This patch fixes alignment whereever it doesn't match the open parenthesis
alignment.
Signed-off-by: Kalesh AP <kalesh.purayil@emulex.com>
Signed-off-by: Sathya Perla <sathya.perla@emulex.com>
This patch removes multiple assignments on a single line as warned
by checkpatch.
This patch removes unnecessary spaces after typecasts as per checkpatch warnings.
This patch fixes checkpatch warnings about blank lines after an open brace '{'.
This patch inserts a blank line after function/struct/union/enum definitions
This patch removes multiple blank lines in the driver as per checkpatch
warnings.
This patch fixes checkpatch warnings in be2net by adding a blank line
between declaration and code blocks.
This patch adds speed reporting via ethtool for 20G KR2 interface on the
Skyhawk-R chip.
Signed-off-by: Vasundhara Volam <vasundhara.volam@emulex.com>
This patch adds speed reporting via ethtool for 40Gbps KR4 interface
on the Skyhawk-R chip.
This patch fixes a sprase warnings regarding endian declarations introduced
by the following commit:
fixes: e36edd9 ("be2net: add ethtool "-m" option support")
Signed-off-by: Suresh Reddy <Suresh.Reddy@emulex.com>
This patch fixes a sparse warning about missing static declaration that was
introduced by the following commit:
fixes: 936767039cdf ("be2net: send a max of 8 EQs to be_cmd_modify_eqd() on Lancer")
There have extra identation before .skb_copy_to_linear_data_offset(),
this patch just remove the identation.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Fugang Duan <B38611@freescale.com>
Fix the below warning message:
qlge_main.c:1754: warning: 'lbq_desc' may be used uninitialized in this function
Signed-off-by: Harish Patil <harish.patil@qlogic.com>
Resolves compile warning about use of a deprecated function call:
drivers/net/ethernet/amd/nmclan_cs.c: In function ‘nmclan_config’:
drivers/net/ethernet/amd/nmclan_cs.c:624:3: warning: ‘pcmcia_request_exclusive_irq’ is deprecated (declared at include/pcmcia/ds.h:213) [-Wdeprecated-declarations]
ret = pcmcia_request_exclusive_irq(link, mace_interrupt);
Updates pcmcia_request_exclusive_irq() to pcmcia_request_irq().
CC: Roger Pao <rpao@paonet.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jkirsher/net-next
Jeff Kirsher says:
Intel Wired LAN Driver Updates 2014-09-18
This series contains updates to ixgbe and ixgbevf.
Ethan Zhao cleans up ixgbe and ixgbevf by removing bd_number from the
adapter struct because it is not longer useful.
Mark fixes ixgbe where if a hardware transmit timestamp is requested,
an uninitialized workqueue entry may be scheduled. Added a check for
a PTP clock to avoid that.
Jacob provides a number of cleanups for ixgbe. Since we may call
ixgbe_acquire_msix_vectors() prior to registering our netdevice, we
should not use the netdevice specific printk and use e_dev_warn()
instead. Similar to how ixgbevf handles acquiring MSI-X vectors, we
can return an error code instead of relying on the flag being set.
This makes it more clear that we have failed to setup MSI-X mode and
will make it easier to consolidate MSI-X related code into a single
function. In the case of disabling DCB, it is not an error since we
still can function, we just have to let the user know. So use
e_dev_warn() instead of e_err(). Added warnings for other features
that are disabled when we are without MSI-X support. Cleanup flags
that are no longer used or needed.
This function derives the base address of the CQE from the CQE size,
and calculates the real CQE context segment in it from the factor
(this is like before). Before this change the code used the factor to
calculate the base address of the CQE as well.
The factor indicates in which segment of the cqe stride the cqe information
is located. For 32-byte strides, the segment is 0, and for 64 byte strides,
the segment is 1 (bytes 32..63). Using the factor was ok as long as we had
only 32 and 64 byte strides. However, with larger strides, the factor is zero,
and so cannot be used to calculate the base of the CQE.
The helper uses the same method of CQE buffer pulling made by all other
components that reads the CQE buffer (mlx4_ib driver and libmlx4).
Signed-off-by: Ido Shamay <idos@mellanox.com>
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Enable mlx4 interrupt handler to work with EQE stride feature,
The feature may be enabled when cache line is bigger than 64B.
The EQE size will then be the cache line size, and the context
segment resides in [0-31] offset.
This feature is intended for archs having cache line larger then 64B.
Since our CQE/EQEs are generally 64B in those systems, HW will write
twice to the same cache line consecutively, causing pipe locks due to
he hazard prevention mechanism. For elements in a cyclic buffer, writes
are consecutive, so entries smaller than a cache line should be
avoided, especially if they are written at a high rate.
Reduce consecutive writes to same cache line in CQs/EQs, by allowing the
driver to increase the distance between entries so that each will reside
in a different cache line. Until the introduction of this feature, there
were two types of CQE/EQE:
1. 32B stride and context in the [0-31] segment
2. 64B stride and context in the [32-63] segment
This feature introduces two additional types:
3. 128B stride and context in the [0-31] segment (128B cache line)
4. 256B stride and context in the [0-31] segment (256B cache line)
Modify the mlx4_core driver to query the device for the CQE/EQE cache
line stride capability and to enable that capability when the host
cache line size is larger than 64 bytes (supported cache lines are
128B and 256B).
The mlx4 IB driver and libmlx4 need not be aware of this change. The PF
context behaviour is changed to require this change in VF drivers
running on such archs.
When using new Multi-function modes it's possible that due to incompatible
configuration management FW will fallback into an existing mode.
Notice that at the moment this fallback is exactly the same as the already
existing switch-independent multi-function mode, but we still use existing
infrastructure to hold this information [in case some small differences will
arise in the future].
Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com>
Signed-off-by: Dmitry Kravkov <Dmitry.Kravkov@qlogic.com>
Signed-off-by: Ariel Elior <Ariel.Elior@qlogic.com>
Add support for a new multi-function mode based on the Unified Fabric Port
system specifications.
Support includes configuration of:
1. Outer vlan tags.
2. Bandwidth settings.
3. Virtual link enable/disable.
Rearrange macros to query for storage-only modes in different MF environment.
Improves the readibility and maintainability of the code. E.g.:
- if (IS_MF_STORAGE_SD(bp) || IS_MF_FCOE_AFEX(bp))
+ if (IS_MF_STORAGE_ONLY(bp))
In addition, this removes the need for bnx2x_is_valid_ether_addr().
The integrated BCM7xxx PHY contains no useful revision information in
its MII_PHYSID2 bits 3:0, that information is instead contained in the
GENET hardware block.
We already read the GENET 32-bit revision register, so store the
integrated PHY revision in the driver private structure, and then
communicate this revision value to the PHY driver by overriding the
phy_flags value.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Now that we have removed the need for the PHY_BRCM_100MBPS_WAR flag, we
can remove it from the GENET driver and the broadcom shared header file.
The PHY driver checks the PHY supported bitmask instead.
When enable three queues on imx6sx enet, and then do tx performance
test with iperf tool, after some time running, tx hang.
Found that:
If uDMA is running, software set TDAR may cause tx hang.
If uDMA is in idle, software set TDAR don't cause tx hang.
There is a TDAR race condition for mutliQ when the software sets TDAR
and the UDMA clears TDAR simultaneously or in a small window (2-4 cycles).
This will cause the udma_tx and udma_tx_arbiter state machines to hang.
The issue exist at i.MX6SX enet IP.
So, the Workaround is checking TDAR status four time, if TDAR cleared by
hardware and then write TDAR, otherwise don't set TDAR.
The patch is only one Workaround for the issue ERR007885.
Signed-off-by: Frank Li <Frank.Li@freescale.com>
when enable interrupt coalesce, 8 BD is not enough.
i.MX6 SX support interrupt coalescence feature
By default, init the interrupt coalescing frame count threshold and
timer threshold.
Supply the ethtool interfaces as below for user tuning to improve
enet performance:
rx_max_coalesced_frames
rx_coalesce_usecs
tx_max_coalesced_frames
tx_coalesce_usecs
check tx and rx queue seperately.
fix typo, "Invalidate" and "fail".
change pr_err to pr_warn.
They were not used, and we don't need them, so we shouldn't bother with
keeping values in the flags field that could be misleading.
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Tested-by: Phil Schmitt <phillip.j.schmitt@intel.com>
When we can't get MSI-X vectors, we disable a few features which require
MSI-X vectors. Print warnings just like we do when disabling DCB.
Again, we should not be directly using netif_printk, as we have our own
error print routines that we generate. In addition, instead of using an
early return we can just use the else block of this one line if
statement.
In this case, disabling DCB is not an error. We can still function, but
we just have to let the user know. In addition, since we call this
during probe before allocating our netdevice structure, we should use
e_dev_warn instead of e_warn.
Our calculated v_budget doesn't matter except if we allocate MSI-X
vectors. We shouldn't need to calculate this outside of the function, so
don't. Instead, only calculate it once we attempt to acquire MSI-X
vectors. This helps collocate all of the MSI-X vector code together.
We already have to kfree this value if we fail, and this is only part of
MSI-X mode, so we should simply allocate the value where we need it.
This is cleaner, and makes it a lot more obvious why we are freeing it
inside of ixgbe_acquire_msix_vectors.
Similar to how ixgbevf handles acquiring MSI-X vectors, we can return an
error code instead of relying on the flag being set. This makes it more
clear that we have failed to setup MSI-X mode, and also will make it
easier to consolidate MSI-X related code all into the single function.
The netif_printk relies on our netdevice structure to be registered
already. We may call ixgbe_acquire_msix_vectors prior to registering our
netdevice, so we should not use the netdevice specific printk.
If a hardware Tx timestamp is requested, an uninitialized
workqueue entry may be scheduled, especially on an 82598 adapter.
Add a check for a PTP clock to avoid that. Also only apply the
unlikely to the first term of the conditional. That will make the
rest of the checks be in the cold path.
Signed-off-by: Mark Rustad <mark.d.rustad@intel.com>
Acked-by: Matthew Vick <matthew.vick@intel.com>
Because bd_number is not useful anymore, so remove it from adapter struct, or
if keep it, we have to fix the boards driven counter bug in ixgbe_remove() and
ixgbe_probe() only for trivial debug purpose -- other output is enough.
Signed-off-by: Ethan Zhao <ethan.zhao@oracle.com>
It is useless and buggy, just remove it.
reproduce:
wget https://git.kernel.org/cgit/linux/kernel/git/wfg/lkp-tests.git/plain/sbin/make.cross -O ~/bin/make.cross
chmod +x ~/bin/make.cross
git checkout 4d494cdc92b3b9a0f5fb9e1560810fa27d5a0489
make.cross ARCH=m68k m5272c3_defconfig
drivers/net/ethernet/freescale/fec.h:262:0: warning: "FEC_R_DES_START" redefined
#define FEC_R_DES_START(X) ((X == 1) ? FEC_R_DES_START_1 : \
drivers/net/ethernet/freescale/fec.h:158:0: note: this is the location of the previous definition
#define FEC_R_DES_START 0x3d0 /* Receive descriptor ring */
drivers/net/ethernet/freescale/fec.h:265:0: warning: "FEC_X_DES_START" redefined
#define FEC_X_DES_START(X) ((X == 1) ? FEC_X_DES_START_1 : \
null-terminate in conjunction with strncpy
Replacing strncpy with strlcpy to avoid strings that lacks null terminate.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
Use container_of instead of casting first structure member.
Compiled but untested.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
ARM cross-compiled but untested.
Print the IP revision when probing.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Software clear the MDIO interrupt before MDIO bus access, but
MAC still generate MDIO interrupt. The issue only happen on
imx6slx chip.
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.17.0-rc1-00399-g0bcad17 #315
Backtrace:
[<800121fc>] (dump_backtrace) from [<800124e0>] (show_stack+0x18/0x1c)
r6:8096e534 r5:8096e534 r4:00000000 r3:00000000
[<800124c8>] (show_stack) from [<806a4c60>] (dump_stack+0x8c/0xa4)
[<806a4bd4>] (dump_stack) from [<80060ab8>] (__lock_acquire+0x1814/0x1c40)
r6:be078000 r5:be074000 r4:be03f6e4 r3:be078000
[<8005f2a4>] (__lock_acquire) from [<800616e0>] (lock_acquire+0x70/0x84)
r10:809ada33 r9:be010600 r8:00000096 r7:00000001 r6:be074000 r5:00000000
r4:60000193
[<80061670>] (lock_acquire) from [<806abb20>] (_raw_spin_lock_irqsave+0x40/0x54)
r7:00000000 r6:8005a3f8 r5:00000193 r4:be03f6d4
[<806abae0>] (_raw_spin_lock_irqsave) from [<8005a3f8>] (complete+0x1c/0x4c)
r6:80950904 r5:be03f6d0 r4:be03f6d4
[<8005a3dc>] (complete) from [<8041b4c0>] (fec_enet_interrupt+0x128/0x164)
r6:80950904 r5:00800000 r4:be03f000 r3:00000000
[<8041b398>] (fec_enet_interrupt) from [<8006aeac>] (handle_irq_event_percpu+0x38/0x13c)
r6:00000000 r5:be01065c r4:be399e00 r3:8041b398
[<8006ae74>] (handle_irq_event_percpu) from [<8006aff4>] (handle_irq_event+0x44/0x64)
r10:be03f000 r9:80989fe0 r8:00000000 r7:00000096 r6:be399e00 r5:be01065c
r4:be010600
[<8006afb0>] (handle_irq_event) from [<8006e3e8>] (handle_fasteoi_irq+0xc8/0x1bc)
r6:8096e764 r5:be01065c r4:be010600 r3:00000000
[<8006e320>] (handle_fasteoi_irq) from [<8006a63c>] (generic_handle_irq+0x30/0x44)
r6:be074010 r5:80945e4c r4:00000096 r3:8006e320
[<8006a60c>] (generic_handle_irq) from [<8000f218>] (handle_IRQ+0x54/0xbc)
r4:80950d74 r3:00000180
[<8000f1c4>] (handle_IRQ) from [<800086cc>] (gic_handle_irq+0x30/0x68)
r8:be3ab478 r7:c080e100 r6:be075bd8 r5:80950eec r4:c080e10c r3:000000a0
[<8000869c>] (gic_handle_irq) from [<80013064>] (__irq_svc+0x44/0x5c)
i.MX6 SX change FEC alignment requirement.
i.MX6 SX change internal bus from AHB to AXI.
It require RX buffer must be 64 bytes alignment.
And remove TX buffer alignment requirement.
Add compatible string "fsl,imx6sx-fec" for i.MX6SX.
i.MX6SX Enet-AVB support 3 tx queues, 3 rx queues.
For tx queues: ring 0 -> best effort
ring 1 -> Class A
ring 2 -> Class B
For rx queues:
ring 1 -> receive VLAN packet with classification match
ring 2 -> receive VLAN packet with classification match
Add enet-avb IP multiqueue support for the driver.
For i.MX6SX enet use AXI bus, reset MAC will make system bus dead
if ENET-AXI bus has pending access (AHB bus should not have such issue).
So, disable enet with AVB MAC instead of reset MAC itself.
