It's been a useless no-op for long enough in 2.6 so I figured it's time to
remove it. The number of people that could object because they're
maintaining unified 2.4 and 2.6 drivers is probably rather small.
[ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ]
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Fix following section mismatch warning in hp100:
WARNING: drivers/net/hp100.o(.init.text+0x26a): Section mismatch: reference to .exit.text: (after 'init_module')
The warning says that we use a function marked __exit from a
function marked __init.
This is not good on architectures where we discard __exit section
for drivers that are built-in.
Note: This warning is only seen by my local copy of modpost
but the change will soon hit upstream.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Acked-by: Jeff Garzik <jeff@garzik.org>
One less thing for drivers writers to worry about.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Convert pci_module_init() to pci_register_driver().
Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se>
Cc: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
The previous hp100 changeset attempted to kill warnings, but was only
tested on !CONFIG_ISA platforms. The correct conditional compilation
setup involves tested CONFIG_ISA rather than just MODULE.
Fixes link on CONFIG_ISA platforms (i386) in current -git.
The previous '#ifndef MODULE' block did not cover all the
static-build-only code. Now it does.
config.h is automatically included by kbuild these days.
Signed-off-by: Dave Jones <davej@redhat.com>
First of all it is unnecessary to allocate a new skb in skb_pad since
the existing one is not shared. More importantly, our hard_start_xmit
interface does not allow a new skb to be allocated since that breaks
requeueing.
This patch uses pskb_expand_head to expand the existing skb and linearize
it if needed. Actually, someone should sift through every instance of
skb_pad on a non-linear skb as they do not fit the reasons why this was
originally created.
Incidentally, this fixes a minor bug when the skb is cloned (tcpdump,
TCP, etc.). As it is skb_pad will simply write over a cloned skb. Because
of the position of the write it is unlikely to cause problems but still
it's best if we don't do it.
for mode 2 (memory-mapped) we always set ->mem_ptr_virt; dead code removed.
They deal with wrapping correctly and are nicer to read. Also make
jiffies-holding variables unsigned long.
Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br>
Cc: Jeff Garzik <jgarzik@pobox.com>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
This patch removes almost all inclusions of linux/version.h. The 3
#defines are unused in most of the touched files.
A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is
unfortunatly in linux/version.h.
There are also lots of #ifdef for long obsolete kernels, this was not
touched. In a few places, the linux/version.h include was move to where
the LINUX_VERSION_CODE was used.
quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'`
search pattern:
/UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h
Signed-off-by: Olaf Hering <olh@suse.de>
Use schedule_timeout_interruptible() instead of
set_current_state()/schedule_timeout() to reduce kernel size.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Use the DMA_{64,32}BIT_MASK constants from dma-mapping.h when calling
pci_set_dma_mask() or pci_set_consistent_dma_mask()
This patch includes dma-mapping.h explicitly because it caused errors
on some architectures otherwise.
See http://marc.theaimsgroup.com/?t=108001993000001&r=1&w=2 for details
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
Signed-off-by: Domen Puncer <domen@coderock.org>
Those cards really need A in their names. Otherwise it is pretty hard
to find anything about them on the net.
Signed-off-by: Pavel Machek <pavel@suse.cz>
infrastructure for it.
Let it rip!
