path: root/drivers/net/ethernet/dec
2012-02-24dec/tulip/de4x5: print MAC via printk format specifierDanny Kukawka
Print MAC/dev_addr via printk extended format specifier %pM instead of custom code. Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-08netdev: ethernet dev_alloc_skb to netdev_alloc_skbPradeep A. Dalvi
Replaced deprecating dev_alloc_skb with netdev_alloc_skb in drivers/net/ethernet - Removed extra skb->dev = dev after netdev_alloc_skb Signed-off-by: Pradeep A Dalvi <netdev@pradeepdalvi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-06netdev: ethernet dev_alloc_skb to netdev_alloc_skbPradeep A Dalvi
2012-01-31drivers/net: Remove alloc_etherdev error messagesJoe Perches
alloc_etherdev has a generic OOM/unable to alloc message. Remove the duplicative messages after alloc_etherdev calls. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-30drivers/net: fix up stale paths from driver reorgPaul Gortmaker
The reorganization of the driver layout in drivers/net left behind some stale paths in comments and in Kconfig help text. Bring them up to date. No actual change to any code takes place here. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> CC: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-19net: fix assignment of 0/1 to bool variables.Rusty Russell
DaveM said: Please, this kind of stuff rots forever and not using bool properly drives me crazy. Joe Perches <joe@perches.com> gave me the spatch script: @@ bool b; @@ -b = 0 +b = false @@ bool b; @@ -b = 1 +b = true I merely installed coccinelle, read the documentation and took credit. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-19de4x5/PCI: use list_for_each_entry() for bus->devices traversalBjorn Helgaas
Replace open-coded list traversal with list_for_each_entry(). CC: Grant Grundler <grundler@parisc-linux.org> CC: netdev@vger.kernel.org Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-08sweep the floors and convert some .get_drvinfo routines to strlcpyRick Jones
Per the mention made by Ben Hutchings that strlcpy is now the preferred string copy routine for a .get_drvinfo routine, do a bit of floor sweeping and convert some of the as-yet unconverted ethernet drivers to it. Signed-off-by: Rick Jones <rick.jones2@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1745 commits) dp83640: free packet queues on remove dp83640: use proper function to free transmit time stamping packets ipv6: Do not use routes from locally generated RAs |PATCH net-next] tg3: add tx_dropped counter be2net: don't create multiple RX/TX rings in multi channel mode be2net: don't create multiple TXQs in BE2 be2net: refactor VF setup/teardown code into be_vf_setup/clear() be2net: add vlan/rx-mode/flow-control config to be_setup() net_sched: cls_flow: use skb_header_pointer() ipv4: avoid useless call of the function check_peer_pmtu TCP: remove TCP_DEBUG net: Fix driver name for mdio-gpio.c ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT rtnetlink: Add missing manual netlink notification in dev_change_net_namespaces ipv4: fix ipsec forward performance regression jme: fix irq storm after suspend/resume route: fix ICMP redirect validation net: hold sock reference while processing tx timestamps tcp: md5: add more const attributes Add ethtool -g support to virtio_net ... Fix up conflicts in: - drivers/net/Kconfig: The split-up generated a trivial conflict with removal of a stale reference to Documentation/networking/net-modules.txt. Remove it from the new location instead. - fs/sysfs/dir.c: Fairly nasty conflicts with the sysfs rb-tree usage, conflicting with Eric Biederman's changes for tagged directories.
2011-10-03drivers/net/ethernet: remove unused #define.françois romieu
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-15MII: fix Kconfig dependencies for MIIJeff Kirsher
MII Kconfig option is apart of the core networking drivers and by default NET_CORE is enabled so drivers selecting MII will have MII enabled as well. It was found using the randconfig option during testing, MII would be selected but NET_CORE could be disabled. This caused a dependency error. Resolved the dependency by selecting NET_CORE when MII is selected. Reported-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-27drivers/net/ethernet/*: Enabled vendor Kconfig optionsJeff Kirsher
Based on finds for Stephen Rothwell, where current defconfig's enable a ethernet driver and it is not compiled due to the newly added NET_VENDOR_* component of Kconfig. This patch enables all the "new" Kconfig options so that current defconfig's will continue to compile the expected drivers. In addition, by enabling all the new Kconfig options does not add any un-expected options. CC: Stephen Rothwll <sfc@canb.auug.org.au> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-17net: remove use of ndo_set_multicast_list in driversJiri Pirko
replace it by ndo_set_rx_mode Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-12ewrk3/tulip: Move the DEC - Tulip driversJeff Kirsher
Move the DEC - Tulip driver into drivers/net/ethernet/dec/tulip/ and make the necessary Kconfig and Makefile changes. The Digital Equioment (DEC) driver ewrk3 was moved into drivers/net/ethernet/dec/ and the remaining drivers (Tulip) were moved into drivers/net/ethernet/dec/tulip/ CC: Tobias Ringstrom <tori@unhappy.mine.nu> CC: Grant Grundler <grundler@parisc-linux.org> CC: David Davies <davies@maniac.ultranet.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Grant Grundler <grundler@parisc-linux.org>
