path: root/drivers/net/forcedeth.c
2008-06-10forcedeth: msi interruptsAyaz Abdulla
Add a workaround for lost MSI interrupts. There is a race condition in the HW in which future interrupts could be missed. The workaround is to toggle the MSI irq mask. Added cleanup based on comments from Andrew Morton. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22[netdrvr] forcedeth: Restore multicast settings on resumeTobias Diedrich
nv_open() resets multicast settings, call nv_set_multicast(dev) to restore them. (Maybe this should rather be moved into nv_open()) Signed-off-by: Tobias Diedrich <ranma+kernel@tdiedrich.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25forcedeth: realtek phy crossover detectionAyaz Abdulla
This patch fixes an issue seen with the realtek 8201 phy. This phy has a problem with crossover detection and it needs to be disabled. The problem only arises on certain switches. Therefore, a module parameter has been added to allow enabling crossover detection if needed. The default will be set to disabled. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25forcedeth: new backoff implementationAyaz Abdulla
This patch adds support for a new backoff algorithm for half duplex supported in newer hardware. The old method is will be designated as legacy mode. Re-seeding random values for the backoff algorithms are performed when a transmit has failed due to a maximum retry count (1 to 15, where max is considered the wraparound case of 0). Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17[netdrvr] forcedeth: internal simplifications; changelog removalJeff Garzik
* remove changelog from source; its kept in git repository * consolidate descriptor version tests using nv_optimized() * consolidate NIC DMA start, stop and drain into nv_start_txrx(), nv_stop_txrx(), nv_drain_txrx() Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-12forcedeth: mac address fixAyaz Abdulla
This critical patch fixes a mac address issue recently introduced. If the device's mac address was in correct order and the flag NVREG_TRANSMITPOLL_MAC_ADDR_REV was set, during nv_remove the flag would get cleared. During next load, the mac address would get reversed because the flag is missing. As it has been indicated previously, the flag is cleared across a low power transition. Therefore, the driver should set the mac address back into the reversed order when clearing the flag. Also, the driver should set back the flag after a low power transition to protect against kexec command calling nv_probe a second time. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Cc: "Yinghai Lu" <yhlu.kernel@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-04fix endian lossage in forcedethAl Viro
a) if you initialize something with le32_to_cpu(...), then |= it with host-endian and feed to cpu_to_le32(), it's most definitely *not* __le32. As sparse would've told you... b) the whole sequence is |= cpu_to_le32(host-endian constant) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-04-02Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/s2io.c
2008-03-28forcedeth: fix locking bug with netconsoleIngo Molnar
While using netconsole on forcedeth, lockdep noticed the following locking bug: ================================= [ INFO: inconsistent lock state ] 2.6.24-rc6 #6 Signed-off-by: Ingo Molnar <mingo@elte.hu> --------------------------------- inconsistent {softirq-on-W} -> {in-softirq-W} usage. udevd/719 [HC0[0]:SC1[1]:HE1:SE0] takes: (_xmit_ETHER){-+..}, at: [<c043062e>] dev_watchdog+0x1c/0xb9 {softirq-on-W} state was registered at: [<c0147f67>] mark_held_locks+0x4e/0x66 [<c014810e>] trace_hardirqs_on+0xfe/0x136 [<c048ae63>] _spin_unlock_irq+0x22/0x42 [<c02ec617>] nv_start_xmit_optimized+0x347/0x37a [<c042c80d>] netpoll_send_skb+0xa4/0x147 [<c042d4a6>] netpoll_send_udp+0x238/0x242 [<c02f44f6>] write_msg+0x6d/0x9b [<c012c129>] __call_console_drivers+0x4e/0x5a [<c012c18c>] _call_console_drivers+0x57/0x5b [<c012c2dd>] release_console_sem+0x11c/0x1b9 [<c012caeb>] register_console+0x1eb/0x1f3 [<c06ae673>] init_netconsole+0x119/0x15f [<c069149b>] kernel_init+0x147/0x294 [<c01058cb>] kernel_thread_helper+0x7/0x10 [<ffffffff>] 0xffffffff irq event stamp: 950 hardirqs last enabled at (950): [<c048ae63>] _spin_unlock_irq+0x22/0x42 hardirqs last disabled at (949): [<c048aaf7>] _spin_lock_irq+0xc/0x38 softirqs last enabled at (0): [<c012a29c>] copy_process+0x375/0x126d softirqs last disabled at (947): [<c0106d43>] do_softirq+0x61/0xc6 other info that might help us debug this: no locks held by udevd/719. stack backtrace: Pid: 719, comm: udevd Not tainted 2.6.24-rc6 #6 [<c0105c46>] show_trace_log_lvl+0x12/0x25 [<c01063ec>] show_trace+0xd/0x10 [<c010670c>] dump_stack+0x57/0x5f [<c0147505>] print_usage_bug+0x10a/0x117 [<c0147c38>] mark_lock+0x121/0x402 [<c01488b6>] __lock_acquire+0x3d1/0xb64 [<c0149405>] lock_acquire+0x4e/0x6a [<c048a99b>] _spin_lock+0x23/0x32 [<c043062e>] dev_watchdog+0x1c/0xb9 [<c0133e4a>] run_timer_softirq+0x133/0x193 [<c0130907>] __do_softirq+0x78/0xed [<c0106d43>] do_softirq+0x61/0xc6 ======================= eth1: link down The fix is to disable/restore irqs instead of disable/enable. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Ayaz Abdulla <aabdulla@nvidia.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-26forcedeth: Use round_jiffies for stats timerDaniel Drake
This timer doesn't need to run at precise times, so round it to a whole second to decrease wakeups. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-17forcedeth: limit tx to 16Ayaz Abdulla
This is a critical patch which adds a workaround for a HW bug. The patch will limit the number of outstanding tx packets to 16. Otherwise, the HW could send out packets with bad checksums. The driver will still setup the tx packets into the ring, however, will only set the Valid bit on 16 packets at a time. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11forcedeth: tx pause watermarksAyaz Abdulla
New chipsets introduced variant Rx FIFO sizes that need to be taken into account when setting up the tx pause watermarks. This patch introduces the new device feature flags based on a version and implements the new watermarks. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11forcedeth: tx collision fixAyaz Abdulla
This patch supports a new fix in hardware regarding tx collisions. In the cases where we are in autoneg mode and the link partner is in forced mode, we need to setup the tx deferral register differently in order to reduce collisions on the wire. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-06forcedeth: preserve registersAyaz Abdulla
Various registers need to be preserved before resetting the device. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-06forcedeth: phy status fixAyaz Abdulla
The driver needs to ack only the phy status bits that it is currently handling and preserve the other bits for the other handlers. For example, when reading/writing from the phy, it should not clear the link change interrupt bit. This will cause a missing link change interrupt. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-06forcedeth: restart tx/rxAyaz Abdulla
This patch fixes the issue where the transmitter and receiver must be restarted when applying new changes to certain registers. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-03forcedeth: mac address mcp77/79Ayaz Abdulla
This patch is a critical fix for MCP77 and MCP79 devices. The feature flags were missing the define for correct mac address (DEV_HAS_CORRECT_MACADDR). Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-03forcedeth: multicast fixAyaz Abdulla
This patch fixes the case where no multicast addresses are requested to be added to the multicast filter. The multicast mask must be set to all 1's instead of all 0's. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-03forcedeth: tx pause fixAyaz Abdulla
This patch fixes the tx pause enable watermark flags. The new values where determined to be optimal during testing. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-03forcedeth: updated copyright sectionAyaz Abdulla
This patch updates the copyright section to include 2007 and 2008. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-03forcedeth: checksum fixAyaz Abdulla
The driver should inform the stack when checksum has been performed by the HW when both IP and TCP (or UDP) checksum flags are indicated by HW. Previously, it would also inform the stack when only IP checksum flag was indicated by HW. This can cause data corruption when IP fragments are used. The IP Identification field can wrap around and cause data from new fragments to fill into older fragment slots with same IP Id. The stack would then not perform TCP/UDP checksum (after re-assembly of all fragments) since driver falsely stated it was already calculated. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-03forcedeth: reset register fixAyaz Abdulla
This patch fixes the reset register definition from 0x3C to 0x34. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28forcedeth endianness bugsAl Viro
* misannotation: struct register_test members are actually host-endian * bug: cpu_to_le64(n) >> 32 instead of cpu_to_le32(n >> 32) in setting ->bufhigh and similar for ->buflow (take low bits, _then_ convert to little-endian, not the other way round). * bug: setup_hw_rings() should not convert to little-endian at all (we feed the result to writel(), not store in shared data structure), let alone try to play with shifting and masking little-endian values. Introduced when setup_hw_rings() went in, screwed both 64bit case and the old code for 32bit rings it had replaced. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-08[FORCEDETH]: Fix reversing the MAC address on suspend.Björn Steinbrink
For cards that initially have the MAC address stored in reverse order, the forcedeth driver uses a flag to signal whether the address was already corrected, so that it is not reversed again on a subsequent probe. Unfortunately this flag, which is stored in a register of the card, seems to get lost during suspend, resulting in the MAC address being reversed again. To fix that, the MAC address needs to be written back in reversed order before we suspend and the flag needs to be reset. The flag is still required because at least kexec will never write back the reversed address and thus needs to know what state the card is in. Signed-off-by: Björn Steinbrink <B.Steinbrink@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-23forcedeth boot delay fixAyaz Abdulla
Fix a long boot delay in the forcedeth driver. During initialization, the timeout for the handshake between mgmt unit and driver can be very long. The patch reduces the timeout by eliminating a extra loop around the timeout logic. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=9308 Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Cc: Alex Howells <astinus@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-23forcedeth: new mcp79 pci idsAyaz Abdulla
This patch adds new device ids and features for mcp79 devices into the forcedeth driver. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-25[netdrvr] forcedeth: add MCP77 device IDsAyaz Abdulla
2007-10-17forcedeth msi bugfixManfred Spraul
pci_enable_msi() replaces the INTx irq number in pci_dev->irq with the new MSI irq number. The forcedeth driver did not update the copy in netdevice->irq and parts of the driver used the stale copy. See bugzilla.kernel.org, bug 9047. The patch - updates netdevice->irq - replaces all accesses to netdevice->irq with pci_dev->irq. The patch is against 2.6.23.1. IMHO suitable for both 2.6.23 and 2.6.24 Signed-Off-By: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-17forcedeth: fix rx-work condition in nv_rx_process_optimized() tooIngo Molnar
The merge of my previous fix to forcedeth.c, bcb5febb248f7cc1e4a39ff61507f6343ba1c594, lost an important hunk. We need to fix nv_rx_process_optimized() too, as it contains duplicate logic. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-16[netdrvr] forcedeth: remove in-driver copy of net_device_statsJeff Garzik
A copy of struct net_device_stats now lives in struct net_device, making in-driver copies a waste of memory. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-16[netdrvr] forcedeth: improved probe info; dev_printk() cleanupsJeff Garzik
main change: * greatly improve per-NIC probe diagnostic output. Similar to other net drivers, print out MAC address, PHY info, and various hardware and software flags that may be relevant. other changes: * similar to other net drivers, only print the initial version message when we have found at least one board. * don't bother to print error message when pci_enable_device() fails, it will do so for us. * use dev_printk() rather than printk() in nv_probe(). This gives use a standardized output similar to the rest of the kernel, and eliminates the need to manually print out PCI bus id. * use DRV_NAME constant where appropriate * clean struct pci_driver indentation Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-16forcedeth: fix NAPI rx poll functionIngo Molnar
fix the forcedeth NAPI poll function to not emit this warning: [ 186.635916] WARNING: at net/core/dev.c:2166 net_rx_action() [ 186.641351] [<c060d9f5>] net_rx_action+0x145/0x1b0 [ 186.646191] [<c011d752>] __do_softirq+0x42/0x90 [ 186.650784] [<c011d7c6>] do_softirq+0x26/0x30 [ 186.655202] [<c011db48>] local_bh_enable+0x48/0xa0 [ 186.660055] [<c06023e0>] lock_sock_nested+0xa0/0xc0 [ 186.664995] [<c065da16>] tcp_recvmsg+0x16/0xbc0 [ 186.669588] [<c013e94b>] __generic_file_aio_write_nolock+0x27b/0x520 [ 186.676001] [<c0601d75>] sock_common_recvmsg+0x45/0x70 [ 186.681202] [<c05ff5df>] sock_aio_read+0x11f/0x140 [ 186.686054] [<c015c086>] do_sync_read+0xc6/0x110 [ 186.690735] [<c012b9b0>] autoremove_wake_function+0x0/0x40 [ 186.696280] [<c060dcfc>] net_tx_action+0x3c/0xe0 [ 186.700961] [<c015c9c2>] vfs_read+0x132/0x140 [ 186.705378] [<c015cd41>] sys_read+0x41/0x70 [ 186.709625] [<c0102b66>] sysenter_past_esp+0x5f/0x89 [ 186.714651] ======================= Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-10forcedeth: "no link" is informationalEd Swierk
Log "no link during initialization" at KERN_INFO as it's not an error, and occurs every time the interface comes up (when the forcedeth-phy-power-down patch is applied). Signed-off-by: Ed Swierk <eswierk@arastra.com> Cc: Ayaz Abdulla <aabdulla@nvidia.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[netdrvr] Stop using legacy hooks ->self_test_count, ->get_stats_countJeff Garzik
These have been superceded by the new ->get_sset_count() hook. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[ETHTOOL] Provide default behaviors for a few ethtool sub-ioctlsJeff Garzik
For the operations get-tx-csum get-sg get-tso get-ufo the default ethtool_op_xxx behavior is fine for all drivers, so we permit op==NULL to imply the default behavior. This provides a more uniform behavior across all drivers, eliminating ethtool(8) "ioctl not supported" errors on older drivers that had not been updated for the latest sub-ioctls. The ethtool_op_xxx() functions are left exported, in case anyone wishes to call them directly from a driver-private implementation -- a not-uncommon case. Should an ethtool_op_xxx() helper remain unused for a while, except by net/core/ethtool.c, we can un-export it at a later date. [ Resolved conflicts with set/get value ethtool patch... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-25fix realtek phy id in forcedethWilly Tarreau
As noticed by Chuck Ebbert, commit c5e3ae8823693b260ce1f217adca8add1bc0b3de introduced a copy-paste typo, as realtek phy is 0x732 and not 0x1c1. Obvious fix below suggested by Ayaz Abdulla. Signed-off-by: Willy Tarreau <w@1wt.eu> Cc: Ayaz Abdulla <aabdulla@nvidia.com> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-18fix random hang in forcedeth driver when using netconsoleTimo Jantunen
If the forcedeth driver receives too much work in an interrupt, it assumes it has a broken hardware with stuck IRQ. It works around the problem by disabling interrupts on the nic but makes a printk while holding device spinlog - which isn't smart thing to do if you have netconsole on the same nic. This patch moves the printk's out of the spinlock protected area. Without this patch the machine hangs hard. With this patch everything still works even when there is significant increase on CPU usage while using the nic. Signed-off-by: Timo Jantunen <jeti@iki.fi> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31[NET]: ethtool_perm_addr only has one implementationMatthew Wilcox
All drivers implement ethtool get_perm_addr the same way -- by calling the generic function. So we can inline the generic function into the caller and avoid going through the drivers. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-30forcedeth: mac address correctAyaz Abdulla
In older chipsets, the mac address was stored in reversed order. However, in newer chipsets, the mac address is in correct order. This patch takes those newer chipsets into account and does not rely on a special bit setup by BIOS'. Signed-Off-By: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-24forcedeth: mcp73 device additionAyaz Abdulla
This patch contains new device settings for MCP73 chipset. Signed-Off-By: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (37 commits) forcedeth bug fix: realtek phy forcedeth bug fix: vitesse phy forcedeth bug fix: cicada phy atl1: reorder atl1_main functions atl1: fix excessively indented code atl1: cleanup atl1_main atl1: header file cleanup atl1: remove irq_sem cdc-subset to support new vendor/product ID 8139cp: implement the missing dev->tx_timeout myri10ge: Remove nonsensical limit in the tx done routine gianfar: kill unused header EP93XX_ETH must select MII macb: Add multicast capability macb: Use generic PHY layer s390: add barriers to qeth driver s390: scatter-gather for inbound traffic in qeth driver eHEA: Introducing support vor DLPAR memory add Fix a potential NULL pointer dereference in free_shared_mem() in drivers/net/s2io.c [PATCH] softmac: Fix ESSID problem ...
2007-07-16forcedeth bug fix: realtek phyAyaz Abdulla
This patch contains errata fixes for the realtek phy. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-16forcedeth bug fix: vitesse phyAyaz Abdulla
This patch contains errata fixes for the vitesse phy. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-16forcedeth bug fix: cicada phyAyaz Abdulla
This patch contains errata fixes for the cicada phy. It only renamed the defines to be phy specific. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
