path: root/drivers/net/igbvf
2009-10-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sh_eth.c
2009-10-26igbvf: fix memory leak when ring size changed while interface downAlexander Duyck
This patch resolves a memory leak which occurs while changing the ring size while the interface is down. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: Use netdev_alloc_skb_ip_align()Eric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-05net: Convert ethtool {get_stats, self_test}_count() ops to get_sset_count()Ben Hutchings
These string query operations were supposed to be replaced by the generic get_sset_count() starting in 2007. Convert the remaining implementations. Also remove calls to these operations to initialise drvinfo->n_stats. The ethtool core code already does that. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02drivers: Kill now superfluous ->last_rx storesEric Dumazet
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Neil Horman <nhorman@txudriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01intel: convert drivers to netdev_tx_tStephen Hemminger
Get rid of some bogus return wrapping as well. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-08-04igbvf: Allow VF driver to correctly recognize failure to set macAlexander Duyck
The VF driver was not correctly recognizing that it did not correctly set it's mac address. As a result the VF driver was unable to receive network traffic until being unloaded and reloaded. The issue was root caused to the fact that the CTS bit was not taken into account when checking for the request being NAKed. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-01igbvf: return PCI_ERS_RESULT_DISCONNECT on permanent failureDean Nelson
PCI drivers that implement the struct pci_error_handlers' error_detected callback should return PCI_ERS_RESULT_DISCONNECT if the state passed in is pci_channel_io_perm_failure. This patch fixes the issue for igbvf. Signed-off-by: Dean Nelson <dnelson@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-26igbvf: resolve "frees DMA memory with different size" warningsAlexander Duyck
This change resolves some warnings seen with DMA debugging enabled in which we were mapping skb->data with size + NET_IP_ALIGN and unmapping it with just size. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-19convert some DMA_nnBIT_MASK() callersAndrew Morton
We're about to make DMA_nnBIT_MASK() emit `deprecated' warnings. Convert the remaining stragglers which are visible to the x86_64 build. Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Eric Moore <Eric.Moore@lsil.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Alexander Duyck <alexander.h.duyck@intel.com> Cc: Yi Zou <yi.zou@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/scsi/fcoe/fcoe.c net/core/drop_monitor.c net/core/net-traces.c
2009-06-12trivial: fix typos s/paramter/parameter/ and s/excute/execute/ in ↵Martin Olsson
documentation and source comments. Signed-off-by: Martin Olsson <martin@minimum.se> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-08net: skb_shared_info optimizationEric Dumazet
skb_dma_unmap() is quite expensive for small packets, because we use two different cache lines from skb_shared_info. One to access nr_frags, one to access dma_maps[0] Instead of dma_maps being an array of MAX_SKB_FRAGS + 1 elements, let dma_head alone in a new dma_head field, close to nr_frags, to reduce cache lines misses. Tested on my dev machine (bnx2 & tg3 adapters), nice speedup ! Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: dont update dev->trans_startEric Dumazet
Second round of drivers for Gb cards (and NIU one I forgot in the 10GB round) Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-06igbvf: cleanup flags and allow for rx checksum to be disabledAlexander Duyck
This patch cleans up a number of unused or unneeded feature flags. As a result of these changes the user should now be able to enable or disable rx checksumming via ethtool. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-11igbvf: fix unused external referencesAlexander Duyck
The igbvbf driver exposed several unused extrnal references due to the fact that code was copied from igb and then some functionality was removed. This changes that so that unused functions are either removed or made static. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08igbvf: add new driver to support 82576 virtual functionsAlexander Duyck
This adds an igbvf driver to handle virtual functions provided by the igb driver when SR-IOV has been enabled. A virtual function is a lightweight pci-e function that supports a single queue and shares resources with the 82576 physical function contained within the igb driver. To spawn virtual functions from the igb driver all that is needed is to enable CONFIG_PCI_IOV and have an 82576 Ethernet adapter on a system that supports SR-IOV in the BIOS. The virtual functions will appear after the interface is loaded. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
