PAD is not a multiple of the cache line size, mv643xx_eth allocates a couple of extra bytes at the start of each receive buffer to make the data payload end up on a cache line boundary. These extra bytes are skb_reserve()'d before DMA mapping, so they should not be included in the DMA map byte count (as the mapping is done starting at skb->data), nor should they be included in the receive descriptor buffer size field, or the hardware can end up DMAing beyond the end of the buffer, which can happen if someone sends us a larger-than-MTU sized packet. This problem was introduced in commit 7fd96ce47ff ("mv643xx_eth: rework receive skb cache alignment", May 6 2009), but hasn't appeared to be problematic so far, probably as the main users of mv643xx_eth all have NET_SKB_PAD == L1_CACHE_BYTES. Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08mv643xx_eth: check for valid hw address (resubmit)Denis Kirjanov
Check for valid hw address. Signed-off-by: Denis Kirjanov <kirjanov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29mv643xx: convert to netdev_tx_tDenis Kirjanov
2009-09-11mv643xx_eth.c: remove unused txq_set_wrr()Mikael Pettersson
The txq_set_wrr() function in drivers/net/mv643xx_eth.c is unused, not even referenced under #if 0 or something like that, which results in a compile-time warning: drivers/net/mv643xx_eth.c:1070: warning: 'txq_set_wrr' defined but not used Fix: remove it. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-19mv643xx_eth: fix unicast filter programming in promiscuous modePrabhanjan Sarnaik
The Unicast Promiscious Mode (UPM) bit in the mv643xx_eth port configuration register doesn't do exactly what its name would suggest: setting this bit merely enables reception of all unicast frames with a destination address that differs from our local MAC address in bits [47:4]. In particular, it doesn't have any effect on unicast frames with a destination address that matches our MAC address in bits [47:4] -- these will still be tested against the 16-entry unicast address filter table. Therefore, if the interface is set to promiscuous mode, just setting the unicast promiscuous bit isn't enough -- we need to set all filter bits in the unicast filter table to 1 as well. Reported-by: Sachin Sanap <ssanap@marvell.com> Signed-off-by: Prabhanjan Sarnaik <sarnaik@marvell.com> Tested-by: Siddarth Gore <gores@marvell.com> Tested-by: Mahavir Jain <mjain@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: group address list and its countJiri Pirko
This patch is inspired by patch recently posted by Johannes Berg. Basically what my patch does is to group list and a count of addresses into newly introduced structure netdev_hw_addr_list. This brings us two benefits: 1) struct net_device becames a bit nicer. 2) in the future there will be a possibility to operate with lists independently on netdevices (with exporting right functions). I wanted to introduce this patch before I'll post a multicast lists conversion. Signed-off-by: Jiri Pirko <jpirko@redhat.com> drivers/net/bnx2.c | 4 +- drivers/net/e1000/e1000_main.c | 4 +- drivers/net/ixgbe/ixgbe_main.c | 6 +- drivers/net/mv643xx_eth.c | 2 +- drivers/net/niu.c | 4 +- drivers/net/virtio_net.c | 10 ++-- drivers/s390/net/qeth_l2_main.c | 2 +- include/linux/netdevice.h | 17 +++-- net/core/dev.c | 130 ++++++++++++++++++-------------------- 9 files changed, 89 insertions(+), 90 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: convert unicast addr listJiri Pirko
This patch converts unicast address list to standard list_head using previously introduced struct netdev_hw_addr. It also relaxes the locking. Original spinlock (still used for multicast addresses) is not needed and is no longer used for a protection of this list. All reading and writing takes place under rtnl (with no changes). I also removed a possibility to specify the length of the address while adding or deleting unicast address. It's always dev->addr_len. The convertion touched especially e1000 and ixgbe codes when the change is not so trivial. Signed-off-by: Jiri Pirko <jpirko@redhat.com> drivers/net/bnx2.c | 13 +-- drivers/net/e1000/e1000_main.c | 24 +++-- drivers/net/ixgbe/ixgbe_common.c | 14 ++-- drivers/net/ixgbe/ixgbe_common.h | 4 +- drivers/net/ixgbe/ixgbe_main.c | 6 +- drivers/net/ixgbe/ixgbe_type.h | 4 +- drivers/net/macvlan.c | 11 +- drivers/net/mv643xx_eth.c | 11 +- drivers/net/niu.c | 7 +- drivers/net/virtio_net.c | 7 +- drivers/s390/net/qeth_l2_main.c | 6 +- drivers/scsi/fcoe/fcoe.c | 16 ++-- include/linux/netdevice.h | 18 ++-- net/8021q/vlan.c | 4 +- net/8021q/vlan_dev.c | 10 +- net/core/dev.c | 195 +++++++++++++++++++++++++++----------- net/dsa/slave.c | 10 +- net/packet/af_packet.c | 4 +- 18 files changed, 227 insertions(+), 137 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/scsi/fcoe/fcoe.c
2009-05-17mv643xx_eth: fix PPC DMA breakageGabriel Paubert
After 2.6.29, PPC no more admits passing NULL to the dev parameter of the DMA API. The result is a BUG followed by solid lock-up when the mv643xx_eth driver brings an interface up. The following patch makes the driver work on my Pegasos again; it is mostly a search and replace of NULL by mp->dev->dev.parent in dma allocation/freeing/mapping/unmapping functions. Signed-off-by: Gabriel Paubert <paubert@iram.es> Acked-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-06mv643xx_eth: only unmask RX and TX_END interrupts for available queuesSaeed Bishara
It is not a good idea to blindly unmask the RX and TX_END interrupts for all eight queues on all mv643xx_eth hardware, since some variations of the hardware have less than eight transmit/receive queues, and the RX/TX_END interrupts for the queues they don't have can be in use by other interrupt sources. Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-06mv643xx_eth: rework receive skb cache alignmentLennert Buytenhek
On the platforms that mv643xx_eth is used on, the manual skb->data alignment logic in mv643xx_eth can be simplified, as the only case we need to handle is where NET_SKB_PAD is not a multiple of the cache line size. If this is the case, the extra padding we need can be computed at compile time, while if NET_SKB_PAD _is_ a multiple of the cache line size, the code can be optimised out entirely. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-06mv643xx_eth: minor register definition cleanupLennert Buytenhek
Move the definitions for the SDMA and port serial configuration register values to where all the other register definitions live, and expand the shifts to 32 bit constants. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-06mv643xx_eth: count handling a link event as one unit of napi workLennert Buytenhek
2009-05-06mv643xx_eth: fix variable shadowing sparse warningLennert Buytenhek
2009-04-29mv643xx_eth: 64bit mib counter read fixLennert Buytenhek
On several mv643xx_eth hardware versions, the two 64bit mib counters for 'good octets received' and 'good octets sent' are actually 32bit counters, and reading from the upper half of the register has the same effect as reading from the lower half of the register: an atomic read-and-clear of the entire 32bit counter value. This can under heavy traffic occasionally lead to small numbers being added to the upper half of the 64bit mib counter even though no 32bit wrap has occured. Since we poll the mib counters at least every 30 seconds anyway, we might as well just skip the reads of the upper halves of the hardware counters without breaking the stats, which this patch does. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-29mv643xx_eth: OOM handling fixesLennert Buytenhek
Currently, when OOM occurs during rx ring refill, mv643xx_eth will get into an infinite loop, due to the refill function setting the OOM bit but not clearing the 'rx refill needed' bit for this queue, while the calling function (the NAPI poll handler) will call the refill function in a loop until the 'rx refill needed' bit goes off, without checking the OOM bit. This patch fixes this by checking the OOM bit in the NAPI poll handler before attempting to do rx refill. This means that once OOM occurs, we won't try to do any memory allocations again until the next invocation of the poll handler. While we're at it, change the OOM flag to be a single bit instead of one bit per receive queue since OOM is a system state rather than a per-queue state, and cancel the OOM timer on entry to the NAPI poll handler if it's running to prevent it from firing when we've already come out of OOM. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08mv643xx_eth: don't reset the rx coal timer on interface upLennert Buytenhek
Move SDMA configuration from interface up to port probe, to prevent overwriting the receive coalescing timer value on interface up. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/igb/igb_main.c drivers/net/qlge/qlge_main.c drivers/net/wireless/ath9k/ath9k.h drivers/net/wireless/ath9k/core.h drivers/net/wireless/ath9k/hw.c
2009-03-13mv643xx_eth: fix unicast address filter corruption on mtu changeLennert Buytenhek
When mv643xx_eth_open() is called to up an interface, port_start() will first re-program the unicast address filter, and then re-initialise the PORT_CONFIG register, but that will disable unicast promiscuous mode if it was enabled by the unicast address filter setup. This isn't a problem on ifconfig up, as ->set_rx_mode() will be called shortly afterwards which will program the filters again, but it does trigger when changing the MTU, which calls mv643xx_eth_stop() and then mv643xx_eth_open() by hand to repopulate the receive rings with skbuffs of the new size. Swap the initialisation of the PORT_START register and the call to the unicast filter setup function to fix this. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-24mv643xx_eth: set sane default receive coalescing timeoutLennert Buytenhek
A receive coalescing timeout of 250 usec appears to strike a good balance between allowing enough received frames to be aggregated for LRO to do its job and not allowing the connection to stall due to delaying ACKs to the remote end for too long. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-24mv643xx_eth: move a couple of init actions from ->open() to port probeLennert Buytenhek
Move the netif_carrier_off() call in ->open() to port probe, so that ethtool doesn't report the link as being up before we have up'd the interface. Move initialisation of the rx/tx coalescing timers from ->open() to port probe, so that we don't reset the coalescing timers every time the interface is up'd. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-24mv643xx_eth: convert to net_device_opsLennert Buytenhek
2009-02-24mv643xx_eth: make LRO unconditionalLennert Buytenhek
2009-02-24Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2009-02-18net/mv643xx: don't disable the mib timer too early and lock properlySebastian Siewior
mib_counters_update() also restarts the timer. So the timer is dequeued, the stats are read and then the timer is enqueued again. This is "okay" unless someone unloads the module. The locking here is also broken: mib_counters_update() grabs just a simple spinlock. The only thing the lock is good for is to protect the timer func against other callers namely mv643xx_eth_stop() && mv643xx_eth_get_ethtool_stats(). That means if the spinlock is taken via the ethtool path and than the timer kicks in then the box will lock up. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Acked-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-18net/mv643xx: use GFP_ATOMIC while atomicSebastian Siewior
dev_set_rx_mode() grabs netif_addr_lock_bh(): |BUG: sleeping function called from invalid context at /home/bigeasy/git/cryptodev-2.6/mm/slub.c:1599 |in_atomic(): 1, irqs_disabled(): 0, pid: 859, name: ifconfig |2 locks held by ifconfig/859: | #0: (rtnl_mutex){--..}, at: [<c0239ccc>] rtnl_lock+0x18/0x20 | #1: (_xmit_ETHER){-...}, at: [<c022d094>] dev_set_rx_mode+0x1c/0x30 |[<c029f118>] (dump_stack+0x0/0x14) from [<c003df28>] (__might_sleep+0x11c/0x13c) |[<c003de0c>] (__might_sleep+0x0/0x13c) from [<c00a8854>] (kmem_cache_alloc+0x30/0xd4) | r5:c78093a0 r4:c034a47c |[<c00a8824>] (kmem_cache_alloc+0x0/0xd4) from [<c01a5fd0>] (mv643xx_eth_set_rx_mode+0x70/0x188) |[<c01a5f60>] (mv643xx_eth_set_rx_mode+0x0/0x188) from [<c022ced0>] (__dev_set_rx_mode+0x40/0xac) |[<c022ce90>] (__dev_set_rx_mode+0x0/0xac) from [<c022d09c>] (dev_set_rx_mode+0x24/0x30) | r6:00001043 r5:c78090f8 r4:c7809000 |[<c022d078>] (dev_set_rx_mode+0x0/0x30) from [<c02304c4>] (dev_open+0xe4/0x114) | r5:c7809350 r4:c7809000 |[<c02303e0>] (dev_open+0x0/0x114) from [<c022fd18>] (dev_change_flags+0xb0/0x190) | r5:00000041 r4:c7809000 |[<c022fc68>] (dev_change_flags+0x0/0x190) from [<c0270250>] (devinet_ioctl+0x2f0/0x710) | r7:c7221e70 r6:c7aadb00 r5:00000000 r4:00000001 |[<c026ff60>] (devinet_ioctl+0x0/0x710) from [<c02717c8>] (inet_ioctl+0xd4/0x110) |[<c02716f4>] (inet_ioctl+0x0/0x110) from [<c021fb74>] (sock_ioctl+0x1f4/0x254) | r4:c7242b40 |[<c021f980>] (sock_ioctl+0x0/0x254) from [<c00b8160>] (vfs_ioctl+0x38/0x98) | r6:beec9bb8 r5:00008914 r4:c7242b40 |[<c00b8128>] (vfs_ioctl+0x0/0x98) from [<c00b873c>] (do_vfs_ioctl+0x484/0x4d4) | r6:00008914 r5:c7242b40 r4:c74db1c0 |[<c00b82b8>] (do_vfs_ioctl+0x0/0x4d4) from [<c00b87cc>] (sys_ioctl+0x40/0x64) |[<c00b878c>] (sys_ioctl+0x0/0x64) from [<c00269a0>] (ret_fast_syscall+0x0/0x2c) |[42949399.520000] r7:00000036 r6:beec9c80 r5:00000041 r4:beec9bb8 Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Acked-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15mv643xx_eth: implement Large Receive OffloadLennert Buytenhek
Controlled by a compile-time (Kconfig) option for now, since it isn't a win in all cases. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15mv643xx_eth: allow enabling/disabling tx checksumming via ethtoolLennert Buytenhek
2009-02-15mv643xx_eth: export rx csum get/set methods via ethtoolLennert Buytenhek
2009-02-15mv643xx_eth: implement ethtool rx/tx ring size query and resizingLennert Buytenhek
Rename the mp->default_[rt]x_ring_size variables to ->[rt]x_ring_size, allow them to be read via the standard ethtool ->get_ringparam() op, and add a ->set_ringparam() op to allow resizing them at run time. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15mv643xx_eth: rework interrupt coalescing, and export via ethtoolLennert Buytenhek
This patch: - increases the precision of the receive/transmit interrupt coalescing register value computations by using 64bit temporaries; - adds functions to read the current hardware coalescing register values and convert them back to usecs; - exports the {get,set} {rx,tx} coal methods via the standard ethtool coalescing interface. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15mv643xx_eth: unify ethtool ops for phy'd and phy-less interfacesLennert Buytenhek
It's a waste having two different versions of this structure around when the differences between ethtool ops for phy'd and phy-less interfaces are so minor. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-26net: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-19mv643xx_eth: prevent interrupt storm on ifconfig downGabriel Paubert
Contrary to what the docs say, the 'extended interrupt cause' bit in the interrupt cause register (bit 1) appears to not be maskable on at least some of the mv643xx_eth platforms, making writing zeroes to the interrupt mask register but not the extended interrupt mask register insufficient to stop interrupts from occuring. Therefore, also write zeroes to the extended interrupt mask register when shutting down the port. This fixes the interrupt storm seen on the Pegasos board when shutting down the interface. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-19mv643xx_eth: fix multicast filter programmingLennert Buytenhek
Commit 66e63ffbc04706568d8789cbb00eaa8ddbcae648 ("mv643xx_eth: implement ->set_rx_mode()") cleaned up mv643xx_eth's multicast filter programming, but broke it as well. The non-special multicast filter table (for multicast addresses that are not of the form 01:00:5e:00:00:xx) consists of 256 hash table buckets organised as 64 32-bit words, where the 'accept' bits are in the LSB of each byte, so in bits 24 16 8 0 of each 32-bit word. The old code got this right, but the referenced commit broke this by using bits 3 2 1 0 instead. This commit fixes this up. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-19Revert "mv643xx_eth: use longer DMA bursts".Lennert Buytenhek
This reverts commit cd4ccf76bfd2c36d351e68be7e6a597268f98a1a. On the Pegasos board, we can't do DMA burst that are longer than one cache line. For now, go back to using 32 byte DMA bursts for all mv643xx_eth platforms -- we can switch the ARM-based platforms back to doing long 128 byte bursts in the next development cycle. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Reported-by: Alan Curry <pacman@kosh.dhis.org> Reported-by: Gabriel Paubert <paubert@iram.es> Signed-off-by: David S. Miller <davem@davemloft.net>
