path: root/drivers/net/ethernet/moxa
2014-08-25net: moxa: continue loop on skb allocation failureJonas Jensen
If netdev_alloc_skb_ip_align() fails, subsequent code will try to dereference an invalid pointer. Continue to next descriptor on error. While we're at it, 1. eliminate the chance of an endless loop, replace the main loop with while(rx < budget) 2. use napi_complete() and remove the explicit napi_gro_flush() Signed-off-by: Jonas Jensen <jonas.jensen@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-25net: moxa: synchronize DMA memoryJonas Jensen
DMA memory should be synchronized before data is passed to/from controller. Add dma_sync_single_for_cpu(.., DMA_FROM_DEVICE) to RX path and dma_sync_single_for_device(.., DMA_TO_DEVICE) to TX path. Signed-off-by: Jonas Jensen <jonas.jensen@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-25net: moxa: replace build_skb() with netdev_alloc_skb_ip_align() / memcpy()Jonas Jensen
build_skb() is used to make skbs out of existing RX ring memory which is bad because the RX ring is allocated only once, on probe. Memory corruption occur because said memory is reclaimed, i.e. __kfree_skb() (and eventually put_page()). Replace build_skb() with netdev_alloc_skb_ip_align() and use memcpy(). Remove SKB_DATA_ALIGN() from RX buffer size while we're at it. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=69041 Signed-off-by: Jonas Jensen <jonas.jensen@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-25net: moxa: clear DESC1 on ndo_start_xmit()Jonas Jensen
TX buffer length is not cleared on ndo_start_xmit(). Failing to do so can bug/hang the controller and cause TX interrupts to stop altogether. Remove the readl() and compute a new value for DESC1. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=69031 Signed-off-by: Jonas Jensen <jonas.jensen@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-16drivers/net: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. This covers everything under drivers/net except for wireless, which has been submitted separately. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-21ethernet: moxa: remove duplicate includesMichael Opdenacker
Reported by "make includecheck" Tested that drivers/net/ethernet/moxa/moxart_ether.c still compiles well on ARM Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-08moxa: fix the error handling in moxart_mac_probe()Wei Yongjun
This patch fix the error handling in moxart_mac_probe(): - return -ENOMEM in some memory alloc fail cases - add missing free_netdev() in the error handling case Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-30ethernet: moxa: fix incorrect placement of __initdata tagBartlomiej Zolnierkiewicz
__initdata tag should be placed between the variable name and equal sign for the variable to be placed in the intended .init.data section. In this particular case __initdata is incorrect as moxart_mac_driver can be used after the driver gets initialized. Also while at it static-ize moxart_mac_driver. Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-22ethernet: moxa: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-20moxa: fix missing unlock on error in moxart_mac_start_xmit()Wei Yongjun
Add the missing unlock before return from function moxart_mac_start_xmit() in the error handling case. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-11net: Add MOXA ART SoCs ethernet driverJonas Jensen
The MOXA UC-711X hardware(s) has an ethernet controller that seem to be developed internally. The IC used is "RTL8201CP". Since there is no public documentation, this driver is mostly the one published by MOXA that has been heavily cleaned up / ported from linux 2.6.9. Signed-off-by: Jonas Jensen <jonas.jensen@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
