This patch implements PHC (ptp hardware clock) driver for stmmac
driver to support 1588 PTP.
V2: added support for FINE method, reduced loop delay and review spinlock.
Signed-off-by: Rayagond Kokatanur <rayagond@vayavyalabs.com>
Hacked-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Cc: Richard Cochran <richardcochran@gmail.com>
This patch enhances the stmmac driver to support IEEE 1588-2002
PTP (Precision Time Protocol) version 1 and IEEE 1588-2008 PPT
version 2.
Precision Time Protocol(PTP),which enables precise synchronization
of clocks in measurement and control systems implemented with
technologies such as network communication,local computing,
& distributed objects.
Both PTPv1 and PTPv2 is selected at run-time using the HW capability
register.
The PTPv1 TimeStamp support can be used on chips that have the normal
descriptor structures and PTPv2 TimeStamp support can be used on chips
that have the Extended descriptors(DES4-5-6-7). All such sanity checks
are done and verified by using HW capability register.
V2: in this version the ethtool support has been included in this patch;
Koptions have been completely removed (previously added to select
PTP and PTPv2). PTPv1 and PTPv2 is now added in a single patch instead of
two patches.
get_timestamp() and get_systemtime() L/H have been combined into single APIs.
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Previously we had two Koptions to decide if the stmmac
had to use either a ring or a chain to manage its descriptors.
This patch removes the Kernel configuration options and it allow us
to use the chain mode by passing a module option.
Ring mode continues to be the default.
Also with this patch, it will be easier to validate the driver built and
guarantee that all the two modes always compile fine.
The TIMER option is not longer supported and this
code can be considered dead for this driver in
the new kernel series.
In fact, It was not updated at all and never used.
This patch adds the PCI support (as EXPERIMENTAL)
this has been also tested on XLINX XC2V3000 FF1152AMT0221
D1215994A VIRTEX FPGA board.
To support the PCI bus the main part has been reworked
and both the platform and the PCI specific parts have
been moved into different files.
This patch enhances the STMMAC driver to support CHAINED mode of
descriptor.
STMMAC supports DMA descriptor to operate both in dual buffer(RING)
and linked-list(CHAINED) mode. In RING mode (default) each descriptor
points to two data buffer pointers whereas in CHAINED mode they point
to only one data buffer pointer.
In CHAINED mode each descriptor will have pointer to next descriptor in
the list, hence creating the explicit chaining in the descriptor itself,
whereas such explicit chaining is not possible in RING mode.
First version of this work has been done by Rayagond.
Then the patch has been reworked avoiding ifdef inside the C code.
A new header file has been added to define all the functions needed for
managing enhanced and normal descriptors.
In fact, these have to be specialized according to the ring/chain usage.
Two new C files have been also added to implement the helper routines
needed to manage: jumbo frames, chain and ring setup (i.e. desc3).
This patch adds the MMC management counters support.
MMC module is an extension of the register address
space and all the hardware counters can be accessed
via ethtoo -S ethX.
Note that, the MMC interrupts remain masked and the logic
to handle this kind of interrupt will be added later (if
actually useful).
Move the STMicroelectronics driver into driver/net/ethernet/stmicro/ and
make the necessary Kconfig and Makefile changes.
CC: Giuseppe Cavallaro <peppe.cavallaro@st.com>
