A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
This covers everything under drivers/net except for wireless, which
has been submitted separately.
This patch proposes to remove the IRQF_DISABLED flag from
code in drivers/net/ethernet/natsemi/
It's a NOOP since 2.6.35 and it will be removed one day.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
I believe these error messages are already logged
on allocation failure by warn_alloc_failed and so
get a dump_stack on OOM.
Remove the unnecessary additional error logging.
Around these deletions:
o Alignment neatening.
o Remove unnecessary casts of dma_alloc_coherent.
o Hoist assigns from ifs.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
This patch converts the drivers in drivers/net/ethernet/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
Cc: Pantelis Antoniou <pantelis.antoniou@gmail.com>
Cc: Vitaly Bordug <vbordug@ru.mvista.com>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Nicolas Pitre <nico@fluxnic.net>
Cc: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Cc: Marc Kleine-Budde <mkl@pengutronix.de>
Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Cc: Jiri Pirko <jpirko@redhat.com>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Tobias Klauser <tklauser@distanz.ch>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Richard Cochran <richard.cochran@omicron.at>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Sebastian Poehn <sebastian.poehn@belden.com>
Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
replace it by ndo_set_rx_mode
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Move the National Semi-conductor drivers into drivers/net/ethernet/natsemi/
and make the necessary Kconfig and Makefile changes. Also moved the 8390
(National Semi-conductor) devices as a sub-menu of National Semi-conductor
devices.
- moved the ibmlana driver as well into this directory since it is a
"SONIC" driver
CC: Alfred Arnold <alfred.arnold@lancom.de>
CC: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
CC: Harald Welte <laforge@gnumonks.org>
CC: Tim Hockin <thockin@hockin.org>
CC: <linux-ns83820@kvack.org>
CC: Kevin Chea <kchea@yahoo.com>
CC: Marc Gauthier <marc@linux-xtensa.org>
CC: Chris Zankel <chris@zankel.net>
Acked-by: Marc Gauthier <marc@tensilica.com>
