path: root/drivers/net/gianfar_ethtool.c
2007-02-07[POWERPC] Add "is_power_of_2" checking to log2.h.Robert P. J. Day
Add the inline function "is_power_of_2()" to log2.h, where the value zero is *not* considered to be a power of two. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-04-20[PATCH] Fix locking in gianfarAndy Fleming
This patch fixes several bugs in the gianfar driver, including a major one where spinlocks were horribly broken: * Split gianfar locks into two types: TX and RX * Made it so gfar_start() now clears RHALT * Fixed a bug where calling gfar_start_xmit() with interrupts off would corrupt the interrupt state * Fixed a bug where a frame could potentially arrive, and never be handled (if no more frames arrived * Fixed a bug where the rx_work_limit would never be observed by the rx completion code * Fixed a bug where the interrupt handlers were not actually protected by their spinlocks Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-02-07[PATCH] gianfar: Fix sparse warningsKumar Gala
Fixed sparse warnings mainly due to lack of __iomem. Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-18[PATCH] Gianfar update and sysfs supportAndy Fleming
This seems to have gotten lost, so I'll resend. Signed-off-by: Andy Fleming <afleming@freescale.com> * Added sysfs support to gianfar for modifying FIFO and stashing parameters * Updated driver to support 10 Mbit, full duplex operation * Improved comments throughout * Cleaned up and optimized offloading code * Fixed a bug where rx buffers were being improperly mapped and unmapped * (only manifested if cache-coherency was off) * Added support for using the eTSEC exact-match MAC registers * Bumped the version to 1.3 * Added support for distinguishing between reduced 100 and 10 Mbit modes * Modified default coalescing values to lower latency * Added documentation Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-13[PATCH] Update email address for KumarKumar Gala
Changed jobs and the Freescale address is no longer valid. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-23[netdrvr gianfar] use new phy layerAndy Fleming
Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-27[PATCH] gianfar: Add support enhanced TSEC features on the MPC 8548Kumar Gala
Jeff, Just incase this got lost in the recent netdev mailing list transition here is a nicer version of Andy's patch for gianfar. - kumar * TCP/IP/UDP checksumming and verification * VLAN tag insertion/extraction * Larger multicast hash-table * Padding to align IP headers Also added: * msg lvl support * Some whitespace cleanup Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
