Add sleep mode support for i.MX8QM/QXP platforms.
Reviewed-by: Richard Zhu <hongxing.zhu@nxp.com>
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
Fix the cherry pick and merge issue by below commit on kernel 4.9:
Fixes: 19b76fd012ce ("net: fec: add stop mode support for dts register set")
Reviewed-by: Gao Pan <pandy.gao@nxp.com>
Signed-off-by: Fugang Duan <B38611@freescale.com>
The i.MX8MQ ENET version support IEEE802.3az eee mode, add
eee mode tx lpi enable to support ethtool interface.
usage:
1. set sleep and wake timer to 5ms:
ethtool --set-eee eth0 eee on tx-lpi on tx-timer 5000
2. check the eee mode:
~# ethtool --show-eee eth0
EEE Settings for eth0:
EEE status: enabled - active
Tx LPI: 5000 (us)
Supported EEE link modes: 100baseT/Full
1000baseT/Full
Advertised EEE link modes: 100baseT/Full
1000baseT/Full
Link partner advertised EEE link modes: 100baseT/Full
Note: For realtime case and IEEE1588 ptp case, it should disable
EEE mode.
i.MX8QM/QXP ENET IP version add new feture to generate delayed TXC/RXC
as an alternative option to make sure it can work well with various PHYs,
which also is useful for MAC-to-MAC case. Add the new feature support.
i.MX8QM/QXP MAC address only can be program by SCU, and A core
read fuse enet MAC address by sc APIs interface. i.MX8mScale is
inherited from i.MX7D, can directly read fuse in A-core.
Add i.MX8QM/QXP/MQ ENET MAC address check from fuse.
Some SOC clock have some limits:
- ahb clock should be disabled before ipg.
- ahb and ipg clocks are required for MAC mii to work.
So, move the ahb clock to runtime pm together with ipg clock.
This reverts commit a87bb06a0bc7 that breaks busfreq test case.
Many boards installed with i.MX chip only use two pins for mii bus
in two NET MAC system to save two pins. Then one MAC need to share
the mii bus with the other one. Since two net interface operation
are parallel and separate, we should keep the shared mii bus always
be active. So it should keep MAC clocks on.
(cherry picked from commit: d0f18f7633ed)
system resume back"
The patch commit:586fbe526860 introduce the issue that suspend/resume
is failed on i.MX6SX sabreauto/sdb board. Now revert it.
Function .fec_resume() had called .fec_restart() before phy resume to ensure
MAC mii bus can work, but the firth .adjust_link() call .fec_restart() to re-init
the MAC again that is not necessary since PHY duplex and speed have no change
during suspend status, so remove the unnecessary mac re-inited after resume back.
In MAC-MAC fixed link case, it don't need phy fixup setting.
Register Athreos PHY AR8031 fixup.
(cherry picked and merged from commit:676bf1d92b3e6babdab623694fd83d54f881fc2f)
Add FEC support for NXP i.MX8x chips.
During normal suspend process, disable all irqs to avoid the late
TXF interrupt comming after clocks disabled that accessing registers
cause system hang.
There exists one issue in Android environment when do power key on/off
test that cause system hang. Because suspend function disable enet all
clocks while timer interrupt comming that introduces registers access.
When link down and suspend, the timer interrupt is not necessary
to enable, so disable it.
Tested-by: Fugang Duan <B38611@freescale.com>
Tested-by: Chen Guoyin <B07211@freescale.com>
Tested-by: Zhu Wenbo <B52619@freescale.com>
(cherry picked from commit: 048f62891bc4936991fd58dbaf4a606a30282404)
Add mii bus up_failed flag to reflect the real mii bus status.
Reported-and-tested-by: Zhang Sanshan <B51434@freescale.com>
(cherry picked from commit: ea348e597501d44841a28d8ee099361e89d63520)
The current driver support stop mode by calling machine api.
The patch add dts support to set gpr register for stop request.
After magic pattern comming during system suspend status, system will
be waked up, and irq handler will be running, there have enet register
access. Since all clocks are disabled in suspend, and clocks are enabled
after resume function. But irq handler run before resume function.
For imx7d chip, access register need some clocks enabled, otherwise system
hang. So the patch also disable wake up irq in the suspend, after resume
back enable the irq, which can avoid system hang issue.
(cherry pick and merge from commit: 8da4f80af0913781a4f9d50917c1dd66180e519d)
i.MX6SX-AI board has two enet MACs (MAC0 and MAC1), they share MAC0 MII
bus. When PHY0 don't connect to enet MAC0, MAC0 mii bus probe phy0 failed,
and the net interface is set to unattach mode. During suspend resume test,
driver don't reinit MAC0 after resume back, so MII bus don't work that causes
MAC1 also cannot access PHY1.
The patch just is workaround that reinit MAC0 MII bus for MAC1 using.
(cherry picked from commit: b730adeef4f9b44e302c793cbef35ea74f24fbef)
This is a combination of commits 919d46e37e04 (ENGR00265935 net: fec:
add pm_qos to avoid cpu enter to wait mode) and 8a12c90c9974
(ENGR00313685-14 net: fec: check workaround for FEC_QUIRK_BUG_WAITMODE)
from imx_3.10.y branch. It's added for imx_3.14.y branch to work around
imx6qdl issue ERR006687 (ENET: Only the ENET wake-up interrupt request
can wake the system from Wait mode).
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
(cherry-pick and merge from commit: 4f406fae257cc7945a0e3a425213440bb12ba345)
Execution 'ethtool -S' on fec device that is down causes OOPS on Vybrid
board:
Unhandled fault: external abort on non-linefetch (0x1008) at 0xe0898200
pgd = ddecc000
[e0898200] *pgd=9e406811, *pte=400d1653, *ppte=400d1453
Internal error: : 1008 [#1] SMP ARM
Reason of OOPS is that fec_enet_get_ethtool_stats() accesses fec
registers while IPG clock is stopped by PM.
Fix that by caching statistics in fec_enet_private. Cache is initialized
at device probe time, and updated at statistics request time if device
is up, and also just before turning device off on down path.
Additional locking is not needed, since cached statistics is accessed
either before device is registered, or under rtnl_lock().
Signed-off-by: Nikita Yushchenko <nikita.yoush@cogentembedded.com>
Pull ARM SoC platform updates from Olof Johansson:
"Improved and new platform support for various SoCs:
New SoC support:
- Broadcom BCM23550
- Freescale i.MX7Solo
- Qualcomm MDM9615
- Renesas r8a7792
Improvements:
- convert clps711x to multiplatform
- debug uart improvements for Atmel platforms
- Tango platform improvements: HOTPLUG_CPU, Suspend-to-ram
- OMAP tweaks and improvements to hwmod
- OMAP support for kexec on SMP"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (109 commits)
ARM: davinci: fix build break because of undeclared dm365_evm_snd_data
ARM: s3c64xx: smartq: Avoid sparse warnings
ARM: sti: Implement dummy L2 cache's write_sec
ARM: STi: Update machine _namestr to be more generic.
arm: meson: explicitly select clk drivers
ARM: tango: add Suspend-to-RAM support
ARM: hisi: consolidate the hisilicon machine entries
ARM: tango: fix CONFIG_HOTPLUG_CPU=n build
MAINTAINERS: Update BCM281XX/BCM11XXX/BCM216XX entry
MAINTAINERS: Update BCM63XX entry
MAINTAINERS: Add NS2 entry
MAINTAINERS: Fix nsp false-positives
MAINTAINERS: Change L to M for Broadcom ARM/ARM64 SoC entries
ARM: debug: Enable DEBUG_BCM_5301X for Northstar Plus SoCs
ARM: clps711x: Switch to MULTIPLATFORM
ARM: clps711x: Remove boards support
ARM: clps711x: Add basic DT support
ARM: clps711x: Reduce static map size
ARM: SAMSUNG: Constify iomem address passed to s5p_init_cpu
ARM: oxnas: Change OX810SE default driver config
Different i.MX SOC FEC support different features like :
- i.MX6Q/DL FEC does not support AVB and interrupt coalesc
- i.MX6SX/i.MX7D supports AVB and interrupt coalesc
- i.MX6UL/ULL does not support AVB, but support interrupt coalesc
So, add new quirk flag to judge the supported features.
The i.MX6 Q/DL has an erratum (ERR006687) that prevents the FEC from
waking the CPUs when they are in wait(unclocked) state. As the hardware
workaround isn't applicable to all boards, disable the deeper idle state
when the workaround isn't present and the FEC is in use.
This allows to safely run a kernel with CPUidle enabled on all i.MX6
boards.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Acked-by: David S. Miller <davem@davemloft.net> (for network changes)
The private structure contain a pointer to phydev, but the structure
net_device already contain such pointer. So we can remove the pointer
phydev in the private structure, and update the driver to use the one
contained in struct net_device.
Signed-off-by: Philippe Reynes <tremyfr@gmail.com>
Only the interrupt routine processes this condition.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
There is no need for complex macros every time we need to activate
a queue. Also, no need to call skb_get_queue_mapping when we already
know which queue it is using.
This reduces code and gains speed.
Setting the FTRL register will stop the fec from
trying to use multiple receive buffers.
As Arnd Bergmann points out, using CONFIG_ARCH_MXC and/or SOC_IMX28
is wrong if some other ARM platform uses this device - the operation
of the driver would depend on an unrelated ARM platform that might
or might not be set for multi-platform kernels.
Prior to my previous patch, any other platforms using it would have
been broken already due to having the cbd_datlen/cbd_sc fields in
the wrong order, but byte ordering correctly, so no such platforms
can exist and work today.
In any case, it seems likely that only Freescale SoCs use this part,
and those are little-endian on ARM, so CONFIG_ARM is safe for them.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
The driver treats the device descriptors as CPU-endian, which appears
to be correct with the default endianness on both ARM (typically LE)
and PowerPC (typically BE) SoCs, indicating that the hardware block
is generated differently. Add endianness annotations and byteswaps as
necessary.
It's not clear that the ifdef there really is correct and shouldn't
just be #ifdef CONFIG_ARM, but I also can't test on anything but the
i.MX6 HummingBoard where this gets it working with a BE kernel.
This function frees resources and cancels delayed work item that
have been initialized in fec_ptp_init().
Use this to do proper error handling if something goes wrong in
probe function after fec_ptp_init has been called.
Acked-by: Fugang Duan <B38611@freescale.com>
Not all silicon implementations of the Freescale FEC hardware module
have the RACC (Receive Accelerator Function) register, so we should not
be trying to access it on those that don't. Currently none of the ColdFire
based parts with a FEC have it.
Support for RACC was introduced by commit 4c09eed9 ("net: fec: Enable imx6
enet checksum acceleration"). A fix was introduced in commit d1391930
("net: fec: Fix build for MCF5272") that disables its use on the ColdFire
M5272 part, but it doesn't fix the general case of other ColdFire parts.
To fix we create a quirk flag, FEC_QUIRK_HAS_RACC, and check it before
working with the RACC register.
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
drivers/net/xen-netfront.c
Minor overlapping changes in xen-netfront.c, mostly to do
with some buffer management changes alongside the split
of stats into TX and RX.
On i.MX28, the MDIO bus is shared between the two FEC instances.
The driver makes sure that the second FEC uses the MDIO bus of the
first FEC. This is done conditionally if FEC_QUIRK_ENET_MAC is set.
However, in newer designs, such as Vybrid or i.MX6SX, each FEC MAC
has its own MDIO bus. Simply removing the quirk FEC_QUIRK_ENET_MAC
is not an option since other logic, triggered by this quirk, is
still needed.
Furthermore, there are board designs which use the same MDIO bus
for both PHY's even though the second bus would be available on the
SoC side. Such layout are popular since it saves pins on SoC side.
Due to the above quirk, those boards currently do work fine. The
boards in the mainline tree with such a layout are:
- Freescale Vybrid Tower with TWR-SER2 (vf610-twr.dts)
- Freescale i.MX6 SoloX SDB Board (imx6sx-sdb.dts)
This patch adds a new quirk FEC_QUIRK_SINGLE_MDIO for i.MX28, which
makes sure that the MDIO bus of the first FEC is used in any case.
However, the boards above do have a SoC with a MDIO bus for each FEC
instance. But the PHY's are not connected in a 1:1 configuration. A
proper device tree description is needed to allow the driver to
figure out where to find its PHY. This patch fixes that shortcoming
by adding a MDIO bus child node to the first FEC instance, along
with the two PHY's on that bus, and making use of the phy-handle
property to add a reference to the PHY's.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Signed-off-by: Stefan Agner <stefan@agner.ch>
Support for Wake-on-LAN using Magic Packet. ENET IP supports sleep mode
in low power status, when system enter suspend status, Magic packet can
wake up system even if all SOC clocks are gate. The patch doing below things:
- flagging the device as a wakeup source for the system, as well as
its Wake-on-LAN interrupt
- prepare the hardware for entering WoL mode
- add standard ethtool WOL interface
- enable the ENET interrupt to wake us
Tested on i.MX6q/dl sabresd, sabreauto boards, i.MX6SX arm2 boards.
The timecounter code has almost nothing to do with the clocksource
code. Let it live in its own file. This will help isolate the
timecounter users from the clocksource users in the source tree.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
i.MX6SX fec support three rx ring1, the current driver lost to init
ring1 and ring2 maximum receive buffer size, that cause receving
frame date length error. The driver reports "rcv is not +last" error
log in user case.
fec_enet_private struct
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
fep->bufdesc_ex is treated as a boolean value, thus declare it as
such.
consistently use TABs for indentation
iMX6SX IEEE 1588 module has one hw issue in capturing the ATVR register.
The current SW flow is:
ENET0->ATCR |= ENET_ATCR_CAPTURE_MASK;
ts_counter_ns = ENET0->ATVR;
The ATVR value is not expected value that cause LinuxPTP stack cannot be convergent.
ENET Block Guide/ Chapter for the iMX6SX (PELE) address the issue:
After set ENET_ATCR[Capture], there need some time cycles before the counter
value is capture in the register clock domain. The wait-time-cycles is at least
6 clock cycles of the slower clock between the register clock and the 1588 clock.
So need something like:
wait();
For iMX6SX, the 1588 ts_clk is fixed to 25Mhz, register clock is 66Mhz, so the
wait-time-cycles must be greater than 240ns (40ns * 6). The patch add 1us delay
before cpu read ATVR register.
Changes V2:
Modify the commit/comments log to describe the issue clearly.
Acked-by: Richard Cochran <richardcochran@gmail.com>
FEC ptp timer has 4 channel compare/trigger function. It can be used to
enable pps output.
The pulse would be ouput high exactly on N second. The pulse ouput high
on compare event mode is used to produce pulse per second. The pulse
width would be one cycle based on ptp timer clock source.Since 31-bit
ptp hardware timer is used, the timer will wrap more than 2 seconds. We
need to reload the compare compare event about every 1 second.
Signed-off-by: Luwei Zhou <b45643@freescale.com>
The FEC IP supports hardware adjustment for ptp timer. Refer to the description of
ENET_ATCOR and ENET_ATINC registers in the spec about the hardware adjustment. This
patch uses hardware support to adjust the ptp offset and frequency on the slave side.
Signed-off-by: Frank Li <Frank.Li@freescale.com>
Signed-off-by: Fugang Duan <b38611@freescale.com>
- Copy short frames and keep the buffers mapped, re-allocate skb instead of
memory copy for long frames.
- Add support for setting/getting rx_copybreak using generic ethtool tunable
Changes V3:
* As Eric Dumazet's suggestion that removing the copybreak module parameter
and only keep the ethtool API support for rx_copybreak.
Changes V2:
* Implements rx_copybreak
* Rx_copybreak provides module parameter to change this value
* Add tunable_ops support for rx_copybreak
The current driver loss Ftype field init for BD, which cause tx
queue #1 and #2 cannot work well.
Add Ftype field to BD to distiguish three queues for AVB:
0 -> Best Effort
1 -> ClassA
2 -> ClassB
when enable interrupt coalesce, 8 BD is not enough.
i.MX6 SX support interrupt coalescence feature
By default, init the interrupt coalescing frame count threshold and
timer threshold.
Supply the ethtool interfaces as below for user tuning to improve
enet performance:
rx_max_coalesced_frames
rx_coalesce_usecs
tx_max_coalesced_frames
tx_coalesce_usecs
reproduce:
wget https://git.kernel.org/cgit/linux/kernel/git/wfg/lkp-tests.git/plain/sbin/make.cross -O ~/bin/make.cross
chmod +x ~/bin/make.cross
git checkout 4d494cdc92b3b9a0f5fb9e1560810fa27d5a0489
make.cross ARCH=m68k m5272c3_defconfig
drivers/net/ethernet/freescale/fec.h:262:0: warning: "FEC_R_DES_START" redefined
#define FEC_R_DES_START(X) ((X == 1) ? FEC_R_DES_START_1 : \
drivers/net/ethernet/freescale/fec.h:158:0: note: this is the location of the previous definition
#define FEC_R_DES_START 0x3d0 /* Receive descriptor ring */
drivers/net/ethernet/freescale/fec.h:265:0: warning: "FEC_X_DES_START" redefined
#define FEC_X_DES_START(X) ((X == 1) ? FEC_X_DES_START_1 : \
