path: root/drivers/net/hamachi.c
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/sfe4001.c drivers/net/wireless/libertas/cmd.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/rtl8187se/Kconfig drivers/staging/rtl8192e/Kconfig
2009-10-13net: Use netdev_alloc_skb_ip_align()Eric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-07-08Remove multiple KERN_ prefixes from printk formatsJoe Perches
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up handling of log-levels and newlines") changed printk semantics. printk lines with multiple KERN_<level> prefixes are no longer emitted as before the patch. <level> is now included in the output on each additional use. Remove all uses of multiple KERN_<level>s in formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: use symbolic values for ndo_start_xmit() return codesPatrick McHardy
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively. 0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases where its in direct proximity to one of the other values. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: dont update dev->trans_startEric Dumazet
Second round of drivers for Gb cards (and NIU one I forgot in the 10GB round) Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26hamachi: fix non-constant printk warningsStephen Hemminger
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11netdev: add missing set_mac_address hookStephen Hemminger
Many drivers lost the ability to set ethernet address accidently during the net_device_ops conversion. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21hamachi: convert to net_device_opsStephen Hemminger
Convert driver to new net_device_ops. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-22hamachi: use netdev_alloc_skbStephen Hemminger
Use netdev_alloc_skb. This sets skb->dev and allows arch specific allocation. Remove dead code and dead comments. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29net: use get/put_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Auke Kok <auke-jan.h.kok@intel.com> Cc: John Ronciak <john.ronciak@intel.com> Cc: Jesse Brandeburg <jesse.brandeburg@intel.com> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-14hamachi endianness fixesAl Viro
badly broken on big-endian * passing little-endian to pci_unmap_single() et.al. * cpu_to_le32() before passing value to writel() * worse, cpu_to_le64() and shifting/masking result before the same * hmp->tx_ring[i].status_n_length = cpu_to_le32( DescEndRing | (hmp->tx_ring[i].status_n_length & 0x0000FFFF)); is obviously bogus on big-endian. Not hard to untangle, fortunately... * poisoning addresses in rx_ring is better done after we'd done pci_unmap_single() on them, not before that. [this one affects little-endian as well, obviously, provided that pci_unmap_single() is not a no-op on target in question] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10network drivers: sparse warning fixesStephen Hemminger
Fix some of the easy warnings in network device drivers. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Kill eth_copy_and_sum().David S. Miller
It hasn't "summed" anything in over 7 years, and it's just a straight mempcy ala skb_copy_to_linear_data() so just get rid of it. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-24Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (217 commits) net/ieee80211: fix more crypto-related build breakage [PATCH] Spidernet: add ethtool -S (show statistics) [NET] GT96100: Delete bitrotting ethernet driver [PATCH] mv643xx_eth: restrict to 32-bit PPC_MULTIPLATFORM [PATCH] Cirrus Logic ep93xx ethernet driver r8169: the MMIO region of the 8167 stands behin BAR#1 e1000, ixgb: Remove pointless wrappers [PATCH] Remove powerpc specific parts of 3c509 driver [PATCH] s2io: Switch to pci_get_device [PATCH] gt96100: move to pci_get_device API [PATCH] ehea: bugfix for register access functions [PATCH] e1000 disable device on PCI error drivers/net/phy/fixed: #if 0 some incomplete code drivers/net: const-ify ethtool_ops declarations [PATCH] ethtool: allow const ethtool_ops [PATCH] sky2: big endian [PATCH] sky2: fiber support [PATCH] sky2: tx pause bug fix drivers/net: Trim trailing whitespace [PATCH] ehea: IBM eHEA Ethernet Device Driver ... Manually resolved conflicts in drivers/net/ixgb/ixgb_main.c and drivers/net/sky2.c related to CHECKSUM_HW/CHECKSUM_PARTIAL changes by commit 84fa7933a33f806bbbaae6775e87459b1ec584c0 that just happened to be next to unrelated changes in this update.
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-09-12[PATCH] Remove more unnecessary driver printk'sAndy Gospodarek
As I promised last week, here is the first pass at removing all unnecessary printk's that exist in network device drivers currently in promiscuous mode. The duplicate messages are not needed so they have been removed. Some of these drivers are quite old and might not need an update, but I did them all anyway. I am currently auditing the remaining conditional printk's and will send out a patch for those soon. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] Use dev_printk() when ethernet interface isn't availableJeff Garzik
For messages prior to register_netdev(), prefer dev_printk() because that prints out both our driver name and our [PCI | whatever] bus id. Updates: 8139{cp,too}, b44, bnx2, cassini, {eepro,epic}100, fealnx, hamachi, ne2k-pci, ns83820, pci-skeleton, r8169. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] Remove Linux-specific changelogs from several Becker template driversJeff Garzik
When in-kernel net drivers branched from Donald Becker's vanilla driver set, in the days before BitKeeper and git, a driver changelog was maintained in the driver source code. These days, the kernel's changelog is far superior and much more accurate, so the in-driver changelogs are removed. Another relic of the Becker/kernel split was version numbering, using "foo-LKx.y.z" notation, resulting in weird version numbers like "1.17b-LK1.1.9". These drivers are for older hardware, and see few changes these days, so the version numbers were all bumped to something more simple. Finally, in xircom_tulip_cb specifically, an additional cleanup removes the always-enabled CARDBUS cpp macro. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-03Massive net driver const-ification.Arjan van de Ven
2005-09-07[PATCH] -Wundef fixes (hamachi)viro@ZenIV.linux.org.uk
All uses of ADDRLEN are comparisons with 64 (it's an address width). added define to 32 (again, we only care about comparisons with 64) if not defined. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[NET]: Remove gratuitous use of skb->tail in network drivers.David S. Miller
Many drivers use skb->tail unnecessarily. In these situations, the code roughly looks like: dev = dev_alloc_skb(...); [optional] skb_reserve(skb, ...); ... skb->tail ... But even if the skb_reserve() happens, skb->data equals skb->tail. So it doesn't make any sense to use anything other than skb->data in these cases. Another case was the s2io.c driver directly mucking with the skb->data and skb->tail pointers. It really just wanted to do an skb_reserve(), so that's what the code was changed to do instead. Another reason I'm making this change as it allows some SKB cleanups I have planned simpler to merge. In those cleanups, skb->head, skb->tail, and skb->end pointers are removed, and replaced with skb->head_room and skb->tail_room integers. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jgarzik@pobox.com>
