Port rel_imx_2.6.26_3.3.0 to 2.6.28.
PMIC Regulator and ASoC drivers are removed and not yet ported.
Updated asm/arch headers for move to plat-mxc/include/mach
device_create parameters changed.
sysdev attribute functions changed.
Adopt mainline MX3 timer code and update clock init flow.
Signed-off-by: Rob Herring <r.herring@freescale.com>
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
USB should not be having it's own printk macros, so remove info() and
use the system-wide standard of dev_info() wherever possible.
Cc: Jeff Garzik <jgarzik@pobox.com>
USB should not be having it's own printk macros, so remove warn() and
use the system-wide standard of dev_warn() wherever possible. In the
few places that will not work out, use a basic printk().
Straight forward conversions to CONFIG_MODULE; many drivers
include <linux/kmod.h> conditionally and then don't have any
other conditional code so remove it from those.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Cc: video4linux-list@redhat.com
Cc: linux-ppp@vger.kernel.org
Cc: dm-devel@redhat.com
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (236 commits)
[ARM] 5300/1: fixup spitz reset during boot
[ARM] 5295/1: make ZONE_DMA optional
[ARM] 5239/1: Palm Zire 72 power management support
[ARM] 5298/1: Drop desc_handle_irq()
[ARM] 5297/1: [KS8695] Fix two compile-time warnings
[ARM] 5296/1: [KS8695] Replace macro's with trailing underscores.
[ARM] pxa: allow multi-machine PCMCIA builds
[ARM] pxa: add preliminary CPUFREQ support for PXA3xx
[ARM] pxa: add missing ACCR bit definitions to pxa3xx-regs.h
[ARM] pxa: rename cpu-pxa.c to cpufreq-pxa2xx.c
[ARM] pxa/zylonite: add support for USB OHCI
[ARM] ohci-pxa27x: use ioremap() and offset for register access
[ARM] ohci-pxa27x: introduce pxa27x_clear_otgph()
[ARM] ohci-pxa27x: use platform_get_{irq,resource} for the resource
[ARM] ohci-pxa27x: move OHCI controller specific registers into the driver
[ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registers
[ARM] pxa: move I2S register and bit definitions into pxa2xx-i2s.c
[ARM] pxa: simplify DMA register definitions
[ARM] pxa: make additional DCSR bits valid for PXA3xx
[ARM] pxa: move i2c register and bit definitions into i2c-pxa.c
Fixed up conflicts in
arch/arm/mach-versatile/core.c
sound/soc/pxa/pxa2xx-ac97.c
sound/soc/pxa/pxa2xx-i2s.c
manually.
1. DRCMRxx is no longer recommended, use DRCMR(xx) instead, and
pass DRCMR index by "struct resource" if possible
2. DCSRxx, DDADRxx, DSADRxx, DTADRxx, DCMDxx is never used, use
DCSR(), DDADR(), DSADR(), DTADR(), DCMD() instead
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Acked-by: Nicolas Pitre <nico@cam.org>
Use "[%04x:%04x]" for PCI vendor/device IDs to follow the format used by
lspci(8).
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This is necessary to set the dongle type on the nsc driver in order to get
it to work correctly. Thinkpads all appear to use dongle type 9. This
patch defaults nsc devices with an IBM PnP descriptor to use type 9.
Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org>
Signed-off-by: Ben Collins <ben.collins@canonical.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (1232 commits)
iucv: Fix bad merging.
net_sched: Add size table for qdiscs
net_sched: Add accessor function for packet length for qdiscs
net_sched: Add qdisc_enqueue wrapper
highmem: Export totalhigh_pages.
ipv6 mcast: Omit redundant address family checks in ip6_mc_source().
net: Use standard structures for generic socket address structures.
ipv6 netns: Make several "global" sysctl variables namespace aware.
netns: Use net_eq() to compare net-namespaces for optimization.
ipv6: remove unused macros from net/ipv6.h
ipv6: remove unused parameter from ip6_ra_control
tcp: fix kernel panic with listening_get_next
tcp: Remove redundant checks when setting eff_sacks
tcp: options clean up
tcp: Fix MD5 signatures for non-linear skbs
sctp: Update sctp global memory limit allocations.
sctp: remove unnecessary byteshifting, calculate directly in big-endian
sctp: Allow only 1 listening socket with SO_REUSEADDR
sctp: Do not leak memory on multiple listen() calls
sctp: Support ipv6only AF_INET6 sockets.
Move the line disciplines towards a conventional ->ops arrangement. For
the moment the actual 'tty_ldisc' struct in the tty is kept as part of
the tty struct but this can then be changed if it turns out that when it
all settles down we want to refcount ldiscs separately to the tty.
Pull the ldisc code out of /proc and put it with our ldisc code.
Signed-off-by: Alan Cox <alan@redhat.com>
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/powerpc/booting-without-of.txt
drivers/atm/Makefile
drivers/net/fs_enet/fs_enet-main.c
drivers/pci/pci-acpi.c
net/8021q/vlan.c
net/iucv/iucv.c
* 'for-2.6.27' of git://git.infradead.org/users/dwmw2/firmware-2.6: (64 commits)
firmware: convert sb16_csp driver to use firmware loader exclusively
dsp56k: use request_firmware
edgeport-ti: use request_firmware()
edgeport: use request_firmware()
vicam: use request_firmware()
dabusb: use request_firmware()
cpia2: use request_firmware()
ip2: use request_firmware()
firmware: convert Ambassador ATM driver to request_firmware()
whiteheat: use request_firmware()
ti_usb_3410_5052: use request_firmware()
emi62: use request_firmware()
emi26: use request_firmware()
keyspan_pda: use request_firmware()
keyspan: use request_firmware()
ttusb-budget: use request_firmware()
kaweth: use request_firmware()
smctr: use request_firmware()
firmware: convert ymfpci driver to use firmware loader exclusively
firmware: convert maestro3 driver to use firmware loader exclusively
Fix up trivial conflicts with BKL removal in drivers/char/dsp56k.c and
drivers/char/ip2/ip2main.c manually.
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (241 commits)
[ARM] 5171/1: ep93xx: fix compilation of modules using clocks
[ARM] 5133/2: at91sam9g20 defconfig file
[ARM] 5130/4: Support for the at91sam9g20
[ARM] 5160/1: IOP3XX: gpio/gpiolib support
[ARM] at91: Fix NAND FLASH timings for at91sam9x evaluation kits.
[ARM] 5084/1: zylonite: Register AC97 device
[ARM] 5085/2: PXA: Move AC97 over to the new central device declaration model
[ARM] 5120/1: pxa: correct platform driver names for PXA25x and PXA27x UDC drivers
[ARM] 5147/1: pxaficp_ir: drop pxa_gpio_mode calls, as pin setting
[ARM] 5145/1: PXA2xx: provide api to control IrDA pins state
[ARM] 5144/1: pxaficp_ir: cleanup includes
[ARM] pxa: remove pxa_set_cken()
[ARM] pxa: allow clk aliases
[ARM] Feroceon: don't disable BPU on boot
[ARM] Orion: LED support for HP mv2120
[ARM] Orion: add RD88F5181L-FXO support
[ARM] Orion: add RD88F5181L-GE support
[ARM] Orion: add Netgear WNR854T support
[ARM] s3c2410_defconfig: update for current build
[ARM] Acer n30: Minor style and indentation fixes.
sound/pci/Kconfig
This includes PXA work up to the SPI changes for the initial merge,
since e172274ccc55d20536fbdceb6131f38e288541e0 depends on the SPI
tree being merged.
arch/arm/configs/em_x270_defconfig
arch/arm/configs/xm_x270_defconfig
is handled in board code
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
drivers/net/wireless/iwlwifi/iwl-3945.c
net/mac80211/mlme.c
Some IRDA headers contain references to 'struct pm_dev' that are not
necessary any more and may be removed.
Acked-by: Pavel Machek <pavel@suse.cz>
Signed-off-by: Samuel Ortiz <samuel@sortiz.org>
HP OmniBook 500's DSDT code changes the HID of the FIR device from
NSC6001 to HWPC224 when run under an "NT" operating system. Add the
new ID to the pnp device id table.
Signed-off-by: Ville Syrjala <syrjala@sci.fi>
1. dma should be freed when dma2 request fail.
2. dma2 should be freed too when device close.
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
This patch removes CVS keyword that weren't updated for a long time.
One of them was printed as part of a printk, which also doesn't make
much sense for a 5 year old and no longer updated keyword.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
-tip testing found the following build error:
drivers/built-in.o: In function `mcs_receive_irq':
mcs7780.c:(.text+0x4e429): undefined reference to `crc32_le'
drivers/built-in.o: In function `mcs_hard_xmit':
mcs7780.c:(.text+0x4e9af): undefined reference to `crc32_le'
with:
http://redhat.com/~mingo/misc/config-Sun_Jun__8_22_56_14_CEST_2008.bad
the reason is a missing enablement of the CRC32 library in the Kconfig.
x86.git testing found this build bug on v2.6.26-rc1:
ERROR: "pnp_get_resource" [drivers/net/irda/smsc-ircc2.ko] undefined!
make[1]: *** [__modpost] Error 1
make: *** [modules] Error 2
the driver did not anticipate the case of !CONFIG_PNP which is rare but
still possible. Instead of restricting the driver to PNP-only in the
Kconfig space, add the (trivial) dummy struct pnp_driver - this is that
other drivers use in the !PNP case too.
The driver itself can in theory be initialized on !PNP too in certain
cases, via smsc_ircc_legacy_probe().
Patch only minimally build tested, i dont have this hardware.
x86.git testing found the following build failure in latest -git:
drivers/built-in.o: In function `nsc_ircc_pnp_probe':
nsc-ircc.c:(.text+0xdf1b6): undefined reference to `pnp_get_resource'
nsc-ircc.c:(.text+0xdf1d4): undefined reference to `pnp_get_resource'
nsc-ircc.c:(.text+0xdf1ee): undefined reference to `pnp_get_resource'
nsc-ircc.c:(.text+0xdf237): undefined reference to `pnp_get_resource'
nsc-ircc.c:(.text+0xdf24c): undefined reference to `pnp_get_resource'
drivers/built-in.o:nsc-ircc.c:(.text+0xdf266): more undefined references to `pnp_get_resource' follow
make: *** [.tmp_vmlinux1] Error 1
triggered via this config:
http://redhat.com/~mingo/misc/config-Sat_May__3_20_53_13_CEST_2008.bad
while generally most users will have PNP enabled, drivers can support
non-PNP build mode too - and most drivers implement it. That is typically
done by providing a dummy pnp_driver structure that will not probe anything.
The fallback routines in the driver will handle this dumber mode of
operation too.
This patch implements that. I have not tested whether this actually
works on real hardware so take care. It does resolve the build bug.
[ Another solution that is used by a few drivers is to exclude the driver
in the Kconfig if PNP is disabled, via "depends on PNP", but this would
limit the availability of the driver needlessly. ]
- Operations are now a shared const function block as with most other Linux
objects
- Introduce wrappers for some optional functions to get consistent behaviour
- Wrap put_char which used to be patched by the tty layer
- Document which functions are needed/optional
- Make put_char report success/fail
- Cache the driver->ops pointer in the tty as tty->ops
- Remove various surplus lock calls we no longer need
- Remove proc_write method as noted by Alexey Dobriyan
- Introduce some missing sanity checks where certain driver/ldisc
combinations would oops as they didn't check needed methods were present
[akpm@linux-foundation.org: fix fs/compat_ioctl.c build]
[akpm@linux-foundation.org: fix isicom]
[akpm@linux-foundation.org: fix arch/ia64/hp/sim/simserial.c build]
[akpm@linux-foundation.org: fix kgdb]
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Auke Kok <auke-jan.h.kok@intel.com>
Cc: John Ronciak <john.ronciak@intel.com>
Cc: Jesse Brandeburg <jesse.brandeburg@intel.com>
Cc: Grant Grundler <grundler@parisc-linux.org>
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data
be setup before gluing PDE to main tree.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (48 commits)
net: Fix wrong interpretation of some copy_to_user() results.
xfrm: alg_key_len & alg_icv_len should be unsigned
[netdrvr] tehuti: move ioctl perm check closer to function start
ipv6: Fix typo in net/ipv6/Kconfig
via-velocity: fix vlan receipt
tg3: sparse cleanup
forcedeth: realtek phy crossover detection
ibm_newemac: Increase MDIO timeouts
gianfar: Fix skb allocation strategy
netxen: reduce stack usage of netxen_nic_flash_print
smc911x: test after postfix decrement fails in smc911x_{reset,drop_pkt}
net drivers: fix platform driver hotplug/coldplug
forcedeth: new backoff implementation
ehea: make things static
phylib: Add support for board-level PHY fixups
[netdrvr] atlx: code movement: move atl1 parameter parsing
atlx: remove flash vendor parameter
korina: misc cleanup
korina: fix misplaced return statement
WAN: Fix confusing insmod error code for C101 too.
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is
prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable network
platform drivers, to re-enable auto loading.
NOTE: didn't change drivers/net/fs_enet/fs_enet-main.c "old binding" support.
That looks problematic in the first place (it even uses the ancient "struct
device_driver" binding scheme for platform_bus!) and I suspect it will vanish
soonish when arch/powerpc rules the world. Also, drivers/net/ne.c would have
needed more thought to sort out.
[akpm@linux-foundation.org: fix sgiseeq.c]
[dbrownell@users.sourceforge.net: more drivers, registration fixes]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Scott Wood <scottwood@freescale.com>
Cc: Vitaly Bordug <vitb@kernel.crashing.org>
Cc: Dale Farnsworth <dale@farnsworth.org>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Andrew Victor <andrew@sanpeople.com>
Cc: Bryan Wu <bryan.wu@analog.com>
Let platform do some specific initialisation and cleanup
things during pxaficp_ir probing and removing. E.g. this
can be usefull to request/free gpios used by the platform
to control the transceiver.
two reasons:
1. GPIO namings and their mode definitions are conceptually not part
of the PXA register definitions
2. this is actually a temporary move in the transition of PXA2xx to
use MFP-alike APIs (as what PXA3xx is now doing), so that legacy
code will still work and new code can be added in step by step
Signed-off-by: eric miao <eric.miao@marvell.com>
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com>
This patch removes IrPORT and the old dongle drivers (all off them
have replacement drivers).
* use irq_handler_t where appropriate
* no need to use 'irq' function arg, its already stored in a data struct
* rename irq handler 'irq' argument to 'dummy', where the function
has been analyzed and proven not to use its first argument.
* remove always-false "dev_id == NULL" test from irq handlers
* remove pointless casts from void*
* declance: irq argument is not const
* add KERN_xxx printk prefix
* fix minor whitespace weirdness
From: Olaf Hartmann <olaf.hartmann@s1998.tu-chemnitz.de>
The attached patch observes the stir4200 fifo size and will clear the
fifo, if the size is increasing, while it should be transmitting bytes
While testing the mcs7780 based IrDA USB dongle I've stumbled upon
memory leak in mcs_net_close(). Patch below fixes it.
Signed-off-by: Hinko Kocevar <hinko.kocevar@cetrtapot.si>
It seems to me that irda_usb_net_open() must set self->netopen
under spinlock or disconnect() may fail to kill all URBs, if it is called
while an interface is opened.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
We conciously make a change here - we permit mode and speed setting to
be done in things like SLIP mode. There isn't actually a technical
reason to disallow this. It's usually a silly thing to do but we can
do it and soemone might wish to do so.
interrupt handlers return a return value these days.
Also, kill always-true test and unneeded void* cast.
* Convert files to UTF-8.
* Also correct some people's names
(one example is Eißfeldt, which was found in a source file.
Given that the author used an ß at all in a source file
indicates that the real name has in fact a 'ß' and not an 'ss',
which is commonly used as a substitute for 'ß' when limited to
7bit.)
* Correct town names (Goettingen -> Göttingen)
* Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313)
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Fix the various misspellings of "system", controller", "interrupt" and
"[un]necessary".
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
