path: root/drivers/net/irda
2008-02-03Spelling fixes: lenght->lengthPaulius Zaleckas
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-28[IrDA]: Irport removal - part 2Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IrDA]: Irport removal - part 1Adrian Bunk
This patch removes IrPORT and the old dongle drivers (all off them have replacement drivers). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[netdrvr] irq handler minor cleanups in several driversJeff Garzik
* use irq_handler_t where appropriate * no need to use 'irq' function arg, its already stored in a data struct * rename irq handler 'irq' argument to 'dummy', where the function has been analyzed and proven not to use its first argument. * remove always-false "dev_id == NULL" test from irq handlers * remove pointless casts from void* * declance: irq argument is not const * add KERN_xxx printk prefix * fix minor whitespace weirdness Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-12-16[IRDA]: stir4200 fixes.Olaf Hartmann
From: Olaf Hartmann <olaf.hartmann@s1998.tu-chemnitz.de> The attached patch observes the stir4200 fifo size and will clear the fifo, if the size is increasing, while it should be transmitting bytes Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-16[IRDA]: mcs7780 needs to free allocated rx buffer.Hinko Kocevar
While testing the mcs7780 based IrDA USB dongle I've stumbled upon memory leak in mcs_net_close(). Patch below fixes it. Signed-off-by: Hinko Kocevar <hinko.kocevar@cetrtapot.si> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-16[IRDA]: Race between open and disconnect in irda-usb.Oliver Neukum
It seems to me that irda_usb_net_open() must set self->netopen under spinlock or disconnect() may fail to kill all URBs, if it is called while an interface is opened. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-07[TTY]: Use tty_mode_ioctl() in network drivers.Alan Cox
We conciously make a change here - we permit mode and speed setting to be done in things like SLIP mode. There isn't actually a technical reason to disallow this. It's usually a silly thing to do but we can do it and soemone might wish to do so. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-29drivers/net/irda/au1k_ir: fix obvious irq handler bugsJeff Garzik
interrupt handlers return a return value these days. Also, kill always-true test and unneeded void* cast. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-15Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (95 commits) [ARM] 4578/1: CM-x270: PCMCIA support [ARM] 4577/1: ITE 8152 PCI bridge support [ARM] 4576/1: CM-X270 machine support [ARM] pxa: Avoid pxa_gpio_mode() in gpio_direction_{in,out}put() [ARM] pxa: move pxa_set_mode() from pxa2xx_mainstone.c to mainstone.c [ARM] pxa: move pxa_set_mode() from pxa2xx_lubbock.c to lubbock.c [ARM] pxa: Make cpu_is_pxaXXX dependent on configuration symbols [ARM] pxa: PXA3xx base support [NET] smc91x: fix PXA DMA support code [SERIAL] Fix console initialisation ordering [ARM] pxa: tidy up arch/arm/mach-pxa/Makefile [ARM] Update arch/arm/Kconfig for drivers/Kconfig changes [ARM] 4600/1: fix kernel build failure with build-id-supporting binutils [ARM] 4599/1: Preserve ATAG list for use with kexec (2.6.23) [ARM] Rename consistent_sync() as dma_cache_maint() [ARM] 4572/1: ep93xx: add cirrus logic edb9307 support [ARM] 4596/1: S3C2412: Correct IRQs for SDI+CF and add decoding support [ARM] 4595/1: ns9xxx: define registers as void __iomem * instead of volatile u32 [ARM] 4594/1: ns9xxx: use the new gpio functions [ARM] 4593/1: ns9xxx: implement generic clockevents ...
2007-10-15netdev: convert non-obvious instances to use ARRAY_SIZE()Alejandro Martinez Ruiz
This will convert remaining non-obvious or naive calculations of array sizes to use ARRAY_SIZE() macro. Signed-off-by: Alejandro Martinez Ruiz <alex@flawedcode.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[ARM] pxa: update pxa irda driver to use clk supportRussell King
2007-10-10[IRDA]: Oops fix for ksdazzleAlex Villacís Lasso
This fixes a kernel oops triggered by the ksdazzle SIR driver. We need more space for input frames, and 2048 should be plenty of it. Signed-off-by: Alex Villacís Lasso <a_villacis@palosanto.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IRDA]: Document the fact that smsc-ircc2 will not use PNP by defaultJonathan Bastien-Filiatrault
This avoids user confusion when they see that their device is not detected. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10drivers/net/irda: endianness, NULL noiseAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10drivers/net/: all drivers/net/ cleanup with ARRAY_SIZEDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10Clean up duplicate includes in drivers/net/Jesper Juhl
This patch cleans up duplicate includes in drivers/net/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[IrDA]: Kingsun KS-959 IrDA USB driverAlex Villacís Lasso
This dongle does not follow the usb-irda specification, so it needs its own special driver. First, it uses control URBs for data transfer, instead of bulk or interrupt transfers; the only interrupt endpoint exposed seems to be a dummy to prevent the interface from being rejected. Second, it uses obfuscation and padding at the USB traffic level, for no apparent reason other than to make reverse engineering harder (full details on obfuscation in comments at beginning of source). Although it is advertised as a "4 Mbps FIR dongle", it apparently loses packets at speeds greater than 57600 bps. On plugin, this dongle reports vendor and device IDs: 0x07d0:0x4959 . The Windows driver that is used normally to control this dongle has a filename of KS-959.SYS . Signed-off-by: Alex Villacís Lasso <a_villacis@palosanto.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IrDA]: Kingsun Dazzle IrDA USB driverAlex Villacís Lasso
This dongle does not follow the usb-irda specification, so it needs its own special driver. Just like the Kingsun/Donshine dongle, it exposes two interrupt endpoints. Reception is performed through direct reads from the input endpoint. Transmission requires splitting the IrDA frames into 8-byte segments, in which the first byte encodes how many of the remaining 7 bytes are used as data. Speed change is made with a control URB just like the one in cypress_m8, and it seems to support up to 115200 bps. On plugin, this dongle reports vendor and device IDs: 0x07d0:0x4100 Signed-off-by: Alex Villacís Lasso <a_villacis@palosanto.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-26[IRDA]: Do not do pointless kmalloc return value cast in KingSun driverJesper Juhl
kmalloc() returns a void pointer, so there is no need to cast it in drivers/net/irda/kingsun-sir.c::kingsun_probe(). Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-13[IRDA] irda-usb.c: mostly kmalloc + memset conversion to k[cz]allocMariusz Kozlowski
drivers/net/irda/irda-usb.c | 59694 -> 59541 (-153 bytes) drivers/net/irda/irda-usb.o | 170588 -> 169256 (-1332 bytes) Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-21[IrDA]: TOSHIBA_FIR depends on virt_to_busStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-21[IrDA]: EP7211 IR driver port to the latest SIR APISamuel Ortiz
The EP7211 SIR driver was the only one left without a new SIR API port. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10[IRDA]: use mutex instead of semaphore in VLSI 82C147 IrDA controller driverMatthias Kaehlcke
The VLSI 82C147 IrDA controller driver uses a semaphore as mutex. Use the mutex API instead of the (binary) semaphore. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[IrDA]: kingsun-sir.c charset fix.Samuel Ortiz
2007-07-01smsc-ircc2: bypass PNP detection until we get the quirks worked outBjorn Helgaas
Don't use PNP detection by default yet. We have some PNP and BIOS issues to work out first. Sample problem on a Toshiba Portege 4000: the SMCf010 device is handed off disabled. We assign I/O ports originally assigned to the SMCf010 to a PCMCIA device instead. We enable the SMCf010, configuring it to use disjoint ports, but _SRS doesn't work correctly, so the device doesn't work. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-29Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [IRDA]: fix printk format [NETPOLL] netconsole: fix soft lockup when removing module [NETPOLL]: tx lock deadlock fix SCTP: lock_sock_nested in sctp_sock_migrate SCTP: Fix sctp_getsockopt_get_peer_addrs SCTP: update sctp_getsockopt helpers to allow oversized buffers
2007-06-28[IRDA]: fix printk formatRandy Dunlap
Fix printk format warning: drivers/net/irda/irport.c:512: warning: format '%d' expects type 'int', but argument 5 has type 'long int' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-28smsc-ircc2: skip preconfiguration for PNP devicesBjorn Helgaas
If we rely on the device resources from PNPBIOS, we also have to rely on the BIOS to configure any bridges on the way to the device. Using the PNPBIOS resources but changing the configuration of a bridge behind the back of the firmware is likely to make things inconsistent. This patch addresses part of the 2.6.22 regression: "no irda0 interface (2.6.21 was OK), smsc does not find chip" It fixes smsc-ircc2 PNP device detection on HP nx5000 laptops. Other laptops, including HP nc6000, HP nc8000, HP nw8000, and Toshiba Portege 4000, still need PNP quirks to make this work. With "smsc-ircc2.nopnp", we do the legacy device probe, including manual bridge preconfiguration, as before. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Samuel Ortiz <samuel@sortiz.org> Acked-by: "Linus Walleij (LD/EAB)" <linus.walleij@ericsson.com> Cc: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10[IrDA]: KingSun/DonShine USB IrDA dongle support.Alex Villac�s Lasso
This dongle does not follow the usb-irda specification, so it needs its own special driver. In addition, it uses interrupt endpoints instead of bulk ones as the rest of USB IrDA dongles supported by Linux (just to be different?) and data reads need to be parsed to extract the valid bytes before being unwrapped (details in the comment at the start of the source). No speed commands have been discovered for this dongle, and I suspect it does not have any at all. On plugin, this dongle reports vendor and device IDs: 0x07c0:0x4200 . The Windows driver that is used normally to control this dongle has a filename of DSIR620.SYS . Signed-off-by: Alex Villac�s Lasso <a_villacis@palosanto.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-09Fix misspellings collected by members of KJ list.Robert P. J. Day
Fix the misspellings of "propogate", "writting" and (oh, the shame :-) "kenrel" in the source tree. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08smsc-ircc2: add PNP supportBjorn Helgaas
Claim devices using PNP, unless the user explicitly specified device addresses. This can be disabled with the "smsc-ircc2.nopnp" option. This removes the need for probing legacy addresses and helps untangle IR devices from serial8250 devices. Sometimes the SMC device is at a legacy COM port address but does not use the legacy COM IRQ. In this case, claiming the device using PNP rather than 8250 legacy probe means we can automatically use the correct IRQ rather than forcing the user to use "setserial" to set the IRQ manually. If the PNP claim doesn't work, make sure you don't have a setserial init script, e.g., /etc/init.d/setserial, configured to poke in legacy COM port resources for the IRDA device. That causes the serial driver to claim resources needed by this driver. Based on this patch by Ville Syrjälä: http://www.hpl.hp.com/personal/Jean_Tourrilhes/IrDA/ir260_smsc_pnp.diff Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Keith Owens <kaos@ocs.com.au> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Matthieu CASTET <castet.matthieu@free.fr> Cc: Jean Tourrilhes <jt@hpl.hp.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Russell King <rmk+serial@arm.linux.org.uk> Acked-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08smsc-ircc2: tidy up module parameter checkingBjorn Helgaas
To determine whether the user specified a module parameter, use some #defines instead of checking for bare magic numbers. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Keith Owens <kaos@ocs.com.au> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Matthieu CASTET <castet.matthieu@free.fr> Cc: Jean Tourrilhes <jt@hpl.hp.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Russell King <rmk+serial@arm.linux.org.uk> Cc: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-06Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (82 commits) [ARM] Add comments marking in-use ptrace numbers [ARM] Move syscall saving out of the way of utrace [ARM] 4360/1: S3C24XX: regs-udc.h remove unused macro [ARM] 4358/1: S3C24XX: mach-qt2410.c: remove linux/mmc/protocol.h header [ARM] mm 10: allow memory type to be specified with ioremap [ARM] mm 9: add additional device memory types [ARM] mm 8: define mem_types table L1 bit 4 to be for ARMv6 [ARM] iop: add missing parens in macro [ARM] mm 7: remove duplicated __ioremap() prototypes ARM: OMAP: fix OMAP1 mpuio suspend/resume oops ARM: OMAP: MPUIO wake updates ARM: OMAP: speed up gpio irq handling ARM: OMAP: plat-omap changes for 2430 SDP ARM: OMAP: gpio object shrinkage, cleanup ARM: OMAP: /sys/kernel/debug/omap_gpio ARM: OMAP: Implement workaround for GPIO wakeup bug in OMAP2420 silicon ARM: OMAP: Enable 24xx GPIO autoidling [ARM] 4318/2: DSM-G600 Board Support [ARM] 4227/1: minor head.S fixups [ARM] 4328/1: Move i.MX UART regs to driver ...
2007-04-25[IrDA]: Adding carriage returns to mcs7780 debug statementsSamuel Ortiz
2007-04-25[SK_BUFF]: Introduce skb_copy_to_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying to linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[IrDA]: SMC SuperIO Chip LPC47N227 not identified properlyPeter Kovar
SMC SuperIO Chip LPC47N227 used for IrDA is not detected because its device identification byte can be 0x7A instead of 0x5A. Patch from Peter Kovar <peter.kovar@gmail.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IrDA]: removing stir4200 useless includeSamuel Ortiz
stir4200 doesn't need to include irlap.h Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_mac_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-21[ARM] 4304/1: removes the unnecessary bit number from CKENnn_XXXXEric Miao
This patch removes the unnecessary bit number from CKENnn_XXXX definitions for PXA, so that CKEN0_PWM0 --> CKEN_PWM0 CKEN1_PWM1 --> CKEN_PWM1 ... CKEN24_CAMERA --> CKEN_CAMERA The reasons for the change of these defitions are: 1. they do not scale - they are currently valid for pxa2xx, but definitely not valid for pxa3xx, e.g., pxa3xx has bit 3 for camera instead of bit 24 2. they are unnecessary - the peripheral name within the definition has already announced its usage, we don't need those bit numbers to know which peripheral we are going to enable/disable clock for 3. they are inconvenient - think about this: a driver programmer for pxa has to remember which bit in the CKEN register to turn on/off Another change in the patch is to make the definitions equal to its clock bit index, so that #define CKEN_CAMERA (24) instead of #define CKEN_CAMERA (1 << 24) this change, however, will add a run-time bit shift operation in pxa_set_cken(), but the benefit of this change is that it scales when bit index exceeds 32, e.g., pxa3xx has two registers CKENA and CKENB, totally 64 bit for this, suppose CAMERA clock enabling bit is CKENB:10, one can simply define CKEN_CAMERA to be (32 + 10) and so that pxa_set_cken() need minimum change to adapt to that. Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-01[ARM] 4295/2: Fix error-handling in pxaficp_ir.c (version 2)Guennadi Liakhovetski
This patch addresses the following issues with the pxa2xx FIr driver: 1. increment overrun error counter and not frame error counter on ICSR1_ROR bit set in ICSR1. 2. drop frames reported with the frame error from the IC. 3. when resetting the receiver and preparing it for the next DMA in pxa_irda_fir_irq() actually clear the Rx FIFO. See description in Table 11-2 in PXA270 Developer's Manual of the RXE bit. Correction added in version 2: clearing the IC Rx FIFO also has to be done in pxa_irda_fir_dma_tx_irq() Signed-off-by: G. Liakhovetski <gl@dsa-ac.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-20[IrDA]: Delay needed when uploading firmware chunksNigel Williams
With 42101001.sb firmwares, we need a 10 ms delay between firmware chunks upload on irda-usb. Patch from Nigel Williams <nigelw@elder-gods.net> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 5Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
