path: root/drivers/net/mlx4
2010-08-24mlx4_en: Fix build warning in mlx4_en_create_rx_ring.David S. Miller
drivers/net/mlx4/en_rx.c: In function ‘mlx4_en_create_rx_ring’: drivers/net/mlx4/en_rx.c:305: warning: label ‘err_map’ defined but not used Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-24mlx4_en: updated driver versionYevgeny Petrilin
Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-24mlx4_en: Moving to work with GROYevgeny Petrilin
2010-08-24mlx4_en: UDP RSS supportYevgeny Petrilin
Adding capability for RSS for UDP traffic, hashing is done based on IP addresses and UDP port number. The support depends on HW/FW capabilities. Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-24mlx4_en: reconfiguring mac address.Yevgeny Petrilin
When Mac address is removed from one port of the CX2 device, the other device should reconfigure its Mac. This fixes an issue with failover, when both ports have the same Mac address, and one of the ports, is closed, the second one stops receiving traffic. (bugzilla #1965 at bugs.openfabrics.org) Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-24mlx4_en: get/set ringsize uses actual ring sizeYevgeny Petrilin
In case that the rings were not fully filled, the report in Ethtool should be according to the actual size that was filled. Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-24mlx4_en: Fixing report in Ethtool get_settingsYevgeny Petrilin
The report now based on query from FW, giving the correct tranciever type and link speed. Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-24mlx4_en: Added self diagnostics test implementationYevgeny Petrilin
The selftest includes 5 features: 1. Interrupt test: Executing commands and receiving command completion on all our interrupt vectors. 2. Link test: Verifying we are connected to valid link partner. 3. Speed test: Check that we negotiated link speed correctly. 4. Registers test: Activate HW health check command. 5. Loopback test: Send a packet on loopback interface and catch it on RX side. Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-24mlx4_en: Validate port up prior to transmittingYevgeny Petrilin
We might try to use resources which were not activated. Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-24mlx4_en: Reporting link state with KERN_INFOYevgeny Petrilin
2010-08-24mlx4_en: Fixed MAX_TX_RINGS definitionYevgeny Petrilin
Defined as sum of default number of TX rings and number of rings used for priority flow control mode. Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-24mlx4_en: performing CLOSE_PORT at the end of tear-down processYevgeny Petrilin
All port's resources should be closed before we give the CLOSE_PORT command to the firmware. Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-24mlx4_en: Setting dev->perm_addr fieldYevgeny Petrilin
2010-08-24mlx4_en: Setting actual RX ring sizeYevgeny Petrilin
When configuring HW resources, the RX ring size that is passed should be the actual size that depends on number of buffers that we succeeded to allocate. The mask for ring size should also be configured accordingly Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-24mlx4_en: Fixed incorrect unmapping on RX flow.Yevgeny Petrilin
When allocating new fragments to replace the ones that would be passed to the stack, The fragments that should be replaced, are the ones that were already used. Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-22mlx4: remove num_lro parameterAmerigo Wang
As suggested by David, this parameter can die, we can use ethtool to turn LRO on/off. Compile tests only. Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17drivers/net: Convert unbounded kzalloc calls to kcallocJoe Perches
These changes may be slightly safer in some instances. There are other kzalloc calls with a multiply, but those calls are typically "small fixed #" * sizeof(some pointer)" and those are not converted. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Luciano Coelho <luciano.coelho@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-15drivers/net/mlx4: Use %pV, pr_<level>, printk_onceJoe Perches
Remove near duplication of format string constants by using the newly introduced vsprintf extention %pV to reduce text by 20k or so. $ size drivers/net/mlx4/built-in.o* text data bss dec hex filename 161367 1866 48784 212017 33c31 drivers/net/mlx4/built-in.o 142621 1866 46248 190735 2e90f drivers/net/mlx4/built-in.o.new Use printk_once as appropriate. Convert printks to pr_<level>, some bare printks now use pr_cont. Remove now unused #define PFX. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-28mlx4: add dynamic LRO disable supportAmerigo Wang
This patch adds dynamic LRO diable support for mlx4 net driver. It also fixes a bug of mlx4, which checks NETIF_F_LRO flag in rx path without rtnl lock. (I don't have mlx4 card, so only did compiling test. Anyone who wants to test this is more than welcome.) This is based on Neil's initial work too, and heavily modified based on Stanislaw's suggestions. Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Neil Horman <nhorman@redhat.com> Acked-by: Neil Horman <nhorman@redhat.com> Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03drivers/net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in drivers/net/ Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-31mlx4_en: use net_device dev_id to indicate port numberEli Cohen
Today, there are no means to know which port of a hardware device a netdev interface uses. struct net_device conatins a field, dev_id, that can be used for that. Use this field to save the port number in ConnectX that is being used by the net device; port numbers are zero based. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/nes: Fix incorrect unlock in nes_process_mac_intr() RDMA/nes: Async event for closed QP causes crash RDMA/nes: Have ethtool read hardware registers for rx/tx stats RDMA/cxgb4: Only insert sq qid in lookup table RDMA/cxgb4: Support IB_WR_READ_WITH_INV opcode RDMA/cxgb4: Set fence flag for inv-local-stag work requests RDMA/cxgb4: Update some HW limits RDMA/cxgb4: Don't limit fastreg page list depth RDMA/cxgb4: Return proper errors in fastreg mr/pbl allocation RDMA/cxgb4: Fix overflow bug in CQ arm RDMA/cxgb4: Optimize CQ overflow detection RDMA/cxgb4: CQ size must be IQ size - 2 RDMA/cxgb4: Register RDMA provider based on LLD state_change events RDMA/cxgb4: Detach from the LLD after unregistering RDMA device IB/ipath: Remove support for QLogic PCIe QLE devices IB/qib: Add new qib driver for QLogic PCIe InfiniBand adapters IB/mad: Make needlessly global mad_sendq_size/mad_recvq_size static IB/core: Allow device-specific per-port sysfs files mlx4_core: Clean up mlx4_alloc_icm() a bit mlx4_core: Fix possible chunk sg list overflow in mlx4_alloc_icm()
2010-05-21drivers/base: Convert dev->sem to mutexThomas Gleixner
The semaphore is semantically a mutex. Convert it to a real mutex and fix up a few places where code was relying on semaphore.h to be included by device.h, as well as the users of the trylock function, as that value is now reversed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20mlx4_core: Clean up mlx4_alloc_icm() a bitRoland Dreier
Handle the allocation error case first, so that we don't have further nested if for handling the common case of success. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-05-20mlx4_core: Fix possible chunk sg list overflow in mlx4_alloc_icm()Sebastien Dugue
If the number of sg entries in the ICM chunk reaches MLX4_ICM_CHUNK_LEN, we must set chunk to NULL even for coherent mappings so that the next time through the loop will allocate another chunk. Otherwise we'll overflow the sg list the next time through the loop. This will lead to memory corruption if this case is hit. mthca does not have this bug. Signed-off-by: Sebastien Dugue <sebastien.dugue@bull.net> Cc: <stable@kernel.org> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-05-17drivers/net: remove useless semicolonsJoe Perches
switch and while statements don't need semicolons at end of statement [ Fixup minor conflicts with recent wimax merge... -DaveM ] Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bonding/bond_main.c drivers/net/via-velocity.c drivers/net/wireless/iwlwifi/iwl-agn.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24net/various: remove trailing space in messagesFrans Pop
Signed-off-by: Frans Pop <elendil@planet.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-19sysfs: fix sysfs lockdep warning in mlx4 codeGreg Kroah-Hartman
This fixes a sysfs lockdep warning in the mlx4 code. Cc: Yinghai Lu <yinghai@kernel.org> Cc: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-16net: convert multiple drivers to use netdev_for_each_mc_addr, part7Jiri Pirko
In mlx4, using char * to store mc address in private structure instead. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-19mlx4: replace the dma_sync_single_range_for_cpu/device APIFUJITA Tomonori
There are only two users of the dma_sync_single_range_for_cpu/device API in mainline (mlx4 and ssb). The dma_sync_single_range_for_cpu/device API has never been documented and the dma_sync_single_for_cpu/device API also support a partial sync. This converts mlx4 to use the dma_sync_single_for_cpu/device API (preparations for the removal of the dma_sync_single_range_for_cpu/device API). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23Merge branch 'master' of ↵David S. Miller
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-06mlx4_core: Fix cleanup in __mlx4_init_one() error pathEli Cohen
If mlx4_init_port_info() fails, cleanup the initialized ports only. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-12-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (26 commits) net: sh_eth alignment fix for sh7724 using NET_IP_ALIGN V2 ixgbe: allow tx of pre-formatted vlan tagged packets ixgbe: Fix 82598 premature copper PHY link indicatation ixgbe: Fix tx_restart_queue/non_eop_desc statistics counters bcm63xx_enet: fix compilation failure after get_stats_count removal packet: dont call sleeping functions while holding rcu_read_lock() tcp: Revert per-route SACK/DSACK/TIMESTAMP changes. ipvs: zero usvc and udest netfilter: fix crashes in bridge netfilter caused by fragment jumps ipv6: reassembly: use seperate reassembly queues for conntrack and local delivery sky2: leave PCI config space writeable sky2: print Optima chip name x25: Update maintainer. ipvs: fix synchronization on connection close netfilter: xtables: document minimal required version drivers/net/bonding/: : use pr_fmt can: CAN_MCP251X should depend on HAS_DMA drivers/net/usb: Correct code taking the size of a pointer drivers/net/cpmac.c: Correct code taking the size of a pointer drivers/net/sfc: Correct code taking the size of a pointer ...
2009-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (45 commits) RDMA/cxgb3: Fix error paths in post_send and post_recv RDMA/nes: Fix stale ARP issue RDMA/nes: FIN during MPA startup causes timeout RDMA/nes: Free kmap() resources RDMA/nes: Check for zero STag RDMA/nes: Fix Xansation test crash on cm_node ref_count RDMA/nes: Abnormal listener exit causes loopback node crash RDMA/nes: Fix crash in nes_accept() RDMA/nes: Resource not freed for REJECTed connections RDMA/nes: MPA request/response error checking RDMA/nes: Fix query of ORD values RDMA/nes: Fix MAX_CM_BUFFER define RDMA/nes: Pass correct size to ioremap_nocache() RDMA/nes: Update copyright and branding string RDMA/nes: Add max_cqe check to nes_create_cq() RDMA/nes: Clean up struct nes_qp RDMA/nes: Implement IB_SIGNAL_ALL_WR as an iWARP extension RDMA/nes: Add additional SFP+ PHY uC status check and PHY reset RDMA/nes: Correct fast memory registration implementation IB/ehca: Fix error paths in post_send and post_recv ...
2009-12-16mlx4: use bitmap_find_next_zero_areaAkinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Reviewed-by: Roland Dreier <rolandd@cisco.com> Cc: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-13mlx4_core: return a negative error valueroel kluin
The return value should be negative. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-12mlx4_core: Fix parsing of reserved EQ capYevgeny Petrilin
Value returned by firmware is the actual value, not a log. Signed-off-by: Liran Liss <liranl@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-11-12IB/mlx4: Remove limitation on LSO header sizeEli Cohen
Current code has a limitation: an LSO header is not allowed to cross a 64 byte boundary. This patch removes this limitation by setting the WQE RR for large headers thus allowing LSO headers of any size. The extra buffer reserved for MLX4_IB_QP_LSO QPs has been doubled, from 64 to 128 bytes, assuming this is reasonable upper limit for header length. Also, this patch will cause IB_DEVICE_UD_TSO to be set only for HCA FW versions that set MLX4_DEV_CAP_FLAG_BLH; e.g. FW version 2.6.000 and higher. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-10-14mlx4_core: Add a new supported 40 GigE device IDEli Cohen
Add MT26438 (ConnectX EN 40GigE PCIe 2.0 5GT/s) to the list of supported devices. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-10-07mlx4_core: Add 40GigE device IDYevgeny Petrilin
Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-09-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IPoIB: Don't turn on carrier for a non-active port IB/mthca: Fix access to freed memory in catastrophic event handling mlx4_core: Pass cache line size to device FW RDMA/nes: Remove duplicate .ndo_set_mac_address field initialization IB/mad: Fix lock-lock-timer deadlock in RMPP code
2009-09-24mlx4_core: Pass cache line size to device FWEli Cohen
ConnectX can work more efficiently if the CPU cache line size is passed to it with the INIT_HCA firmware command. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-09-16mlx4: Fix access to freed memoryVitaliy Gusev
catas_reset() uses pointer to mlx4_priv, but mlx4_priv is not valid after call mlx4_restart_one(). Signed-off-by: Vitaliy Gusev <vgusev@openvz.org> Acked-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: David S. Miller <davem@davemloft.net>
