Signed-off-by: Jiri Pirko <jiri@mellanox.com>
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Connect current dpipe tables to resources. The tables are connected
in the following fashion:
1. IPv4 host -> KVD hash single
2. IPv6 host -> KVD hash double
3. Adjacency -> KVD linear
Signed-off-by: Arkadi Sharshevsky <arkadis@mellanox.com>
During the dump the per netlink packet entry counter should be zeroed out
when new packet is created.
Fixes: 190d38a52a73 ("mlxsw: spectrum_dpipe: Add support for adjacency table dump")
Reported-by: David Ahern <dsahern@gmail.com>
The adjacency group size is part of the match on the adjacency group and
should therefore be exposed using dpipe.
When non-equal-cost multi-path support will be introduced, the group's
size will help users understand the exact number of adjacency entries
each nexthop occupies, as a nexthop will no longer correspond to a
single entry.
The output for a multi-path route with two nexthops, one with weight 255
and the second 1 will be:
Example:
$ devlink dpipe table dump pci/0000:01:00.0 name mlxsw_adj
pci/0000:01:00.0:
index 0
match_value:
type field_exact header mlxsw_meta field adj_index value 65536
type field_exact header mlxsw_meta field adj_size value 512
type field_exact header mlxsw_meta field adj_hash_index value 0
action_value:
type field_modify header ethernet field destination mac value e4:1d:2d:a5:f3:64
type field_modify header mlxsw_meta field erif_port mapping ifindex mapping_value 3 value 1
index 1
match_value:
type field_exact header mlxsw_meta field adj_hash_index value 510
action_value:
type field_modify header ethernet field destination mac value e4:1d:2d:a5:f3:65
type field_modify header mlxsw_meta field erif_port mapping ifindex mapping_value 4 value 2
Thus, the first nexthop occupies 510 adjacency entries and the second 2,
which leads to a ratio of 255 to 1.
Add support for controlling nexthop counters via dpipe.
Add support for adjacency table dump.
Add initial support for router adjacency table. The table does lookup
based on the nexthop-group index and the local nexthop offset. After
locating the nexthop entry it sets the destination MAC address and the
egress RIF.
This patch adds field for mlxsw's meta header which will be used to
describe the match/action behavior of the adjacency table.
The fields are:
1. Adj_index - The global index of the nexthop group in the adjacency
table.
2. Adj_hash_index - Local index offset which is based on packets hash
mod the nexthop group size.
Fix indentation in mlxsw_meta header's description.
Add support for controlling IPv6 neighbor counters via dpipe.
Add support for IPv6 host table dump.
Change the host entry filler helper to be applicable for both IPv4/6
addresses.
Add IPv6 host table initial support. The action behavior for both IPv4/6
tables is the same, thus the same action dump op is used. Neighbors with
link local address are ignored.
During the neighbor traversal the neighbors from different families
should be ignored.
Fixes: c58035a74aba ("mlxsw: spectrum_dpipe: Add support for IPv4 host table dump")
Add support for controlling neighbor counters via dpipe.
Add support for IPv4 host table dump.
Add IPv4 host table initial support.
Change label name for case of erif table init failure.
The entry clear routine can be shared between the drivers, thus it is
moved inside devlink.
Up until now the dpipe table's size was static and known at registration
time. The host table does not have constant size and it is resized in
dynamic manner. In order to support this behavior the size is changed
to be obtained dynamically via an op.
This patch also adjust the current dpipe table for the new API.
Fix ERIF's table operations name space.
drivers/net/ethernet/mellanox/mlxsw//spectrum_dpipe.c:221:52: warning:
Using plain integer as NULL pointer
drivers/net/ethernet/mellanox/mlxsw//spectrum_dpipe.c:221:74: warning:
Reviewed-by: Ido Schimmel <idosch@mellanox.com>
In case of disabled counters the entry index will be incorrect. Fix this
by moving the entry index set before the counter status check.
Fixes: 2ba5999f009d ("mlxsw: spectrum: Add Support for erif table entries access")
The router interfaces (RIFs) array is of no interest to code outside the
routing realm, so declare it inside the router specific struct instead
of the chip-wide one.
Implement dpipe's table ops for erif table which provide:
1. Getting the entries in the table with the associate values.
- match on "mlxsw_meta:erif_index"
- action on "mlxsw_meta:forwared_out"
2. Synchronize the hardware in case of enabling/disabling counters which
mean removing erif counters from all interfaces.
Add definition for egress router interface table. This table describes
the final part in the routing pipeline. This table matches the egress
interface index (rif index, which is set by the previous stages and
determine the out port) and makes the decision of forwarding the packet
towards the L2 logic or dropping it.
The metadata header is added to represent this internal information.
The rif index field is mapped logically to netdevice ifindex.
Add placeholder for dpipe. Support for specific tables and headers will
be introduced in following patches. The headers are shared between all
mlxsw_sp instances.
