This howto made sense in the 1990s when users had to manually configure
ISA cards with jumpers or vendor utilities, but with the implementation
of PCI it became increasingly less and less relevant, to the point where
it has been well over a decade since I last updated it. And there is
no value in anyone else taking over updating it either.
However the references to it continue to spread as boiler plate text
from one Kconfig file into the next. We are not doing end users any
favours by pointing them at this old document, so lets kill it with
fire, once and for all, to hopefully stop any further spread.
No code is changed in this commit, just Kconfig help text.
The same macros are used for rx as well. So rename it.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
As of commit e4dc601bf99ccd1c ("m68k: Disable/restore interrupts in
hwreg_present()/hwreg_write()"), this is no longer needed.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to
meet kernel coding style guidelines. This issue was reported by checkpatch.
A simplified version of the semantic patch that makes this change is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
identifier i;
declarer name DEFINE_PCI_DEVICE_TABLE;
initializer z;
- DEFINE_PCI_DEVICE_TABLE(i)
+ const struct pci_device_id i[]
= z;
// </smpl>
[bhelgaas: add semantic patch]
Signed-off-by: Benoit Taine <benoit.taine@lip6.fr>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
net: get rid of SET_ETHTOOL_OPS
Dave Miller mentioned he'd like to see SET_ETHTOOL_OPS gone.
This does that.
Mostly done via coccinelle script:
struct ethtool_ops *ops;
struct net_device *dev;
- SET_ETHTOOL_OPS(dev, ops);
+ dev->ethtool_ops = ops;
Compile tested only, but I'd seriously wonder if this broke anything.
Suggested-by: Dave Miller <davem@davemloft.net>
Signed-off-by: Wilfried Klaebe <w-lkml@lebenslange-mailadresse.de>
Acked-by: Felipe Balbi <balbi@ti.com>
Pull networking updates from David Miller:
1) BPF debugger and asm tool by Daniel Borkmann.
2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann.
3) Correct reciprocal_divide and update users, from Hannes Frederic
Sowa and Daniel Borkmann.
4) Currently we only have a "set" operation for the hw timestamp socket
ioctl, add a "get" operation to match. From Ben Hutchings.
5) Add better trace events for debugging driver datapath problems, also
from Ben Hutchings.
6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we
have a small send and a previous packet is already in the qdisc or
device queue, defer until TX completion or we get more data.
7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko.
8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel
Borkmann.
9) Share IP header compression code between Bluetooth and IEEE802154
layers, from Jukka Rissanen.
10) Fix ipv6 router reachability probing, from Jiri Benc.
11) Allow packets to be captured on macvtap devices, from Vlad Yasevich.
12) Support tunneling in GRO layer, from Jerry Chu.
13) Allow bonding to be configured fully using netlink, from Scott
Feldman.
14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can
already get the TCI. From Atzm Watanabe.
15) New "Heavy Hitter" qdisc, from Terry Lam.
16) Significantly improve the IPSEC support in pktgen, from Fan Du.
17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom
Herbert.
18) Add Proportional Integral Enhanced packet scheduler, from Vijay
Subramanian.
19) Allow openvswitch to mmap'd netlink, from Thomas Graf.
20) Key TCP metrics blobs also by source address, not just destination
address. From Christoph Paasch.
21) Support 10G in generic phylib. From Andy Fleming.
22) Try to short-circuit GRO flow compares using device provided RX
hash, if provided. From Tom Herbert.
The wireless and netfilter folks have been busy little bees too.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits)
net/cxgb4: Fix referencing freed adapter
ipv6: reallocate addrconf router for ipv6 address when lo device up
fib_frontend: fix possible NULL pointer dereference
rtnetlink: remove IFLA_BOND_SLAVE definition
rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info
qlcnic: update version to 5.3.55
qlcnic: Enhance logic to calculate msix vectors.
qlcnic: Refactor interrupt coalescing code for all adapters.
qlcnic: Update poll controller code path
qlcnic: Interrupt code cleanup
qlcnic: Enhance Tx timeout debugging.
qlcnic: Use bool for rx_mac_learn.
bonding: fix u64 division
rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC
sfc: Use the correct maximum TX DMA ring size for SFC9100
Add Shradha Shah as the sfc driver maintainer.
net/vxlan: Share RX skb de-marking and checksum checks with ovs
tulip: cleanup by using ARRAY_SIZE()
ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called
net/cxgb4: Don't retrieve stats during recovery
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
This covers everything under drivers/net except for wireless, which
has been submitted separately.
The driver core clears the driver data to NULL after device_release
or on probe failure. Thus, it is not needed to manually clear the
device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Several files refer to an old address for the Free Software Foundation
in the file header comment. Resolve by replacing the address with
the URL <http://www.gnu.org/licenses/> so that we do not have to keep
updating the header comments anytime the address changes.
CC: Santosh Raspatur <santosh@chelsio.com>
CC: Dimitris Michailidis <dm@chelsio.com>
CC: Michael Chan <mchan@broadcom.com>
CC: Santiago Leon <santil@linux.vnet.ibm.com>
CC: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
CC: Olof Johansson <olof@lixom.net>
CC: Manish Chopra <manish.chopra@qlogic.com>
CC: Sony Chacko <sony.chacko@qlogic.com>
CC: Rajesh Borundia <rajesh.borundia@qlogic.com>
CC: Nicolas Pitre <nico@fluxnic.net>
CC: Steve Glendinning <steve.glendinning@shawell.net>
Add missing platform_set_drvdata() in xtsonic_probe(), otherwise
calling platform_get_drvdata() in xtsonic_device_remove() may
returns NULL.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
This patch proposes to remove the IRQF_DISABLED flag from
code in drivers/net/ethernet/natsemi/
It's a NOOP since 2.6.35 and it will be removed one day.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Add a protocol argument to the VLAN packet tagging functions. In case of HW
tagging, we need that protocol available in the ndo_start_xmit functions,
so it is stored in a new field in the skb. The new field fits into a hole
(on 64 bit) and doesn't increase the sks's size.
Rename the hardware VLAN acceleration features to include "CTAG" to indicate
that they only support CTAGs. Follow up patches will introduce 802.1ad
server provider tagging (STAGs) and require the distinction for hardware not
supporting acclerating both.
I believe these error messages are already logged
on allocation failure by warn_alloc_failed and so
get a dump_stack on OOM.
Remove the unnecessary additional error logging.
Around these deletions:
o Alignment neatening.
o Remove unnecessary casts of dma_alloc_coherent.
o Hoist assigns from ifs.
Emitting netdev_alloc_skb and netdev_alloc_skb_ip_align OOM
messages is unnecessary as there is already a dump_stack
after allocation failures.
Other trivial changes around these removals:
Convert a few comparisons of pointer to 0 to !pointer.
Change flow to remove unnecessary label.
Remove now unused variable.
Hoist assignment from if.
Pull driver core patches from Greg Kroah-Hartman:
"Here is the big driver core merge for 3.9-rc1
There are two major series here, both of which touch lots of drivers
all over the kernel, and will cause you some merge conflicts:
- add a new function called devm_ioremap_resource() to properly be
able to check return values.
- remove CONFIG_EXPERIMENTAL
Other than those patches, there's not much here, some minor fixes and
updates"
Fix up trivial conflicts
* tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits)
base: memory: fix soft/hard_offline_page permissions
drivercore: Fix ordering between deferred_probe and exiting initcalls
backlight: fix class_find_device() arguments
TTY: mark tty_get_device call with the proper const values
driver-core: constify data for class_find_device()
firmware: Ignore abort check when no user-helper is used
firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER
firmware: Make user-mode helper optional
firmware: Refactoring for splitting user-mode helper code
Driver core: treat unregistered bus_types as having no devices
watchdog: Convert to devm_ioremap_resource()
thermal: Convert to devm_ioremap_resource()
spi: Convert to devm_ioremap_resource()
power: Convert to devm_ioremap_resource()
mtd: Convert to devm_ioremap_resource()
mmc: Convert to devm_ioremap_resource()
mfd: Convert to devm_ioremap_resource()
media: Convert to devm_ioremap_resource()
iommu: Convert to devm_ioremap_resource()
drm: Convert to devm_ioremap_resource()
In commit a5e371f61ad33c07b28e7c9b60c78d71fdd34e2a ("drivers/net: delete
all code/drivers depending on CONFIG_MCA") most of the MCA drivers went,
including the Kconfig/Makefile hooks for ibmlana, but it seems that I
missed the "git rm" on these actual driver files, and with the namespace
overlap with machine check architecture, it got missed by various git
grep type checking done at that time.
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
CC: Paul Gortmaker <paul.gortmaker@windriver.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
perm_addr is initialized correctly in register_netdevice() so to init it in
drivers is no longer needed.
The __dev* removal patches for the network drivers ended up messing up
the function prototypes for a bunch of drivers. This patch fixes all of
them back up to be properly aligned.
Bonus is that this almost removes 100 lines of code, always a nice
surprise.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
The function sonic_probe1() return 0 for success and negative value
for most of its internal tests failures. There is one exception
that is error case going to out:. For this error case, the
function abort its success execution path, but returns non negative
value, making it difficult for a caller function to notice the error.
This patch fixes the error case that do not return negative value.
This was found by Coccinelle, but the code change was made by hand.
This patch is not robot generated.
A simplified version of the semantic match that finds this problem is
as follows: (http://coccinelle.lip6.fr/)
// <smpl>
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
The function natsemi_probe1() return 0 for success and negative value
that is error case going to err_create_file:. Fore this error case the
function abort its success execution path, but returns non negative value,
// <smpl>
{ ... return ret; }
ret@p1 = 0
when != &ret
*if(...)
when forall
return ret;
// </smpl>
Acked-by: Francois Romieu <romieu@fr.zoreil.com>
The support for CONFIG_MCA is being removed, since the 20
year old hardware simply isn't capable of meeting today's
software demands on CPU and memory resources.
This commit removes any MCA specific net drivers, and removes
any MCA specific probe/support code from drivers that were
doing a dual ISA/MCA role.
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: netdev@vger.kernel.org
It's useless to check mem_start on a newly allocated device.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Cc: Tim Hockin <thockin@hockin.org>
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Replace usage of random_ether_addr() with eth_hw_addr_random()
to set addr_assign_type correctly to NET_ADDR_RANDOM.
Change the trivial cases.
v2: adapt to renamed eth_hw_addr_random()
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Replaced deprecating dev_alloc_skb with netdev_alloc_skb in drivers/net/ethernet
- Removed extra skb->dev = dev after netdev_alloc_skb
Signed-off-by: Pradeep A Dalvi <netdev@pradeepdalvi.com>
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: (21 commits)
m68k/mac: Make CONFIG_HEARTBEAT unavailable on Mac
m68k/serial: Remove references to obsolete serial config options
m68k/net: Remove obsolete IRQ_FLG_* users
m68k: Don't comment out syscalls used by glibc
m68k/atari: Move declaration of atari_SCC_reset_done to header file
m68k/serial: Remove references to obsolete CONFIG_SERIAL167
m68k/hp300: Export hp300_ledstate
m68k: Initconst section fixes
m68k/mac: cleanup macro case
mac_scsi: fix mac_scsi on some powerbooks
m68k/mac: fix powerbook 150 adb_type
m68k/mac: fix baboon irq disable and shutdown
m68k/mac: oss irq fixes
m68k/mac: fix nubus slot irq disable and shutdown
m68k/mac: enable via_alt_mapping on performa 580
m68k/mac: cleanup forward declarations
m68k/mac: cleanup mac_irq_pending
m68k/mac: cleanup mac_clear_irq
m68k/mac: early console
m68k/mvme16x: Add support for EARLY_PRINTK
Fix up trivial conflict in arch/m68k/Kconfig.debug due to new
EARLY_PRINTK config option addition clashing with movement of the
BOOTPARAM options.
The m68k core irq code stopped honoring these flags during the irq
restructuring in 2006.
This patch converts the drivers in drivers/net/ethernet/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
Cc: Pantelis Antoniou <pantelis.antoniou@gmail.com>
Cc: Vitaly Bordug <vbordug@ru.mvista.com>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Nicolas Pitre <nico@fluxnic.net>
Cc: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Cc: Marc Kleine-Budde <mkl@pengutronix.de>
Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Cc: Jiri Pirko <jpirko@redhat.com>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Tobias Klauser <tklauser@distanz.ch>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Richard Cochran <richard.cochran@omicron.at>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Sebastian Poehn <sebastian.poehn@belden.com>
Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Per the mention made by Ben Hutchings that strlcpy is now the preferred
string copy routine for a .get_drvinfo routine, do a bit of floor
sweeping and convert some of the as-yet unconverted ethernet drivers to
it.
Signed-off-by: Rick Jones <rick.jones2@hp.com>
i825xx and xscale are "sub" Kconfigs to NET_VENDOR_INTEL, so
NET_VENDOR_INTEL should contain ALL the dependencies of the
"sub" Kconfigs.
Same with 8390 is a "sub" Kconfig to NET_VENDOR_NATSEMI, so
NET_VENDOR_NATSEMI needs to contains ALL the dependencies.
Freescale Kconfig only had fs_enet as a sub Kconfig, and already
contained the needed dependencies, just cleaned up the dependencies.
To ease skb->truesize sanitization, its better to be able to localize
all references to skb frags size.
Define accessors : skb_frag_size() to fetch frag size, and
skb_frag_size_{set|add|sub}() to manipulate it.
When I converted some drivers from pci_map_page to skb_frag_dma_map I
neglected to convert PCI_DMA_xDEVICE into DMA_x_DEVICE and
pci_dma_mapping_error into dma_mapping_error.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
We check ether_type before registering the platform device in
arch/m68k/mac/config.c. Doing the same test again in the driver is
redundant so remove it.
Multiple probes should not happen since the conversion to platform devices,
so lose that test too.
Then macmace.c need not include macintosh.h, so remove that and irq.h and
include linux/interrupt.h explicitly.
Tested on PowerBook 520, Quadra 660av, LC 630.
Signed-off-by: Finn Thain <fthain@telegraphics.com.au>
Based on finds for Stephen Rothwell, where current defconfig's
enable a ethernet driver and it is not compiled due to the newly
added NET_VENDOR_* component of Kconfig.
This patch enables all the "new" Kconfig options so that current
defconfig's will continue to compile the expected drivers. In
addition, by enabling all the new Kconfig options does not add
any un-expected options.
CC: Stephen Rothwll <sfc@canb.auug.org.au>
replace it by ndo_set_rx_mode
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Move the National Semi-conductor drivers into drivers/net/ethernet/natsemi/
and make the necessary Kconfig and Makefile changes. Also moved the 8390
(National Semi-conductor) devices as a sub-menu of National Semi-conductor
devices.
- moved the ibmlana driver as well into this directory since it is a
"SONIC" driver
CC: Alfred Arnold <alfred.arnold@lancom.de>
CC: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
CC: Harald Welte <laforge@gnumonks.org>
CC: Tim Hockin <thockin@hockin.org>
CC: <linux-ns83820@kvack.org>
CC: Kevin Chea <kchea@yahoo.com>
CC: Marc Gauthier <marc@linux-xtensa.org>
CC: Chris Zankel <chris@zankel.net>
Acked-by: Marc Gauthier <marc@tensilica.com>
