[ Upstream commit 9ca01b25dffffecf6c59339aad6b4736680e9fa3 ]
Use the new of_get_ethdev_address() helper for the cases
where dev->dev_addr is passed in directly as the destination.
expression dev, np;
- of_get_mac_address(np, dev->dev_addr)
+ of_get_ethdev_address(np, dev)
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
Stable-dep-of: 1d6d537dc55d ("net: ethernet: mtk_eth_soc: handle probe deferral")
[ Upstream commit f3956ebb3bf06ab2266ad5ee2214aed46405810c ]
Convert Ethernet from ether_addr_copy() to eth_hw_addr_set():
expression dev, np;
- ether_addr_copy(dev->dev_addr, np)
+ eth_hw_addr_set(dev, np)
[ Upstream commit 42330a32933fb42180c52022804dcf09f47a2f99 ]
The nicvf_probe() won't destroy workqueue when register_netdev()
failed. Add destroy_workqueue err handle case to fix this issue.
Fixes: 2ecbe4f4a027 ("net: thunderx: replace global nicvf_rx_mode_wq work queue for all VFs to private for each of them.")
Signed-off-by: Yongqiang Liu <liuyongqiang13@huawei.com>
Reviewed-by: Pavan Chebbi <pavan.chebbi@broadcom.com>
Link: https://lore.kernel.org/r/20221203094125.602812-1-liuyongqiang13@huawei.com
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit 661e5ebbafd26d9d2e3c749f5cf591e55c7364f5 ]
The ACPI buffer memory (string.pointer) should be freed as the buffer is
not used after returning from bgx_acpi_match_id(), free it to prevent
memory leak.
Fixes: 46b903a01c05 ("net, thunder, bgx: Add support to get MAC address from ACPI.")
Signed-off-by: Yu Liao <liaoyu15@huawei.com>
Link: https://lore.kernel.org/r/20221123082237.1220521-1-liaoyu15@huawei.com
[ Upstream commit 733d4bbf9514890eb53ebe75827bf1fb4fd25ebe ]
Fix the warning reported by kbuild:
cocci warnings: (new ones prefixed by >>)
>> drivers/net/ethernet/cavium/liquidio/lio_main.c:1797:54-56: WARNING !A || A && B is equivalent to !A || B
drivers/net/ethernet/cavium/liquidio/lio_main.c:1827:54-56: WARNING !A || A && B is equivalent to !A || B
Fixes: 8979f428a4af ("net: liquidio: release resources when liquidio driver open failed")
Reported-by: kernel test robot <lkp@intel.com>
Signed-off-by: Leon Romanovsky <leonro@nvidia.com>
Reviewed-by: Saeed Mahameed <saeed@kernel.org>
[ Upstream commit 8979f428a4afc215e390006e5ea19fd4e22c7ca9 ]
When liquidio driver open failed, it doesn't release resources. Compile
tested only.
Fixes: 5b07aee11227 ("liquidio: MSIX support for CN23XX")
Fixes: dbc97bfd3918 ("net: liquidio: Add missing null pointer checks")
Signed-off-by: Zhengchao Shao <shaozhengchao@huawei.com>
Reviewed-by: Leon Romanovsky <leonro@nvidia.com>
During the process of driver probing, the probe function should return < 0
for failure, otherwise, the kernel will treat value > 0 as success.
Signed-off-by: Zheyu Ma <zheyuma97@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Enumeration:
- Convert controller drivers to generic_handle_domain_irq() (Marc
Zyngier)
- Simplify VPD (Vital Product Data) access and search (Heiner
Kallweit)
- Update bnx2, bnx2x, bnxt, cxgb4, cxlflash, sfc, tg3 drivers to use
simplified VPD interfaces (Heiner Kallweit)
- Run Max Payload Size quirks before configuring MPS; work around
ASMedia ASM1062 SATA MPS issue (Marek Behún)
Resource management:
- Refactor pci_ioremap_bar() and pci_ioremap_wc_bar() (Krzysztof
Wilczyński)
- Optimize pci_resource_len() to reduce kernel size (Zhen Lei)
PCI device hotplug:
- Fix a double unmap in ibmphp (Vishal Aslot)
PCIe port driver:
- Enable Bandwidth Notification only if port supports it (Stuart
Hayes)
Sysfs/proc/syscalls:
- Add schedule point in proc_bus_pci_read() (Krzysztof Wilczyński)
- Return ~0 data on pciconfig_read() CAP_SYS_ADMIN failure (Krzysztof
Wilczyński)
- Return "int" from pciconfig_read() syscall (Krzysztof Wilczyński)
Virtualization:
- Extend "pci=noats" to also turn on Translation Blocking to protect
against some DMA attacks (Alex Williamson)
- Add sysfs mechanism to control the type of reset used between
device assignments to VMs (Amey Narkhede)
- Add support for ACPI _RST reset method (Shanker Donthineni)
- Add ACS quirks for Cavium multi-function devices (George Cherian)
- Add ACS quirks for NXP LX2xx0 and LX2xx2 platforms (Wasim Khan)
- Allow HiSilicon AMBA devices that appear as fake PCI devices to use
PASID and SVA (Zhangfei Gao)
Endpoint framework:
- Add support for SR-IOV Endpoint devices (Kishon Vijay Abraham I)
- Zero-initialize endpoint test tool parameters so we don't use
random parameters (Shunyong Yang)
APM X-Gene PCIe controller driver:
- Remove redundant dev_err() call in xgene_msi_probe() (ErKun Yang)
Broadcom iProc PCIe controller driver:
- Don't fail devm_pci_alloc_host_bridge() on missing 'ranges' because
it's optional on BCMA devices (Rob Herring)
- Fix BCMA probe resource handling (Rob Herring)
Cadence PCIe driver:
- Work around J7200 Link training electrical issue by increasing
delays in LTSSM (Nadeem Athani)
Intel IXP4xx PCI controller driver:
- Depend on ARCH_IXP4XX to avoid useless config questions (Geert
Uytterhoeven)
Intel Keembay PCIe controller driver:
- Add Intel Keem Bay PCIe controller (Srikanth Thokala)
Marvell Aardvark PCIe controller driver:
- Work around config space completion handling issues (Evan Wang)
- Increase timeout for config access completions (Pali Rohár)
- Emulate CRS Software Visibility bit (Pali Rohár)
- Configure resources from DT 'ranges' property to fix I/O space
access (Pali Rohár)
- Serialize INTx mask/unmask (Pali Rohár)
MediaTek PCIe controller driver:
- Add MT7629 support in DT (Chuanjia Liu)
- Fix an MSI issue (Chuanjia Liu)
- Get syscon regmap ("mediatek,generic-pciecfg"), IRQ number
("pci_irq"), PCI domain ("linux,pci-domain") from DT properties if
present (Chuanjia Liu)
Microsoft Hyper-V host bridge driver:
- Add ARM64 support (Boqun Feng)
- Support "Create Interrupt v3" message (Sunil Muthuswamy)
NVIDIA Tegra PCIe controller driver:
- Use seq_puts(), move err_msg from stack to static, fix OF node leak
(Christophe JAILLET)
NVIDIA Tegra194 PCIe driver:
- Disable suspend when in Endpoint mode (Om Prakash Singh)
- Fix MSI-X address programming error (Om Prakash Singh)
- Disable interrupts during suspend to avoid spurious AER link down
(Om Prakash Singh)
Renesas R-Car PCIe controller driver:
- Work around hardware issue that prevents Link L1->L0 transition
(Marek Vasut)
- Fix runtime PM refcount leak (Dinghao Liu)
Rockchip DesignWare PCIe controller driver:
- Add Rockchip RK356X host controller driver (Simon Xue)
TI J721E PCIe driver:
- Add support for J7200 and AM64 (Kishon Vijay Abraham I)
Toshiba Visconti PCIe controller driver:
- Add Toshiba Visconti PCIe host controller driver (Nobuhiro
Iwamatsu)
Xilinx NWL PCIe controller driver:
- Enable PCIe reference clock via CCF (Hyun Kwon)
Miscellaneous:
- Convert sta2x11 from 'pci_' to 'dma_' API (Christophe JAILLET)
- Fix pci_dev_str_match_path() alloc while atomic bug (used for
kernel parameters that specify devices) (Dan Carpenter)
- Remove pointless Precision Time Management warning when PTM is
present but not enabled (Jakub Kicinski)
- Remove surplus "break" statements (Krzysztof Wilczyński)"
* tag 'pci-v5.15-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (132 commits)
PCI: ibmphp: Fix double unmap of io_mem
x86/PCI: sta2x11: switch from 'pci_' to 'dma_' API
PCI/VPD: Use unaligned access helpers
PCI/VPD: Clean up public VPD defines and inline functions
cxgb4: Use pci_vpd_find_id_string() to find VPD ID string
PCI/VPD: Add pci_vpd_find_id_string()
PCI/VPD: Include post-processing in pci_vpd_find_tag()
PCI/VPD: Stop exporting pci_vpd_find_info_keyword()
PCI/VPD: Stop exporting pci_vpd_find_tag()
PCI: Set dma-can-stall for HiSilicon chips
PCI: rockchip-dwc: Add Rockchip RK356X host controller driver
PCI: dwc: Remove surplus break statement after return
PCI: artpec6: Remove local code block from switch statement
PCI: artpec6: Remove surplus break statement after return
MAINTAINERS: Add entries for Toshiba Visconti PCIe controller
PCI: visconti: Add Toshiba Visconti PCIe host controller driver
PCI/portdrv: Enable Bandwidth Notification only if port supports it
PCI: Allow PASID on fake PCIe devices without TLP prefixes
PCI: mediatek: Use PCI domain to handle ports detection
PCI: mediatek: Add new method to get irq number
In order to support more coalesce parameters through netlink,
add two new parameter kernel_coal and extack for .set_coalesce
and .get_coalesce, then some extra info can return to user with
the netlink API.
Signed-off-by: Yufeng Mo <moyufeng@huawei.com>
Signed-off-by: Huazhong Tan <tanhuazhong@huawei.com>
Change the type of probe argument in functions which implement reset
methods from int to bool to make the context and intent clear.
Suggested-by: Alex Williamson <alex.williamson@redhat.com>
Link: https://lore.kernel.org/r/20210817180500.1253-10-ameynarkhede03@gmail.com
Signed-off-by: Amey Narkhede <ameynarkhede03@gmail.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
"reset_fn" indicates whether the device supports any reset mechanism.
Remove the use of reset_fn in favor of the reset_methods array that tracks
supported reset mechanisms of a device and their ordering.
The octeon driver incorrectly used reset_fn to detect whether the device
supports FLR or not. Use pcie_reset_flr() to probe whether it supports FLR.
Co-developed-by: Alex Williamson <alex.williamson@redhat.com>
Link: https://lore.kernel.org/r/20210817180500.1253-5-ameynarkhede03@gmail.com
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Reviewed-by: Alex Williamson <alex.williamson@redhat.com>
Reviewed-by: Raphael Norwitz <raphael.norwitz@nutanix.com>
The 'imply' keyword does not do what most people think it does, it only
politely asks Kconfig to turn on another symbol, but does not prevent
it from being disabled manually or built as a loadable module when the
user is built-in. In the ICE driver, the latter now causes a link failure:
aarch64-linux-ld: drivers/net/ethernet/intel/ice/ice_main.o: in function `ice_eth_ioctl':
ice_main.c:(.text+0x13b0): undefined reference to `ice_ptp_get_ts_config'
ice_main.c:(.text+0x13b0): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `ice_ptp_get_ts_config'
aarch64-linux-ld: ice_main.c:(.text+0x13bc): undefined reference to `ice_ptp_set_ts_config'
ice_main.c:(.text+0x13bc): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `ice_ptp_set_ts_config'
aarch64-linux-ld: drivers/net/ethernet/intel/ice/ice_main.o: in function `ice_prepare_for_reset':
ice_main.c:(.text+0x31fc): undefined reference to `ice_ptp_release'
ice_main.c:(.text+0x31fc): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `ice_ptp_release'
aarch64-linux-ld: drivers/net/ethernet/intel/ice/ice_main.o: in function `ice_rebuild':
This is a recurring problem in many drivers, and we have discussed
it several times befores, without reaching a consensus. I'm providing
a link to the previous email thread for reference, which discusses
some related problems.
To solve the dependency issue better than the 'imply' keyword, introduce a
separate Kconfig symbol "CONFIG_PTP_1588_CLOCK_OPTIONAL" that any driver
can depend on if it is able to use PTP support when available, but works
fine without it. Whenever CONFIG_PTP_1588_CLOCK=m, those drivers are
then prevented from being built-in, the same way as with a 'depends on
PTP_1588_CLOCK || !PTP_1588_CLOCK' dependency that does the same trick,
but that can be rather confusing when you first see it.
Since this should cover the dependencies correctly, the IS_REACHABLE()
hack in the header is no longer needed now, and can be turned back
into a normal IS_ENABLED() check. Any driver that gets the dependency
wrong will now cause a link time failure rather than being unable to use
PTP support when that is in a loadable module.
However, the two recently added ptp_get_vclocks_index() and
ptp_convert_timestamp() interfaces are only called from builtin code with
ethtool and socket timestamps, so keep the current behavior by stubbing
those out completely when PTP is in a loadable module. This should be
addressed properly in a follow-up.
As Richard suggested, we may want to actually turn PTP support into a
'bool' option later on, preventing it from being a loadable module
altogether, which would be one way to solve the problem with the ethtool
interface.
Fixes: 06c16d89d2cb ("ice: register 1588 PTP clock device object for E810 devices")
Link: https://lore.kernel.org/netdev/20210804121318.337276-1-arnd@kernel.org/
Link: https://lore.kernel.org/netdev/CAK8P3a06enZOf=XyZ+zcAwBczv41UuCTz+=0FMf2gBz1_cOnZQ@mail.gmail.com/
Link: https://lore.kernel.org/netdev/CAK8P3a3=eOxE-K25754+fB_-i_0BZzf9a9RfPTX3ppSwu9WZXw@mail.gmail.com/
Link: https://lore.kernel.org/netdev/20210726084540.3282344-1-arnd@kernel.org/
Acked-by: Shannon Nelson <snelson@pensando.io>
Acked-by: Jacob Keller <jacob.e.keller@intel.com>
Acked-by: Richard Cochran <richardcochran@gmail.com>
Reviewed-by: Vladimir Oltean <vladimir.oltean@nxp.com>
Link: https://lore.kernel.org/r/20210812183509.1362782-1-arnd@kernel.org
All kernel devlink implementations call to devlink_alloc() during
initialization routine for specific device which is used later as
a parent device for devlink_register().
Such late device assignment causes to the situation which requires us to
call to device_register() before setting other parameters, but that call
opens devlink to the world and makes accessible for the netlink users.
Any attempt to move devlink_register() to be the last call generates the
following error due to access to the devlink->dev pointer.
[ 8.758862] devlink_nl_param_fill+0x2e8/0xe50
[ 8.760305] devlink_param_notify+0x6d/0x180
[ 8.760435] __devlink_params_register+0x2f1/0x670
[ 8.760558] devlink_params_register+0x1e/0x20
The simple change of API to set devlink device in the devlink_alloc()
instead of devlink_register() fixes all this above and ensures that
prior to call to devlink_register() everything already set.
Reviewed-by: Jiri Pirko <jiri@nvidia.com>
The wrappers in include/linux/pci-dma-compat.h should go away.
The patch has been generated with the coccinelle script below. It has been
hand modified to use 'dma_set_mask_and_coherent()' instead of
'pci_set_dma_mask()/pci_set_consistent_dma_mask()' when applicable.
It has been compile tested.
- PCI_DMA_BIDIRECTIONAL
+ DMA_BIDIRECTIONAL
- PCI_DMA_TODEVICE
+ DMA_TO_DEVICE
- PCI_DMA_FROMDEVICE
+ DMA_FROM_DEVICE
- PCI_DMA_NONE
+ DMA_NONE
expression e1, e2, e3;
- pci_alloc_consistent(e1, e2, e3)
+ dma_alloc_coherent(&e1->dev, e2, e3, GFP_)
- pci_zalloc_consistent(e1, e2, e3)
expression e1, e2, e3, e4;
- pci_free_consistent(e1, e2, e3, e4)
+ dma_free_coherent(&e1->dev, e2, e3, e4)
- pci_map_single(e1, e2, e3, e4)
+ dma_map_single(&e1->dev, e2, e3, e4)
- pci_unmap_single(e1, e2, e3, e4)
+ dma_unmap_single(&e1->dev, e2, e3, e4)
expression e1, e2, e3, e4, e5;
- pci_map_page(e1, e2, e3, e4, e5)
+ dma_map_page(&e1->dev, e2, e3, e4, e5)
- pci_unmap_page(e1, e2, e3, e4)
+ dma_unmap_page(&e1->dev, e2, e3, e4)
- pci_map_sg(e1, e2, e3, e4)
+ dma_map_sg(&e1->dev, e2, e3, e4)
- pci_unmap_sg(e1, e2, e3, e4)
+ dma_unmap_sg(&e1->dev, e2, e3, e4)
- pci_dma_sync_single_for_cpu(e1, e2, e3, e4)
+ dma_sync_single_for_cpu(&e1->dev, e2, e3, e4)
- pci_dma_sync_single_for_device(e1, e2, e3, e4)
+ dma_sync_single_for_device(&e1->dev, e2, e3, e4)
- pci_dma_sync_sg_for_cpu(e1, e2, e3, e4)
+ dma_sync_sg_for_cpu(&e1->dev, e2, e3, e4)
- pci_dma_sync_sg_for_device(e1, e2, e3, e4)
+ dma_sync_sg_for_device(&e1->dev, e2, e3, e4)
expression e1, e2;
- pci_dma_mapping_error(e1, e2)
+ dma_mapping_error(&e1->dev, e2)
expression e1, e2;
- pci_set_dma_mask(e1, e2)
+ dma_set_mask(&e1->dev, e2)
expression e1, e2;
- pci_set_consistent_dma_mask(e1, e2)
+ dma_set_coherent_mask(&e1->dev, e2)
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Most users of ndo_do_ioctl are ethernet drivers that implement
the MII commands SIOCGMIIPHY/SIOCGMIIREG/SIOCSMIIREG, or hardware
timestamping with SIOCSHWTSTAMP/SIOCGHWTSTAMP.
Separate these from the few drivers that use ndo_do_ioctl to
implement SIOCBOND, SIOCBR and SIOCWANDEV commands.
This is a purely cosmetic change intended to help readers find
their way through the implementation.
Cc: Doug Ledford <dledford@redhat.com>
Cc: Jason Gunthorpe <jgg@ziepe.ca>
Cc: Jay Vosburgh <j.vosburgh@gmail.com>
Cc: Veaceslav Falico <vfalico@gmail.com>
Cc: Andy Gospodarek <andy@greyhouse.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Vivien Didelot <vivien.didelot@gmail.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: Vladimir Oltean <olteanv@gmail.com>
Cc: Leon Romanovsky <leon@kernel.org>
Cc: linux-rdma@vger.kernel.org
Acked-by: Jason Gunthorpe <jgg@nvidia.com>
Shifting the u16 integer oct->pcie_port by CN23XX_PKT_INPUT_CTL_MAC_NUM_POS
(29) bits will be promoted to a 32 bit signed int and then sign-extended
to a u64. In the cases where oct->pcie_port where bit 2 is set (e.g. 3..7)
the shifted value will be sign extended and the top 32 bits of the result
will be set.
Fix this by casting the u16 values to a u64 before the 29 bit left shift.
Addresses-Coverity: ("Unintended sign extension")
Fixes: 3451b97cce2d ("liquidio: CN23XX register setup")
The thunderx driver has rcu_read_lock()/rcu_read_unlock() pairs around XDP
program invocations. However, the actual lifetime of the objects referred
by the XDP program invocation is longer, all the way through to the call to
xdp_do_flush(), making the scope of the rcu_read_lock() too small. This
turns out to be harmless because it all happens in a single NAPI poll
cycle (and thus under local_bh_disable()), but it makes the rcu_read_lock()
misleading.
Rather than extend the scope of the rcu_read_lock(), just get rid of it
entirely. With the addition of RCU annotations to the XDP_REDIRECT map
types that take bh execution into account, lockdep even understands this to
be safe, so there's really no reason to keep it around.
Signed-off-by: Toke Høiland-Jørgensen <toke@redhat.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Cc: Sunil Goutham <sgoutham@marvell.com>
Link: https://lore.kernel.org/bpf/20210624160609.292325-10-toke@redhat.com
cdc-wdm: s/kill_urbs/poison_urbs/ to fix build
The result of container_of() operations is never NULL unless the embedded
element is the first element of the structure. This is not the case here.
The NULL check is therefore unnecessary and misleading. Remove it.
This change was made automatically with the following Coccinelle script.
type t;
identifier v;
statement s;
t v = container_of(...);
when != v
- if (\( !v \| v == NULL \) ) s
The functions send_rx_ctrl_cmd() in both liquidio/lio_main.c and
liquidio/lio_vf_main.c do not check if the call to
octeon_alloc_soft_command() fails and returns a null pointer. Both
functions also return void so errors are not propagated back to the
caller.
Fix these issues by updating both instances of send_rx_ctrl_cmd() to
return an integer rather than void, and have them return -ENOMEM if an
allocation failure occurs. Also update all callers of send_rx_ctrl_cmd()
so that they now check the return value.
Signed-off-by: Tom Seewald <tseewald@gmail.com>
Link: https://lore.kernel.org/r/20210503115736.2104747-66-gregkh@linuxfoundation.org
This reverts commit fe543b2f174f34a7a751aa08b334fe6b105c4569.
Because of recent interactions with developers from @umn.edu, all
commits from them have been recently re-reviewed to ensure if they were
correct or not.
Upon review, this commit was found to be incorrect for the reasons
below, so it must be reverted. It will be fixed up "correctly" in a
later kernel change.
While the original commit does keep the immediate "NULL dereference"
from happening, it does not properly propagate the error back to the
callers, AND it does not fix this same identical issue in the
drivers/net/ethernet/cavium/liquidio/lio_vf_main.c for some reason.
Cc: Kangjie Lu <kjlu@umn.edu>
Link: https://lore.kernel.org/r/20210503115736.2104747-65-gregkh@linuxfoundation.org
drivers/net/ethernet/stmicro/stmmac/stmmac_main.c
- keep the ZC code, drop the code related to reinit
net/bridge/netfilter/ebtables.c
- fix build after move to net_generic
Fix the following coccicheck warning:
./drivers/net/ethernet/cavium/liquidio/cn66xx_regs.h:413:6-28:
duplicated argument to & or |
The CN6XXX_INTR_M1UPB0_ERR here is duplicate.
Here should be CN6XXX_INTR_M1UNB0_ERR.
Signed-off-by: Wan Jiabing <wanjiabing@vivo.com>
of_get_mac_address() returns a "const void*" pointer to a MAC address.
Lately, support to fetch the MAC address by an NVMEM provider was added.
But this will only work with platform devices. It will not work with
PCI devices (e.g. of an integrated root complex) and esp. not with DSA
ports.
There is an of_* variant of the nvmem binding which works without
devices. The returned data of a nvmem_cell_read() has to be freed after
use. On the other hand the return of_get_mac_address() points to some
static data without a lifetime. The trick for now, was to allocate a
device resource managed buffer which is then returned. This will only
work if we have an actual device.
Change it, so that the caller of of_get_mac_address() has to supply a
buffer where the MAC address is written to. Unfortunately, this will
touch all drivers which use the of_get_mac_address().
Usually the code looks like:
const char *addr;
addr = of_get_mac_address(np);
if (!IS_ERR(addr))
ether_addr_copy(ndev->dev_addr, addr);
This can then be simply rewritten as:
of_get_mac_address(np, ndev->dev_addr);
Sometimes is_valid_ether_addr() is used to test the MAC address.
of_get_mac_address() already makes sure, it just returns a valid MAC
address. Thus we can just test its return code. But we have to be
careful if there are still other sources for the MAC address before the
of_get_mac_address(). In this case we have to keep the
is_valid_ether_addr() call.
The following coccinelle patch was used to convert common cases to the
new style. Afterwards, I've manually gone over the drivers and fixed the
return code variable: either used a new one or if one was already
available use that. Mansour Moufid, thanks for that coccinelle patch!
<spml>
@a@
identifier x;
expression y, z;
- x = of_get_mac_address(y);
+ x = of_get_mac_address(y, z);
- ether_addr_copy(z, x);
identifier a.x;
- if (<+... x ...+>) {}
identifier a.x;
- else {}
identifier a.x;
expression e;
- if (<+... x ...+>@e)
- else
+ if (!(e))
expression x, y, z;
- x = of_get_mac_address(y, z);
+ of_get_mac_address(y, z);
... when != x
</spml>
All drivers, except drivers/net/ethernet/aeroflex/greth.c, were
compile-time tested.
Suggested-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Michael Walle <michael@walle.cc>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
The shifting of the u8 integers rq->caching by 26 bits to
the left will be promoted to a 32 bit signed int and then
sign-extended to a u64. In the event that rq->caching is
greater than 0x1f then all then all the upper 32 bits of
the u64 end up as also being set because of the int
sign-extension. Fix this by casting the u8 values to a
u64 before the 26 bit left shift.
Fixes: 4863dea3fab0 ("net: Adding support for Cavium ThunderX network controller")
The macro CN23XX_PEM_BAR1_INDEX_REG is being used to shift oct->pcie_port
(a u16) left 24 places. There are two subtle issues here, first the
shift gets promoted to an signed int and then sign extended to a u64.
If oct->pcie_port is 0x80 or more then the upper bits get sign extended
to 1. Secondly shfiting a u16 24 bits will lead to an overflow so it
needs to be cast to a u64 for all the bits to not overflow.
It is entirely possible that the u16 port value is never large enough
for this to fail, but it is useful to fix unintended overflows such
as this.
Fix this by casting the port parameter to the macro to a u64 before
the shift.
Fixes: 5bc67f587ba7 ("liquidio: CN23XX register definitions")
Simplify the code by using module_platform_driver macro
for octeon_mgmt.
Signed-off-by: dingsenjie <dingsenjie@yulong.com>
Link: https://lore.kernel.org/r/20210128035330.17676-1-dingsenjie@163.com
Introduce xdp_prepare_buff utility routine to initialize per-descriptor
xdp_buff fields (e.g. xdp_buff pointers). Rely on xdp_prepare_buff() in
all XDP capable drivers.
Signed-off-by: Lorenzo Bianconi <lorenzo@kernel.org>
Reviewed-by: Alexander Duyck <alexanderduyck@fb.com>
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
Acked-by: John Fastabend <john.fastabend@gmail.com>
Acked-by: Shay Agroskin <shayagr@amazon.com>
Acked-by: Martin Habets <habetsm.xilinx@gmail.com>
Acked-by: Camelia Groza <camelia.groza@nxp.com>
Acked-by: Marcin Wojtas <mw@semihalf.com>
Link: https://lore.kernel.org/bpf/45f46f12295972a97da8ca01990b3e71501e9d89.1608670965.git.lorenzo@kernel.org
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Introduce xdp_init_buff utility routine to initialize xdp_buff fields
const over NAPI iterations (e.g. frame_sz or rxq pointer). Rely on
xdp_init_buff in all XDP capable drivers.
Link: https://lore.kernel.org/bpf/7f8329b6da1434dc2b05a77f2e800b29628a8913.1608670965.git.lorenzo@kernel.org
All UDP tunnel port management is now routed via udp_tunnel_nic
infra directly. Remove the old callbacks.
Reviewed-by: Jacob Keller <jacob.e.keller@intel.com>
Use kzalloc rather than kcalloc(1,...)
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
- kcalloc(1,
+ kzalloc(
// </smpl>
Signed-off-by: Zheng Yongjun <zhengyongjun3@huawei.com>
spinlock can be initialized automatically with DEFINE_SPINLOCK()
rather than explicitly calling spin_lock_init().
git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net-next
Pull networking updates from Jakub Kicinski:
"Core:
- support "prefer busy polling" NAPI operation mode, where we defer
softirq for some time expecting applications to periodically busy
poll
- AF_XDP: improve efficiency by more batching and hindering the
adjacency cache prefetcher
- af_packet: make packet_fanout.arr size configurable up to 64K
- tcp: optimize TCP zero copy receive in presence of partial or
unaligned reads making zero copy a performance win for much smaller
messages
- XDP: add bulk APIs for returning / freeing frames
- sched: support fragmenting IP packets as they come out of conntrack
- net: allow virtual netdevs to forward UDP L4 and fraglist GSO skbs
BPF:
- BPF switch from crude rlimit-based to memcg-based memory accounting
- BPF type format information for kernel modules and related tracing
enhancements
- BPF implement task local storage for BPF LSM
- allow the FENTRY/FEXIT/RAW_TP tracing programs to use
bpf_sk_storage
Protocols:
- mptcp: improve multiple xmit streams support, memory accounting and
many smaller improvements
- TLS: support CHACHA20-POLY1305 cipher
- seg6: add support for SRv6 End.DT4/DT6 behavior
- sctp: Implement RFC 6951: UDP Encapsulation of SCTP
- ppp_generic: add ability to bridge channels directly
- bridge: Connectivity Fault Management (CFM) support as is defined
in IEEE 802.1Q section 12.14.
Drivers:
- mlx5: make use of the new auxiliary bus to organize the driver
internals
- mlx5: more accurate port TX timestamping support
- mlxsw:
- improve the efficiency of offloaded next hop updates by using
the new nexthop object API
- support blackhole nexthops
- support IEEE 802.1ad (Q-in-Q) bridging
- rtw88: major bluetooth co-existance improvements
- iwlwifi: support new 6 GHz frequency band
- ath11k: Fast Initial Link Setup (FILS)
- mt7915: dual band concurrent (DBDC) support
- net: ipa: add basic support for IPA v4.5
Refactor:
- a few pieces of in_interrupt() cleanup work from Sebastian Andrzej
Siewior
- phy: add support for shared interrupts; get rid of multiple driver
APIs and have the drivers write a full IRQ handler, slight growth
of driver code should be compensated by the simpler API which also
allows shared IRQs
- add common code for handling netdev per-cpu counters
- move TX packet re-allocation from Ethernet switch tag drivers to a
central place
- improve efficiency and rename nla_strlcpy
- number of W=1 warning cleanups as we now catch those in a patchwork
build bot
Old code removal:
- wan: delete the DLCI / SDLA drivers
- wimax: move to staging
- wifi: remove old WDS wifi bridging support"
* tag 'net-next-5.11' of git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net-next: (1922 commits)
net: hns3: fix expression that is currently always true
net: fix proc_fs init handling in af_packet and tls
nfc: pn533: convert comma to semicolon
af_vsock: Assign the vsock transport considering the vsock address flags
af_vsock: Set VMADDR_FLAG_TO_HOST flag on the receive path
vsock_addr: Check for supported flag values
vm_sockets: Add VMADDR_FLAG_TO_HOST vsock flag
vm_sockets: Add flags field in the vsock address data structure
net: Disable NETIF_F_HW_TLS_TX when HW_CSUM is disabled
tcp: Add logic to check for SYN w/ data in tcp_simple_retransmit
net: mscc: ocelot: install MAC addresses in .ndo_set_rx_mode from process context
nfc: s3fwrn5: Release the nfc firmware
net: vxget: clean up sparse warnings
mlxsw: spectrum_router: Use eXtended mezzanine to offload IPv4 router
mlxsw: spectrum: Set KVH XLT cache mode for Spectrum2/3
mlxsw: spectrum_router_xm: Introduce basic XM cache flushing
mlxsw: reg: Add Router LPM Cache Enable Register
mlxsw: reg: Add Router LPM Cache ML Delete Register
mlxsw: spectrum_router_xm: Implement L-value tracking for M-index
mlxsw: reg: Add XM Router M Table Register
Alexei Starovoitov says:
pull-request: bpf-next 2020-12-03
The main changes are:
1) Support BTF in kernel modules, from Andrii.
2) Introduce preferred busy-polling, from Björn.
3) bpf_ima_inode_hash() and bpf_bprm_opts_set() helpers, from KP Singh.
4) Memcg-based memory accounting for bpf objects, from Roman.
5) Allow bpf_{s,g}etsockopt from cgroup bind{4,6} hooks, from Stanislav.
* https://git.kernel.org/pub/scm/linux/kernel/git/bpf/bpf-next: (118 commits)
selftests/bpf: Fix invalid use of strncat in test_sockmap
libbpf: Use memcpy instead of strncpy to please GCC
selftests/bpf: Add fentry/fexit/fmod_ret selftest for kernel module
selftests/bpf: Add tp_btf CO-RE reloc test for modules
libbpf: Support attachment of BPF tracing programs to kernel modules
libbpf: Factor out low-level BPF program loading helper
bpf: Allow to specify kernel module BTFs when attaching BPF programs
bpf: Remove hard-coded btf_vmlinux assumption from BPF verifier
selftests/bpf: Add CO-RE relocs selftest relying on kernel module BTF
selftests/bpf: Add support for marking sub-tests as skipped
selftests/bpf: Add bpf_testmod kernel module for testing
libbpf: Add kernel module BTF support for CO-RE relocations
libbpf: Refactor CO-RE relocs to not assume a single BTF object
libbpf: Add internal helper to load BTF data by FD
bpf: Keep module's btf_data_size intact after load
bpf: Fix bpf_put_raw_tracepoint()'s use of __module_address()
selftests/bpf: Add Userspace tests for TCP_WINDOW_CLAMP
bpf: Adds support for setting window clamp
samples/bpf: Fix spelling mistake "recieving" -> "receiving"
bpf: Fix cold build of test_progs-no_alu32
Link: https://lore.kernel.org/r/20201204021936.85653-1-alexei.starovoitov@gmail.com
Add napi_id to the xdp_rxq_info structure, and make sure the XDP
socket pick up the napi_id in the Rx path. The napi_id is used to find
the corresponding NAPI structure for socket busy polling.
Signed-off-by: Björn Töpel <bjorn.topel@intel.com>
Acked-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Tariq Toukan <tariqt@nvidia.com>
Link: https://lore.kernel.org/bpf/20201130185205.196029-7-bjorn.topel@gmail.com
Get rid of the __call_single_node union and cleanup the API a little
to avoid external code relying on the structure layout as much.
Reviewed-by: Frederic Weisbecker <frederic@kernel.org>
linux/netdevice.h is included in very many places, touching any
of its dependecies causes large incremental builds.
Drop the linux/ethtool.h include, linux/netdevice.h just needs
a forward declaration of struct ethtool_ops.
Fix all the places which made use of this implicit include.
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Reviewed-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Link: https://lore.kernel.org/r/20201120225052.1427503-1-kuba@kernel.org
Remove duplicated include.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Link: https://lore.kernel.org/r/20201031024744.39020-1-yuehaibing@huawei.com
Make use of the new struct_size() helper instead of the offsetof() idiom.
Signed-off-by: Gustavo A. R. Silva <gustavoars@kernel.org>
Rejecting non-native endian BTF overlapped with the addition
of support for it.
The rest were more simple overlapping changes, except the
renesas ravb binding update, which had to follow a file
move as well as a YAML conversion.
To start also "phy state machine", with UP state as it should be,
the phy_start() has to be used, in another case machine even is not
triggered. After this change negotiation is supposed to be triggered
by SM workqueue.
It's not correct usage, but it appears after the following patch,
so add it as a fix.
Fixes: 74a992b3598a ("net: phy: add phy_check_link_status")
Signed-off-by: Ivan Khoronzhuk <ikhoronz@cisco.com>
As part of the W=1 cleanups for ethernet, a million [*] driver
comments had to be cleaned up to get the W=1 compilation to
succeed. This change finally makes the drivers/net/ethernet tree
compile with W=1 set on the command line. NOTE: The kernel uses
kdoc style (see Documentation/process/kernel-doc.rst) when
documenting code, not doxygen or other styles.
After this patch the x86_64 build has no warnings from W=1, however
scripts/kernel-doc says there are 1545 more warnings in source files, that
I need to develop a script to fix in a followup patch.
The errors fixed here are all kdoc of a few classes, with a few outliers:
In file included from drivers/net/ethernet/qlogic/netxen/netxen_nic_hw.c:10:
drivers/net/ethernet/qlogic/netxen/netxen_nic.h:1193:18: warning: ‘FW_DUMP_LEVELS’ defined but not used [-Wunused-const-variable=]
1193 | static const u32 FW_DUMP_LEVELS[] = { 0x3, 0x7, 0xf, 0x1f, 0x3f, 0x7f, 0xff };
... repeats 4 times...
drivers/net/ethernet/sun/cassini.c:2084:24: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body]
2084 | RX_USED_ADD(page, i);
drivers/net/ethernet/natsemi/ns83820.c: In function ‘phy_intr’:
drivers/net/ethernet/natsemi/ns83820.c:603:6: warning: variable ‘tbisr’ set but not used [-Wunused-but-set-variable]
603 | u32 tbisr, tanar, tanlpar;
drivers/net/ethernet/natsemi/ns83820.c: In function ‘ns83820_get_link_ksettings’:
drivers/net/ethernet/natsemi/ns83820.c:1207:11: warning: variable ‘tanar’ set but not used [-Wunused-but-set-variable]
1207 | u32 cfg, tanar, tbicr;
drivers/net/ethernet/packetengines/yellowfin.c:1063:18: warning: variable ‘yf_size’ set but not used [-Wunused-but-set-variable]
1063 | int data_size, yf_size;
Normal kdoc fixes:
warning: Function parameter or member 'x' not described in 'y'
warning: Excess function parameter 'x' description in 'y'
warning: Cannot understand <string> on line <NNN> - I thought it was a doc line
[*] - ok it wasn't quite a million, but it felt like it.
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
The W=1 builds showed a few files exporting functions
(non-static) that were not prototyped. What actually happened is
that there were prototypes, but the include file was forgotten in
the implementation file.
Add the include file and remove the warnings.
Fixed Warnings:
drivers/net/ethernet/cavium/liquidio/cn68xx_device.c:124:5: warning: no previous prototype for ‘lio_setup_cn68xx_octeon_device’ [-Wmissing-prototypes]
drivers/net/ethernet/cavium/liquidio/octeon_mem_ops.c:159:1: warning: no previous prototype for ‘octeon_pci_read_core_mem’ [-Wmissing-prototypes]
drivers/net/ethernet/cavium/liquidio/octeon_mem_ops.c:168:1: warning: no previous prototype for ‘octeon_pci_write_core_mem’ [-Wmissing-prototypes]
drivers/net/ethernet/cavium/liquidio/octeon_mem_ops.c:176:5: warning: no previous prototype for ‘octeon_read_device_mem64’ [-Wmissing-prototypes]
drivers/net/ethernet/cavium/liquidio/octeon_mem_ops.c:185:5: warning: no previous prototype for ‘octeon_read_device_mem32’ [-Wmissing-prototypes]
drivers/net/ethernet/cavium/liquidio/octeon_mem_ops.c:194:6: warning: no previous prototype for ‘octeon_write_device_mem32’ [-Wmissing-prototypes]
drivers/net/ethernet/hisilicon/hns3/hns3pf/hclge_dcb.c:453:6: warning: no previous prototype for ‘hclge_dcb_ops_set’ [-Wmissing-prototypes]
Fixes gcc '-Wunused-but-set-variable' warning:
drivers/net/ethernet/cavium/liquidio/octeon_device.c: In function lio_pci_readq:
drivers/net/ethernet/cavium/liquidio/octeon_device.c:1327:6: warning: variable ‘val32’ set but not used [-Wunused-but-set-variable]
drivers/net/ethernet/cavium/liquidio/octeon_device.c: In function lio_pci_writeq:
drivers/net/ethernet/cavium/liquidio/octeon_device.c:1358:6: warning: variable ‘val32’ set but not used [-Wunused-but-set-variable]
these variable is never used, so remove it.
If the header file containing a function's prototype isn't included by
the sourcefile containing the associated function, the build system
complains of missing prototypes.
Fixes the following W=1 kernel build warning(s):
Signed-off-by: Wang Hai <wanghai38@huawei.com>
Reviewed-by: Saeed Mahameed <saeedm@nvidia.com>
In preparation for unconditionally passing the
struct tasklet_struct pointer to all tasklet
callbacks, switch to using the new tasklet_setup()
and from_tasklet() to pass the tasklet pointer explicitly.
Signed-off-by: Romain Perier <romain.perier@gmail.com>
Signed-off-by: Allen Pais <apais@linux.microsoft.com>
Rename ptp to ptp_info.
Fix W=1 compile warnings (invalid kerneldoc):
drivers/net/ethernet/cavium/common/cavium_ptp.c:94: warning: Excess function parameter 'ptp' description in 'cavium_ptp_adjfine'
drivers/net/ethernet/cavium/common/cavium_ptp.c:141: warning: Excess function parameter 'ptp' description in 'cavium_ptp_adjtime'
drivers/net/ethernet/cavium/common/cavium_ptp.c:163: warning: Excess function parameter 'ptp' description in 'cavium_ptp_gettime'
drivers/net/ethernet/cavium/common/cavium_ptp.c:185: warning: Excess function parameter 'ptp' description in 'cavium_ptp_settime'
drivers/net/ethernet/cavium/common/cavium_ptp.c:208: warning: Excess function parameter 'ptp' description in 'cavium_ptp_enable'
We got slightly different patches removing a double word
in a comment in net/ipv4/raw.c - picked the version from net.
Simple conflict in drivers/net/ethernet/ibm/ibmvnic.c. Use cached
values instead of VNIC login response buffer (following what
commit 507ebe6444a4 ("ibmvnic: Fix use-after-free of VNIC login
response buffer") did).
Remove unneeded return value cast.
This is detected by coccinelle.
