path: root/drivers/net/gianfar_ethtool.c
2010-09-26drivers/net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-02gianfar: Basic Support for programming hash rulesSandeep Gopalpet
This patch provides basic hash rules programming via the ethtool interface. Signed-off-by: Sandeep Gopalpet <Sandeep.Kumar@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02gianfar: Add Multiple group SupportSandeep Gopalpet
This patch introduces multiple group support for etsec2.0 devices. Multiple group support is provided by mapping the set of enabled queues to different groups and then programming the per group regsiters imask, ievent, rstat, tstat. The queues corresponding to a group are indicated by programming isrg (interrupt steering) registers. Signed-off-by: Sandeep Gopalpet <Sandeep.Kumar@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02gianfar: Add Multiple Queue SupportSandeep Gopalpet
This patch introduces multiple Tx and Rx queues. The incoming packets can be classified into different queues based on filer rules (out of scope of this patch). The number of queues enabled will be based on a DTS entries fsl,num_tx_queues and fsl,num_rx_queues. Although we are enabling multiple queues, the interrupt coalescing is on per device level (etsec-1.7 doesn't support multiple rxics and txics). Signed-off-by: Sandeep Gopalpet <Sandeep.Kumar@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02gianfar: Introduce logical group support.Sandeep Gopalpet
This patch introduces the group structure. The elements of this structure are the interrupt lines, their corresponding names, the register memory map. The elements for this group are factored out from the gfar_private structure. The introduction of group structure will help in providing support for newer versions of etsec. Currently, the support is present only for single group and single tx/rx queues. Signed-off-by: Sandeep Gopalpet <Sandeep.Kumar@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02gianfar: Add per queue structure supportSandeep Gopalpet
This patch introduces per tx and per rx queue structures. Earlier the members of these structures were inside the gfar_private structure. Moving forward if we want to support multiple queues, we need to refactor the gfar_private structure so that introduction of multiple queues is easier. Signed-off-by: Sandeep Gopalpet <Sandeep.Kumar@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-21trivial: remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-07-30gianfar: fix coalescing setup in ethtool support Jiajun Wu
Parameter order for using mk_ic_value(count, time) was reversed, the patch fixes this. Signed-off-by: Jiajun Wu <b06378@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01gianfar: Implement proper, per netdevice wakeup managementAnton Vorontsov
This patch implements wakeup management for the gianfar driver. The driver should set wakeup enable if WOL is enabled, so that phylib won't power off an attached PHY. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-17gianfar: Add Scatter Gather supportDai Haruki
Scatter Gather support in gianfar driver to handle fragmented frames on the transmit side. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Dai Haruki <dai.haruki@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-16gianfar: Fix eTSEC configuration procedureDai Haruki
Fix some bugs in the ethtool configuration functions: * gfar_clean_rx_ring should not be called with interrupts disabled. * Update last transmission time to avoid tx timeout. * Delete redundant NETIF_F_IP_CSUM check in gfar_start_xmit * Use netif_tx_lock_bh when reconfiguring the tx csum Signed-off-by: Dai Haruki <dai.haruki@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-16gianfar: Optimize interrupt coalescing configurationDai Haruki
Store the interrupt coalescing values in the form in which they will be written to the interrupt coalescing registers. This puts a little overhead into the ethtool configuration, and takes it out of the interrupt handler Signed-off-by: Dai Haruki <dai.haruki@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-16gianfar: Convert gianfar to an of_platform_driverAndy Fleming
Does the same for the accompanying MDIO driver, and then modifies the TBI configuration method. The old way used fields in einfo, which no longer exists. The new way is to create an MDIO device-tree node for each instance of gianfar, and create a tbi-handle property to associate ethernet controllers with the TBI PHYs they are connected to. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16gianfar: Add magic packet and suspend/resume support.Scott Wood
Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-10[netdrvr] Stop using legacy hooks ->self_test_count, ->get_stats_countJeff Garzik
These have been superceded by the new ->get_sset_count() hook. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10Clean up duplicate includes in drivers/net/Jesper Juhl
This patch cleans up duplicate includes in drivers/net/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-07[POWERPC] Add "is_power_of_2" checking to log2.h.Robert P. J. Day
Add the inline function "is_power_of_2()" to log2.h, where the value zero is *not* considered to be a power of two. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-04-20[PATCH] Fix locking in gianfarAndy Fleming
This patch fixes several bugs in the gianfar driver, including a major one where spinlocks were horribly broken: * Split gianfar locks into two types: TX and RX * Made it so gfar_start() now clears RHALT * Fixed a bug where calling gfar_start_xmit() with interrupts off would corrupt the interrupt state * Fixed a bug where a frame could potentially arrive, and never be handled (if no more frames arrived * Fixed a bug where the rx_work_limit would never be observed by the rx completion code * Fixed a bug where the interrupt handlers were not actually protected by their spinlocks Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-02-07[PATCH] gianfar: Fix sparse warningsKumar Gala
Fixed sparse warnings mainly due to lack of __iomem. Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-18[PATCH] Gianfar update and sysfs supportAndy Fleming
This seems to have gotten lost, so I'll resend. Signed-off-by: Andy Fleming <afleming@freescale.com> * Added sysfs support to gianfar for modifying FIFO and stashing parameters * Updated driver to support 10 Mbit, full duplex operation * Improved comments throughout * Cleaned up and optimized offloading code * Fixed a bug where rx buffers were being improperly mapped and unmapped * (only manifested if cache-coherency was off) * Added support for using the eTSEC exact-match MAC registers * Bumped the version to 1.3 * Added support for distinguishing between reduced 100 and 10 Mbit modes * Modified default coalescing values to lower latency * Added documentation Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-13[PATCH] Update email address for KumarKumar Gala
Changed jobs and the Freescale address is no longer valid. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-23[netdrvr gianfar] use new phy layerAndy Fleming
Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-27[PATCH] gianfar: Add support enhanced TSEC features on the MPC 8548Kumar Gala
Jeff, Just incase this got lost in the recent netdev mailing list transition here is a nicer version of Andy's patch for gianfar. - kumar * TCP/IP/UDP checksumming and verification * VLAN tag insertion/extraction * Larger multicast hash-table * Padding to align IP headers Also added: * msg lvl support * Some whitespace cleanup Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
