[ Upstream commit 11ec18b1d8d92b9df307d31950dcba0b3dd7283c ]
Every iteration of for_each_child_of_node() decrements
the reference count of the previous node.
When break from a for_each_child_of_node() loop,
we need to explicitly call of_node_put() on the child node when
not need anymore.
Add missing of_node_put() to avoid refcount leak.
Fixes: bbd2190ce96d ("Altera TSE: Add main and header file for Altera Ethernet Driver")
Signed-off-by: Miaoqian Lin <linmq006@gmail.com>
Link: https://lore.kernel.org/r/20220607041144.7553-1-linmq006@gmail.com
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
commit badd7857f5c933a3dc34942a2c11d67fdbdc24de upstream.
There are two error paths which accidentally return success instead of
a negative error code.
of_get_mac_address() returns a "const void*" pointer to a MAC address.
Lately, support to fetch the MAC address by an NVMEM provider was added.
But this will only work with platform devices. It will not work with
PCI devices (e.g. of an integrated root complex) and esp. not with DSA
ports.
There is an of_* variant of the nvmem binding which works without
devices. The returned data of a nvmem_cell_read() has to be freed after
use. On the other hand the return of_get_mac_address() points to some
static data without a lifetime. The trick for now, was to allocate a
device resource managed buffer which is then returned. This will only
work if we have an actual device.
Change it, so that the caller of of_get_mac_address() has to supply a
buffer where the MAC address is written to. Unfortunately, this will
touch all drivers which use the of_get_mac_address().
Usually the code looks like:
const char *addr;
addr = of_get_mac_address(np);
if (!IS_ERR(addr))
ether_addr_copy(ndev->dev_addr, addr);
This can then be simply rewritten as:
of_get_mac_address(np, ndev->dev_addr);
Sometimes is_valid_ether_addr() is used to test the MAC address.
of_get_mac_address() already makes sure, it just returns a valid MAC
address. Thus we can just test its return code. But we have to be
careful if there are still other sources for the MAC address before the
of_get_mac_address(). In this case we have to keep the
is_valid_ether_addr() call.
The following coccinelle patch was used to convert common cases to the
new style. Afterwards, I've manually gone over the drivers and fixed the
return code variable: either used a new one or if one was already
available use that. Mansour Moufid, thanks for that coccinelle patch!
<spml>
@a@
identifier x;
expression y, z;
- x = of_get_mac_address(y);
+ x = of_get_mac_address(y, z);
- ether_addr_copy(z, x);
identifier a.x;
- if (<+... x ...+>) {}
identifier a.x;
- else {}
identifier a.x;
expression e;
- if (<+... x ...+>@e)
- else
+ if (!(e))
expression x, y, z;
- x = of_get_mac_address(y, z);
+ of_get_mac_address(y, z);
... when != x
</spml>
All drivers, except drivers/net/ethernet/aeroflex/greth.c, were
compile-time tested.
Suggested-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Michael Walle <michael@walle.cc>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
The method ndo_start_xmit() returns a value of type netdev_tx_t. Fix
the ndo function to use the correct type.
Signed-off-by: Yunjian Wang <wangyunjian@huawei.com>
ioremap has provided non-cached semantics by default since the Linux 2.6
days, so remove the additional ioremap_nocache interface.
Before this change of_get_phy_mode() returned an enum,
phy_interface_t. On error, -ENODEV etc, is returned. If the result of
the function is stored in a variable of type phy_interface_t, and the
compiler has decided to represent this as an unsigned int, comparision
with -ENODEV etc, is a signed vs unsigned comparision.
Fix this problem by changing the API. Make the function return an
error, or 0 on success, and pass a pointer, of type phy_interface_t,
where the phy mode should be stored.
v2:
Return with *interface set to PHY_INTERFACE_MODE_NA on error.
Add error checks to all users of of_get_phy_mode()
Fixup a few reverse christmas tree errors
Fixup a few slightly malformed reverse christmas trees
v3:
Fix 0-day reported errors.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms and conditions of the gnu general public license
version 2 as published by the free software foundation this program
is distributed in the hope it will be useful but without any
warranty without even the implied warranty of merchantability or
fitness for a particular purpose see the gnu general public license
for more details you should have received a copy of the gnu general
public license along with this program if not see http www gnu org
licenses
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 228 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Steve Winslow <swinslow@gmail.com>
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Reviewed-by: Alexios Zavras <alexios.zavras@intel.com>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190528171438.107155473@linutronix.de
There was NVMEM support added to of_get_mac_address, so it could now
return ERR_PTR encoded error values, so we need to adjust all current
users of of_get_mac_address to this new fact.
While at it, remove superfluous is_valid_ether_addr as the MAC address
returned from of_get_mac_address is always valid and checked by
is_valid_ether_addr anyway.
Fixes: d01f449c008a ("of_net: add NVMEM support to of_get_mac_address")
Signed-off-by: Petr Štetiar <ynezz@true.cz>
The connect_local_phy should return NULL (not negative errno) on
error, since its caller expects it.
Signed-off-by: Atsushi Nemoto <atsushi.nemoto@sord.co.jp>
Acked-by: Thor Thayer <thor.thayer@linux.intel.com>
Many Ethernet MAC drivers want to limit the PHY to only advertise a
maximum speed of 100Mbs or 1Gbps. Rather than using a mask, make use
of the helper function phy_set_max_speed().
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Prefer the direct use of octal for permissions.
Done with checkpatch -f --types=SYMBOLIC_PERMS --fix-inplace
and some typing.
Miscellanea:
o Whitespace neatening around these conversions.
napi_complete_done() allows to opt-in for gro_flush_timeout,
added back in linux-3.19, commit 3b47d30396ba
("net: gro: add a per device gro flush timer")
This allows for more efficient GRO aggregation without
sacrifying latencies.
Couple conflicts resolved here:
1) In the MACB driver, a bug fix to properly initialize the
RX tail pointer properly overlapped with some changes
to support variable sized rings.
2) In XGBE we had a "CONFIG_PM" --> "CONFIG_PM_SLEEP" fix
overlapping with a reorganization of the driver to support
ACPI, OF, as well as PCI variants of the chip.
3) In 'net' we had several probe error path bug fixes to the
stmmac driver, meanwhile a lot of this code was cleaned up
and reorganized in 'net-next'.
4) The cls_flower classifier obtained a helper function in
'net-next' called __fl_delete() and this overlapped with
Daniel Borkamann's bug fix to use RCU for object destruction
in 'net'. It also overlapped with Jiri's change to guard
the rhashtable_remove_fast() call with a check against
tc_skip_sw().
5) In mlx4, a revert bug fix in 'net' overlapped with some
unrelated changes in 'net-next'.
6) In geneve, a stale header pointer after pskb_expand_head()
bug fix in 'net' overlapped with a large reorganization of
the same code in 'net-next'. Since the 'net-next' code no
longer had the bug in question, there was nothing to do
other than to simply take the 'net-next' hunks.
The driver already uses its private lock for synchronization between xmit
and xmit completion handler making the additional use of the xmit_lock
unnecessary.
Furthermore the driver does not set NETIF_F_LLTX resulting in xmit to be
called with the xmit_lock held and then taking the private lock while xmit
completion handler does the reverse, first take the private lock, then the
xmit_lock.
Fix these issues by not taking the xmit_lock in the tx completion handler.
Signed-off-by: Lino Sanfilippo <LinoSanfilippo@gmx.de>
An explicit dma sync for device directly after mapping as well as an
explicit dma sync for cpu directly before unmapping is unnecessary and
costly on the hotpath. So remove these calls.
Add support for the (optional) SGMII PCS functionality of the Altera
TSE MAC. If the phy-mode is set to 'sgmii' then we attempt to discover
and initialise the PCS so that the MAC can communicate to the PHY.
The PCS IP block provides a scratch register for testing presence of
the PCS, which is mapped into one of the two MDIO spaces present in
the MAC's register space. Once we have determined that the scratch
register is functioning, we attempt to initialise the PCS to
auto-negotiate an SGMII link with the PHY. There is no need to monitor
or manage the SGMII link beyond this, since the normal PHY MDIO will
then be used to monitor the media layer.
The Altera TSE MAC has only one way in which it can be configured with an
SGMII PCS, and as such, this patch only looks to the phy-mode to select
whether or not to attempt to initialise the PCS registers. During
initialisation, we report the PCS's equivalent of a PHY ID register.
This can be parameterised during the IP instantiation and is often left
as '0x00000000' which is not an error.
Signed-off-by: Neill Whillans <neill.whillans@codethink.co.uk>
Reviewed-by: Daniel Silverstone <daniel.silverstone@codethink.co.uk>
Make sure to deregister and free any fixed-link PHY registered using
of_phy_register_fixed_link() on probe errors and on driver unbind.
Fixes: 7cdbc6f74f8e ("altera tse: add support for fixed-links.")
Signed-off-by: Johan Hovold <johan@kernel.org>
Fix to return error code -EINVAL from the error handling
case instead of 0, as done elsewhere in this function.
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
et131x: min_mtu 64, max_mtu 9216
altera_tse: min_mtu 64, max_mtu 1500
amd8111e: min_mtu 60, max_mtu 9000
bnad: min_mtu 46, max_mtu 9000
macb: min_mtu 68, max_mtu 1500 or 10240 depending on hardware capability
xgmac: min_mtu 46, max_mtu 9000
cxgb2: min_mtu 68, max_mtu 9582 (pm3393) or 9600 (vsc7326)
enic: min_mtu 68, max_mtu 9000
gianfar: min_mtu 50, max_mu 9586
hns_enet: min_mtu 68, max_mtu 9578 (v1) or 9706 (v2)
ksz884x: min_mtu 60, max_mtu 1894
myri10ge: min_mtu 68, max_mtu 9000
natsemi: min_mtu 64, max_mtu 2024
nfp: min_mtu 68, max_mtu hardware-specific
forcedeth: min_mtu 64, max_mtu 1500 or 9100, depending on hardware
pch_gbe: min_mtu 46, max_mtu 10300
pasemi_mac: min_mtu 64, max_mtu 9000
qcaspi: min_mtu 46, max_mtu 1500
- remove qcaspi_netdev_change_mtu as it is now redundant
rocker: min_mtu 68, max_mtu 9000
sxgbe: min_mtu 68, max_mtu 9000
stmmac: min_mtu 46, max_mtu depends on hardware
tehuti: min_mtu 60, max_mtu 16384
- driver had no max mtu checking, but product docs say 16k jumbo packets
are supported by the hardware
netcp: min_mtu 68, max_mtu 9486
- remove netcp_ndo_change_mtu as it is now redundant
via-velocity: min_mtu 64, max_mtu 9000
octeon: min_mtu 46, max_mtu 65370
CC: netdev@vger.kernel.org
CC: Mark Einon <mark.einon@gmail.com>
CC: Vince Bridgers <vbridger@opensource.altera.com>
CC: Rasesh Mody <rasesh.mody@qlogic.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Santosh Raspatur <santosh@chelsio.com>
CC: Hariprasad S <hariprasad@chelsio.com>
CC: Christian Benvenuti <benve@cisco.com>
CC: Sujith Sankar <ssujith@cisco.com>
CC: Govindarajulu Varadarajan <_govind@gmx.com>
CC: Neel Patel <neepatel@cisco.com>
CC: Claudiu Manoil <claudiu.manoil@freescale.com>
CC: Yisen Zhuang <yisen.zhuang@huawei.com>
CC: Salil Mehta <salil.mehta@huawei.com>
CC: Hyong-Youb Kim <hykim@myri.com>
CC: Jakub Kicinski <jakub.kicinski@netronome.com>
CC: Olof Johansson <olof@lixom.net>
CC: Jiri Pirko <jiri@resnulli.us>
CC: Byungho An <bh74.an@samsung.com>
CC: Girish K S <ks.giri@samsung.com>
CC: Vipul Pandya <vipul.pandya@samsung.com>
CC: Giuseppe Cavallaro <peppe.cavallaro@st.com>
CC: Alexandre Torgue <alexandre.torgue@st.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: Wingman Kwok <w-kwok2@ti.com>
CC: Murali Karicheri <m-karicheri2@ti.com>
CC: Francois Romieu <romieu@fr.zoreil.com>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
of_node_put needs to be called when the device node which is got
from of_parse_phandle (or of_node_get) has finished using.
Signed-off-by: Peter Chen <peter.chen@nxp.com>
The private structure contain a pointer to phydev, but the structure
net_device already contain such pointer. So we can remove the pointer
phydev in the private structure, and update the driver to use the
one contained in struct net_device.
Signed-off-by: Philippe Reynes <tremyfr@gmail.com>
priv->mdio->irq used to be allocated and required freeing, but it
is now a fixed sized array and should no longer be free'd.
Issue detected using static analysis with CoverityScan
Fixes: e7f4dc3536a400 ("mdio: Move allocation of interrupts into core")
Not all devices attached to an MDIO bus are phys. So add an
mdio_device structure to represent the generic parts of an mdio
device, and place this structure into the phy_device.
Have mdio_alloc() create the array of interrupt numbers, and
initialize it to POLLING. This is what most MDIO drivers want, so
allowing code to be removed from the drivers.
Call netif_carrier_off() prior to register_netdev(), otherwise
userspace can see incorrect link state.
Signed-off-by: Atsushi Nemoto <nemoto@toshiba-tops.co.jp>
tse_poll() calls __napi_complete() with irq enabled. This leads napi
poll_list corruption and may stop all napi drivers working.
Use napi_complete() instead of __napi_complete().
Altera TSE MAC rx DMA transfer starts with the 2 additional bytes for IP
payload alignment. This patch fixes tse_rx() function loop which reads DMA
rx status and extracts packet length from it. Status signalises a whole DMA
transfer length, which is 2 bytes longer than the packet itself.
Signed-off-by: Vlastimil Setka <setka@vsis.cz>
Add support for fixed-links in configurations without PHY.
(e.g. connection to a switch, SGMII point to point, SFPs)
Check: Documentation/devicetree/bindings/net/fixed-link.txt.
Signed-off-by: Andreas Oetken <ennoerlangen@gmail.com>
Fix bug which occurs when more than <limit> packets are available during
napi-poll, leading to "delays" and retransmissions on the network.
Check for (count < limit) before checking the get_rx_status in tse_rx-function.
Function get_rx_status is reading from the response-fifo.
If there is currently a response in the fifo,
reading the last byte of the response pops the value from the fifo.
If the limit is checked as second condition
and the limit is reached the fifo is popped but the packet is not processed.
of_device_id is always used as const.
(See driver.of_match_table and open firmware functions)
Signed-off-by: Fabian Frederick <fabf@skynet.be>
drivers/net/ethernet/rocker/rocker.c
The rocker commit was two overlapping changes, one to rename
the ->vport member to ->pport, and another making the bitmask
expression use '1ULL' instead of plain '1'.
Incorrect NAPI polling caused WARNING at net/core/dev.c net_rx_action.
Some stability issues were also seen at high throughput and system
load before this patch.
This patch contains several changes in altera_tse_main.c:
- tse_rx() is fixed to not process more than `limit` frames
- tse_poll() is refactored to match NAPI logic
- only received frames are counted for return value
- removed bogus condition `(rxcomplete >= budget || txcomplete > 0)`
- replace by: if (rxcomplete < budget) -> call __napi_complete and enable irq
- altera_isr()
- replace spin_lock_irqsave() by spin_lock() - we are in isr
- use spinlocks just over irq manipulation, not over __napi_schedule
- reset IRQ first, then disable and schedule napi
This is a cleaned up resubmission from Vlastimil's recent submission.
Signed-off-by: Roman Pisl <rpisl@kky.zcu.cz>
Signed-off-by: Vince Bridgers <vbridger@opensource.altera.com>
This patch corrects a typo in the way tx_fifo_depth is read from the
devicetree. This patch was submitted by Vlastimil about a week ago,
and is now cleaned up and resubmitted.
This debug output is not really an error message since mac reset can fail
if the phy clocks are gated, specifically when the phy has been placed in
a powered down or isolation mode. The netdev output masks were changed from
err to dbg, and comments added in the code.
Change use of Altera TSE's MDIO access from phy 0 registers to phy 1
registers. This allows support for GMII, MII, RGMII, and SGMII
designs where the external PHY is always accesible through
Altera TSE's MDIO phy 1 registers and Altera's PCS is accessible
through MDIO phy 0 registers for SGMII applications.
Tested-by: Kai Lin Ng <kailng@altera.com>
Tested-by: Dalon Westergreen <dwesterg@gmail.com>
Altera network device doesn't come up after
ifconfig eth0 down
ifconfig eth0 up
The reason behind is clearing priv->phydev during tse_shutdown().
The phydev is not restored back at tse_open().
Resubmiting as to follow Tobias Klauser suggestion.
phy_start/phy_stop are called on each ifup/ifdown and
phy_disconnect is called once during the module removal.
Signed-off-by: Kostya Belezko <bkostya@hotmail.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
This patch avoids PHY and MDIO probing if no PHY chip is present.
This is the case mainly in optical links where there is no need for
PHY chip, and therefore no need of MDIO. In this scenario Ethernet
MAC is directly connected to an optical module through an external
SFP transceiver.
Signed-off-by: Walter Lozano <walter@vanguardiasur.com.ar>
Move PHY get addr and MDIO create to a new function to improve readability
and make it easier to avoid its usage. This will be useful for example in
the case where there is no PHY chip.
There is no need to call ether_setup after alloc_ethdev since it was
already called there.
Follow commits c706471b2601 ("net: axienet: remove unnecessary
ether_setup after alloc_etherdev") and 3c87dcbfb36c ("net: ll_temac:
Remove unnecessary ether_setup after alloc_etherdev") and fix the
pattern in all remaining ethernet drivers.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
This patch disables multicast hash filtering if present in the hardware
and uses promiscuous mode instead until the problem with multicast
filtering has been debugged, integrated and tested.
Signed-off-by: Vince Bridgers <vbridgers2013@gmail.com>
This patch fixes the many sparse errors and warnings contained in the
initial submission of the Altera Triple Speed Ethernet driver, and a
few minor cppcheck warnings. Changes are tested on ARM and NIOS2
example designs, and compile tested against multiple architectures.
Typical issues addressed were as follows:
altera_tse_ethtool.c:136:19: warning: incorrect type in argument
1 (different address spaces)
altera_tse_ethtool.c:136:19: expected void const volatile
[noderef] <asn:2>*addr
altera_tse_ethtool.c:136:19: got unsigned int *<noident>
altera_sgdma.c:129:31: warning: cast removes address space of
expression
This patch addresses a fault in the error recovery path of the probe
routine where the netdev structure was not being unregistered properly
leading to a panic only when the phy probe failed.
Abbreviated panic stack seen is as follows:
(free_netdev+0xXX) from (altera_tse_probe+0xXX)
(altera_tse_probe+0xXX) from (platform_drv_probe+0xXX)
(platform_drv_probe+0xXX) from (driver_probe_device+0xXX)
(driver_probe_device+0xXX) from (__driver_attach+0xXX)
(__driver_attach+0xXX) from (bus_for_each_dev+0xXX)
(bus_for_each_dev+0xXX) from (driver_attach+0xXX)
(driver_attach+0xXX) from (bus_add_driver+0xXX)
(bus_add_driver+0xXX) from (driver_register+0xXX)
(driver_register+0xXX) from (__platform_driver_register+0xXX)
(__platform_driver_register+0xXX) from (altera_tse_driver_init+0xXX)
(altera_tse_driver_init+0xXX) from (do_one_initcall+0xXX)
(do_one_initcall+0xXX) from (kernel_init_freeable+0xXX)
(kernel_init_freeable+0xXX) from (kernel_init+0xXX)
(kernel_init+0xXX) from (ret_from_fork+0xXX)
This patch initializes the pause quanta set for transmitted pause frames
to the IEEE specified default of 0xffff.
This patch works around a recently discovered unaligned receive dma problem
with the Altera SGMDA. The Altera SGDMA component cannot be configured to
DMA data to unaligned addresses for receive packet operations from the
Triple Speed Ethernet component because of a potential data transfer
corruption that can occur. This patch addresses this issue by
utilizing the shift 16 bits feature of the Altera Triple Speed Ethernet
component and modifying the receive buffer physical addresses accordingly
such that the target receive DMA address is always aligned on a 32-bit
boundary.
Tested-by: Matthew Gerlach <mgerlach@altera.com>
Casting a pointer to a pointer of the same type is pointless,
so remove these unnecessary casts.
Done via coccinelle script:
$ cat typecast_2.cocci
type T;
T *foo;
- (T *)foo
+ foo
Acked-by: Vince Bridgers <vbridgers2013@gmail.com>
This patch adds the main driver and header file for the Altera Triple
Speed Ethernet driver.
