path: root/drivers/net/irda
2008-12-26drivers/net/irda: fix sparse warnings: make symbols staticHannes Eder
Fix this sparse warnings: drivers/net/irda/ma600-sir.c:239:5: warning: symbol 'ma600_reset' was not declared. Should it be static? drivers/net/irda/smsc-ircc2.c:875:5: warning: symbol 'smsc_ircc_hard_xmit_sir' was not declared. Should it be static? drivers/net/irda/smsc-ircc2.c:1131:6: warning: symbol 'smsc_ircc_set_sir_speed' was not declared. Should it be static? drivers/net/irda/smsc-ircc2.c:1897:6: warning: symbol 'smsc_ircc_sir_start' was not declared. Should it be static? drivers/net/irda/w83977af_ir.c:150:5: warning: symbol 'w83977af_open' was not declared. Should it be static? drivers/net/irda/w83977af_ir.c:313:5: warning: symbol 'w83977af_probe' was not declared. Should it be static? drivers/net/irda/w83977af_ir.c:412:6: warning: symbol 'w83977af_change_speed' was not declared. Should it be static? drivers/net/irda/w83977af_ir.c:492:5: warning: symbol 'w83977af_hard_xmit' was not declared. Should it be static? drivers/net/irda/w83977af_ir.c:734:5: warning: symbol 'w83977af_dma_receive' was not declared. Should it be static? drivers/net/irda/w83977af_ir.c:806:5: warning: symbol 'w83977af_dma_receive_complete' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-05tty: Flags should be accessed via the foo_bit interfacesAlan Cox
We have various drivers that poke around directly and we need to clean this up before it causes problems. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12netdevice: safe convert to netdev_priv() #part-2Wang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. This patch is a safe convert for netdev->priv to netdev_priv(netdev). Since all of the netdev->priv is only for read. But it is too big to be sent in one mail. I split it to 4 parts and make every part smaller than 100,000 bytes, which is max size allowed by vger. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath5k/base.c net/8021q/vlan_core.c
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-01IRDA: remove double inclusion of module.hAlexander Beregalov
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-17USB: remove info() macro from usb network driversGreg Kroah-Hartman
USB should not be having it's own printk macros, so remove info() and use the system-wide standard of dev_info() wherever possible. Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: remove warn() macro from usb net driversGreg Kroah-Hartman
USB should not be having it's own printk macros, so remove warn() and use the system-wide standard of dev_warn() wherever possible. In the few places that will not work out, use a basic printk(). Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17remove CONFIG_KMOD from driversJohannes Berg
Straight forward conversions to CONFIG_MODULE; many drivers include <linux/kmod.h> conditionally and then don't have any other conditional code so remove it from those. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: video4linux-list@redhat.com Cc: David Woodhouse <dwmw2@infradead.org> Cc: linux-ppp@vger.kernel.org Cc: dm-devel@redhat.com Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-10-11Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (236 commits) [ARM] 5300/1: fixup spitz reset during boot [ARM] 5295/1: make ZONE_DMA optional [ARM] 5239/1: Palm Zire 72 power management support [ARM] 5298/1: Drop desc_handle_irq() [ARM] 5297/1: [KS8695] Fix two compile-time warnings [ARM] 5296/1: [KS8695] Replace macro's with trailing underscores. [ARM] pxa: allow multi-machine PCMCIA builds [ARM] pxa: add preliminary CPUFREQ support for PXA3xx [ARM] pxa: add missing ACCR bit definitions to pxa3xx-regs.h [ARM] pxa: rename cpu-pxa.c to cpufreq-pxa2xx.c [ARM] pxa/zylonite: add support for USB OHCI [ARM] ohci-pxa27x: use ioremap() and offset for register access [ARM] ohci-pxa27x: introduce pxa27x_clear_otgph() [ARM] ohci-pxa27x: use platform_get_{irq,resource} for the resource [ARM] ohci-pxa27x: move OHCI controller specific registers into the driver [ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registers [ARM] pxa: move I2S register and bit definitions into pxa2xx-i2s.c [ARM] pxa: simplify DMA register definitions [ARM] pxa: make additional DCSR bits valid for PXA3xx [ARM] pxa: move i2c register and bit definitions into i2c-pxa.c ... Fixed up conflicts in arch/arm/mach-versatile/core.c sound/soc/pxa/pxa2xx-ac97.c sound/soc/pxa/pxa2xx-i2s.c manually.
2008-10-07[ARM] pxa: simplify DMA register definitionsEric Miao
1. DRCMRxx is no longer recommended, use DRCMR(xx) instead, and pass DRCMR index by "struct resource" if possible 2. DCSRxx, DDADRxx, DSADRxx, DTADRxx, DCMDxx is never used, use DCSR(), DDADR(), DSADR(), DTADR(), DCMD() instead Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-22irda: follow lspci device/vendor styleBjorn Helgaas
Use "[%04x:%04x]" for PCI vendor/device IDs to follow the format used by lspci(8). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesRussell King
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-30irda: replace __FUNCTION__ with __func__Harvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-30nsc-ircc: default to dongle type 9 on IBM hardwareMatthew Garrett
This is necessary to set the dongle type on the nsc driver in order to get it to work correctly. Thinkpads all appear to use dongle type 9. This patch defaults nsc devices with an IBM PnP descriptor to use type 9. Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Ben Collins <ben.collins@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-07-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (1232 commits) iucv: Fix bad merging. net_sched: Add size table for qdiscs net_sched: Add accessor function for packet length for qdiscs net_sched: Add qdisc_enqueue wrapper highmem: Export totalhigh_pages. ipv6 mcast: Omit redundant address family checks in ip6_mc_source(). net: Use standard structures for generic socket address structures. ipv6 netns: Make several "global" sysctl variables namespace aware. netns: Use net_eq() to compare net-namespaces for optimization. ipv6: remove unused macros from net/ipv6.h ipv6: remove unused parameter from ip6_ra_control tcp: fix kernel panic with listening_get_next tcp: Remove redundant checks when setting eff_sacks tcp: options clean up tcp: Fix MD5 signatures for non-linear skbs sctp: Update sctp global memory limit allocations. sctp: remove unnecessary byteshifting, calculate directly in big-endian sctp: Allow only 1 listening socket with SO_REUSEADDR sctp: Do not leak memory on multiple listen() calls sctp: Support ipv6only AF_INET6 sockets. ...
2008-07-20tty: Ldisc revampAlan Cox
Move the line disciplines towards a conventional ->ops arrangement. For the moment the actual 'tty_ldisc' struct in the tty is kept as part of the tty struct but this can then be changed if it turns out that when it all settles down we want to refcount ldiscs separately to the tty. Pull the ldisc code out of /proc and put it with our ldisc code. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/powerpc/booting-without-of.txt drivers/atm/Makefile drivers/net/fs_enet/fs_enet-main.c drivers/pci/pci-acpi.c net/8021q/vlan.c net/iucv/iucv.c
2008-07-14Merge branch 'for-2.6.27' of git://git.infradead.org/users/dwmw2/firmware-2.6Linus Torvalds
* 'for-2.6.27' of git://git.infradead.org/users/dwmw2/firmware-2.6: (64 commits) firmware: convert sb16_csp driver to use firmware loader exclusively dsp56k: use request_firmware edgeport-ti: use request_firmware() edgeport: use request_firmware() vicam: use request_firmware() dabusb: use request_firmware() cpia2: use request_firmware() ip2: use request_firmware() firmware: convert Ambassador ATM driver to request_firmware() whiteheat: use request_firmware() ti_usb_3410_5052: use request_firmware() emi62: use request_firmware() emi26: use request_firmware() keyspan_pda: use request_firmware() keyspan: use request_firmware() ttusb-budget: use request_firmware() kaweth: use request_firmware() smctr: use request_firmware() firmware: convert ymfpci driver to use firmware loader exclusively firmware: convert maestro3 driver to use firmware loader exclusively ... Fix up trivial conflicts with BKL removal in drivers/char/dsp56k.c and drivers/char/ip2/ip2main.c manually.
2008-07-14Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (241 commits) [ARM] 5171/1: ep93xx: fix compilation of modules using clocks [ARM] 5133/2: at91sam9g20 defconfig file [ARM] 5130/4: Support for the at91sam9g20 [ARM] 5160/1: IOP3XX: gpio/gpiolib support [ARM] at91: Fix NAND FLASH timings for at91sam9x evaluation kits. [ARM] 5084/1: zylonite: Register AC97 device [ARM] 5085/2: PXA: Move AC97 over to the new central device declaration model [ARM] 5120/1: pxa: correct platform driver names for PXA25x and PXA27x UDC drivers [ARM] 5147/1: pxaficp_ir: drop pxa_gpio_mode calls, as pin setting [ARM] 5145/1: PXA2xx: provide api to control IrDA pins state [ARM] 5144/1: pxaficp_ir: cleanup includes [ARM] pxa: remove pxa_set_cken() [ARM] pxa: allow clk aliases [ARM] Feroceon: don't disable BPU on boot [ARM] Orion: LED support for HP mv2120 [ARM] Orion: add RD88F5181L-FXO support [ARM] Orion: add RD88F5181L-GE support [ARM] Orion: add Netgear WNR854T support [ARM] s3c2410_defconfig: update for current build [ARM] Acer n30: Minor style and indentation fixes. ...
2008-07-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
Conflicts: sound/pci/Kconfig
2008-07-14[ARM] Merge most of the PXA work for initial mergeRussell King
This includes PXA work up to the SPI changes for the initial merge, since e172274ccc55d20536fbdceb6131f38e288541e0 depends on the SPI tree being merged. Conflicts: arch/arm/configs/em_x270_defconfig arch/arm/configs/xm_x270_defconfig
2008-07-10irda-usb: treat firmware data as constDavid Woodhouse
2008-07-09[ARM] 5147/1: pxaficp_ir: drop pxa_gpio_mode calls, as pin settingDmitry Baryshkov
is handled in board code Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] 5144/1: pxaficp_ir: cleanup includesDmitry Baryshkov
2008-07-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-3945.c net/mac80211/mlme.c
2008-07-08irda: Remove useless pm_dev referencesRafael J. Wysocki
Some IRDA headers contain references to 'struct pm_dev' that are not necessary any more and may be removed. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08irda: New device ID for nsc-irccVille Syrjala
HP OmniBook 500's DSDT code changes the HID of the FIR device from NSC6001 to HWPC224 when run under an "NT" operating system. Add the new ID to the pnp device id table. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08irda: via-ircc proper dma freeingWang Chen
1. dma should be freed when dma2 request fail. 2. dma2 should be freed too when device close. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11irda: remove CVS keywordsAdrian Bunk
This patch removes CVS keyword that weren't updated for a long time. One of them was printed as part of a printk, which also doesn't make much sense for a 5 year old and no longer updated keyword. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-09irda: net/irda build fix: mcs7780Ingo Molnar
-tip testing found the following build error: drivers/built-in.o: In function `mcs_receive_irq': mcs7780.c:(.text+0x4e429): undefined reference to `crc32_le' drivers/built-in.o: In function `mcs_hard_xmit': mcs7780.c:(.text+0x4e9af): undefined reference to `crc32_le' with: http://redhat.com/~mingo/misc/config-Sun_Jun__8_22_56_14_CEST_2008.bad the reason is a missing enablement of the CRC32 library in the Kconfig. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-21irda-usb endianness annotations and fixesAl Viro
2008-05-05irda: fix !PNP support for drivers/net/irda/smsc-ircc2.cIngo Molnar
x86.git testing found this build bug on v2.6.26-rc1: ERROR: "pnp_get_resource" [drivers/net/irda/smsc-ircc2.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 the driver did not anticipate the case of !CONFIG_PNP which is rare but still possible. Instead of restricting the driver to PNP-only in the Kconfig space, add the (trivial) dummy struct pnp_driver - this is that other drivers use in the !PNP case too. The driver itself can in theory be initialized on !PNP too in certain cases, via smsc_ircc_legacy_probe(). Patch only minimally build tested, i dont have this hardware. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-05irda: fix !PNP support in drivers/net/irda/nsc-ircc.cIngo Molnar
x86.git testing found the following build failure in latest -git: drivers/built-in.o: In function `nsc_ircc_pnp_probe': nsc-ircc.c:(.text+0xdf1b6): undefined reference to `pnp_get_resource' nsc-ircc.c:(.text+0xdf1d4): undefined reference to `pnp_get_resource' nsc-ircc.c:(.text+0xdf1ee): undefined reference to `pnp_get_resource' nsc-ircc.c:(.text+0xdf237): undefined reference to `pnp_get_resource' nsc-ircc.c:(.text+0xdf24c): undefined reference to `pnp_get_resource' drivers/built-in.o:nsc-ircc.c:(.text+0xdf266): more undefined references to `pnp_get_resource' follow make: *** [.tmp_vmlinux1] Error 1 triggered via this config: http://redhat.com/~mingo/misc/config-Sat_May__3_20_53_13_CEST_2008.bad while generally most users will have PNP enabled, drivers can support non-PNP build mode too - and most drivers implement it. That is typically done by providing a dummy pnp_driver structure that will not probe anything. The fallback routines in the driver will handle this dumber mode of operation too. This patch implements that. I have not tested whether this actually works on real hardware so take care. It does resolve the build bug. [ Another solution that is used by a few drivers is to exclude the driver in the Kconfig if PNP is disabled, via "depends on PNP", but this would limit the availability of the driver needlessly. ] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-30tty: The big operations reworkAlan Cox
- Operations are now a shared const function block as with most other Linux objects - Introduce wrappers for some optional functions to get consistent behaviour - Wrap put_char which used to be patched by the tty layer - Document which functions are needed/optional - Make put_char report success/fail - Cache the driver->ops pointer in the tty as tty->ops - Remove various surplus lock calls we no longer need - Remove proc_write method as noted by Alexey Dobriyan - Introduce some missing sanity checks where certain driver/ldisc combinations would oops as they didn't check needed methods were present [akpm@linux-foundation.org: fix fs/compat_ioctl.c build] [akpm@linux-foundation.org: fix isicom] [akpm@linux-foundation.org: fix arch/ia64/hp/sim/simserial.c build] [akpm@linux-foundation.org: fix kgdb] Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29net: use get/put_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Auke Kok <auke-jan.h.kok@intel.com> Cc: John Ronciak <john.ronciak@intel.com> Cc: Jesse Brandeburg <jesse.brandeburg@intel.com> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29netdev: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (48 commits) net: Fix wrong interpretation of some copy_to_user() results. xfrm: alg_key_len & alg_icv_len should be unsigned [netdrvr] tehuti: move ioctl perm check closer to function start ipv6: Fix typo in net/ipv6/Kconfig via-velocity: fix vlan receipt tg3: sparse cleanup forcedeth: realtek phy crossover detection ibm_newemac: Increase MDIO timeouts gianfar: Fix skb allocation strategy netxen: reduce stack usage of netxen_nic_flash_print smc911x: test after postfix decrement fails in smc911x_{reset,drop_pkt} net drivers: fix platform driver hotplug/coldplug forcedeth: new backoff implementation ehea: make things static phylib: Add support for board-level PHY fixups [netdrvr] atlx: code movement: move atl1 parameter parsing atlx: remove flash vendor parameter korina: misc cleanup korina: fix misplaced return statement WAN: Fix confusing insmod error code for C101 too. ...
2008-04-25net drivers: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable network platform drivers, to re-enable auto loading. NOTE: didn't change drivers/net/fs_enet/fs_enet-main.c "old binding" support. That looks problematic in the first place (it even uses the ancient "struct device_driver" binding scheme for platform_bus!) and I suspect it will vanish soonish when arch/powerpc rules the world. Also, drivers/net/ne.c would have needed more thought to sort out. [akpm@linux-foundation.org: fix sgiseeq.c] [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Scott Wood <scottwood@freescale.com> Cc: Vitaly Bordug <vitb@kernel.crashing.org> Cc: Dale Farnsworth <dale@farnsworth.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Andrew Victor <andrew@sanpeople.com> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-19[ARM] 4971/1: pxaficp_ir: provide startup and shutdown hooksDmitry Baryshkov
Let platform do some specific initialisation and cleanup things during pxaficp_ir probing and removing. E.g. this can be usefull to request/free gpios used by the platform to control the transceiver. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] pxa: separate GPIOs and their mode definitions to pxa2xx-gpio.heric miao
two reasons: 1. GPIO namings and their mode definitions are conceptually not part of the PXA register definitions 2. this is actually a temporary move in the transition of PXA2xx to use MFP-alike APIs (as what PXA3xx is now doing), so that legacy code will still work and new code can be added in step by step Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-03Spelling fixes: lenght->lengthPaulius Zaleckas
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-28[IrDA]: Irport removal - part 2Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IrDA]: Irport removal - part 1Adrian Bunk
This patch removes IrPORT and the old dongle drivers (all off them have replacement drivers). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[netdrvr] irq handler minor cleanups in several driversJeff Garzik
* use irq_handler_t where appropriate * no need to use 'irq' function arg, its already stored in a data struct * rename irq handler 'irq' argument to 'dummy', where the function has been analyzed and proven not to use its first argument. * remove always-false "dev_id == NULL" test from irq handlers * remove pointless casts from void* * declance: irq argument is not const * add KERN_xxx printk prefix * fix minor whitespace weirdness Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-12-16[IRDA]: stir4200 fixes.Olaf Hartmann
From: Olaf Hartmann <olaf.hartmann@s1998.tu-chemnitz.de> The attached patch observes the stir4200 fifo size and will clear the fifo, if the size is increasing, while it should be transmitting bytes Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-16[IRDA]: mcs7780 needs to free allocated rx buffer.Hinko Kocevar
While testing the mcs7780 based IrDA USB dongle I've stumbled upon memory leak in mcs_net_close(). Patch below fixes it. Signed-off-by: Hinko Kocevar <hinko.kocevar@cetrtapot.si> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-16[IRDA]: Race between open and disconnect in irda-usb.Oliver Neukum
It seems to me that irda_usb_net_open() must set self->netopen under spinlock or disconnect() may fail to kill all URBs, if it is called while an interface is opened. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
