path: root/drivers/net/e1000e/82571.c
2011-08-10intel: Move the Intel wired LAN driversJeff Kirsher
Moves the Intel wired LAN drivers into drivers/net/ethernet/intel/ and the necessary Kconfig and Makefile changes. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-07-12e1000e: Add Jumbo Frame support to 82583 devicesCarolyn Wyborny
This patch adds support for the Jumbo Frames feature on 82583 devices. Signed-off-by: Carolyn Wyborny <carolyn.wyborny@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27e1000e: implement ethtool set_phys_idBruce Allan
Based on a patch from Stephen Hemminger <shemminger@vyatta.com>. The new ethtool set_phys_id takes over controlling the LED for identifying boards. This fixes the lockout during that period. For this device lots of extra infrastructure can also be removed by using set_phys_id. v2: - return blink frequency for parts that do not support blink in h/w - add blink_led function pointers for devices that do support blink in h/w to cleanup the test for this functionality Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-04-13e1000e: If ASPM L0s needs to be disabled, do it prior to enabling deviceBruce Allan
Based on a patch from Naga Chumbalkar <nagananda.chumbalkar@hp.com>: If ASPM L0s needs to be disabled due to HW errata, do it prior to "enabling" the device. This way if the kernel ever defaults its aspm_policy to POLICY_POWERSAVE, then the e1000e driver will get a chance to disable ASPM on the misbehaving device *prior* to calling pci_enable_device_mem(). This will be useful in situations where the BIOS indicates ASPM support on the server by clearing the ACPI FADT "ASPM Controls" bit. Note: The kernel (2.6.38) currently uses the BIOS "default" as its aspm_policy. However, Linux distros can diverge from that and set the default to "powersave". v2: o cleanup namespace pollution of e1000e_disable_aspm(), o fix type and initialization of the new aspm_disable_flag in a few functions, and o redefine FLAG2_DISABLE_ASPM_L0S to the first unused bit in adapter->flags2. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Cc: Naga Chumbalkar <nagananda.chumbalkar@hp.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-04-13e1000e: convert short duration msleep() to usleep_range()Bruce Allan
With durations less than 20ms, the jiffies or legacy timer backed msleep() may sleep ~20ms which might not be what the caller expects. Instead, it is recommended to use the hrtimers backed usleep_range(). For more, see Documentation/timers/timers-howto.txt. Issues reported by checkpatch. In addition, remove unnecessary sleep in e1000e_write_nvm_spi(). Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-01-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits) GRETH: resolve SMP issues and other problems GRETH: handle frame error interrupts GRETH: avoid writing bad speed/duplex when setting transfer mode GRETH: fixed skb buffer memory leak on frame errors GRETH: GBit transmit descriptor handling optimization GRETH: fix opening/closing GRETH: added raw AMBA vendor/device number to match against. cassini: Fix build bustage on x86. e1000e: consistent use of Rx/Tx vs. RX/TX/rx/tx in comments/logs e1000e: update Copyright for 2011 e1000: Avoid unhandled IRQ r8169: keep firmware in memory. netdev: tilepro: Use is_unicast_ether_addr helper etherdevice.h: Add is_unicast_ether_addr function ks8695net: Use default implementation of ethtool_ops::get_link ks8695net: Disable non-working ethtool operations USB CDC NCM: Don't deref NULL in cdc_ncm_rx_fixup() and don't use uninitialized variable. vxge: Remember to release firmware after upgrading firmware netdev: bfin_mac: Remove is_multicast_ether_addr use in netdev_for_each_mc_addr ipsec: update MAX_AH_AUTH_LEN to support sha512 ...
2011-01-14e1000e: consistent use of Rx/Tx vs. RX/TX/rx/tx in comments/logsBruce Allan
Some minor comment errors and whitespace issues discovered while looking into this are also addressed. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-01-14e1000e: update Copyright for 2011Bruce Allan
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-09e1000e: add custom set_d[0|3]_lplu_state function pointer for 82574Bruce Allan
82574 needs to configure Low Power Link Up (or LPLU) differently than the other parts in the 8257x family supported by the driver. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-09e1000e: cleanup variables set but not usedBruce Allan
The ICR register is clear on read and we don't care what the returned value is when resetting the hardware so the icr variable(s) can be removed. We should not ignore the return from e1000_lv_jumbo_workaround_ich8lan() and from e1000_get_phy_id_82571() (dump a debug message when it fails and when an unknown Phy id is returned). Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10e1000e: 82571 Serdes can fail to get linkBruce Allan
When link partner is sending continuous Config symbols, the 82571 Serdes FIFO can overflow resulting in Invalid bit getting set. To resolve this, if Sync and Config bits are both 1 ignore the Invalid bit and restart auto-negotiation. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2010-12-10e1000e: 82574/82583 performance improvementBruce Allan
Increasing the transmit fifo by 4K (by decreasing the receive fifo size specified in .pba by the same amount) increases Tx performance. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2010-12-10e1000e: 82571-based mezzanine card can fail ethtool link testBruce Allan
On certain 82571-based mezzanine NICs in some blade servers, the ethtool link test can fail due to the serdes_has_link flag not set correctly. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2010-11-16e1000e: 82574 intermittently fails to initialize with manageability f/wBruce Allan
The driver can fail initializing the hardware when manageability firmware is performing concurrent MDIO operations because the hardware semaphore scheme to prevent concurrent operations between software and firmware is incorrect for 82574/82583. Instead of using the SWSM register, the driver should be using the EXTCNF_CTRL register. A software mutex is also added to prevent simultaneous software threads from performing similar concurrent accesses. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2010-11-16e1000e: 82571 SerDes link handle null code word from partnerBruce Allan
SerDes Link detection on certain 82571 mezzanine cards can fail when the link is forced, the link partner does not recognize forced link and the link partner sends null code words. Detect the null code words and return to auto-negotiation state which causes the link partner to begin responding with valid code words. Within a reasonable interval the link will finally settle as forced by both partners. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-28e1000e: reset PHY after errors detectedCarolyn Wyborny
Some errors can be induced in the PHY via environmental testing (specifically extreme temperature changes and electro static discharge testing), and in the case of the PHY hanging due to this input, this detects the problem and resets to continue. This issue only applies to 82574 silicon. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Carolyn Wyborny <carolyn.wyborny@intel.com> Tested-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-30e1000e: use hardware writeback batchingJesse Brandeburg
Most e1000e parts support batching writebacks. The problem with this is that when some of the TADV or TIDV timers are not set, Tx can sit forever. This is solved in this patch with write flushes using the Flush Partial Descriptors (FPD) bit in TIDV and RDTR. This improves bus utilization and removes partial writes on e1000e, particularly from 82571 parts in S5500 chipset based machines. Only ES2LAN and 82571/2 parts are included in this optimization, to reduce testing load. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Tested-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-19e1000e: don't check for alternate MAC addr on parts that don't support itBruce Allan
From: Bruce Allan <bruce.w.allan@intel.com> The alternate MAC address feature is only supported by 80003ES2LAN and 82571 LOMs as well as a couple 82571 mezzanine cards. Checking for an alternate MAC address on other parts can fail leading to the driver not able to load. This patch limits the check for an alternate MAC address to be done only for parts that support the feature. This issue has been around since support for the feature was introduced to the e1000e driver in 2.6.34. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Reported-by: Fabio Varesano <fax8@users.sourceforge.net> Cc: stable@kernel.org Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-19e1000e: disable ASPM L1 on 82573Bruce Allan
On the e1000-devel mailing list, Nils Faerber reported latency issues with the 82573 LOM on a ThinkPad X60. It was found to be caused by ASPM L1; disabling it resolves the latency. The issue is present in kernels back to 2.6.34 and possibly 2.6.33. Reported-by: Nils Faerber <nils.faerber@kernelconcepts.de> Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Cc: stable@kernel.org Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-18e1000e: update copyright informationBruce Allan
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-12e1000e: fix checks for manageability enabled and management pass-throughBruce Allan
The mac->arc_subsystem was being incorrectly used to flag whether or not manageability was enabled when it should only be used to state whether the ARC (Host interface) subsystem is available on a particular MAC _and_ only valid when any manageability is enabled. The ARC subsystem is currently only available on 80003es2lan and 82573 parts supported by the driver. A new flag, has_fwsm, is introduced to be used when checking if manageability is enabled but only on parts that acutally have an FWSM register. While the above parts have an FWSM register, there are other parts that have FWSM but do not have support for the ARC subsystem, namely 82571/2 and ICHx/PCH. And then there are parts that have manageability, but do not have either FWSM register or support for the ARC subsystem - these are 82574 and 82583. For 80003es2lan, 82571/2/3 and ICH/PCH parts, this patch makes no functional changes, it only corrects the usage of the manageability flags. For 82574 and 82583, it fixes the incorrect accesses of the non-existent FWSM register and ARC subsystem as well as corrects the check for management pass-through. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-05e1000e: increase rx fifo size to 36K on 82574 and 82583Alexander Duyck
This change increases the RX fifo size to 36K for standard frames and decreases the TX fifo size to 4K. The reason for this change is that on slower systems the RX is much more likely to backfill and need space than the TX is. As long as the TX fifo is twice the size of the MTU we should have more than enough TX fifo. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e100.c drivers/net/e1000e/netdev.c
2010-04-27e1000e: enable/disable ASPM L0s and L1 and ERT according to hardware errataBruce Allan
Prompted by a previous patch submitted by Matthew Garret <mjg@redhat.com>, further digging into errata documentation reveals the current enabling or disabling of ASPM L0s and L1 states for certain parts supported by this driver are incorrect. 82571 and 82572 should always disable L1. For standard frames, 82573/82574/82583 can enable L1 but L0s must be disabled, and for jumbo frames 82573/82574 must disable L1. This allows for some parts to enable L1 in certain configurations leading to better power savings. Also according to the same errata, Early Receive (ERT) should be disabled on 82573 when using jumbo frames. Cc: Matthew Garret <mjg@redhat.com> Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30e1000e: typo correctionsJoe Perches
Here are the other miscellaneous corrections done by an earlier larger suggested patch now made unnecessary by a less invasive change. Correct a few missing newlines from logging messages and a typo fix. Fix speed/duplex logging message. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-13e1000e: genericize the update multicast address listBruce Allan
Make updating the multicast address list generic for all families and enforce the requirement to update the entire multicast table array all at once instead of piecemeal which causes problems on some parts. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-13e1000e: provide MAC-family-specific function to set LAN IDBruce Allan
Provide MAC-specific function pointer to determine the LAN ID (PCI func). The LAN ID is used internally by the driver to determine which h/w lock to use to protect accessing the PHY on ESB2 as well as help to determine the alternate MAC address on some parts. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-13e1000e: use alternate MAC address on ESB2 if availableBruce Allan
Similar to 82571/2/3 parts that already do this, if ESB2/80003es2lan parts have an alternate MAC address provided in the EEPROM use it instead of the default MAC address. This patch makes the the actual code that does this generic so that it can be better used by both MAC families. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-08e1000e: perform 10/100 adaptive IFS only on parts that support itBruce Allan
Adaptive IFS which involves writing to the Adaptive IFS Throttle register was being done for all devices supported by the driver even though it is not supported (i.e. the register doesn't even exist) on some devices. The feature is supported on 8257x/82583 and ICH/PCH based devices, but not on ESB2. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18e1000e: LED settings in EEPROM ignored on 82571 and 82572Bruce Allan
Do not override the customizable LED configuration set in the EEPROM. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02e1000e: check_polarity function pointers not set for 8257xBruce Allan
The function pointers for 8257x devices are not set. This is not really a problem now because there is nothing in the driver that references the pointers for this particular MAC-family (the appropriate functions are called directly), but the pointers should be set in case they are used in the future. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02e1000e: comment correctionsBruce Allan
2009-12-02e1000e: ensure the link state is correct for serdes linksBruce Allan
This patch ensures that the link state (as reported in mac->serdes_has_link) will transition to false when autoneg fails to complete but valid codewords were detected. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02e1000e: provide family-specific PHY power up/down operationsBruce Allan
The different families (80003es2lan, 8257x, ICHx/PCH) supported by the driver each have their own conditions when the PHY can be powered down. This patch rewrites the PHY power up/down code to fit with the family- specific style used in the driver. All pre-existing calls to power up or down the PHY remain untouched. A new call to power down the PHY when removing the driver when the interface is down replaces the current call to reset the PHY in order to reduce power consumption. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02e1000e: provide family-specific functions to manage VLAN filter arraysBruce Allan
The two MAC-families that have VLAN filter table register arrays manage each a bit differently from one another, so provide family-specific functions for managing the register arrays and function pointers to access the appropriate function. Also make sure attempts to access these register arrays are not done on parts not supporting that feature. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-21e1000e: cosmetic - group local variables of the same typeBruce Allan
2009-11-21e1000e: do not error out on identification LED init failureBruce Allan
A failure to initialize the identification LED is not a fatal condition and should allow the init path to continue. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-21e1000e: cleanup functions that clear hardware statisticsBruce Allan
The e1000_clear_hw_cntrs_*() functions read the registers to clear them. There is no reason to save the register contents so the temp variable can be removed. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-21e1000e: set bools to true/false instead of 1/0Bruce Allan
Set booleans to 'true' or 'false' to make it clear it is a boolean. Also change instances of TRUE/FALSE in comments to lowercase true/false. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-21e1000e: provide comment for 82571 workaroundBruce Allan
2009-11-21e1000e: remove comments regarding a non-existent api moduleBruce Allan
2009-11-21e1000e: update copyright informationBruce Allan
2009-11-21e1000e: cleanup ops function pointersBruce Allan
The phy and nvm operations structures have function pointers that contain "phy" and "nvm" in the pointer names which are redundant since the structures are already obviously in phy and nvm structures. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-21e1000e: consolidate two dbug macros into one simpler oneBruce Allan
This patch depends on a previous one that cleans up redundant #includes. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-21e1000e: cleanup redundant #include'sBruce Allan
