[ Upstream commit 21b52fed928e96d2f75d2f6aa9eac7a4b0b55d22 ]
rtnl_fdb_dump() has logic to split a dump of PF_BRIDGE neighbors into
multiple netlink skbs if the buffer provided by user space is too small
(one buffer will typically handle a few hundred FDB entries).
When the current buffer becomes full, nlmsg_put() in
dsa_slave_port_fdb_do_dump() returns -EMSGSIZE and DSA saves the index
of the last dumped FDB entry, returns to rtnl_fdb_dump() up to that
point, and then the dump resumes on the same port with a new skb, and
FDB entries up to the saved index are simply skipped.
Since dsa_slave_port_fdb_do_dump() is pointed to by the "cb" passed to
drivers, then drivers must check for the -EMSGSIZE error code returned
by it. Otherwise, when a netlink skb becomes full, DSA will no longer
save newly dumped FDB entries to it, but the driver will continue
dumping. So FDB entries will be missing from the dump.
Fix the broken backpressure by propagating the "cb" return code and
allow rtnl_fdb_dump() to restart the FDB dump with a new skb.
Fixes: 291d1e72b756 ("net: dsa: sja1105: Add support for FDB and MDB management")
Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com>
statically added ones
[ Upstream commit 6c5fc159e0927531707895709eee1f8bfa04289f ]
The procedure to add a static FDB entry in sja1105 is concurrent with
dynamic learning performed on all bridge ports and the CPU port.
The switch looks up the FDB from left to right, and also learns
dynamically from left to right, so it is possible that between the
moment when we pick up a free slot to install an FDB entry, another slot
to the left of that one becomes free due to an address ageing out, and
that other slot is then immediately used by the switch to learn
dynamically the same address as we're trying to add statically.
The result is that we succeeded to add our static FDB entry, but it is
being shadowed by a dynamic FDB entry to its left, and the switch will
behave as if our static FDB entry did not exist.
We cannot really prevent this from happening unless we make the entire
process to add a static FDB entry a huge critical section where address
learning is temporarily disabled on _all_ ports, and then re-enabled
according to the configuration done by sja1105_port_set_learning.
However, that is kind of disruptive for the operation of the network.
What we can do alternatively is to simply read back the FDB for dynamic
entries located before our newly added static one, and delete them.
This will guarantee that our static FDB entry is now operational. It
will still not guarantee that there aren't dynamic FDB entries to the
_right_ of that static FDB entry, but at least those entries will age
out by themselves since they aren't hit, and won't bother anyone.
Fixes: 1da73821343c ("net: dsa: sja1105: Add FDB operations for P/Q/R/S series")
.port_fdb_add
[ Upstream commit e11e865bf84e3c6ea91563ff3e858cfe0e184bd2 ]
The SJA1105 switch family leaves it up to software to decide where
within the FDB to install a static entry, and to concatenate destination
ports for already existing entries (the FDB is also used for multicast
entries), it is not as simple as just saying "please add this entry".
This means we first need to search for an existing FDB entry before
adding a new one. The driver currently manages to fool itself into
thinking that if an FDB entry already exists, there is nothing to be
done. But that FDB entry might be dynamically learned, case in which it
should be replaced with a static entry, but instead it is left alone.
This patch checks the LOCKEDS ("locked/static") bit from found FDB
entries, and lets the code "goto skip_finding_an_index;" if the FDB
entry was not static. So we also need to move the place where we set
LOCKEDS = true, to cover the new case where a dynamic FDB entry existed
but was dynamic.
commit 6729188d2646709941903052e4b78e1d82c239b9 upstream.
The driver continues probing when a port is configured for an
unsupported PHY interface type, instead it should stop.
Fixes: 8aa9ebccae87 ("net: dsa: Introduce driver for NXP SJA1105 5-port L2 switch")
[ Upstream commit 27afe0d34e9121a3d61cc0af9b17c2542dadde24 ]
The sja1105_parse_ports_node function was tested only on device trees
where all ports were enabled. Fix this check so that the driver
continues to probe only with the ports where status is not "disabled",
as expected.
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 54fa49ee88138756df0fcf867cb1849904710a8c ]
For first-generation switches (SJA1105E and SJA1105T):
- TPID means C-Tag (typically 0x8100)
- TPID2 means S-Tag (typically 0x88A8)
While for the second generation switches (SJA1105P, SJA1105Q, SJA1105R,
SJA1105S) it is the other way around:
- TPID means S-Tag (typically 0x88A8)
- TPID2 means C-Tag (typically 0x8100)
In other words, E/T tags untagged traffic with TPID, and P/Q/R/S with
TPID2.
So the patch mentioned below fixed VLAN filtering for P/Q/R/S, but broke
it for E/T.
We strive for a common code path for all switches in the family, so just
lie in the static config packing functions that TPID and TPID2 are at
swapped bit offsets than they actually are, for P/Q/R/S. This will make
both switches understand TPID to be ETH_P_8021Q and TPID2 to be
ETH_P_8021AD. The meaning from the original E/T was chosen over P/Q/R/S
because E/T is actually the one with public documentation available
(UM10944.pdf).
Fixes: f9a1a7646c0d ("net: dsa: sja1105: Reverse TPID and TPID2")
Signed-off-by: Vladimir Oltean <olteanv@gmail.com>
[ Upstream commit af580ae2dcb250719857b4b7024bd4bb0c2e05fb ]
The purpose here is to avoid ptp4l fail due to this condition:
timed out while polling for tx timestamp
increasing tx_timestamp_timeout may correct this issue, but it is likely caused by a driver bug
port 1: send peer delay request failed
So either reset the switch before the management frame was sent, or
after it was timestamped as well, but not in the middle.
The condition may arise either due to a true timeout (i.e. because
re-uploading the static config takes time), or due to the TX timestamp
actually getting lost due to reset. For the former we can increase
tx_timestamp_timeout in userspace, for the latter we need this patch.
Locking all traffic during switch reset does not make sense at all,
though. Forcing all CPU-originated traffic to potentially block waiting
for a sleepable context to send > 800 bytes over SPI is not a good idea.
Flows that are autonomously forwarded by the switch will get dropped
anyway during switch reset no matter what. So just let all other
CPU-originated traffic be dropped as well.
[ Upstream commit 9bca3a0a923fc3f0fb9e41391be1d0f291e86858 ]
This function was using configuration of port 0 in devicetree for all ports.
In case CPU port was not 0, the delay settings was ignored. This resulted not
working communication between CPU and the switch.
Fixes: f5b8631c293b ("net: dsa: sja1105: Error out if RGMII delays are requested in DT")
Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de>
Reviewed-by: Vladimir Oltean <olteanv@gmail.com>
An earlier bugfix introduced a dependency on CONFIG_NET_SCH_TAPRIO,
but this missed the case of NET_SCH_TAPRIO=m and NET_DSA_SJA1105=y,
which still causes a link error:
drivers/net/dsa/sja1105/sja1105_tas.o: In function `sja1105_setup_tc_taprio':
sja1105_tas.c:(.text+0x5c): undefined reference to `taprio_offload_free'
sja1105_tas.c:(.text+0x3b4): undefined reference to `taprio_offload_get'
drivers/net/dsa/sja1105/sja1105_tas.o: In function `sja1105_tas_teardown':
sja1105_tas.c:(.text+0x6ec): undefined reference to `taprio_offload_free'
Change the dependency to only allow selecting the TAS code when it
can link against the taprio code.
Fixes: a8d570de0cc6 ("net: dsa: sja1105: Add dependency for NET_DSA_SJA1105_TAS")
Fixes: 317ab5b86c8e ("net: dsa: sja1105: Configure the Time-Aware Scheduler via tc-taprio offload")
This patch corrects the SPDX License Identifier style
in header files related to Distributed Switch Architecture
drivers for NXP SJA1105 series Ethernet switch support.
It uses an expilict block comment for the SPDX License
Identifier.
Changes made by using a script provided by Joe Perches here:
https://lkml.org/lkml/2019/2/7/46.
Suggested-by: Joe Perches <joe@perches.com>
Signed-off-by: Nishad Kamdar <nishadkamdar@gmail.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Currently this stack trace can be seen with CONFIG_DEBUG_ATOMIC_SLEEP=y:
[ 41.568348] BUG: sleeping function called from invalid context at kernel/locking/mutex.c:909
[ 41.576757] in_atomic(): 1, irqs_disabled(): 0, pid: 208, name: ptp4l
[ 41.583212] INFO: lockdep is turned off.
[ 41.587123] CPU: 1 PID: 208 Comm: ptp4l Not tainted 5.3.0-rc6-01445-ge950f2d4bc7f-dirty #1827
[ 41.599873] [<c0313d7c>] (unwind_backtrace) from [<c030e13c>] (show_stack+0x10/0x14)
[ 41.607584] [<c030e13c>] (show_stack) from [<c1212d50>] (dump_stack+0xd4/0x100)
[ 41.614863] [<c1212d50>] (dump_stack) from [<c037dfc8>] (___might_sleep+0x1c8/0x2b4)
[ 41.622574] [<c037dfc8>] (___might_sleep) from [<c122ea90>] (__mutex_lock+0x48/0xab8)
[ 41.630368] [<c122ea90>] (__mutex_lock) from [<c122f51c>] (mutex_lock_nested+0x1c/0x24)
[ 41.638340] [<c122f51c>] (mutex_lock_nested) from [<c0c6fe08>] (sja1105_static_config_reload+0x30/0x27c)
[ 41.647779] [<c0c6fe08>] (sja1105_static_config_reload) from [<c0c7015c>] (sja1105_hwtstamp_set+0x108/0x1cc)
[ 41.657562] [<c0c7015c>] (sja1105_hwtstamp_set) from [<c0feb650>] (dev_ifsioc+0x18c/0x330)
[ 41.665788] [<c0feb650>] (dev_ifsioc) from [<c0febbd8>] (dev_ioctl+0x320/0x6e8)
[ 41.673064] [<c0febbd8>] (dev_ioctl) from [<c0f8b1f4>] (sock_ioctl+0x334/0x5e8)
[ 41.680340] [<c0f8b1f4>] (sock_ioctl) from [<c05404a8>] (do_vfs_ioctl+0xb0/0xa10)
[ 41.687789] [<c05404a8>] (do_vfs_ioctl) from [<c0540e3c>] (ksys_ioctl+0x34/0x58)
[ 41.695151] [<c0540e3c>] (ksys_ioctl) from [<c0301000>] (ret_fast_syscall+0x0/0x28)
[ 41.702768] Exception stack(0xe8495fa8 to 0xe8495ff0)
[ 41.707796] 5fa0: beff4a8c 00000001 00000011 000089b0 beff4a8c beff4a80
[ 41.715933] 5fc0: beff4a8c 00000001 0000000c 00000036 b6fa98c8 004e19c1 00000001 00000000
[ 41.724069] 5fe0: 004dcedc beff4a6c 004c0738 b6e7af4c
[ 41.729860] BUG: scheduling while atomic: ptp4l/208/0x00000002
[ 41.735682] INFO: lockdep is turned off.
Enabling RX timestamping will logically disturb the fastpath (processing
of meta frames). Replace bool hwts_rx_en with a bit that is checked
atomically from the fastpath and temporarily unset from the sleepable
context during a change of the RX timestamping process (a destructive
operation anyways, requires switch reset).
If found unset, the fastpath (net/dsa/tag_sja1105.c) will just drop any
received meta frame and not take the meta_lock at all.
Fixes: a602afd200f5 ("net: dsa: sja1105: Expose PTP timestamping ioctls to userspace")
Otherwise, with CONFIG_DEBUG_SPINLOCK=y, this stack trace gets printed
when enabling RX timestamping and receiving a PTP frame:
[ 318.537078] INFO: trying to register non-static key.
[ 318.542040] the code is fine but needs lockdep annotation.
[ 318.547500] turning off the locking correctness validator.
[ 318.552972] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.3.0-13257-g0825b0669811-dirty #1962
[ 318.561283] Hardware name: Freescale LS1021A
[ 318.565566] [<c03144bc>] (unwind_backtrace) from [<c030e164>] (show_stack+0x10/0x14)
[ 318.573289] [<c030e164>] (show_stack) from [<c11b9f50>] (dump_stack+0xd4/0x100)
[ 318.580579] [<c11b9f50>] (dump_stack) from [<c03b9b40>] (register_lock_class+0x728/0x734)
[ 318.588731] [<c03b9b40>] (register_lock_class) from [<c03b60c4>] (__lock_acquire+0x78/0x25cc)
[ 318.597227] [<c03b60c4>] (__lock_acquire) from [<c03b8ef8>] (lock_acquire+0xd8/0x234)
[ 318.605033] [<c03b8ef8>] (lock_acquire) from [<c11db934>] (_raw_spin_lock+0x44/0x54)
[ 318.612755] [<c11db934>] (_raw_spin_lock) from [<c1164370>] (sja1105_rcv+0x1f8/0x4e8)
[ 318.620561] [<c1164370>] (sja1105_rcv) from [<c115d7cc>] (dsa_switch_rcv+0x80/0x204)
[ 318.628283] [<c115d7cc>] (dsa_switch_rcv) from [<c0f58c80>] (__netif_receive_skb_one_core+0x50/0x6c)
[ 318.637386] [<c0f58c80>] (__netif_receive_skb_one_core) from [<c0f58f04>] (netif_receive_skb_internal+0xac/0x264)
[ 318.647611] [<c0f58f04>] (netif_receive_skb_internal) from [<c0f59e98>] (napi_gro_receive+0x1d8/0x338)
[ 318.656887] [<c0f59e98>] (napi_gro_receive) from [<c0c298a4>] (gfar_clean_rx_ring+0x328/0x724)
[ 318.665472] [<c0c298a4>] (gfar_clean_rx_ring) from [<c0c29e60>] (gfar_poll_rx_sq+0x34/0x94)
[ 318.673795] [<c0c29e60>] (gfar_poll_rx_sq) from [<c0f5b40c>] (net_rx_action+0x128/0x4f8)
[ 318.681860] [<c0f5b40c>] (net_rx_action) from [<c03022f0>] (__do_softirq+0x148/0x5ac)
[ 318.689666] [<c03022f0>] (__do_softirq) from [<c0355af4>] (irq_exit+0x160/0x170)
[ 318.697040] [<c0355af4>] (irq_exit) from [<c03c6818>] (__handle_domain_irq+0x60/0xb4)
[ 318.704847] [<c03c6818>] (__handle_domain_irq) from [<c07e9440>] (gic_handle_irq+0x58/0x9c)
[ 318.713172] [<c07e9440>] (gic_handle_irq) from [<c0301a70>] (__irq_svc+0x70/0x98)
[ 318.720622] Exception stack(0xc2001f18 to 0xc2001f60)
[ 318.725656] 1f00: 00000001 00000006
[ 318.733805] 1f20: 00000000 c20165c0 ffffe000 c2010cac c2010cf4 00000001 00000000 c2010c88
[ 318.741955] 1f40: c1f7a5a8 00000000 00000000 c2001f68 c03ba140 c030a288 200e0013 ffffffff
[ 318.750110] [<c0301a70>] (__irq_svc) from [<c030a288>] (arch_cpu_idle+0x24/0x3c)
[ 318.757486] [<c030a288>] (arch_cpu_idle) from [<c038a480>] (do_idle+0x1b8/0x2a4)
[ 318.764859] [<c038a480>] (do_idle) from [<c038a94c>] (cpu_startup_entry+0x18/0x1c)
[ 318.772407] [<c038a94c>] (cpu_startup_entry) from [<c1e00f10>] (start_kernel+0x4cc/0x4fc)
Fixes: 844d7edc6a34 ("net: dsa: sja1105: Add a global sja1105_tagger_data structure")
In sja1105_static_config_upload, in two cases memory is leaked: when
static_config_buf_prepare_for_upload fails and when sja1105_inhibit_tx
fails. In both cases config_buf should be released.
Fixes: 1a4c69406cc1 ("net: dsa: sja1105: Prevent PHY jabbering during switch reset")
Signed-off-by: Navid Emamdoost <navid.emamdoost@gmail.com>
past
Sometimes the PTP synchronization on the switch 'jumps':
ptp4l[11241.155]: rms 8 max 16 freq -21732 +/- 11 delay 742 +/- 0
ptp4l[11243.157]: rms 7 max 17 freq -21731 +/- 10 delay 744 +/- 0
ptp4l[11245.160]: rms 33592410 max 134217731 freq +192422 +/- 8530253 delay 743 +/- 0
ptp4l[11247.163]: rms 811631 max 964131 freq +10326 +/- 557785 delay 743 +/- 0
ptp4l[11249.166]: rms 261936 max 533876 freq -304323 +/- 126371 delay 744 +/- 0
ptp4l[11251.169]: rms 48700 max 57740 freq -20218 +/- 30532 delay 744 +/- 0
ptp4l[11253.171]: rms 14570 max 30163 freq -5568 +/- 7563 delay 742 +/- 0
ptp4l[11255.174]: rms 2914 max 3440 freq -22001 +/- 1667 delay 744 +/- 1
ptp4l[11257.177]: rms 811 max 1710 freq -22653 +/- 451 delay 744 +/- 1
ptp4l[11259.180]: rms 177 max 218 freq -21695 +/- 89 delay 741 +/- 0
ptp4l[11261.182]: rms 45 max 92 freq -21677 +/- 32 delay 742 +/- 0
ptp4l[11263.186]: rms 14 max 32 freq -21733 +/- 11 delay 742 +/- 0
ptp4l[11265.188]: rms 9 max 14 freq -21725 +/- 12 delay 742 +/- 0
ptp4l[11267.191]: rms 9 max 16 freq -21727 +/- 13 delay 742 +/- 0
ptp4l[11269.194]: rms 6 max 15 freq -21726 +/- 9 delay 743 +/- 0
ptp4l[11271.197]: rms 8 max 15 freq -21728 +/- 11 delay 743 +/- 0
ptp4l[11273.200]: rms 6 max 12 freq -21727 +/- 8 delay 743 +/- 0
ptp4l[11275.202]: rms 9 max 17 freq -21720 +/- 11 delay 742 +/- 0
ptp4l[11277.205]: rms 9 max 18 freq -21725 +/- 12 delay 742 +/- 0
Background: the switch only offers partial RX timestamps (24 bits) and
it is up to the driver to read the PTP clock to fill those timestamps up
to 64 bits. But the PTP clock readout needs to happen quickly enough (in
0.135 seconds, in fact), otherwise the PTP clock will wrap around 24
bits, condition which cannot be detected.
Looking at the 'max 134217731' value on output line 3, one can see that
in hex it is 0x8000003. Because the PTP clock resolution is 8 ns,
that means 0x1000000 in ticks, which is exactly 2^24. So indeed this is
a PTP clock wraparound, but the reason might be surprising.
What is going on is that sja1105_tstamp_reconstruct(priv, now, ts)
expects a "now" time that is later than the "ts" was snapshotted at.
This, of course, is obvious: we read the PTP time _after_ the partial RX
timestamp was received. However, the workqueue is processing frames from
a skb queue and reuses the same PTP time, read once at the beginning.
Normally the skb queue only contains one frame and all goes well. But
when the skb queue contains two frames, the second frame that gets
dequeued might have been partially timestamped by the RX MAC _after_ we
had read our PTP time initially.
The code was originally like that due to concerns that SPI access for
PTP time readout is a slow process, and we are time-constrained anyway
(aka: premature optimization). But some timing analysis reveals that the
time spent until the RX timestamp is completely reconstructed is 1 order
of magnitude lower than the 0.135 s deadline even under worst-case
conditions. So we can afford to read the PTP time for each frame in the
RX timestamping queue, which of course ensures that the full PTP time is
in the partial timestamp's future.
Fixes: f3097be21bf1 ("net: dsa: sja1105: Add a state machine for RX timestamping")
If CONFIG_NET_DSA_SJA1105_TAS=y and CONFIG_NET_SCH_TAPRIO=n,
below error can be found:
sja1105_tas.c:(.text+0x318): undefined reference to `taprio_offload_free'
sja1105_tas.c:(.text+0x590): undefined reference to `taprio_offload_get'
sja1105_tas.c:(.text+0x610): undefined reference to `taprio_offload_free'
make: *** [vmlinux] Error 1
sja1105_tas needs tc-taprio, so this patch add the dependency for it.
Signed-off-by: Mao Wenan <maowenan@huawei.com>
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
This qdisc offload is the closest thing to what the SJA1105 supports in
hardware for time-based egress shaping. The switch core really is built
around SAE AS6802/TTEthernet (a TTTech standard) but can be made to
operate similarly to IEEE 802.1Qbv with some constraints:
- The gate control list is a global list for all ports. There are 8
execution threads that iterate through this global list in parallel.
I don't know why 8, there are only 4 front-panel ports.
- Care must be taken by the user to make sure that two execution threads
never get to execute a GCL entry simultaneously. I created a O(n^4)
checker for this hardware limitation, prior to accepting a taprio
offload configuration as valid.
- The spec says that if a GCL entry's interval is shorter than the frame
length, you shouldn't send it (and end up in head-of-line blocking).
Well, this switch does anyway.
- The switch has no concept of ADMIN and OPER configurations. Because
it's so simple, the TAS settings are loaded through the static config
tables interface, so there isn't even place for any discussion about
'graceful switchover between ADMIN and OPER'. You just reset the
switch and upload a new OPER config.
- The switch accepts multiple time sources for the gate events. Right
now I am using the standalone clock source as opposed to PTP. So the
base time parameter doesn't really do much. Support for the PTP clock
source will be added in a future series.
This is a preparation patch for the tc-taprio offload (and potentially
for other future offloads such as tc-mqprio).
Instead of looking directly at skb->priority during xmit, let's get the
netdev queue and the queue-to-traffic-class mapping, and put the
resulting traffic class into the dsa_8021q PCP field. The switch is
configured with a 1-to-1 PCP-to-ingress-queue-to-egress-queue mapping
(see vlan_pmap in sja1105_main.c), so the effect is that we can inject
into a front-panel's egress traffic class through VLAN tagging from
Linux, completely transparently.
Unfortunately the switch doesn't look at the VLAN PCP in the case of
management traffic to/from the CPU (link-local frames at
01-80-C2-xx-xx-xx or 01-1B-19-xx-xx-xx) so we can't alter the
transmission queue of this type of traffic on a frame-by-frame basis. It
is only selected through the "hostprio" setting which ATM is harcoded in
the driver to 7.
In order to support tc-taprio offload, the TTEthernet egress scheduling
core registers must be made visible through the static interface.
The switch barely supports traffic I/O, and it does that by repurposing
VLANs when there is no bridge that is taking control of them.
Letting DSA declare this netdev feature as supported (see
dsa_slave_create) would mean that VLAN sub-interfaces created on sja1105
switch ports will be hardware offloaded. That means that
net/8021q/vlan_core.c would install the VLAN into the filter tables of
the switch, potentially interfering with the tag_8021q VLANs.
We need to prevent that from happening and not let the 8021q core
offload VLANs to the switch hardware tables. In vlan_filtering=0 modes
of operation, the switch ports can pass through VLAN-tagged frames with
no problem.
Suggested-by: Florian Fainelli <f.fainelli@gmail.com>
Fixes gcc '-Wunused-but-set-variable' warning:
drivers/net/dsa/sja1105/sja1105_main.c: In function sja1105_fdb_dump:
drivers/net/dsa/sja1105/sja1105_main.c:1226:14: warning:
variable tx_vid set but not used [-Wunused-but-set-variable]
drivers/net/dsa/sja1105/sja1105_main.c:1226:6: warning:
variable rx_vid set but not used [-Wunused-but-set-variable]
They are not used since commit 6d7c7d948a2e ("net: dsa:
sja1105: Fix broken learning with vlan_filtering disabled")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Reviewed-by: Vivien Didelot <vivien.didelot@gmail.com>
The IS_ERR_OR_NULL(priv->clock) check inside
sja1105_ptp_clock_unregister() is preventing cancel_delayed_work_sync
from actually being run.
Additionally, sja1105_ptp_clock_unregister() does not actually get run,
when placed in sja1105_remove(). The DSA switch gets torn down, but the
sja1105 module does not get unregistered. So sja1105_ptp_clock_unregister
needs to be moved to sja1105_teardown, to be symmetrical with
sja1105_ptp_clock_register which is called from the DSA sja1105_setup.
It is strange to fix a "fixes" patch, but the probe failure can only be
seen when the attached PHY does not respond to MDIO (issue which I can't
pinpoint the reason to) and it goes away after I power-cycle the board.
This time the patch was validated on a failing board, and the kernel
panic from the fixed commit's message can no longer be seen.
Fixes: 29dd908d355f ("net: dsa: sja1105: Cancel PTP delayed work on unregister")
It looks like the FDB dump taken from first-generation switches also
contains information on whether entries are static or not. So use that
instead of searching through the driver's tables.
Fixes: d763778224ea ("net: dsa: sja1105: Implement is_static for FDB entries on E/T")
When put under a bridge with vlan_filtering 0, the SJA1105 ports will
flood all traffic as if learning was broken. This is because learning
interferes with the rx_vid's configured by dsa_8021q as unique pvid's.
So learning technically still *does* work, it's just that the learnt
entries never get matched due to their unique VLAN ID.
The setting that saves the day is Shared VLAN Learning, which on this
switch family works exactly as desired: VLAN tagging still works
(untagged traffic gets the correct pvid) and FDB entries are still
populated with the correct contents including VID. Also, a frame cannot
violate the forwarding domain restrictions enforced by its classified
VLAN. It is just that the VID is ignored when looking up the FDB for
taking a forwarding decision (selecting the egress port).
This patch activates SVL, and the result is that frames with a learnt
DMAC are no longer flooded in the scenario described above.
Now exactly *because* SVL works as desired, we have to revisit some
earlier patches:
- It is no longer necessary to manipulate the VID of the 'bridge fdb
{add,del}' command when vlan_filtering is off. This is because now,
SVL is enabled for that case, so the actual VID does not matter*.
- It is still desirable to hide dsa_8021q VID's in the FDB dump
callback. But right now the dump callback should no longer hide
duplicates (one per each front panel port's pvid, plus one for the
VLAN that the CPU port is going to tag a TX frame with), because there
shouldn't be any (the switch will match a single FDB entry no matter
its VID anyway).
* Not really... It's no longer necessary to transform a 'bridge fdb add'
into 5 fdb add operations, but the user might still add a fdb entry with
any vid, and all of them would appear as duplicates in 'bridge fdb
show'. So force a 'bridge fdb add' to insert the VID of 0**, so that we
can prune the duplicates at insertion time.
** The VID of 0 is better than 1 because it is always guaranteed to be
in the ports' hardware filter. DSA also avoids putting the VID inside
the netlink response message towards the bridge driver when we return
this particular VID, which makes it suitable for FDB entries learnt
with vlan_filtering off.
Fixes: 227d07a07ef1 ("net: dsa: sja1105: Add support for traffic through standalone ports")
Signed-off-by: Georg Waibel <georg.waibel@sensor-technik.de>
Each iteration of for_each_child_of_node puts the previous node, but in
the case of a return from the middle of the loop, there is no put, thus
causing a memory leak. Hence add an of_node_put before the return.
Issue found with Coccinelle.
Signed-off-by: Nishka Dasgupta <nishkadg.linux@gmail.com>
We need a better way to signal this, perhaps in phylink_validate, but
for now just print this error message as guidance for other people
looking at this driver's code while trying to rework PHYLINK.
Cc: Russell King <rmk+kernel@armlinux.org.uk>
PHYLINK being designed with PHYs in mind that can change MII protocol,
for correct operation it is necessary to ensure that the PHY interface
mode stays the same (otherwise clear the supported bit mask, as
required).
Because this is just a hypothetical situation for now, we don't bother
to check whether we could actually support the new PHY interface mode.
Actually we could modify the xMII table, reset the switch and send an
updated static configuration, but adding that would just be dead code.
It has been pointed out that PHYLINK can call mac_config only to update
the phy_interface_type and without knowing what the AN results are.
Experimentally, when this was observed to happen, state->link was also
unset, and therefore was used as a proxy to ignore this call. However it
is also suggested that state->link is undefined for this callback and
should not be relied upon.
So let the previously-dead codepath for SPEED_UNKNOWN be called, and
update the comment to make sure the MAC's behavior is sane.
The first generation switches don't tell us through the dynamic config
interface whether the dumped FDB entries are static or not (the LOCKEDS
bit from P/Q/R/S).
However, now that we're keeping a mirror of all 'bridge fdb' commands in
the static config, this is an opportunity to compare a dumped FDB entry
to the driver's private database. After all, what makes an entry static
is that *we* added it.
A FDB entry means that "frames that match this VID and DMAC must be
forwarded to this port".
In the case of dsa_8021q however, the VID is not a single one (and
neither two, as my previous patch assumed). The VID can be set either by
the CPU port (1 tx_vid), or by any of the other front-panel port (n-1
rx_vid's).
Fixes: 93647594d8f5 ("net: dsa: sja1105: Hide the dsa_8021q VLANs from the bridge fdb command")
The reason why this wasn't tackled earlier is that I had hoped I
understood the user manual wrong. But unfortunately hacks are required
in order to retrieve the static/dynamic nature of FDB entries on SJA1105
P/Q/R/S, since this info is stored in the writeback buffer of the
dynamic config command.
When trying to add support for LOCKEDS (static FDB entries) on SJA1105
P/Q/R/S, at first I didn't remember how the abstraction I created
worked, and actually thought it works by mistake.
To avoid other people staring at the code and not making much sense out
of it, add some comments at the top of the file.
After commit 8456721dd4ec ("net: dsa: sja1105: Add support for
configuring address ageing time"), we started to reset the switch rather
often (each time the bridge core changes the ageing time on a switch
port).
The unfortunate reality is that SJA1105 doesn't have any {cold, warm,
whatever} reset mode in which it accepts a new configuration stream
without flushing the FDB. Instead, in its world, the FDB *is* an
optional part of the static configuration.
So we play its game, and do what we also do for VLANs: for each 'bridge
fdb' command, we add the FDB entry through the dynamic interface, and we
append the in-kernel static config memory with info that we're going to
use later, when the next reset command is going to be issued.
The result is that 'bridge fdb' commands are now persistent (dynamically
learned entries are lost, but that's ok).
At the end of the commit 1da73821343c ("net: dsa: sja1105: Add FDB
operations for P/Q/R/S series") message, I said that:
At the moment only FDB entries installed statically through 'bridge fdb'
are visible in the dump callback - the dynamically learned ones are
still under investigation.
It looks like the reason why they were not visible in 'bridge fdb' was
that they were never learned - always flooded.
SJA1105 P/Q/R/S manual says about the MAXADDRP[port] field:
Specify the maximum number of MAC address dynamically learned from
the respective port. It is used to limit the number of learned MAC
addresses per port.
It looks like not providing a value in the static config (aka providing
zeroes) is enough for it to not store the learned addresses in the FDB.
For now we divide the 1024 entry FDB "equally" amongst the 5 ports. This
may be revisited if the situation calls for that - for now I'm happy
that learning works.
In commit 1da73821343c ("net: dsa: sja1105: Add FDB operations for
P/Q/R/S series"), these bits were set in the static config, but
apparently they did not do anything. The reason is that the packing
accessors for them were part of a patch I forgot to send.
In SJA1105 there is no concept of 'default values' per se, everything
needs to be driver-supplied through the static configuration tables.
The issue is that the hardware manual says that 'at least the default
untagging VLAN' is mandatory to be provided through the static config.
But VLAN 0 isn't a very good initial pvid - its use is reserved for
priority-tagged frames, and the layers of the stack that care about
those already make sure that this VLAN is installed, as can be seen in
the message below:
8021q: adding VLAN 0 to HW filter on device swp2
So change the pvid provided through the static configuration to 1, which
matches the bridge core's defaults.
Currently when the driver unloads and PTP is enabled, the delayed work
that prevents the timecounter from expiring becomes a ticking time bomb.
The kernel will schedule the work thread within 60 seconds of driver
removal, but the work handler is no longer there, leading to this
strange and inconclusive stack trace:
[ 64.473112] Unable to handle kernel paging request at virtual address 79746970
[ 64.480340] pgd = 008c4af9
[ 64.483042] [79746970] *pgd=00000000
[ 64.486620] Internal error: Oops: 80000005 [#1] SMP ARM
[ 64.491820] Modules linked in:
[ 64.494871] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.2.0-rc5-01634-ge3a2773ba9e5 #1246
[ 64.503007] Hardware name: Freescale LS1021A
[ 64.507259] PC is at 0x79746970
[ 64.510393] LR is at call_timer_fn+0x3c/0x18c
[ 64.514729] pc : [<79746970>] lr : [<c03bd734>] psr: 60010113
[ 64.520965] sp : c1901de0 ip : 00000000 fp : c1903080
[ 64.526163] r10: c1901e38 r9 : ffffe000 r8 : c19064ac
[ 64.531363] r7 : 79746972 r6 : e98dd260 r5 : 00000100 r4 : c1a9e4a0
[ 64.537859] r3 : c1900000 r2 : ffffa400 r1 : 79746972 r0 : e98dd260
[ 64.544359] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 64.551460] Control: 10c5387d Table: a8a2806a DAC: 00000051
[ 64.557176] Process swapper/0 (pid: 0, stack limit = 0x1ddb27f0)
[ 64.563147] Stack: (0xc1901de0 to 0xc1902000)
[ 64.567481] 1de0: eb6a4918 3d60d7c3 c1a9e554 e98dd260 eb6a34c0 c1a9e4a0 ffffa400 c19064ac
[ 64.575616] 1e00: ffffe000 c03bd95c c1901e34 c1901e34 eb6a34c0 c1901e30 c1903d00 c186f4c0
[ 64.583751] 1e20: c1906488 29e34000 c1903080 c03bdca4 00000000 eaa6f218 00000000 eb6a45c0
[ 64.591886] 1e40: eb6a45c0 20010193 00000003 c03c0a68 20010193 3f7231be c1903084 00000002
[ 64.600022] 1e60: 00000082 00000001 ffffe000 c1a9e0a4 00000100 c0302298 02b64722 0000000f
[ 64.608157] 1e80: c186b3c8 c1877540 c19064ac 0000000a c186b350 ffffa401 c1903d00 c1107348
[ 64.616292] 1ea0: 00200102 c0d87a14 ea823c00 ffffe000 00000012 00000000 00000000 ea810800
[ 64.624427] 1ec0: f0803000 c1876ba8 00000000 c034c784 c18774b8 c039fb50 c1906c90 c1978aac
[ 64.632562] 1ee0: f080200c f0802000 c1901f10 c0709ca8 c03091a0 60010013 ffffffff c1901f44
[ 64.640697] 1f00: 00000000 c1900000 c1876ba8 c0301a8c 00000000 000070a0 eb6ac1a0 c031da60
[ 64.648832] 1f20: ffffe000 c19064ac c19064f0 00000001 00000000 c1906488 c1876ba8 00000000
[ 64.656967] 1f40: ffffffff c1901f60 c030919c c03091a0 60010013 ffffffff 00000051 00000000
[ 64.665102] 1f60: ffffe000 c0376aa4 c1a9da37 ffffffff 00000037 3f7231be c1ab20c0 000000cc
[ 64.673238] 1f80: c1906488 c1906480 ffffffff 00000037 c1ab20c0 c1ab20c0 00000001 c0376e1c
[ 64.681373] 1fa0: c1ab2118 c1700ea8 ffffffff ffffffff 00000000 c1700754 c17dfa40 ebfffd80
[ 64.689509] 1fc0: 00000000 c17dfa40 3f7733be 00000000 00000000 c1700330 00000051 10c0387d
[ 64.697644] 1fe0: 00000000 8f000000 410fc075 10c5387d 00000000 00000000 00000000 00000000
[ 64.705788] [<c03bd734>] (call_timer_fn) from [<c03bd95c>] (expire_timers+0xd8/0x144)
[ 64.713579] [<c03bd95c>] (expire_timers) from [<c03bdca4>] (run_timer_softirq+0xe4/0x1dc)
[ 64.721716] [<c03bdca4>] (run_timer_softirq) from [<c0302298>] (__do_softirq+0x130/0x3c8)
[ 64.729854] [<c0302298>] (__do_softirq) from [<c034c784>] (irq_exit+0xbc/0xd8)
[ 64.737040] [<c034c784>] (irq_exit) from [<c039fb50>] (__handle_domain_irq+0x60/0xb4)
[ 64.744833] [<c039fb50>] (__handle_domain_irq) from [<c0709ca8>] (gic_handle_irq+0x58/0x9c)
[ 64.753143] [<c0709ca8>] (gic_handle_irq) from [<c0301a8c>] (__irq_svc+0x6c/0x90)
[ 64.760583] Exception stack(0xc1901f10 to 0xc1901f58)
[ 64.765605] 1f00: 00000000 000070a0 eb6ac1a0 c031da60
[ 64.773740] 1f20: ffffe000 c19064ac c19064f0 00000001 00000000 c1906488 c1876ba8 00000000
[ 64.781873] 1f40: ffffffff c1901f60 c030919c c03091a0 60010013 ffffffff
[ 64.788456] [<c0301a8c>] (__irq_svc) from [<c03091a0>] (arch_cpu_idle+0x38/0x3c)
[ 64.795816] [<c03091a0>] (arch_cpu_idle) from [<c0376aa4>] (do_idle+0x1bc/0x298)
[ 64.803175] [<c0376aa4>] (do_idle) from [<c0376e1c>] (cpu_startup_entry+0x18/0x1c)
[ 64.810707] [<c0376e1c>] (cpu_startup_entry) from [<c1700ea8>] (start_kernel+0x480/0x4ac)
[ 64.818839] Code: bad PC value
[ 64.821890] ---[ end trace e226ed97b1c584cd ]---
[ 64.826482] Kernel panic - not syncing: Fatal exception in interrupt
[ 64.832807] CPU1: stopping
[ 64.835501] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 5.2.0-rc5-01634-ge3a2773ba9e5 #1246
[ 64.845013] Hardware name: Freescale LS1021A
[ 64.849266] [<c0312394>] (unwind_backtrace) from [<c030cc74>] (show_stack+0x10/0x14)
[ 64.856972] [<c030cc74>] (show_stack) from [<c0ff4138>] (dump_stack+0xb4/0xc8)
[ 64.864159] [<c0ff4138>] (dump_stack) from [<c0310854>] (handle_IPI+0x3bc/0x3dc)
[ 64.871519] [<c0310854>] (handle_IPI) from [<c0709ce8>] (gic_handle_irq+0x98/0x9c)
[ 64.879050] [<c0709ce8>] (gic_handle_irq) from [<c0301a8c>] (__irq_svc+0x6c/0x90)
[ 64.886489] Exception stack(0xea8cbf60 to 0xea8cbfa8)
[ 64.891514] bf60: 00000000 0000307c eb6c11a0 c031da60 ffffe000 c19064ac c19064f0 00000002
[ 64.899649] bf80: 00000000 c1906488 c1876ba8 00000000 00000000 ea8cbfb0 c030919c c03091a0
[ 64.907780] bfa0: 600d0013 ffffffff
[ 64.911250] [<c0301a8c>] (__irq_svc) from [<c03091a0>] (arch_cpu_idle+0x38/0x3c)
[ 64.918609] [<c03091a0>] (arch_cpu_idle) from [<c0376aa4>] (do_idle+0x1bc/0x298)
[ 64.925967] [<c0376aa4>] (do_idle) from [<c0376e1c>] (cpu_startup_entry+0x18/0x1c)
[ 64.933496] [<c0376e1c>] (cpu_startup_entry) from [<803025cc>] (0x803025cc)
[ 64.940422] Rebooting in 3 seconds..
In this case, what happened is that the DSA driver failed to probe at
boot time due to a PHY issue during phylink_connect_phy:
[ 2.245607] fsl-gianfar soc:ethernet@2d90000 eth2: error -19 setting up slave phy
[ 2.258051] sja1105 spi0.1: failed to create slave for port 0.0
Fixes: bb77f36ac21d ("net: dsa: sja1105: Add support for the PTP clock")
Acked-by: Willem de Bruijn <willemb@google.com>
As Arnd Bergmann pointed out in commit 78fe8a28fb96 ("net: dsa: sja1105:
fix ptp link error"), there is no point in having PTP support as a
separate loadable kernel module.
So remove the exported symbols and make sja1105.ko contain PTP support
or not based on CONFIG_NET_DSA_SJA1105_PTP.
Due to a reversed dependency, it is possible to build
the lower ptp driver as a loadable module and the actual
driver using it as built-in, causing a link error:
drivers/net/dsa/sja1105/sja1105_spi.o: In function `sja1105_static_config_upload':
sja1105_spi.c:(.text+0x6f0): undefined reference to `sja1105_ptp_reset'
drivers/net/dsa/sja1105/sja1105_spi.o:(.data+0x2d4): undefined reference to `sja1105et_ptp_cmd'
drivers/net/dsa/sja1105/sja1105_spi.o:(.data+0x604): undefined reference to `sja1105pqrs_ptp_cmd'
drivers/net/dsa/sja1105/sja1105_main.o: In function `sja1105_remove':
sja1105_main.c:(.text+0x8d4): undefined reference to `sja1105_ptp_clock_unregister'
drivers/net/dsa/sja1105/sja1105_main.o: In function `sja1105_rxtstamp_work':
sja1105_main.c:(.text+0x964): undefined reference to `sja1105_tstamp_reconstruct'
drivers/net/dsa/sja1105/sja1105_main.o: In function `sja1105_setup':
sja1105_main.c:(.text+0xb7c): undefined reference to `sja1105_ptp_clock_register'
drivers/net/dsa/sja1105/sja1105_main.o: In function `sja1105_port_deferred_xmit':
sja1105_main.c:(.text+0x1fa0): undefined reference to `sja1105_ptpegr_ts_poll'
sja1105_main.c:(.text+0x1fc4): undefined reference to `sja1105_tstamp_reconstruct'
drivers/net/dsa/sja1105/sja1105_main.o:(.rodata+0x5b0): undefined reference to `sja1105_get_ts_info'
Change the Makefile logic to always build the ptp module
the same way as the rest. Another option would be to
just add it to the same module and remove the exports,
but I don't know if there was a good reason to keep them
separate.
Fix sparse warnings:
drivers/net/dsa/sja1105/sja1105_main.c:1848:6:
warning: symbol 'sja1105_port_rxtstamp' was not declared. Should it be static?
drivers/net/dsa/sja1105/sja1105_main.c:1869:6:
warning: symbol 'sja1105_port_txtstamp' was not declared. Should it be static?
Tested-by: Vladimir Oltean <olteanv@gmail.com>
As per the DT phy-mode specification, RGMII delays are applied by the
MAC when there is no PHY present on the link.
The pad_mii_tx registers point to the same memory region but were
unused. So convert to using these for RGMII I/O cell configuration, as
they bear a shorter name.
The first fact that needs to be stated is that the per-MAC settings in
SJA1105 called EGRESS and INGRESS do *not* disable egress and ingress on
the MAC. They only prevent non-link-local traffic from being
sent/received on this port.
So instead of having .phylink_mac_config essentially mess with the STP
state and force it to DISABLED/BLOCKING (which also brings useless
complications in sja1105_static_config_reload), simply add the
.phylink_mac_link_down and .phylink_mac_link_up callbacks which inhibit
TX at the MAC level, while leaving RX essentially enabled.
Also stop from trying to put the link down in .phylink_mac_config, which
is incorrect.
This will be used to stop egress traffic in .phylink_mac_link_up.
Since the driver is now using PHYLINK exclusively, it makes sense to
remove all references to it and replace them with PHYLINK.
This is a cosmetic patch that replaces the link speed numbers used in
the driver with the corresponding ethtool macros.
Suggested-by: Andrew Lunn <andrew@lunn.ch>
This enables the PTP support towards userspace applications such as
linuxptp.
The switches can timestamp only trapped multicast MAC frames, and
therefore only the profiles of 1588 over L2 are supported.
TX timestamping can be enabled per port, but RX timestamping is enabled
globally. As long as RX timestamping is enabled, the switch will emit
metadata follow-up frames that will be processed by the tagger. It may
be a problem that linuxptp does not restore the RX timestamping settings
when exiting.
Meta frame reception relies on the hardware keeping its promise that it
will send no other traffic towards the CPU port between a link-local
frame and a meta frame. Otherwise there is no other way to associate
the meta frame with the link-local frame it's holding a timestamp of.
The receive function is made stateful, and buffers a timestampable frame
until its meta frame arrives, then merges the two, drops the meta and
releases the link-local frame up the stack.
Without noticing any particular issue, this patch ensures that
management traffic is treated with the maximum priority on RX by the
switch. This is generally desirable, as the driver keeps a state
machine that waits for metadata follow-up frames as soon as a management
frame is received. Increasing the priority helps expedite the reception
(and further reconstruction) of the RX timestamp to the driver after the
MAC has generated it.
This will be used to keep state for RX timestamping. It is global
because the switch serializes timestampable and meta frames when
trapping them towards the CPU port (lower port indices have higher
priority) and therefore having one state machine per port would create
unnecessary complications.
This table is used to program the switch to emit "meta" follow-up
Ethernet frames (which contain partial RX timestamps) after each
link-local frame that was trapped to the CPU port through MAC filtering.
This includes PTP frames.
