Move the Freescale drivers into drivers/net/ethernet/freescale/ and
make the necessary Kconfig and Makefile changes.
CC: Sandeep Gopalpet <sandeep.kumar@freescale.com>
CC: Andy Fleming <afleming@freescale.com>
CC: Shlomi Gridish <gridish@freescale.com>
CC: Li Yang <leoli@freescale.com>
CC: Pantelis Antoniou <pantelis.antoniou@gmail.com>
CC: Vitaly Bordug <vbordug@ru.mvista.com>
CC: Dan Malek <dmalek@jlc.net>
CC: Sylvain Munaut <tnt@246tNt.com>
Extend the fs_enet driver to support MPC512x FEC.
Enable it with CONFIG_FS_ENET_MPC5121_FEC option.
Signed-off-by: John Rigby <jcrigby@gmail.com>
Signed-off-by: Piotr Ziecik <kosmo@semihalf.com>
CONFIG_DUET doesn't exist anymore, remove all the code that exists to
support it.
[ Simplify fs_init() even further -DaveM ]
Now that arch/ppc is gone we don't need CONFIG_PPC_MERGE anymore remove
the dead code associated with !CONFIG_PPC_MERGE.
With this change the pre_request_irq() and post_free_irq() calls became
nops so they have been removed. Also removed fs_request_irq() and
fs_free_irq() and just called request_irq() and free_irq().
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Scott Wood <scottwood@freescale.com>
Now that arch/ppc is gone we always define CONFIG_PPC_CPM_NEW_BINDING so
we can remove all the code associated with !CONFIG_PPC_CPM_NEW_BINDING.
Also fixed some asm/of_platform.h to linux/of_platform.h (and of_device.h)
Rename commproc.[ch] to cpm1.[ch] to be more consistent with cpm2. Also
rename cpm2_common.c to cpm2.c as suggested by Scott Wood. Adjust the
includes accordingly.
Signed-off-by: Jochen Friedrich <jochen@scram.de>
This driver was recently broken by several changes for which this
driver was not (or was improperly) updated:
1. SET_MODULE_OWNER() was removed.
2. netif_napi_add() was only being called when building with
the old CPM binding.
3. The received/budget test was backwards.
4. to_net_dev() was wrong -- the device struct embedded in
the net_device struct is not the same as the of_platform
device in the private struct.
5. napi_disable/napi_enable was being called even when napi
was not being used.
These changes have been fixed, and napi is now on by default.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Mostly a bunch of __iomem annotations.
The existing OF glue code was crufty and broken. Rather than fix it, it
will be removed, and the ethernet driver now talks to the device tree
directly.
The old, non-CONFIG_PPC_CPM_NEW_BINDING code can go away once CPM
platforms are dropped from arch/ppc (which will hopefully be soon), and
existing arch/powerpc boards that I wasn't able to test on for this
patchset get converted (which should be even sooner).
At least some hardware driven by this driver needs receive buffers
to be aligned on a 16-byte boundary. This usually happens by chance,
but it breaks if slab debugging is enabled.
Several devices have multiple independant RX queues per net
device, and some have a single interrupt doorbell for several
queues.
In either case, it's easier to support layouts like that if the
structure representing the poll is independant from the net
device itself.
The signature of the ->poll() call back goes from:
int foo_poll(struct net_device *dev, int *budget)
to
int foo_poll(struct napi_struct *napi, int budget)
The caller is returned the number of RX packets processed (or
the number of "NAPI credits" consumed if you want to get
abstract). The callee no longer messes around bumping
dev->quota, *budget, etc. because that is all handled in the
caller upon return.
The napi_struct is to be embedded in the device driver private data
structures.
Furthermore, it is the driver's responsibility to disable all NAPI
instances in it's ->stop() device close handler. Since the
napi_struct is privatized into the driver's private data structures,
only the driver knows how to get at all of the napi_struct instances
it may have per-device.
With lots of help and suggestions from Rusty Russell, Roland Dreier,
Michael Chan, Jeff Garzik, and Jamal Hadi Salim.
Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra,
Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan.
[ Ported to current tree and all drivers converted. Integrated
Stephen's follow-on kerneldoc additions, and restored poll_list
handling to the old style to fix mutual exclusion issues. -DaveM ]
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Recent update of asm-powerpc/io.h caused cpm-related stuff to break in the
current kernel. Current patch fixes it, as well as other inconsistencies
expressed, that do not permit targets from working properly:
- Updated dts with a chosen node with interrupt controller,
- fixed messed device IDs among CPM2 SoC devices,
- corrected odd header name and fixed type in defines,
- Added 82xx subdir to the powerpc/platforms Makefile, missed during
initial commit,
- new solely-powerpc header file for 8260 family (was using one from
arch/ppc, this one cleaned up from the extra stuff), in fact for now
a placeholder to get the board-specific includes for stuff not yet
capable to live with devicetree peeks only
- Fixed couple of misprints in reference mpc8272 dts.
Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com>
As suggested by Muli Ben-Yehuda this function is moved to generic code as
may be useful for all archs.
[akpm@osdl.org: fix]
Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de>
Cc: Muli Ben-Yehuda <muli@il.ibm.com>
This patch should update the fs_enet infrastructure to utilize Phy Abstraction
Layer subsystem. Along with the above, there are apparent bugfixes, overhaul
and improvements.
This patch removes almost all inclusions of linux/version.h. The 3
#defines are unused in most of the touched files.
A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is
unfortunatly in linux/version.h.
There are also lots of #ifdef for long obsolete kernels, this was not
touched. In a few places, the linux/version.h include was move to where
the LINUX_VERSION_CODE was used.
quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'`
search pattern:
/UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h
Signed-off-by: Olaf Hering <olh@suse.de>
